Results 1 to 6 of 6
Thread: Is there any short of incompatibility between audioshield and XPT2046_Touchscreen???
    Member javiernicola's Avatar
    Apr 2018
    Madrid
    20
    teensy 3.6 + audioshield(i2s) + ILI9341_t3 + XPT2046_Touchscreen
    Everything works perfect by its own... but when i merge code...
    Hi, im playing around the teensy batdetector first coded by DD4WH.
    I have the Screen working no problem with the audio shield but as soon as i try to include and initialice the touchscreen AUDIOSHIELD coms freeze.
    Im using the alternative pinout described in Click image for larger version.
Name:	Sin título.png
    Everything works nicely but when i put the command ts.begin(); in setup();
    communication stops between audioshield and teensy 3.6
    Apr 2018
    Madrid
    20
    My code:
     * first version ultrasound detector
     * using higher sample rate code by Frank Boesing
     * https://forum.pjrc.com/threads/38988-Bat-detector
     * Frank DD4WH 2016_10_31
     *  first experiment
    #include <Metro.h>
    #include "font_Arial.h"
    #include <ILI9341_t3.h>
    #include <XPT2046_Touchscreen.h>
    #define BACKLIGHT_PIN 0
    #define TFT_DC      20
    #define TFT_CS      21
    #define TFT_RST     32  // 255 = unused. connect to 3.3V
    #define TFT_MOSI     7
    #define TFT_SCLK    14
    #define TFT_MISO    12
    #define CS_PIN  8
    #define TIRQ_PIN  2
    XPT2046_Touchscreen ts(CS_PIN);
    ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
    Metro five_sec=Metro(2000); // Set up a 0.5 second Metro
    // this audio comes from the codec by I2S2
    AudioInputI2S            i2s_in;
    AudioRecordQueue         Q_in_L;
    AudioRecordQueue         Q_in_R;
    AudioPlayQueue           Q_out_L;
    AudioPlayQueue           Q_out_R;
    AudioAnalyzeFFT256  myFFT;
    AudioOutputI2S           i2s_out;
    AudioConnection          patchCord1(i2s_in, 0, Q_in_L, 0);
    AudioConnection          patchCord2(i2s_in, 1, Q_in_R, 0);
    AudioConnection      patchCord5(Q_out_R,0,myFFT,0);
    AudioConnection          patchCord3(Q_out_L, 0, i2s_out, 1);
    AudioConnection          patchCord4(Q_out_R, 0, i2s_out, 0);
    AudioControlSGTL5000     sgtl5000_1;     //xy=265.212
    int idx_t = 0;
    int idx = 0;
    int64_t sum;
    float32_t mean;
    int n_L;
    int n_R;
    long int n_clear;
    int8_t mic_gain = 0; // start detecting with this MIC_GAIN in dB 1MIN TO 7MAX
    int peak[512];
    int barm[512];
    ulong samp_ptr = 0;
    bool FFT_state = false;
    //const int myInput = AUDIO_INPUT_LINEIN;
    const int myInput = AUDIO_INPUT_MIC;
    // We're only processing one buffer at a time so the
    // number of samples is fixed at 128
    #define BUFFER_SIZE 128
    float32_t float_buffer_L [BUFFER_SIZE];
    float32_t float_buffer_R [BUFFER_SIZE];
    float32_t float_buffer_L_3 [BUFFER_SIZE];
    float32_t float_buffer_R_3 [BUFFER_SIZE];
      ts.begin();
      // Audio connections require memory. and the record queue
      AudioMemory(100);
      // Enable the audio shield. select input. and enable output
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      sgtl5000_1.adcHighPassFilterDisable(); // does not help too much!
      setI2SFreq (96000); // this works perfectly
    //  setI2SFreq (192000); this sucks with a Teensy 3.5 (because of the slow display driver)
      AudioNoInterrupts();
      sgtl5000_1.micGain (mic_gain);
      AudioInterrupts();
      pinMode( BACKLIGHT_PIN, OUTPUT );
      analogWrite( BACKLIGHT_PIN, 1023 );
      tft.begin();
      tft.setRotation( 3 );
      tft.setCursor(10, 1);
      tft.setTextSize(2);
      tft.setTextColor(ILI9341_WHITE);
      tft.setFont(Arial_14);
      tft.print("Floating point audio processing");
     *  begin to queue the audio from the audio library
        Q_in_L.begin();
        Q_in_R.begin();
    } // END SETUP
    int16_t *sp_L;
    int16_t *sp_R;
     if(ts.touched()){
        tft.fillScreen(ILI9341_BLUE);
     elapsedMicros usec = 0;
     *  Get samples from queue buffers
        // this is supposed to prevent overfilled queue buffers
        if (Q_in_L.available() > 3 || Q_in_R.available() > 3) {
          Q_in_L.clear();
          Q_in_R.clear();
          n_clear ++; // just for debugging to check how often this occurs
        // is there at least one buffer in each channel available ?
        if (Q_in_L.available() >= 1 && Q_in_R.available() >= 1)
        sp_L = Q_in_L.readBuffer();
        sp_R = Q_in_R.readBuffer();
          // convert to float
         arm_q15_to_float (sp_L, float_buffer_L, BUFFER_SIZE); // convert int_buffer to float 32bit
         arm_q15_to_float (sp_L, float_buffer_R, BUFFER_SIZE); // convert int_buffer to float 32bit
         Q_in_L.freeBuffer();
         Q_in_R.freeBuffer();
     * From here, all the 32 bit float audio processing can start
     * END of 32 bit float audio processing
        sp_L = Q_out_L.getBuffer();
        sp_R = Q_out_R.getBuffer();
        arm_float_to_q15 (float_buffer_L, sp_L, BUFFER_SIZE);
        arm_float_to_q15 (float_buffer_R, sp_R, BUFFER_SIZE);
          Q_out_L.playBuffer(); // play it !
          Q_out_R.playBuffer(); // play it !
     *  PRINT ROUTINE FOR ELAPSED MICROSECONDS
          sum = sum + usec;
          idx_t++;
          if (idx_t > 1000) {
              tft.fillRect(240,50,90,20,ILI9341_BLACK);
              tft.setCursor(240, 50);
              mean = sum / idx_t;
              tft.print (mean);
              Serial.print (mean);
              Serial.print (" microsec for 2 stereo blocks    ");
              idx_t = 0;
              sum = 0;
     *  PRINT ROUTINE FOR AUDIO LIBRARY PROCESSOR AND MEMORY USAGE
              if (five_sec.check() == 1)
          Serial.print("Proc = ");
          Serial.print(AudioProcessorUsage());
          Serial.print(" (");
          Serial.print(AudioProcessorUsageMax());
          Serial.print("),  Mem = ");
          Serial.print(AudioMemoryUsage());
          Serial.print(" (");
          Serial.print(AudioMemoryUsageMax());
          Serial.println(")");
          Serial.print("Cleared the audio buffer ");
          Serial.print(n_clear); Serial.println (" times. ");
    /*      tft.fillRect(100,120,200,80,ILI9341_BLACK);
          tft.setCursor(10, 120);
          tft.setTextSize(2);
          tft.print ("Proc = ");
          tft.setCursor(100, 120);
          tft.print (AudioProcessorUsage());
          tft.setCursor(180, 120);
          tft.print (AudioProcessorUsageMax());
          tft.setCursor(10, 150);
          tft.print ("Mem  = ");
          tft.setCursor(100, 150);
          tft.print (AudioMemoryUsage());
          tft.setCursor(180, 150);
          tft.print (AudioMemoryUsageMax());
          AudioProcessorUsageMaxReset();
          AudioMemoryUsageMaxReset();
       spectrum();
     void spectrum() { // spectrum analyser code by rheslip - modified
         if (myFFT.available()) {
        int scale;
        scale = 2;
      for (int16_t x=2; x < 100; x+=1) {
         int bar = (abs(myFFT.output[x]) * scale);
         if (bar >180) bar=180;
         // this is a very simple IIR filter to smooth the reaction of the bars
         bar = 0.05 * bar + 0.95 * barm[x];
    //     if (bar > peak[x]) peak[x]=bar;
    //     tft.drawFastVLine(x, 210-bar,bar, ILI9341_PURPLE);
    //     tft.drawFastVLine(x*2+10, 210-bar,bar, ILI9341_PINK);
         tft.drawPixel(x*2+10, 210-barm[x], ILI9341_BLACK);
         tft.drawPixel(x*2+10, 210-bar, ILI9341_WHITE);
    //     tft.drawFastVLine(x*2+10, 20, 210-bar-20, ILI9341_BLACK);
    //     tft.drawPixel(x*2+10,209-peak[x], ILI9341_YELLOW);
         if(peak[x]>0) peak[x]-=1;
         barm[x] = bar;
      } //end if
       } // end void spectrum
    // sample rate routine by Frank Boesing
    void setI2SFreq(int freq) {
      typedef struct {
        uint8_t mult;
        uint16_t div;
      } tmclk;
      const int numfreqs = 14;
      const int samplefreqs[numfreqs] = { 8000, 11025, 16000, 22050, 32000, 44100, (int)44117.64706 , 48000, 88200, (int)44117.64706 * 2, 96000, 176400, (int)44117.64706 * 4, 192000};
    #if (F_PLL==16000000)
      const tmclk clkArr[numfreqs] = {{16, 125}, {148, 839}, {32, 125}, {145, 411}, {64, 125}, {151, 214}, {12, 17}, {96, 125}, {151, 107}, {24, 17}, {192, 125}, {127, 45}, {48, 17}, {255, 83} };
    #elif (F_PLL==72000000)
      const tmclk clkArr[numfreqs] = {{32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {128, 1125}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375}, {249, 397}, {32, 51}, {185, 271} };
    #elif (F_PLL==96000000)
      const tmclk clkArr[numfreqs] = {{8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {32, 375}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125}, {151, 321}, {8, 17}, {64, 125} };
    #elif (F_PLL==120000000)
      const tmclk clkArr[numfreqs] = {{32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {128, 1875}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625}, {178, 473}, {32, 85}, {145, 354} };
    #elif (F_PLL==144000000)
      const tmclk clkArr[numfreqs] = {{16, 1125}, {49, 2500}, {32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {4, 51}, {32, 375}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375} };
    #elif (F_PLL==180000000)
      const tmclk clkArr[numfreqs] = {{46, 4043}, {49, 3125}, {73, 3208}, {98, 3125}, {183, 4021}, {196, 3125}, {16, 255}, {128, 1875}, {107, 853}, {32, 255}, {219, 1604}, {214, 853}, {64, 255}, {219, 802} };
    #elif (F_PLL==192000000)
      const tmclk clkArr[numfreqs] = {{4, 375}, {37, 2517}, {8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {1, 17}, {8, 125}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125} };
    #elif (F_PLL==216000000)
      const tmclk clkArr[numfreqs] = {{32, 3375}, {49, 3750}, {64, 3375}, {49, 1875}, {128, 3375}, {98, 1875}, {8, 153}, {64, 1125}, {196, 1875}, {16, 153}, {128, 1125}, {226, 1081}, {32, 153}, {147, 646} };
    #elif (F_PLL==240000000)
      const tmclk clkArr[numfreqs] = {{16, 1875}, {29, 2466}, {32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {4, 85}, {32, 625}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625} };
      for (int f = 0; f < numfreqs; f++) {
        if ( freq == samplefreqs[f] ) {
          while (I2S0_MCR & I2S_MCR_DUF) ;
          I2S0_MDR = I2S_MDR_FRACT((clkArr[f].mult - 1)) | I2S_MDR_DIVIDE((clkArr[f].div - 1));
          return;
    its just Frank code but adding touchscreen capabilities, as a example i just made it turn everything blue when touched.
    As soon as i do ts.begin() audioshield stops working, the screen remains working perfect on its own
    Apr 2013
    1,936
    Is there any way to tell the touch screen controller that SPI clock is on pin 14? Or is it overriding things back to pin 13?
    Having a look in the library init section may give you a lead on either commenting out setup line or the format to use a longer begin string like the LCD uses.
    12,398
    Look at use of this when the interrupt pin is to be specified:: XPT2046_Touchscreen ts(CS_PIN);
    Odd it isn't shown here display_ili9341_touch.html
    But if you look here 'github.com/PaulStoffregen/XPT2046_Touchscreen' ( or at library examples ) you'll find:
    The use of the Touch interrupt pin can be optionally specified. If the Teensy pin specified is actively connected to the T_IRQ display pin then the normal touch calls will respond, but can be called more often as each call returns without hardware access when no interrupt was recorded.
    #define TIRQ_PIN  2
    XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN);
    Offhand I'm not sure why this might be affecting your code as I only got that far. But when the IRQ pin is given and connected the Touch Library can be less intrusive to the SPI. One of the examples should show how to use this for no SPI transfer until actual touch happens.
    The real problem may be in this from the github :: "The digital pin used for chip select is required. The normal MISO, MOSI and SCK pins will be used automatically."
    Where the Display has selectors for SPI pins as used:: ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
    I've worked with the XPT2046_Touchscreen - and offered the INT detection code - but I've never used it anywhere but default SPI? I'm not sure if it 'piggybacks' on the ILI9341 SPI settings? If not it will be messing with pins 11 and 13?
    If the Pin13_LED blinks on Touch checks like 'ts.getPoint' then the pins have not moved for Touch data. [ may need to disable audio to confirm this if it is already blinking? ]
    Paul/KurtE? In the Touch code I don't see explicit MOSI/MISO/SCLK pins called out like in the display driver.
    Does changing the above code as follows do anything?
    #define CS_PIN  8
    #define TIRQ_PIN  2
    Apr 2018
    Madrid
    20
    #define TIRQ_PIN  2
    #define CS_PIN  8
    #define TIRQ_PIN  2
    I tried XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN);, same result
    I managed to simply digitalRead(TIRQ_PIN) each loop because i just need to know when the touchscreen is pressed, i dont need the specific position.
    After some testing you were right:
    XPT2046_Touchscreen ts(CS_PIN); uses defaut SPI PINS killing audioshield spi coms,
    if i have time i will work in a <XPT2046_Touchscreen.h> library
    that uses the constructor like this
    XPT2046_Touchscreen  ts = XPT2046_Touchscreen (ts_CS, ts_IRQ, ts_RST, ts_MOSI, ts_SCLK,ts_MISO);
    12,398
    Perhaps a quick test with code like this from ILI9341_t [ ...\hardware\teensy\avr\libraries\ILI9341_t3\ILI93 41_t3.cpp ]- with hardcoded values for the two changed pins would give quick feedback:
    void ILI9341_t3::begin(void)
        // verify SPI pins are valid;
        #if defined(__MK64FX512__) || defined(__MK66FX1M0__)
        if ((_mosi == 11 || _mosi == 7 || _mosi == 28) && (_miso == 12 || _miso == 8 || _miso == 39)
        		&& (_sclk == 13 || _sclk == 14 || _sclk == 27)) {
    	#else
        if ((_mosi == 11 || _mosi == 7) && (_miso == 12 || _miso == 8) && (_sclk == 13 || _sclk == 14)) {
            SPI.setMOSI(_mosi);
            SPI.setMISO(_miso);
            SPI.setSCK(_sclk);
    	} else
            return; // not valid pins...
    	SPI.begin();
    You can copy the [ …\hardware\teensy\avr\libraries\XPT2046_Touchscree n ] to sketchbook libraries to make local changes and see it used in Verbose Console.
    bool XPT2046_Touchscreen::begin()
     // insert proper SPI.set's here
    	SPI.begin();
    Once working maybe this from XPT...Touch:: #define SPI_SETTING SPISettings(2000000, MSBFIRST, SPI_MODE0)
    could run faster like in the ILI9341_t3 ::
    // Teensy 3.1 can only generate 30 MHz SPI when running at 120 MHz (overclock)
    // At all other speeds, SPI.beginTransaction() will use the fastest available clock
    #define SPICLOCK 30000000
    SPI.beginTransaction(SPISettings(SPICLOCK, MSBFIRST, SPI_MODE0));
