Results 1 to 25 of 25
Thread: ILI9341_t font structure format
    Nov 2018
    11
    Since I couldn't find one on the Internet, I'm planning to write a font editor, which will produce fonts compatible with ILI9341_t3 library. I'll probably take Arduino Font Editor as a base, because I'll only have to implement different export mechanism.
    However, it is not entirely clear, what is the specific format of ILi9341_t3's font definition. I'm referring mostly to two pairs of code ranges and format of the index, but it would help a lot if I had some kind of more detailed specification of the whole structure. Could you provide me with some more insight into this format? It would save me a lot of time on reverse-engineering the library.
    Best regards -- Wojciech "Spook" Sura.
    Germany NRW
    5,565
    Here are ~900 Fonts for the ILI9341_t3 library:
    https://github.com/FrankBoesing/fonts/tree/master/ofl
    These are open TTF (True Type Fonts), converted to BDF, then converted to the ILI9341-Format with the tool from Paul.
    Nov 2018
    11
    I actually did quite extensive research before asking. I've been on most of these threads, but the problem is that I'd like to have a font editor, not to convert an existing font. I found out, that I may use the Arduino Font Creator ( https://bitbucket.org/castortiu/arduino-font-creator ) as a base, because it has the whole editor in place, I only need to implement exporting the font.
    I planned to use the Python font builder as a backup plan, but it still would require me to reverse-engineer the code, that's why I asked about specifics of the font structure. If it is not a big trouble for you, it will speed my development a lot (I'll either submit a pull-request to the original project or fork it and make available publicly anyway)
    Germany NRW
    5,565
    I think there are several editors for TTF or BDF - so I think it's less work to simply use one of them and convert it afterwards.
    But of course I don't want to stop you.
    Germany NRW
    5,565
    By the way, i've patched the Adafruit_SSD1306 library to use i2c_t3.h instead of wire.h, 1MHz transfer speed (I tried 2MHz - works fine, too) and added Pauls fonts.
    (To use any ILI9341_t3 font, you have to edit the #inlcude in the font files - that's all)
    Currently it does not have it's own repo, and is a part of another project: https://github.com/FrankBoesing/Mini...afruit_SSD1306
    19,922
    Here's a quick explanation to get you started. But I want to emphasize you'll probably need to look at the code and do some experimenting to fill in the details. Hopefully you'll have time to post followups here on those details... so the next time someone wants to understand the format maybe this thread will help where the others fell short?
    Each font has 3 parts.
    1: Metadata in a ILI9341_t3_font_t struct
    2: Font bitmap data
    3: An index into the bitmap data for each character
    The metadata is the most important. Here's the definition from ILI9341_t3.h:
    typedef struct {
            const unsigned char *index;
            const unsigned char *unicode;
            const unsigned char *data;
            unsigned char version;
            unsigned char reserved;
            unsigned char index1_first;
            unsigned char index1_last;
            unsigned char index2_first;
            unsigned char index2_last;
            unsigned char bits_index;
            unsigned char bits_width;
            unsigned char bits_height;
            unsigned char bits_xoffset;
            unsigned char bits_yoffset;
            unsigned char bits_delta;
            unsigned char line_space;
            unsigned char cap_height;
    } ILI9341_t3_font_t;
    The "index" and "data" are just the arrays for other 2 parts.
    "unicode" was never used, so it should be NULL. Likewise, "version" and "reserved" aren't actually used, but set version=1 just in case the format someday adds more features, so the library can know your fonts were made for the original version of the library.
    The next 4 items tell which character codes your font implements. You can have 2 ranges. The most common is index1_first=32 and index1_last=126, meaning your font provides bitmaps for all the printable ASCII characters, and set the others to zero for no other range. But if you wanted to do something like make a smaller font that had only capital letters and numerical digits, you'd use index1_first=48 and index1_last=57 for the numbers and index2_first=65 and index2_last=90 for the letters.
    The 2 data arrays are bit packed. Even though the type is unsigned char, it's important to think of these as a bit array of bits, not bytes. Nothing is aligned to byte boundaries. ILI9341_t3 actually accesses these arrays using 3 functions, fetchbits_unsigned() and fetchbits_signed() and fetchbit(). These pull a group of bits from the array, as a bit (not byte) index.
    Even though you'll generate the index array last, after you've created the data array and you know the bit index of each character's data, I'll mention it now. The "bits_index" item in the metadata tells ILI9341_t3 how many bits each of the numbers in the index array. If you don't care about size, you could just use a fixed number like 16, which would allow your data array to have up to 65535 bits (or technically, the last character could begin at bit index 65535). The bdf_to_ili9341 utility creates the data array and then chooses the number of bits needed for the index after it knows the bit position where the last character starts.
    For example, if your font has the normal 95 ASCII characters (index1_first=32 and index1_last=126), and if your font data takes a total of 5000 bits (packed into 625 bytes), then you'll need 13 bit numbers in your index array. 95 * 13 = 1235 total bits in your index, which means your index array will be 155 bytes, where the last 5 bits will never be used. To generate the array, just take the bit position of each character's data within the data array and put its 13 bit number into your index array. Usually the first index number is zero, since you'll start the first character's data at the beginning of your data array. But if you wanted to arrange your character data in some different order, you certainly could. ILI9341_t3 just does simple math to figure out where the character code falls within those 2 ranges, then multiplies by the bit size of your index data and reads that many bits. So if the first 13 bits of your index data are all 1s, it will look for the data for whatever ASCII/ISO code index1_first is at bit position 8191 in your array of font bitmap data.
    In the font bitmap data, each character begins with 6 fields. The first has a fixed size of 3 bits, and must be all 0s. This 3 bit field was meant to allow other ways to encode the character. Perhaps someday future versions will do something other than just ignore the other 7 combinations. For now, you must use 000. Any other 3 bit value means ILI9341_t3 will ignore the data and not render that character (nor advance the cursor position), because the following bits are assumed to be some future format.
    You get to choose the number of bits used for the other 5 fields. That's what the bits_width, bits_height, bits_xoffset, bits_yoffset and bits_delta fields in the metadata mean. All characters in your font have to use the same number of bits, but you get to choose. Again, if you don't care about wasting some space, you could just set these to large enough numbers to always accommodate whatever size fonts you intended to ever use. The bdf_to_ili9341 utility looks at all the characters to be encoded and chooses the smallest number of bits needed for each field. Whatever bit size you choose, just pack these bits for each field at the first 3-zeros field.
    The width and height tell how big that character is. The offset numbers let you offset the drawing (useful for fancy fonts, descenders like lowercase 'j' and 'g'). If your font editor just considers everything to "think inside the box" then set these to zero. The delta number tells how many pixels to advance the cursor position for that character.
    After these 5 numbers, ILI9341_t3 expects to find the raw bitmap data. But there are 2 format you can use, depending on the first bit. If that first bit is a zero, then whatever bits follow are the raw bitmap data. If your width field says this character is 10 pixels wide, than you would just write 11 bits each each row.
    However, if you start with a 1 bit, then ILI9341_t3 repeats the last row's data up to 6 times. The next 3 bits are read, where 0 to 5 mean to repeat the prior row 1 to 6 times. Values 6 & 7 are treated the same as 5 (and may do something else in the future so don't use 6 or 7). If you want to repeat the same data more than 6 times, you'll have to use another 4 bits for each group up to 6 lines. Of course, if you want to keep things simple and not achieve the most compact packing, you could just begin each row with 0 and not use this feature. But especially for larger fonts it can make quite a difference in data size.
    For the font data, that's it. Just begin with 3 zero bits, then 5 per-character size fields (where you choose the best numbers of bits for your font's needs), and the follow with the raw pixels where each row begins with 0 for actual bitmap data, or with 1 to repeat the previous row, until you've output all the pixels for your character's height.
    The bdf_to_ili9341 utility packs the font bitmap data efficiently into the bit array. But you're not required to do that. If you wanted to have each character start on a byte or word boundary, you could just add extra padding bits after each character's data. The bit-packed index is used to find where each character's data actually starts, and if you want the index number to fall on byte or word boundaries, you could choose 8 or 16 or 32 bits for their size rather than the smallest number of bits needed.
    The other 2 fields I haven't mentioned in the metadata struct are line_height, which is how far to advance the cursor when "printing" a newline character, and "cap_height" which meant to be height of a capital letter, but really it's just an offset from the cursor position to where the library will "begin" drawing, which allows the yoffset field to (usually) be smaller and let you use fewer bits for it.
    Hopefully that covers the data format pretty well? I'm pretty sure you'll end up looking at the code for finer details. Please do fill in anything you find that I've missed. Ideally this thread can serve as the answer for anyone else who later wants to understand how this encoding works.
    Nov 2018
    11
    This is just so freaking awesome documentation - thanks a ton! It would take forever to extract this information from code. I guess that I should have working version of ILI9341_t font export within a couple of days, I'll post it here for sure.
    Thanks again!
    Nov 2018
    11
    I guess I'll have a couple of questions during development, here's one: can space character (which is usually empty) be compressed to 0-width and 0-height character with only offset-x specified (of course among all other mandatory character-header values)?
    19,922
    Some minor details...
    1: which of the 5 fields are treated as unsigned vs signed numbers
    2: how to do the bit packing (LSB first vs MSB first)
    3: where the character is rendered relative to the cursor X,Y position
    Hopefully you can get these from the code, either in the library code or from extras/bdf_to_ili9341.c. Honestly, it's been a few years since I wrote all this code....
    19,922
    Quote Originally Posted by spook View Post
    Take a look at lines 1312 to 1315 within the font rendering code.
    https://github.com/PaulStoffregen/IL...1_t3.cpp#L1312
    You can see "height" is initialized on line 1271, by simply reading the bits you allocated (in the metadata struct) for the character height. Then it's copied to "linecount". It's structured as a while loop, so if height is zero then linecount is zero and the while loop will not run any of that code which reads the bitmap data.
    Hopefully you can see how this code corresponds to the data format? Inside the while loop, you can see the first thing it does is read that leading bit, using it to know whether to render the raw bitmap data (the do-while loop at line 1321), or to repeat the prior line (the do-while loop at line 1335).
    Nov 2018
    11
    Some update. I've implemented the export, but - as one might have expected - it doesn't work (nothing is displayed). I suspect, that I may have error in format somewhere - if you have a minute or two, you may take a look. I generate diagnostic data, which shows the whole structure of file in bits. Generated .h and .cpp files follows.
    --- Char 32 ( ) index 0 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    0|00000 (Regular row)
    1|101 [5] (Copy rows)
    --- Char 44 (,) index 26 ---
    000 [0] (reserved)
    011 [3] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    100 [4] (Delta)
    0|000 (Regular row)
    1|010 [2] (Copy rows)
    0|001 (Regular row)
    1|000 [0] (Copy rows)
    0|010 (Regular row)
    --- Char 45 (-) index 62 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    1|001 [1] (Copy rows)
    0|01110 (Regular row)
    --- Char 46 (.) index 104 ---
    000 [0] (reserved)
    011 [3] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    100 [4] (Delta)
    0|000 (Regular row)
    1|100 [4] (Copy rows)
    0|010 (Regular row)
    --- Char 47 (/) index 132 ---
    000 [0] (reserved)
    101 [5] (Width)
    101 [5] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    000 [0] (Delta)
    1|011 [3] (Copy rows)
    --- Char 48 (0) index 158 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    0|01010 (Regular row)
    --- Char 49 (1) index 196 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    0|00100 (Regular row)
    0|01100 (Regular row)
    --- Char 50 (2) index 240 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    0|00010 (Regular row)
    0|01000 (Regular row)
    --- Char 51 (3) index 296 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    --- Char 52 (4) index 350 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    0|00110 (Regular row)
    --- Char 53 (5) index 404 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    --- Char 54 (6) index 458 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    --- Char 55 (7) index 512 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    --- Char 56 (8) index 564 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
    --- Char 57 (9) index 618 ---
    000 [0] (reserved)
    101 [5] (Width)
    111 [7] (Height)
    00 [0] (XOffset)
    00 [0] (YOffset)
    110 [6] (Delta)
     (Pad to byte)
    0000000000 [0] (index)
    0000011010 [26] (index)
    0000111110 [62] (index)
    0001101000 [104] (index)
    0010000100 [132] (index)
    0010011110 [158] (index)
    0011000100 [196] (index)
    0011110000 [240] (index)
    0100101000 [296] (index)
    0101011110 [350] (index)
    0110010100 [404] (index)
    0111001010 [458] (index)
    1000000000 [512] (index)
    1000110100 [564] (index)
    1001101010 [618] (index)
    00 (Pad to byte)
    Range1: 32-32
    Range2: 44-57
    BitsIndex: 10
    BitsWidth: 3
    BitsHeight: 3
    BitsXOffset: 2
    BitsYOffset: 2
    BitsDelta: 3
    LineSpace: 0
    CapHeight: 0
    The generated h file looks like this:
    #ifndef __TestFont_h__
    #define __TestFont_h__
    #include <ILI9341_t3.h>
    #ifdef __cplusplus
    extern "C" {
    extern const ILI9341_t3_font_t TestFont;
    #ifdef __cplusplus
    } // extern "C"
    And the cpp file:
    #include "TestFont.h"
    static const unsigned char TestFont_data[] = {
      0x17, 0x86, 0x03, 0x43, 0xE1, 0x02, 0x86, 0x08, 0x5E, 0x18, 0x09, 0x38, 0x09, 0x0F, 0x84, 0x0C,
      0x21, 0x68, 0x00, 0x2C, 0x5E, 0x18, 0xE2, 0xAC, 0xE1, 0x78, 0x61, 0x0C, 0x12, 0x8E, 0x17, 0x86,
      0x10, 0xA0, 0x84, 0x22, 0x0E, 0x17, 0x86, 0x30, 0x28, 0x10, 0x28, 0x30, 0x5E, 0x18, 0x21, 0x8A,
      0x83, 0x82, 0x81, 0x78, 0x63, 0x88, 0x83, 0x02, 0x83, 0x05, 0xE1, 0x86, 0x22, 0x0C, 0x2A, 0x04,
      0x17, 0x86, 0x38, 0x28, 0x12, 0x08, 0x81, 0x78, 0x61, 0x0A, 0x81, 0x0A, 0x81, 0x05, 0xE1, 0x84,
      0x2A, 0x06, 0x0A, 0x0C
    /* Size: 84 bytes */
    static const unsigned char TestFont_index[] = {
      0x00, 0x01, 0xA0, 0xF8, 0x68, 0x21, 0x09, 0xE3, 0x10, 0xF0, 0x4A, 0x15, 0xE6, 0x51, 0xCA, 0x80,
      0x23, 0x49, 0xA8
    /* Size: 19 bytes */
    const ILI9341_t3_font_t TestFont = {
        TestFont_index,
        0,
        TestFont_data,
        1,
        0,
        32,
        32,
        44,
        57,
        10,
        3,
        3,
        2,
        2,
        3,
        0,
        0
    Repository for the project is public: https://gitlab.com/spook/arduinofontcreator.git , feel free to clone.
    Nov 2018
    11
    Hmm. Please take a look at https://github.com/PaulStoffregen/IL...1_t3.cpp#L1265
    data = font->data + fetchbits_unsigned(font->index, bitoffset, font->bits_index);
    uint32_t encoding = fetchbits_unsigned(data, 0, 3);
    This is the part where you fetch address of the character in data. You pick (font->bits_index) bits starting from (bitoffset) bit from (font->index) and then increment font->data by this value. But since font->data is unsigned char *, pointer arithmetics would suggest, that addresses of characters are in bytes, not bits (and therefore characters must be byte-aligned). Fetching encoding from the data starting from bit 0 would also suggest that.
    Can you confirm this?
    Nov 2018
    11
    No need, this is confirmed. So characters must be aligned to byte boundaries and character offsets (indices) must be expressed in bytes, not bits
    Moreover, row repeating works a little bit differently than you described (or more likely than I understood). The structure is:
    0(row) or
    1(repetitions)(row)
    So 1 doesn't repeat last row, but the one, which follows. There are no indications, that repetitions 6 or 7 were used for different purposes, code simply reads count of repetitions and adds 2, so that 0 equals 2 repetitions, ..., 7 equals 9 repetitions.
    Everything else seems to be exactly as you said. I have exporter ready, will now write the whole editor from scratch, because I'd like to introduce some features, that Arduino Font Creator doesn't have (and change internal architecture too).
    I hope, that it'll be useful for anyone else than me
    4,546
    I am not sure if it would help, but my version of the library https://www.github.com/KurtEck/ili9341_t3n also has code to try to output the fonts in. Opaque mode...
    Nov 2018
    11
    I'll post progress shortly, but I might have found a bug in the library regarding fonts. Look at the following image:
    I marked with small corners places where character starts and ends. Character start is defined by OffsetX, character end by AdvanceX. It looks like on the first character cursor advances more than on other ones (possibly adds OffsetX?). The characters looks like following:
    (Yes, I know, that there's a lot free space around, I'll work on optimizing fonts as well, but later)
    The whole font (for verification):
      0x05, 0x66, 0xC6, 0x28, 0x9E, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x07, 0x80, 0x00, 0x03, 0xC0, 0x00,
      0x01, 0xE0, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x78, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x14, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x09, 0xE6, 0xC6, 0x2A, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00,
      0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x08, 0x00, 0x00,
      0x00, 0x3E, 0x01, 0x20, 0x00, 0x00, 0x07, 0x80, 0x28, 0x00, 0x00, 0x01, 0xE0, 0x04, 0x80, 0x00,
      0x00, 0x38, 0x00, 0xA0, 0x00, 0x00, 0x0E, 0x00, 0x10, 0x00, 0x00, 0x01, 0x80, 0x02, 0x00, 0x00,
      0x00, 0x70, 0x00, 0x48, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x08, 0x00, 0x00,
      0x03, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x01,
      0xF0, 0x00, 0x24, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x38,
      0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0xD0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x08, 0xE6, 0xC6, 0x2A, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00,
      0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x10, 0x00, 0x00, 0x07, 0x83, 0x00, 0x00,
      0x00, 0xF8, 0x79, 0x00, 0x00, 0x01, 0xE0, 0xE0, 0x00, 0x00, 0x1C, 0x0F, 0x00, 0x00, 0x00, 0x78,
      0x3E, 0x40, 0x00, 0x00, 0xE0, 0x70, 0x00, 0x00, 0x0C, 0x06, 0x00, 0x00, 0x01, 0xC0, 0xE4, 0x80,
      0x00, 0x03, 0x01, 0x8F, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00,
      0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x10, 0xA6, 0xC6, 0x2E, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0E, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x70, 0x00, 0x10,
      0x00, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x70, 0x00,
      0x08, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x70,
      0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x10, 0x00, 0x00, 0x00, 0x7F, 0xFF,
      0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xC0, 0x70, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x01, 0xC0, 0x70, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xC0, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x0E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0x80, 0x01, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xFF, 0xFE, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x70, 0x00, 0x00,
      0x10, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x70, 0x00,
      0x00, 0x08, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x70,
      0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0,
      0x70, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6,
      0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
      0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0xF3, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x18, 0x63, 0x80, 0x00, 0x00, 0x00,
      0x06, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x60, 0x00,
      0x00, 0x00, 0x00, 0x0E, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC3, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x38, 0x60, 0x00, 0x08, 0x00, 0x00, 0x00, 0xF1, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x60, 0x00,
      0x04, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFE, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x37, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x06, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC7, 0x80,
      0x02, 0x80, 0x00, 0x00, 0x06, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x01, 0x81, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x30, 0x70, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC3, 0x80,
      0x00, 0x00, 0x00, 0x38, 0x30, 0xE0, 0x00, 0x00, 0x00, 0x0F, 0xC6, 0x78, 0x00, 0x00, 0x00, 0x01,
      0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x80, 0x00,
      0x01, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x10, 0x00,
      0x00, 0x06, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x10, 0xA6, 0xC6, 0x2E, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0xF0, 0x01,
      0x80, 0x00, 0x00, 0x00, 0x00, 0x07, 0x0F, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE1, 0xE0,
      0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x3E, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x07,
      0xC0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0xF8, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C,
      0x1F, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x03, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x03,
      0xE0, 0x7C, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x0F, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0x81, 0xE0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x7C, 0x30, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x3E, 0x0F, 0x84, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC1, 0xE1, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x00, 0xF8, 0x38, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x0C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xE1, 0xC3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x70, 0x60, 0x3F, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xF8, 0x18, 0x1C, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x07, 0x0F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC1, 0xE1, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x3C,
      0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0F, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x81,
      0xE0, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x7C, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
      0x0F, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0xE0, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x60, 0x7C, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0F, 0x81, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x01, 0xF0, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x3E, 0x0F, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x18, 0x07, 0xC1, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0xF8, 0x38, 0x00, 0x00, 0x00,
      0x00, 0x00, 0xC0, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x01, 0xE1, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x06, 0x00, 0x1E, 0x70, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0xF8, 0x00, 0x01,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x12, 0x26, 0xC6, 0x2E, 0xFE, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xE0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF,
      0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x80, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x30, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0x80, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x1C, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x0E,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x3E, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x1F, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0xFF, 0x07, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0xC0, 0x01, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x0E, 0x03, 0xE0, 0x00, 0xF0, 0x00, 0x04, 0x00, 0x00, 0x03, 0xC0, 0x3E, 0x00, 0x0E,
      0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x3E, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x3E,
      0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x01, 0xE3, 0xFC, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
      0xF0, 0xF8, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x0F, 0x80, 0x00, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x7C, 0x01, 0xF0, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x7C, 0x00, 0x70,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x0F, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x03,
      0xC0, 0x38, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0xF0, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x03,
      0xF8, 0x00, 0x3C, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x0F, 0x0E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x7F, 0x00, 0x03, 0xCE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xC0, 0x00, 0xFE, 0x00,
      0x06, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x00, 0x3E, 0x00, 0x07, 0x80, 0x00, 0x00, 0x03, 0xFE, 0x00,
      0x1E, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0xFF, 0xE0, 0x3F, 0x80, 0x00, 0xE0, 0x00, 0x00, 0x00,
      0x3F, 0xFF, 0xFD, 0xE0, 0x00, 0x70, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFC, 0x78, 0x00, 0x30, 0x00,
      0x00, 0x00, 0x01, 0xFF, 0xF8, 0x1E, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xE0, 0x07, 0xC0,
      0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x3F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x78, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE6, 0xC6, 0x29, 0xDE, 0x00,
      0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE8,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x39, 0x00, 0x00, 0x00, 0x0F, 0x24, 0x00, 0x00, 0x01,
      0xC4, 0x80, 0x00, 0x00, 0x70, 0x80, 0x00, 0x00, 0x0C, 0x12, 0x00, 0x00, 0x03, 0x03, 0xC0, 0x00,
      0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0xA6, 0xC6, 0x2A, 0xBE, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x03,
      0x80, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00,
      0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00,
      0x00, 0xE0, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x1C,
      0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00,
      0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00,
      0x00, 0xE0, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x80, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x03,
      0xC0, 0x00, 0x40, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x24, 0x00, 0x00, 0xE0,
      0x00, 0x08, 0x00, 0x00, 0x78, 0x00, 0x03, 0xC0, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00,
      0x01, 0x20, 0x00, 0x06, 0x00, 0x00, 0x40, 0x00, 0x01, 0xC0, 0x00, 0x10, 0x00, 0x00, 0x30, 0x00,
      0x00, 0x00, 0x00, 0x70, 0x00, 0x08, 0x00, 0x00, 0x0C, 0x00, 0x02, 0x00, 0x00, 0x01, 0x80, 0x00,
      0x80, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xE6, 0xC6, 0x2A, 0x5E, 0x00,
      0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x06,
      0x00, 0x40, 0x00, 0x00, 0x06, 0x00, 0x80, 0x00, 0x00, 0x06, 0x01, 0x00, 0x00, 0x00, 0x06, 0x00,
      0x00, 0x00, 0x00, 0x70, 0x20, 0x00, 0x00, 0x00, 0x60, 0x40, 0x00, 0x00, 0x00, 0xE0, 0x90, 0x00,
      0x00, 0x00, 0xC1, 0xE0, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x1C, 0x20, 0x00, 0x00, 0x00,
      0x78, 0x48, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x1E, 0x08, 0x00, 0x00, 0x00, 0x38, 0x00,
      0x00, 0x00, 0x07, 0x81, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00,
      0x1C, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x1C,
      0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
      0x00, 0xE0, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x07,
      0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x66, 0xC6, 0x2C, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18,
      0x00, 0x01, 0x20, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x02, 0x00,
      0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFC, 0xF8, 0x00, 0x00, 0x00, 0x3F, 0xE3,
      0xFE, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x78, 0x0F, 0x00, 0x00, 0x00,
      0x00, 0x0E, 0x03, 0x80, 0x00, 0x00, 0x00, 0x01, 0x80, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x30, 0x60,
      0x00, 0x00, 0x00, 0x00, 0x1E, 0x38, 0x00, 0x10, 0x00, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x00, 0x00,
      0x00, 0x7C, 0x78, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0xC0,
      0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D,
      0xE6, 0xC6, 0x2C, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x01, 0x20, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x24,
      0x00, 0x00, 0x3F, 0xFF, 0xFF, 0xF8, 0x07, 0x80, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x90, 0x00,
      0x00, 0x00, 0x0E, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x08, 0xE6, 0xC6, 0x2A, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00,
      0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x03,
      0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x04, 0x00, 0x00,
      0x7E, 0x00, 0x08, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x38, 0x00,
      0x10, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00,
      0x70, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
      0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0xE6, 0xC6, 0x2A, 0xDE, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00,
      0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xC0, 0x00, 0x00,
      0x1F, 0xFF, 0xC0, 0x00, 0x00, 0x1F, 0xFF, 0x80, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x04, 0x80, 0x00,
      0x7E, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x38, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00,
      0x1A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xE6, 0xC6, 0x2B, 0x5A, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38,
      0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x74, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xC8, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x1E, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x07, 0x01, 0x00, 0x00, 0x00,
      0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00,
      0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x38, 0x00, 0x20, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00,
      0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x04, 0x00, 0x00, 0x07, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x78,
      0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x80, 0x00, 0x1C, 0x00, 0x00, 0x01, 0x00, 0x00,
      0x70, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x1C, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x3C,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0xF8, 0x00, 0x00, 0x00, 0x00,
      0x78, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0xF0, 0x08, 0x00, 0x00, 0x00, 0xF0, 0x03, 0xE0,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x07, 0xC0, 0x00, 0x00, 0x01,
      0xE0, 0x00, 0xF8, 0x10, 0x00, 0x00, 0x0F, 0x80, 0x03, 0xE0, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x7C,
      0x08, 0x00, 0x00, 0x0F, 0x80, 0x01, 0xF0, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x3E, 0x04, 0x00, 0x00,
      0x0F, 0x80, 0x00, 0xF8, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x07,
      0xC0, 0x48, 0x00, 0x01, 0xF0, 0x00, 0x1F, 0x01, 0x20, 0x00, 0x07, 0xC0, 0x00, 0xF8, 0x04, 0x00,
      0x00, 0x1F, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x03, 0xE0, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x7C, 0x00,
      0x3E, 0x00, 0x00, 0x00, 0x07, 0x80, 0x07, 0x80, 0x08, 0x00, 0x00, 0x1F, 0x00, 0x3C, 0x00, 0x00,
      0x00, 0x01, 0xE0, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xE1,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x00, 0x78,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x01, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x80, 0x00, 0x00,
      0x00, 0x01, 0xFB, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x38, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x04, 0x0F,
      0x80, 0x02, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x09, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x04, 0x80, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x3C, 0x00, 0x02, 0x80, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x09, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x04, 0x80, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x03, 0xF0, 0x00, 0x02, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x70, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C,
      0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00,
      0x00, 0x07, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x70, 0x7F,
      0x00, 0x00, 0x00, 0x00, 0x1C, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x07, 0x00, 0x7E, 0x00, 0x00, 0x00,
      0x01, 0xC0, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x30, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x1F,
      0x00, 0x00, 0x00, 0x00, 0x80, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x07, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0xC0, 0x00, 0x00, 0x00,
      0x38, 0x00, 0x30, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x03, 0x9F, 0xFF, 0x80,
      0x00, 0x00, 0x00, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x37,
      0xFF, 0xFF, 0x80, 0x06, 0x00, 0x02, 0xE0, 0x00, 0xE0, 0x00, 0xBC, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C,
      0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00,
      0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x70, 0xFE,
      0x00, 0x00, 0x00, 0x00, 0x18, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x06, 0x00, 0xF8, 0x00, 0x00, 0x00,
      0x00, 0x80, 0x1F, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x80, 0x00, 0x00, 0x00, 0x03,
      0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE, 0x00, 0x00, 0x00,
      0x00, 0x04, 0x1F, 0xC0, 0x02, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x0B, 0x00, 0x00, 0x00, 0x00,
      0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x03, 0x00, 0x1E, 0x00, 0x00, 0x00,
      0x00, 0xF0, 0x07, 0x80, 0x00, 0x00, 0x00, 0x1F, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x01, 0xF0, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC, 0x00, 0x00, 0x03, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x07, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x01, 0xCF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x73,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x07, 0x0F, 0x80, 0x00, 0x00,
      0x00, 0x01, 0xC1, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x70, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x0F,
      0x80, 0x00, 0x00, 0x00, 0x07, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x3E, 0x00, 0x00, 0x00,
      0x00, 0x30, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x0C, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x3E,
      0x00, 0x08, 0x00, 0x00, 0x18, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x06, 0x00, 0x3F, 0x00, 0x00, 0x00,
      0x01, 0x80, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0x80, 0x10, 0x00, 0x01, 0xFF, 0xFF,
      0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x28,
      0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x03, 0x00, 0x07, 0xE0, 0x00, 0x60, 0x00, 0x20, 0x00,
      0x00, 0x00, 0x0B, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
      0x7F, 0xFE, 0x02, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFC, 0x00,
      0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x04, 0x80, 0x00, 0x00,
      0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x3F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x01, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xC0, 0x02, 0x40, 0x00, 0x00,
      0x00, 0x3F, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x20, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x00, 0x80, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80,
      0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x07, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00,
      0xF8, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x00, 0x00,
      0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00,
      0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC7, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0xFB, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x1F, 0xE1, 0xF8, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x1F, 0x80,
      0x10, 0x00, 0x00, 0x1F, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x03, 0xE0, 0x0D, 0x00, 0x00,
      0x1F, 0x00, 0x0F, 0x80, 0x20, 0x00, 0x00, 0x7C, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x07, 0x80, 0x0F,
      0x80, 0x10, 0x00, 0x00, 0x1F, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x0F, 0x00, 0x00, 0x00,
      0x00, 0x1E, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x03, 0xF0, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFC,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x40,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C,
      0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF,
      0xFE, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xE0, 0x00, 0x00,
      0x00, 0x3F, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00,
      0xC0, 0x00, 0x00, 0x00, 0x30, 0x00, 0x30, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x0C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x40, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x01, 0x00, 0x00,
      0x00, 0xF8, 0x00, 0x00, 0x05, 0x80, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00,
      0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x78,
      0x3C, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x03, 0x80, 0x00, 0x00, 0x00, 0x07, 0x80, 0x38, 0x08, 0x00,
      0x00, 0x00, 0x3C, 0x00, 0xE0, 0x20, 0x00, 0x00, 0x01, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x3E,
      0x00, 0xE0, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x38, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x0F, 0x00, 0x00,
      0x00, 0x00, 0x1F, 0xC3, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xF8, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x3F,
      0xBC, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x80, 0x00, 0x00,
      0x00, 0x00, 0x07, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF7,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x78, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x0F, 0xE0, 0x00, 0x00,
      0x00, 0x07, 0x80, 0xFC, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x7C, 0x01,
      0xF8, 0x00, 0x80, 0x00, 0x03, 0xE0, 0x03, 0xE0, 0x02, 0x00, 0x00, 0x1F, 0x00, 0x0F, 0x80, 0x08,
      0x00, 0x00, 0x7C, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x0F, 0x80, 0x00, 0x00, 0x01, 0xF0,
      0x01, 0xE0, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x78, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x1E, 0x00, 0x00,
      0x00, 0x00, 0x3F, 0x07, 0x80, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x1F,
      0xE0, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x07,
      0x87, 0xE0, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x78, 0x03, 0xC0, 0x08,
      0x00, 0x00, 0x03, 0xC0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0xF8, 0x00, 0xF0, 0x04, 0x00, 0x00, 0x03,
      0xC0, 0x03, 0xE0, 0x1A, 0x00, 0x00, 0x1F, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x03, 0xE0, 0x03, 0xE0,
      0x08, 0x00, 0x00, 0x07, 0xC0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0xFC, 0x07, 0xF0, 0x00, 0x00, 0x00,
      0x0F, 0xC3, 0xFC, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, 0x80, 0x00, 0x00, 0x00, 0x07, 0xF1, 0xE0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x1F,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0xA6,
      0xC6, 0x2A, 0xBE, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x7C,
      0x00, 0x48, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00,
      0x78, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00,
      0x00, 0x03, 0xE0, 0x00, 0x12, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00,
      0x03, 0x80, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x06, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x09, 0x66, 0xC6, 0x2A, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00,
      0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0,
      0x00, 0x00, 0x00, 0x0F, 0x80, 0x12, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00,
      0x00, 0x00, 0x70, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0E, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x02, 0x00, 0x00, 0x3F, 0x00, 0x01, 0x00, 0x00, 0x0F,
      0x80, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x08, 0x00, 0x00, 0x70, 0x00,
      0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00,
      0x07, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x70, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xE6, 0xC6, 0x2C, 0xDE, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
      0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x60, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0D, 0xE6, 0xC6, 0x2C, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x01, 0x20, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xE0, 0x34, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x04, 0x80, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0x80, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0D, 0xE6, 0xC6, 0x2C, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x0F, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xA6, 0xC6, 0x2B,
      0xBE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xC0, 0x00, 0x00,
      0x00, 0x01, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x03, 0xF1, 0xC0, 0x00, 0x00, 0x00, 0x07, 0x81, 0xC0,
      0x00, 0x00, 0x00, 0x06, 0x01, 0x80, 0x14, 0x00, 0x00, 0x00, 0x00, 0x70, 0x04, 0x00, 0x00, 0x00,
      0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFE, 0x00,
      0x00, 0x00, 0x00, 0x3F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x03, 0xFF,
      0x00, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x1C, 0x00, 0x00, 0x08, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x02, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00,
      0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80,
      0x00, 0x00, 0x90, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x0E, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0xE6, 0xC6, 0x2E, 0x5E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFE, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x03, 0xF0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0F, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x7E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x03, 0x1F,
      0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x07, 0xF0, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x01, 0xFE,
      0x0F, 0x80, 0x00, 0x00, 0x00, 0x07, 0x80, 0x7F, 0xE0, 0xFC, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x0F,
      0x0E, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x0F, 0x01, 0xE0, 0xE0, 0x7C, 0x00, 0x00, 0x00, 0x01, 0xF0,
      0x1C, 0x0E, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x1E, 0x03, 0x80, 0xE0, 0x7C, 0x00, 0x00, 0x00, 0x03,
      0xE0, 0x78, 0x0C, 0x07, 0x80, 0x00, 0x00, 0x00, 0x3C, 0x07, 0x01, 0xC0, 0x78, 0x00, 0x80, 0x00,
      0x00, 0xF8, 0x1E, 0x03, 0x81, 0xF0, 0x00, 0x00, 0x00, 0x0F, 0x83, 0xC0, 0x38, 0x1E, 0x00, 0x00,
      0x00, 0x00, 0xF0, 0x3C, 0x03, 0x81, 0xE0, 0x00, 0x00, 0x00, 0x1F, 0x03, 0xC0, 0x38, 0x3C, 0x00,
      0x00, 0x00, 0x01, 0xF0, 0x7C, 0x07, 0x83, 0x80, 0x00, 0x00, 0x00, 0x1F, 0x07, 0xC0, 0xF0, 0x78,
      0x00, 0x00, 0x00, 0x01, 0xF0, 0x7C, 0x1F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x07, 0xE3, 0x71,
      0xE0, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x7F, 0xE7, 0xB8, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x07, 0xFC,
      0x7F, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x3F, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x81,
      0xC0, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0xC0, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00,
      0x03, 0xE0, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xFC, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x0F, 0x80, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xE0, 0x00, 0x00,
      0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xA6, 0xC6, 0x2D,
      0xBE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x3F, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x01, 0xFC, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xC0, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x1D, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x06, 0x00, 0x77, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0xEF, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x38, 0x03, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x0E, 0x3E, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xF0, 0x38, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x71, 0xF0, 0x00, 0x00,
      0x00, 0x00, 0x01, 0x81, 0xC3, 0xE0, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xF8, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x03, 0x81, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x03, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x18, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x1F, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xC0, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x7C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0E, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x01, 0xF0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x7F, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x07, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x30, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x80, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x18, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xC0, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x7F, 0x08, 0x00, 0x00, 0x00, 0x0C,
      0x00, 0x01, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xC0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0F, 0x26, 0xC6, 0x2D, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3E, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x01, 0xF0, 0x00, 0x00,
      0x00, 0x00, 0xF0, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00,
      0x00, 0xE0, 0x07, 0x80, 0xF8, 0x00, 0x00, 0x00, 0x0C, 0x03, 0xFC, 0x07, 0xC0, 0x00, 0x00, 0x00,
      0xC0, 0x07, 0xC0, 0x3E, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x3E, 0x01, 0xF0, 0x00, 0x00, 0x00, 0xE0,
      0x01, 0xF0, 0x0F, 0x80, 0x00, 0x00, 0x06, 0x00, 0x0F, 0x80, 0xF8, 0x00, 0x00, 0x00, 0x60, 0x00,
      0xF8, 0x07, 0xC0, 0x00, 0x00, 0x03, 0x00, 0x07, 0xC0, 0x7C, 0x00, 0x00, 0x00, 0x30, 0x00, 0x3E,
      0x03, 0xC0, 0x00, 0x00, 0x01, 0x80, 0x01, 0xF0, 0x3C, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x1F, 0x07,
      0x80, 0x00, 0x00, 0x00, 0xC0, 0x00, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x06, 0x00, 0x07, 0xFF, 0xFC,
      0x00, 0x00, 0x00, 0x30, 0x00, 0x7E, 0x1F, 0xF0, 0x00, 0x00, 0x01, 0x80, 0x03, 0xE0, 0x0F, 0xC0,
      0x00, 0x00, 0x0C, 0x00, 0x1F, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x60, 0x00, 0xF8, 0x01, 0xF8, 0x02,
      0x00, 0x00, 0x70, 0x01, 0xF8, 0x00, 0xF8, 0x00, 0x00, 0x01, 0xE0, 0x0F, 0x80, 0x07, 0xC0, 0x00,
      0x00, 0x0F, 0x80, 0x7C, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x3E, 0x07, 0xE0, 0x01, 0xF0, 0x00, 0x00,
      0x00, 0xF0, 0x3E, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x03, 0x81, 0xF0, 0x00, 0xF8, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0x80, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00,
      0x07, 0xC0, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x03,
      0xE0, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF,
      0xFF, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xC0, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0xE0, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x0E,
      0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x06, 0x00, 0x00,
      0x00, 0x03, 0xE0, 0x00, 0x04, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x04, 0x00, 0x00, 0x00, 0x07,
      0x80, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00,
      0x04, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x04, 0x08,
      0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x01, 0x20, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x28, 0x00,
      0x00, 0xF8, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00,
      0x18, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x30, 0x00,
      0x00, 0x00, 0x0F, 0x80, 0x00, 0x70, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0xE0, 0x00, 0x00, 0x00,
      0x03, 0xE0, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0xFC,
      0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00,
      0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x0F, 0xF0, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xE0, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x78, 0x07, 0x00, 0x7E, 0x00,
      0x00, 0x00, 0x00, 0x0E, 0x0F, 0xF0, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x3E, 0x00, 0x1F,
      0x80, 0x00, 0x00, 0x00, 0x30, 0x03, 0xE0, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x06, 0x00, 0x3E, 0x00,
      0x07, 0xC0, 0x00, 0x00, 0x00, 0xC0, 0x03, 0xE0, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x7C,
      0x00, 0x03, 0xE0, 0x00, 0x00, 0x01, 0x80, 0x07, 0xC0, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x30, 0x00,
      0x7C, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x03, 0x00, 0x07, 0xC0, 0x00, 0x1F, 0x00, 0x80, 0x00, 0x0C,
      0x00, 0x1F, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x80, 0x01, 0xF0, 0x00, 0x03, 0xE0, 0x00, 0x00,
      0x18, 0x00, 0x1F, 0x00, 0x00, 0x3E, 0x01, 0x20, 0x00, 0x30, 0x00, 0x7C, 0x00, 0x00, 0x7C, 0x00,
      0x00, 0x03, 0x00, 0x07, 0xC0, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x38, 0x00, 0xFC, 0x00, 0x00, 0xF8,
      0x00, 0x00, 0x03, 0x80, 0x0F, 0x80, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x1E, 0x00, 0xF8, 0x00, 0x01,
      0xF0, 0x00, 0x00, 0x01, 0xF0, 0x0F, 0x80, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x0F, 0x81, 0xF0, 0x00,
      0x03, 0xE0, 0x00, 0x00, 0x00, 0x78, 0x1F, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x03, 0x01, 0xF0,
      0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x03,
      0xE0, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x07, 0xC0, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0x80, 0x1F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x00,
      0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xA6, 0xC6, 0x2D, 0xBE,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
      0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0xF8, 0xFC, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x07, 0x81, 0xF0, 0x00, 0x70, 0x00, 0x00, 0x00, 0x1C, 0x03, 0xE0, 0x00, 0xE0, 0x00,
      0x00, 0x00, 0x70, 0x07, 0xC0, 0x01, 0x80, 0x00, 0x00, 0x01, 0xC0, 0x1F, 0x00, 0x03, 0x00, 0x00,
      0x00, 0x07, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x30, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x01, 0xC0, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x06, 0x00, 0x1F, 0x00, 0x60, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x7C, 0x00, 0xC0, 0x00, 0x00, 0x00,
      0x38, 0x00, 0xF8, 0x03, 0x80, 0x00, 0x00, 0x00, 0x70, 0x01, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00,
      0xE0, 0x03, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x0F, 0x80, 0x18, 0x00, 0x02, 0x00, 0x00,
      0x7C, 0x03, 0xE0, 0x06, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x07, 0xC0, 0x0C, 0x00, 0x00, 0x00, 0x00,
      0xF8, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x3E, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00,
      0x00, 0x0F, 0x80, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0x80, 0x00, 0x38, 0x00, 0x90, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x1F, 0x00, 0x00, 0x00,
      0x00, 0x1F, 0x80, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00,
      0x00, 0xFC, 0xFC, 0x00, 0x70, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xC1, 0xC0, 0x00, 0x00, 0x00,
      0x7F, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x1F, 0xF8, 0x00, 0x0F, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0xE6, 0xC6, 0x2D, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF,
      0xF0, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x80, 0x0E, 0x00, 0x00, 0x00, 0x03, 0xC0, 0xF8, 0x00, 0x60,
      0x00, 0x00, 0x00, 0x70, 0x0F, 0x80, 0x0E, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xF0, 0x00, 0xC0, 0x00,
      0x00, 0x01, 0xC0, 0x1F, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x18, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x00, 0x1F, 0x00, 0x00, 0x08, 0x00, 0x00, 0x0C, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xC0, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80,
      0x0F, 0x80, 0x60, 0x00, 0x00, 0x00, 0x38, 0x00, 0xF8, 0x06, 0x00, 0x00, 0x00, 0x03, 0x80, 0x0F,
      0x80, 0xE0, 0x00, 0x00, 0x00, 0x38, 0x00, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x03, 0x80, 0x0F, 0xFF,
      0xC0, 0x01, 0x00, 0x00, 0x07, 0x80, 0x3E, 0x01, 0x80, 0x00, 0x00, 0x00, 0x7C, 0x03, 0xE0, 0x18,
      0x00, 0x00, 0x00, 0x03, 0xE0, 0x3E, 0x01, 0x80, 0x00, 0x00, 0x00, 0x3E, 0x07, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xC0, 0x7C, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x05,
      0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x10, 0x00,
      0x00, 0x07, 0xFF, 0xF8, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xA6,
      0xC6, 0x2D, 0xBE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F,
      0x01, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80,
      0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00,
      0x01, 0x80, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00,
      0x02, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00,
      0x08, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00,
      0x20, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00,
      0x00, 0x02, 0x80, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x03, 0xFF,
      0xF0, 0x01, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x07, 0xE0, 0x00, 0x40, 0x00, 0x00, 0xF8, 0x00, 0x01,
      0xF0, 0x00, 0x10, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x01,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x0F,
      0xC0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x01, 0xFE,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF0, 0xF8,
      0x00, 0x02, 0x40, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x3E,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x87, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00,
      0x00, 0x10, 0xA6, 0xC6, 0x2E, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0xF8,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x0F, 0x00, 0x00, 0x00, 0x07, 0xFE, 0x00, 0x07, 0x80,
      0x60, 0x00, 0x00, 0x0F, 0xFF, 0x80, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x07, 0xC1, 0xF0, 0x00, 0x3C,
      0x00, 0x00, 0x00, 0x01, 0xC0, 0x3E, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x60, 0x0F, 0x80, 0x01,
      0xE0, 0x00, 0x00, 0x00, 0x18, 0x01, 0xF0, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x07, 0x00, 0x3E, 0x00,
      0x0F, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x07, 0xC0, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x38, 0x01, 0xF0,
      0x00, 0x7C, 0x00, 0x10, 0x00, 0x00, 0xE0, 0x07, 0xC0, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x1E, 0x01,
      0xF8, 0x00, 0x7C, 0x00, 0x08, 0x00, 0x00, 0x78, 0x07, 0xC0, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x06,
      0x00, 0xF8, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x07, 0xC0, 0x1F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x1F, 0xF0, 0x0F, 0x80, 0x00, 0x40, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x3C, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x01, 0xF0, 0x00,
      0x04, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x01, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x07,
      0x80, 0x00, 0x08, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00,
      0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0,
      0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x60, 0x3C, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x1E, 0x0F,
      0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x03, 0xE3, 0xC0, 0x00, 0x3F, 0xFE, 0x00, 0x00, 0x00, 0x3F,
      0xF0, 0x00, 0x07, 0xFF, 0xC0, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
      0x00, 0x0B, 0xA6, 0xC6, 0x2B, 0xBE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xE0, 0x00, 0x00,
      0x00, 0x3F, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x43, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x04,
      0x80, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x02, 0x40, 0x00, 0x00, 0x03,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x01, 0x20, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00,
      0x00, 0x07, 0x80, 0x00, 0x90, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x28, 0x00, 0x00, 0x01, 0xF0, 0x00,
      0x0A, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x02, 0x40, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xF8, 0x00, 0x01, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00,
      0x00, 0x1F, 0xF0, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFC, 0x00,
      0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0B, 0xE6, 0xC6, 0x2B, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFC,
      0x00, 0x00, 0x00, 0x00, 0x7F, 0xFC, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x7C, 0x00, 0x00, 0x00, 0x07,
      0x80, 0xF8, 0x00, 0x00, 0x00, 0x0E, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x1C, 0x00, 0xF8, 0x00, 0x00,
      0x00, 0x18, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x38, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x30, 0x01, 0xF0,
      0x00, 0x00, 0x00, 0x70, 0x01, 0xE0, 0x08, 0x00, 0x00, 0x0E, 0x00, 0x7C, 0x01, 0x00, 0x00, 0x01,
      0xE0, 0x0F, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x1E, 0x00, 0x20, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x07,
      0x80, 0x04, 0x80, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x90, 0x00,
      0x00, 0x00, 0x7C, 0x00, 0x12, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x02, 0x40, 0x00, 0x00, 0x07, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x40, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x08, 0x00, 0x00,
      0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00,
      0x00, 0x0C, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x1E, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x1F, 0x01, 0xC0,
      0x00, 0x00, 0x00, 0x0F, 0xC3, 0x80, 0x00, 0x00, 0x00, 0x07, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x03,
      0xF8, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x10, 0x26, 0xC6, 0x2D, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x07, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFE, 0x00, 0xFF, 0xF8, 0x00,
      0x00, 0x00, 0x7C, 0x3E, 0x00, 0x7F, 0xF0, 0x00, 0x00, 0x00, 0xF0, 0x1F, 0x00, 0x03, 0xE0, 0x00,
      0x00, 0x00, 0xE0, 0x0F, 0x80, 0x03, 0xC0, 0x00, 0x00, 0x00, 0xE0, 0x0F, 0x80, 0x03, 0x80, 0x00,
      0x00, 0x00, 0x60, 0x07, 0xC0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x60, 0x03, 0xE0, 0x03, 0x80, 0x00,
      0x00, 0x00, 0x30, 0x01, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x38, 0x01, 0xF0, 0x07, 0x00, 0x00,
      0x00, 0x00, 0x1C, 0x00, 0xF8, 0x07, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x7C, 0x07, 0x00, 0x00,
      0x00, 0x00, 0x07, 0x80, 0x7E, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x3E, 0x0E, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xC0, 0x1F, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xBC, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x03, 0xEF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF3, 0xE0, 0x00,
      0x00, 0x10, 0x00, 0x00, 0x00, 0x3E, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x07, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x3E,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x0F, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x3E, 0x00,
      0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x3C, 0x00, 0x00, 0x20, 0x00, 0x00, 0x03, 0xE0,
      0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0,
      0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF,
      0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x07, 0x00, 0x70, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x3E, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x3C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x03, 0xC0, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x1E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3E, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFE, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xFC, 0x0D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0xE6, 0xC6, 0x2D, 0x5E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF,
      0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x81, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x60, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x03, 0xF0, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xFC, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00,
      0x07, 0xE0, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xF8, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7E,
      0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80,
      0x00, 0x1C, 0x00, 0x40, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00,
      0x07, 0xC0, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x03,
      0xC0, 0x00, 0x00, 0x03, 0xF9, 0xFE, 0x00, 0x38, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0x07, 0x00,
      0x00, 0x00, 0x1F, 0xFF, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xF8, 0x00, 0x0F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x13, 0x26, 0xC6, 0x2F, 0x7E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
      0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00,
      0x03, 0xFF, 0x80, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFC, 0x00, 0x00, 0x3C, 0x00,
      0x00, 0x00, 0x00, 0x3E, 0x0F, 0xE0, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x07, 0x80, 0x7F, 0x00,
      0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x70, 0x03, 0xF8, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x0E,
      0x00, 0x1F, 0xC0, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0xFE, 0x00, 0x03, 0xF8, 0x00,
      0x00, 0x00, 0x06, 0x00, 0x0F, 0xF0, 0x00, 0x3F, 0xC0, 0x00, 0x00, 0x00, 0x70, 0x00, 0x7F, 0x80,
      0x03, 0xFE, 0x00, 0x00, 0x00, 0x03, 0x00, 0x03, 0xFE, 0x00, 0x3F, 0xE0, 0x00, 0x00, 0x00, 0x38,
      0x00, 0x19, 0xF0, 0x03, 0xDF, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0xCF, 0x80, 0x1C, 0xF8, 0x00,
      0x00, 0x00, 0x0E, 0x00, 0x06, 0x7C, 0x01, 0xCF, 0x80, 0x00, 0x00, 0x00, 0x78, 0x00, 0x73, 0xE0,
      0x1E, 0x7C, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x03, 0x9F, 0x00, 0xE3, 0xE0, 0x00, 0x00, 0x00, 0x1F,
      0x00, 0x1C, 0xF8, 0x0E, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0xC7, 0xC0, 0xE1, 0xF0, 0x00,
      0x00, 0x00, 0x03, 0xE0, 0x0E, 0x3E, 0x07, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x71, 0xF0,
      0x70, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x8F, 0x87, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x18, 0x7C, 0x38, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC3, 0xE3, 0x81, 0xF0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0E, 0x1F, 0x18, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0xF9,
      0xC0, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x07, 0xDC, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x30, 0x3E, 0xC0, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x81, 0xFE, 0x01, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x1C, 0x0F, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x7F,
      0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x01, 0xF0, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xE0, 0x0F, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x78, 0x03, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xF0, 0x03, 0x80, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x1C,
      0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00, 0xC0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x0F,
      0xFF, 0x00, 0x04, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xF0, 0x00, 0x20, 0x03, 0xFF, 0xE0,
      0x00, 0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00,
      0x00, 0x00, 0x10, 0xE6, 0xC6, 0x2E, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24,
      0xF8, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x3F, 0xC0, 0x00,
      0x07, 0xF8, 0x00, 0x00, 0x00, 0x7F, 0xFC, 0x00, 0x00, 0xE1, 0x80, 0x00, 0x00, 0x1F, 0xC7, 0xC0,
      0x00, 0x18, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x7C, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0xF0, 0x07,
      0xE0, 0x00, 0x30, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x7E, 0x00, 0x07, 0x00, 0x00, 0x00, 0x01, 0xC0,
      0x07, 0xE0, 0x00, 0x60, 0x00, 0x00, 0x00, 0x38, 0x00, 0xFE, 0x00, 0x06, 0x00, 0x00, 0x00, 0x03,
      0x00, 0x0D, 0xF0, 0x00, 0xE0, 0x04, 0x00, 0x00, 0x0E, 0x00, 0x19, 0xE0, 0x01, 0x80, 0x00, 0x00,
      0x00, 0xE0, 0x01, 0x9F, 0x00, 0x38, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x38, 0xF0, 0x03, 0x00, 0x00,
      0x00, 0x00, 0xE0, 0x03, 0x0F, 0x00, 0x30, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x30, 0xF8, 0x03, 0x00,
      0x00, 0x00, 0x00, 0xF0, 0x03, 0x07, 0x80, 0x60, 0x00, 0x00, 0x00, 0x07, 0x00, 0x70, 0x78, 0x06,
      0x00, 0x00, 0x00, 0x00, 0x70, 0x06, 0x07, 0xC0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x3C,
      0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x03, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0,
      0x3E, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x01, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xC0, 0x1F, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x01, 0xF1, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x01, 0x80, 0x0F, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0xF9, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x01, 0x80, 0x0F, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x7F, 0x00, 0x00, 0x80,
      0x00, 0x00, 0x00, 0x60, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x07, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x03, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x01,
      0xC0, 0x00, 0x00, 0x00, 0x38, 0x03, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x60, 0x00,
      0x01, 0x80, 0x00, 0x00, 0x00, 0x3F, 0x1E, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x80,
      0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00,
      0x0F, 0x26, 0xC6, 0x2D, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x01, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F,
      0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00,
      0x0F, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00,
      0xF8, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x1F,
      0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x07, 0xE0,
      0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0xF8, 0x08,
      0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x07, 0xC0, 0x48,
      0x00, 0x00, 0xF0, 0x00, 0x00, 0x07, 0xC0, 0x48, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x00, 0x0F, 0x80, 0x00, 0x00, 0x7C, 0x02, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x78, 0x02, 0x00,
      0x00, 0x0F, 0x80, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
      0x01, 0xF0, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00,
      0x7E, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x07,
      0xC0, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0xFE,
      0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFC, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x06, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0E, 0x26, 0xC6, 0x2C, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x00, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x01,
      0xF8, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x1F, 0x80, 0x00, 0x00, 0x07, 0x00, 0x70, 0x07, 0xC0, 0x00, 0x00, 0x07, 0x07, 0xF8, 0x01, 0xF0,
      0x00, 0x00, 0x07, 0x00, 0xFC, 0x00, 0xF8, 0x00, 0x00, 0x06, 0x00, 0x7C, 0x00, 0x7C, 0x00, 0x00,
      0x06, 0x00, 0x3E, 0x00, 0x3E, 0x00, 0x00, 0x07, 0x00, 0x1F, 0x00, 0x1F, 0x00, 0x00, 0x03, 0x00,
      0x0F, 0x80, 0x0F, 0x90, 0x00, 0x00, 0x60, 0x01, 0xF0, 0x01, 0xF0, 0x00, 0x00, 0x60, 0x00, 0xF8,
      0x01, 0xF0, 0x00, 0x00, 0x30, 0x00, 0x7C, 0x01, 0xF0, 0x00, 0x00, 0x10, 0x00, 0x7C, 0x01, 0xF0,
      0x00, 0x00, 0x18, 0x00, 0x3E, 0x01, 0xF0, 0x00, 0x00, 0x0C, 0x00, 0x1F, 0x03, 0xF0, 0x00, 0x00,
      0x06, 0x00, 0x0F, 0xFF, 0xC0, 0x00, 0x00, 0x03, 0x00, 0x0F, 0xFF, 0x00, 0x02, 0x00, 0x00, 0x30,
      0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x7C,
      0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x1F, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x7C, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x0F, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x07, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0xF0, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x80, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xC0, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0x26, 0xC6, 0x2D, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F,
      0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x01, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x03,
      0xF8, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x1F,
      0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x03, 0xF0,
      0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x7C, 0x00,
      0x00, 0x00, 0x0E, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x0F, 0x80, 0x00,
      0x00, 0x07, 0x00, 0x00, 0x00, 0x7C, 0x08, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00,
      0x00, 0xF8, 0x00, 0x00, 0x03, 0xE0, 0x48, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x03, 0xE0, 0x40, 0x00,
      0x01, 0xF0, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x3E, 0x02, 0x00, 0x00,
      0x0F, 0x80, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x03,
      0xE0, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0xFC,
      0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x1F, 0x80,
      0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00,
      0x07, 0x80, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x0F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFE, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC, 0x01, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x07, 0xF8, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0xF1, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x0F, 0x26, 0xC6, 0x2D, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x16,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0xFE, 0x00, 0x00, 0x00,
      0x00, 0x07, 0x80, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00,
      0x0E, 0x00, 0xE0, 0x1F, 0x80, 0x00, 0x00, 0x00, 0xE0, 0xFE, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x0E,
      0x01, 0xF0, 0x03, 0xE0, 0x00, 0x00, 0x00, 0xE0, 0x0F, 0x80, 0x1F, 0x00, 0x00, 0x00, 0x06, 0x00,
      0x7C, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x60, 0x07, 0xC0, 0x07, 0xC0, 0x20, 0x00, 0x00, 0xC0, 0x07,
      0xC0, 0x0F, 0x80, 0x00, 0x00, 0x06, 0x00, 0x3E, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x60, 0x03, 0xE0,
      0x0F, 0x80, 0x00, 0x00, 0x03, 0x00, 0x1F, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x18, 0x00, 0xF8, 0x1F,
      0x80, 0x00, 0x00, 0x00, 0xC0, 0x07, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x06, 0x00, 0x7F, 0xFE, 0x00,
      0x00, 0x00, 0x00, 0x30, 0x03, 0xE7, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x1F, 0x1F, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0x01, 0xF8, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x0F, 0x87, 0xC0, 0x00, 0x00,
      0x00, 0x01, 0xF0, 0x7C, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x07, 0x83, 0xE0, 0xF8, 0x00, 0x00, 0x00,
      0x00, 0x1C, 0x3F, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x3F, 0x00, 0x00, 0x80, 0x00,
      0x00, 0x01, 0xF0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xF8, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x7E, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0xFF,
      0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xF8, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF,
      0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
      0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8,
      0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x83,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xBC,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xE6, 0xC6, 0x2C, 0x5E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xC0, 0x00, 0x00, 0x00,
      0x03, 0xE0, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x78, 0x07, 0x80, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x38,
      0x00, 0x00, 0x00, 0x01, 0xF0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x30, 0x08, 0x00, 0x00,
      0x00, 0x78, 0x00, 0x60, 0x12, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x80, 0x00, 0x00, 0x00, 0x1F, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xC0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x01, 0xFC, 0x00, 0x20, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x50, 0x00, 0x00,
      0x00, 0x01, 0xF0, 0x00, 0x00, 0x03, 0x80, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x03, 0xE0,
      0x00, 0x00, 0x07, 0xC0, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x07, 0x80, 0x00, 0x00, 0x07,
      0xC0, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x03, 0xC0,
      0x00, 0x00, 0x00, 0x0F, 0x81, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFE, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xFF, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x20, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xA6, 0xC6, 0x2C, 0xBE, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF,
      0xFF, 0xF0, 0x00, 0x00, 0x1F, 0xFF, 0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x7F, 0x80, 0x3E, 0x00, 0x00,
      0x00, 0x01, 0xF0, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x1E,
      0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x38, 0x00, 0x07, 0xC0, 0x02, 0x00, 0x00, 0x1C, 0x00, 0x01,
      0xF0, 0x00, 0x00, 0x00, 0x30, 0x00, 0x07, 0xC0, 0x01, 0x20, 0x00, 0x1C, 0x00, 0x01, 0xF0, 0x00,
      0x40, 0x00, 0x07, 0x80, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x01, 0xF0, 0x00, 0x00, 0x00,
      0x0F, 0x80, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x1C, 0x00,
      0x1F, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x50, 0x00, 0x00, 0x00, 0x03, 0xE0,
      0x00, 0x12, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x08,
      0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFE,
      0x02, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x11, 0xA6, 0xC6,
      0x2E, 0xBE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x02, 0x40, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x80, 0x00, 0x0F,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x7C, 0x00,
      0x00, 0x1C, 0x00, 0x00, 0x00, 0x07, 0x00, 0xF8, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x1C, 0x01,
      0xE0, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x70, 0x07, 0xC0, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00,
      0xC0, 0x0F, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x03, 0x00, 0x3E, 0x00, 0x00, 0x03, 0x80, 0x00,
      0x00, 0x06, 0x00, 0x78, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x1C, 0x01, 0xF0, 0x00, 0x00, 0x0C,
      0x00, 0x00, 0x00, 0x38, 0x03, 0xC0, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x78, 0x07, 0x80, 0x00,
      0x00, 0x70, 0x00, 0x00, 0x00, 0xF0, 0x1F, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x01, 0xE0, 0x3C,
      0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x01, 0x80, 0xF8, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00,
      0x01, 0xF0, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x18, 0x00, 0x80,
      0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x18,
      0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00,
      0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7C,
      0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x1C, 0x00, 0x08, 0x00, 0x00,
      0x00, 0x3E, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x38, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xFC, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x03, 0x80,
      0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00,
      0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
      0xF8, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xFC, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x06, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0F, 0xE6, 0xC6, 0x2D, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xF9, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x80,
      0x00, 0x0E, 0x00, 0x00, 0x00, 0x07, 0xFF, 0x80, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x3F, 0x0F, 0x00,
      0x00, 0x0C, 0x00, 0x00, 0x00, 0x78, 0x1E, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x01, 0xE0, 0x3E, 0x00,
      0x00, 0x18, 0x00, 0x00, 0x03, 0x80, 0x7C, 0x00, 0x00, 0x18, 0x00, 0x00, 0x07, 0x00, 0x7C, 0x00,
      0x00, 0x30, 0x00, 0x00, 0x0E, 0x00, 0xF8, 0x00, 0x00, 0x30, 0x00, 0x00, 0x0C, 0x00, 0xF8, 0x00,
      0x00, 0x60, 0x00, 0x00, 0x1C, 0x01, 0xF0, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x18, 0x01, 0xF0, 0x00,
      0x01, 0xC0, 0x00, 0x00, 0x38, 0x03, 0xF0, 0x00, 0x01, 0x80, 0x00, 0x00, 0x38, 0x03, 0xF0, 0x00,
      0x03, 0x00, 0x00, 0x00, 0x38, 0x03, 0xE0, 0x00, 0x06, 0x00, 0x00, 0x00, 0x3C, 0x03, 0xE0, 0x00,
      0x0C, 0x00, 0x00, 0x00, 0x3C, 0x03, 0xE0, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x1C, 0x03, 0xE0, 0x00,
      0x38, 0x00, 0x00, 0x00, 0x1C, 0x03, 0xE0, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00,
      0x60, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x01,
      0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x06,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x38,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x60,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE1, 0x80,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE6, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x13, 0xE6, 0xC6, 0x2F, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C,
      0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC8, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x38, 0x00,
      0x00, 0x00, 0x00, 0xFE, 0x00, 0x03, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x1F, 0xFC, 0x00, 0x07,
      0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x7C, 0x78, 0x00, 0x07, 0x00, 0x00, 0x30, 0x00, 0x00, 0x01,
      0xE0, 0xF8, 0x00, 0x0F, 0x00, 0x00, 0x30, 0x00, 0x00, 0x03, 0x81, 0xF0, 0x00, 0x1E, 0x00, 0x00,
      0x70, 0x00, 0x00, 0x07, 0x03, 0xE0, 0x00, 0x3E, 0x00, 0x00, 0x60, 0x00, 0x00, 0x0E, 0x03, 0xE0,
      0x00, 0x3E, 0x00, 0x00, 0x60, 0x00, 0x00, 0x1C, 0x07, 0xC0, 0x00, 0x7E, 0x00, 0x00, 0xC0, 0x00,
      0x00, 0x18, 0x07, 0xC0, 0x00, 0xDE, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x30, 0x0F, 0xC0, 0x01, 0xDE,
      0x00, 0x01, 0x80, 0x00, 0x00, 0x30, 0x0F, 0x80, 0x01, 0x9E, 0x00, 0x01, 0x80, 0x00, 0x00, 0x70,
      0x0F, 0x80, 0x03, 0x3C, 0x00, 0x03, 0x00, 0x00, 0x00, 0x70, 0x0F, 0x80, 0x07, 0x3C, 0x00, 0x07,
      0x00, 0x00, 0x00, 0x70, 0x1F, 0x80, 0x06, 0x3C, 0x00, 0x06, 0x00, 0x00, 0x00, 0x78, 0x1F, 0x00,
      0x0C, 0x3C, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x78, 0x1F, 0x00, 0x1C, 0x3C, 0x00, 0x0C, 0x00, 0x00,
      0x00, 0x78, 0x1F, 0x00, 0x18, 0x3C, 0x00, 0x18, 0x00, 0x00, 0x00, 0x30, 0x1F, 0x00, 0x30, 0x3C,
      0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x70, 0x3C, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
      0x1F, 0x00, 0x60, 0x3C, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0xC0, 0x3C, 0x00, 0xE0,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0x01, 0xC0, 0x3C, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x01,
      0x80, 0x3C, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x03, 0x00, 0x3C, 0x03, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x1F, 0x07, 0x00, 0x3C, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x86, 0x00, 0x3C,
      0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x8C, 0x00, 0x7C, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x1F, 0x9C, 0x00, 0x7C, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xB8, 0x00, 0x7C, 0x70, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0F, 0xB0, 0x00, 0x7C, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF0,
      0x00, 0x7D, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xC0, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x7F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x78, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x01, 0xE0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0xA6,
      0xC6, 0x2D, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F,
      0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFE, 0x00,
      0x00, 0x00, 0x3F, 0xF0, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x07, 0xFE, 0x00, 0x1C, 0x00, 0x00, 0x00,
      0x00, 0x07, 0xC0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00,
      0x1F, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C,
      0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x30,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE3, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x7C, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xD8, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x01, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00,
      0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xBE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x77, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x0F, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xC1, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x3E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0E, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0xF8, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x60, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07,
      0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x07, 0xFF,
      0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0xFF, 0xE0, 0x00, 0x00, 0x1F, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x07, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0xA6, 0xC6, 0x2D, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x01, 0x80, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x07, 0xC0, 0x00, 0x00,
      0x03, 0xFF, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x01, 0xF3, 0xF0, 0x00, 0x78, 0x00, 0x00, 0x00, 0x70,
      0x7E, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x18, 0x07, 0xE0, 0x07, 0x80, 0x00, 0x00, 0x0E, 0x00, 0x7C,
      0x01, 0xE0, 0x00, 0x00, 0x01, 0x80, 0x0F, 0xC0, 0x38, 0x00, 0x00, 0x00, 0x60, 0x00, 0xF8, 0x0E,
      0x00, 0x00, 0x00, 0x18, 0x00, 0x1F, 0x01, 0x80, 0x00, 0x00, 0x03, 0x00, 0x03, 0xF0, 0x70, 0x00,
      0x00, 0x00, 0xC0, 0x00, 0x3E, 0x1C, 0x00, 0x00, 0x00, 0x18, 0x00, 0x07, 0xC3, 0x00, 0x00, 0x00,
      0x03, 0x00, 0x00, 0xF8, 0xE0, 0x00, 0x00, 0x00, 0x60, 0x00, 0x0F, 0x98, 0x00, 0x00, 0x00, 0x0E,
      0x00, 0x01, 0xF6, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x3E, 0xC0, 0x00, 0x00, 0x00, 0x3E, 0x00,
      0x07, 0xF0, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x1F,
      0x80, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x04, 0x80, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00,
      0x12, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x01, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xEF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xF8, 0x00, 0x1E, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xA0, 0x00, 0x00,
      0x01, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
      0x00, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0x80, 0x78,
      0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0xC7, 0xFF, 0xFF, 0x80,
      0x00, 0x00, 0x00, 0x03, 0x03, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0xFF, 0xF8, 0x00,
      0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x03, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3E, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x30, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x30, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0E, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00,
      0xE0, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x0E,
      0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x38, 0x7F, 0xF8, 0x00, 0x30, 0x00, 0x00, 0x00, 0xEF,
      0xFF, 0xFF, 0x00, 0x60, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xC1, 0x80, 0x00, 0x00, 0x0F, 0xFF,
      0xFF, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x3F, 0xF0, 0x00, 0x00, 0x00, 0x30, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x66, 0xC6,
      0x2A, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x0D, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0F,
      0xFE, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x04, 0x80, 0x00, 0x00, 0x1C, 0x00,
      0x00, 0x00, 0x00, 0xF0, 0x0A, 0x00, 0x00, 0x00, 0x70, 0x05, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00,
      0x00, 0x03, 0xC0, 0x09, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x14, 0x00, 0x00,
      0x07, 0x00, 0x0A, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x12, 0x00, 0x00, 0x1C,
      0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x28, 0x00, 0x00, 0x70, 0x00, 0x14, 0x00, 0x00, 0x70, 0x00,
      0x00, 0x00, 0x03, 0xC0, 0x00, 0x24, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x50,
      0x00, 0x07, 0x00, 0x00, 0x20, 0x00, 0x07, 0xFE, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0D, 0x26, 0xC6, 0x2C, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x14, 0x00, 0x00,
      0x00, 0xE0, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x38,
      0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00,
      0x14, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x14, 0x00,
      0x00, 0x00, 0x01, 0xC0, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x14, 0x00, 0x00, 0x00,
      0x00, 0x70, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0x1C,
      0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x16,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xA6, 0xC6,
      0x2B, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
      0x0F, 0xF8, 0x04, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x14, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xE0, 0x0A, 0x00, 0x00, 0x00, 0x07, 0x00, 0x28, 0x00, 0x00, 0x00, 0x38, 0x00, 0xA0,
      0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x50, 0x00, 0x00, 0x01, 0xC0, 0x01,
      0x40, 0x00, 0x00, 0x0E, 0x00, 0x05, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00,
      0x02, 0x80, 0x00, 0x00, 0x70, 0x00, 0x0A, 0x00, 0x00, 0x03, 0x80, 0x00, 0x28, 0x00, 0x00, 0x1C,
      0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x14, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x40, 0x00, 0x3F,
      0xE0, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xE6,
      0xC6, 0x2C, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x58, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E,
      0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x78, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x07, 0x80, 0x0F, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xD0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xA6, 0xC6, 0x2C, 0xBE,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
      0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
      0xE6, 0xC6, 0x2A, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x80, 0x00, 0x00, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x07, 0x01, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00,
      0x00, 0x30, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00,
      0x01, 0xE0, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0C, 0x66, 0xC6, 0x2C, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xC0, 0x00,
      0x00, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x70,
      0x3E, 0x00, 0x00, 0x00, 0x00, 0x38, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x18, 0x07, 0xC0, 0x00, 0x00,
      0x00, 0x0E, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x07, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x03, 0x80, 0x1E,
      0x00, 0x00, 0x00, 0x00, 0xE0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x78, 0x03, 0xE0, 0x00, 0x00, 0x00,
      0x1C, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x1F, 0x00,
      0x04, 0x00, 0x00, 0x3C, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x07,
      0xC0, 0x1F, 0x80, 0x00, 0x00, 0x01, 0xF0, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x7C, 0x07, 0xF0, 0xC0,
      0x00, 0x00, 0x1F, 0x03, 0x7C, 0x60, 0x00, 0x00, 0x07, 0xE3, 0x9F, 0x30, 0x00, 0x00, 0x01, 0xFF,
      0xC7, 0xF8, 0x00, 0x00, 0x00, 0x3F, 0xE3, 0xFC, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0xFC, 0x00, 0x00,
      0x00, 0x01, 0xE0, 0x3C, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1A, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x66, 0xC6, 0x2C, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x7F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x38, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00,
      0x00, 0x40, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x02, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x10, 0x00,
      0x00, 0x01, 0xF0, 0x00, 0x00, 0xA0, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x1F, 0xE0, 0x00, 0x00,
      0x00, 0x07, 0x8F, 0xFC, 0x00, 0x00, 0x00, 0x03, 0xEE, 0x3F, 0x80, 0x00, 0x00, 0x00, 0xFF, 0x07,
      0xE0, 0x00, 0x00, 0x00, 0x3F, 0x80, 0xF8, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x3E, 0x00, 0x80, 0x00,
      0x00, 0xFC, 0x01, 0xF0, 0x04, 0x00, 0x00, 0x07, 0xC0, 0x0F, 0x80, 0x00, 0x00, 0x01, 0xE0, 0x03,
      0xE0, 0x00, 0x00, 0x00, 0xF8, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x7C, 0x00, 0x00, 0x00,
      0x0F, 0x00, 0x1F, 0x00, 0x20, 0x00, 0x00, 0x78, 0x00, 0xF0, 0x01, 0x00, 0x00, 0x07, 0xC0, 0x0F,
      0x00, 0x00, 0x00, 0x01, 0xF0, 0x07, 0x80, 0x00, 0x00, 0x00, 0x7C, 0x01, 0xC0, 0x00, 0x00, 0x00,
      0x1F, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x78, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x1C, 0x00,
      0x00, 0x00, 0x00, 0x3F, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x7E, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xE6, 0xC6, 0x2B, 0x5E, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x80, 0x00, 0x00,
      0x00, 0x7F, 0xF8, 0x00, 0x00, 0x00, 0x0E, 0x1F, 0x80, 0x00, 0x00, 0x01, 0xC0, 0x70, 0x10, 0x00,
      0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xC0, 0x00, 0x02, 0x40, 0x00, 0x07, 0x80, 0x00, 0x04, 0x80, 0x00, 0x1E, 0x00, 0x00,
      0x0A, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x0C, 0x00, 0x00, 0x00, 0x7C, 0x03,
      0x80, 0x00, 0x00, 0x07, 0xE0, 0x70, 0x00, 0x00, 0x00, 0x7F, 0x1E, 0x00, 0x00, 0x00, 0x03, 0xFF,
      0x80, 0x00, 0x00, 0x00, 0x3F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x01, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x03, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C,
      0xA6, 0xC6, 0x2C, 0x3A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00,
      0x00, 0x00, 0x07, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70,
      0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x40, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x01, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x90, 0x00, 0x00, 0x00, 0x00,
      0xF8, 0x02, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0xF8, 0x00, 0x00, 0x00, 0x00, 0x70, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x03, 0xE0, 0x00, 0x00,
      0x00, 0x07, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x38, 0x03,
      0xE0, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x0F, 0x80, 0x00, 0x00,
      0x00, 0x78, 0x01, 0xE0, 0x00, 0x90, 0x00, 0x03, 0xC0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0xF0, 0x03,
      0xF0, 0x00, 0x40, 0x00, 0x03, 0xC0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0xF8, 0x03, 0xF0, 0x00, 0x00,
      0x00, 0x1F, 0x00, 0xFE, 0x10, 0x00, 0x00, 0x03, 0xE0, 0x3F, 0xC7, 0x00, 0x00, 0x00, 0x7E, 0x0E,
      0xF1, 0xC0, 0x00, 0x00, 0x0F, 0xC3, 0xBE, 0x70, 0x00, 0x00, 0x01, 0xFF, 0xC7, 0xFC, 0x00, 0x00,
      0x00, 0x1F, 0xF0, 0xFE, 0x00, 0x00, 0x00, 0x03, 0xFC, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x3E, 0x03,
      0x80, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xE6, 0xC6,
      0x2B, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00,
      0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0xE3, 0xF0, 0x00, 0x00, 0x00, 0x1C, 0x1F, 0x00, 0x00,
      0x00, 0x03, 0x81, 0xF0, 0x00, 0x00, 0x00, 0x30, 0x1F, 0x00, 0x00, 0x00, 0x07, 0x01, 0xF0, 0x00,
      0x00, 0x00, 0xE0, 0x3E, 0x00, 0x00, 0x00, 0x0E, 0x03, 0xC0, 0x00, 0x00, 0x01, 0xE0, 0x78, 0x00,
      0x00, 0x00, 0x3C, 0x0F, 0x00, 0x00, 0x00, 0x03, 0xC3, 0xE0, 0x00, 0x00, 0x00, 0x3C, 0x78, 0x00,
      0x00, 0x00, 0x07, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00,
      0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x08, 0x00, 0x00, 0x00, 0xF8, 0x01,
      0xC0, 0x00, 0x00, 0x0F, 0x80, 0x3C, 0x00, 0x00, 0x00, 0xF8, 0x07, 0x00, 0x00, 0x00, 0x0F, 0x80,
      0xE0, 0x00, 0x00, 0x00, 0xFC, 0x3C, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x7F,
      0xF0, 0x00, 0x00, 0x00, 0x07, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x1E, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A,
      0xA6, 0xC6, 0x2B, 0x3A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00,
      0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x00,
      0x00, 0x00, 0x01, 0xE1, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00,
      0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x01, 0x00,
      0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x90, 0x00, 0x00, 0x01, 0xF0, 0x02,
      0x40, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFC,
      0x00, 0x00, 0x0F, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x01, 0xF0, 0x00, 0xA0, 0x00, 0x00, 0x0F, 0x80,
      0x02, 0x80, 0x00, 0x00, 0x7C, 0x00, 0x09, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0xFC,
      0x00, 0x04, 0x80, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x02, 0x40, 0x00, 0x03,
      0xE0, 0x00, 0x09, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x04, 0x00, 0x00,
      0x1F, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00,
      0x1E, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x1C, 0x00, 0x00, 0x00, 0x78, 0x0F, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xC0, 0x00, 0x00, 0x03, 0xFF,
      0xF0, 0x00, 0x00, 0x00, 0x7F, 0xF8, 0x00, 0x00, 0x00, 0x07, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x7E,
      0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B,
      0xE6, 0xC6, 0x2B, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x78, 0x3E,
      0x00, 0x00, 0x00, 0x00, 0xE0, 0x3E, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x3E, 0x00, 0x00, 0x00, 0x03,
      0x80, 0x7C, 0x01, 0x00, 0x00, 0x00, 0xE0, 0x0F, 0x80, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x80, 0x20,
      0x00, 0x00, 0x78, 0x03, 0xE0, 0x04, 0x00, 0x00, 0x1E, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x3E, 0x00,
      0xF8, 0x00, 0x80, 0x00, 0x07, 0x80, 0x1F, 0x00, 0x00, 0x00, 0x07, 0x80, 0x3F, 0x00, 0x00, 0x00,
      0x0F, 0x80, 0x3F, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x7E, 0x00, 0x00, 0x00, 0x0F, 0x80, 0xFE, 0x00,
      0x00, 0x00, 0x0F, 0xC1, 0xFE, 0x00, 0x00, 0x00, 0x0F, 0xC7, 0xBE, 0x00, 0x00, 0x00, 0x0F, 0xFE,
      0x3E, 0x00, 0x00, 0x00, 0x07, 0xFC, 0x3E, 0x00, 0x00, 0x00, 0x03, 0xB0, 0x3E, 0x00, 0x00, 0x00,
      0x00, 0xE0, 0x3E, 0x00, 0x00, 0x00, 0x03, 0x80, 0x3E, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x3E, 0x00,
      0x00, 0x00, 0x3C, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x78, 0x00, 0x3E, 0x00, 0x00, 0x00, 0xF0, 0x00,
      0x7C, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x7C, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x7C, 0x00, 0x10, 0x00,
      0x78, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x78, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x7C, 0x00,
      0x00, 0x00, 0x3C, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x1F, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x0F, 0xFF,
      0xC0, 0x00, 0x00, 0x00, 0x01, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00,
      0x00, 0x07, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xF0,
      0x00, 0x00, 0x00, 0x00, 0x78, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x04, 0x80, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x14, 0x00, 0x00,
      0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x3C,
      0x00, 0x00, 0x00, 0x01, 0xF0, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x3E, 0x0F, 0xF8, 0x00, 0x00, 0x00,
      0x0F, 0xC3, 0xFF, 0x00, 0x00, 0x00, 0x01, 0xF0, 0xC7, 0xE0, 0x00, 0x00, 0x00, 0x3E, 0x60, 0xF8,
      0x00, 0x00, 0x00, 0x07, 0xD8, 0x1F, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x07, 0xE0, 0x00, 0x00, 0x00,
      0x3F, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x07, 0xE0,
      0x00, 0x00, 0x00, 0x1E, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x1F, 0x00, 0x00, 0x00, 0x00,
      0xF8, 0x07, 0xE0, 0x02, 0x00, 0x00, 0x03, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x07, 0xE0,
      0x01, 0x20, 0x00, 0x03, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x07, 0xE1, 0x80, 0x00, 0x00,
      0x1F, 0x00, 0xF8, 0x70, 0x00, 0x00, 0x03, 0xE0, 0x1F, 0x18, 0x00, 0x00, 0x00, 0x7C, 0x03, 0xF6,
      0x00, 0x00, 0x00, 0x1F, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x03, 0xE0, 0x0F, 0xC0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0xF0, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xD0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x66, 0xC6, 0x2A, 0x9E, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xE0, 0x48, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x01, 0xC0, 0xF0, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x3F, 0xE0, 0x00, 0x00,
      0x01, 0xFF, 0x00, 0x00, 0x00, 0x0E, 0x7C, 0x00, 0x00, 0x00, 0x61, 0xF0, 0x00, 0x00, 0x03, 0x0F,
      0x80, 0x10, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x24, 0x00, 0x00, 0x1F, 0x00,
      0x00, 0x00, 0x00, 0xFC, 0x00, 0x40, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x90,
      0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x07, 0xC3, 0x00, 0x00, 0x00, 0x3F, 0x18, 0x00, 0x00, 0x00,
      0xFC, 0xC0, 0x00, 0x00, 0x03, 0xF6, 0x00, 0x00, 0x00, 0x0F, 0xF0, 0x00, 0x00, 0x00, 0x3F, 0x00,
      0x00, 0x00, 0x00, 0x70, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x0D, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xE6, 0xC6, 0x2A, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x48, 0x00, 0x00, 0x00,
      0xF8, 0x00, 0x00, 0x00, 0x07, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00, 0x03, 0xDF,
      0x80, 0x00, 0x00, 0x71, 0xF0, 0x00, 0x00, 0x0E, 0x1F, 0x00, 0x00, 0x00, 0x43, 0xF0, 0x10, 0x00,
      0x00, 0x07, 0xC0, 0x20, 0x00, 0x00, 0x1F, 0x80, 0x40, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x07,
      0xE0, 0x08, 0x00, 0x00, 0x0F, 0x80, 0x10, 0x00, 0x00, 0x3F, 0x00, 0x20, 0x00, 0x00, 0x7C, 0x00,
      0x00, 0x00, 0x0F, 0xC0, 0x04, 0x80, 0x00, 0x1F, 0x00, 0x0A, 0x00, 0x00, 0x7C, 0x00, 0x10, 0x00,
      0x01, 0xF0, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x20, 0x00, 0x07, 0x80,
      0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x38,
      0x1C, 0x00, 0x00, 0x07, 0xE3, 0x80, 0x00, 0x00, 0x7F, 0xF0, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3A, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x03,
      0xFE, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xF8, 0x00, 0x00,
      0x00, 0x00, 0x1C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x00, 0x02, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0x00, 0x00, 0x04, 0x80, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x81, 0xE0, 0x00,
      0x00, 0x00, 0x01, 0xE0, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x67, 0xE0, 0x00, 0x00, 0x00, 0x0F,
      0x90, 0x7C, 0x00, 0x00, 0x00, 0x01, 0xF4, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x3F, 0x01, 0xF0, 0x00,
      0x00, 0x00, 0x0F, 0xC0, 0x3E, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x3E,
      0x01, 0xE0, 0x00, 0x00, 0x00, 0x07, 0xC0, 0xF8, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x7E, 0x00, 0x00,
      0x00, 0x00, 0x3F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x70, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC7, 0x00, 0x00, 0x00,
      0x00, 0x00, 0xF8, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE1,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x3E, 0x00, 0x00, 0x80, 0x00, 0x03, 0xE0, 0x78, 0x00, 0x02,
      0x00, 0x00, 0x0F, 0x80, 0xF0, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x7C,
      0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0xC0, 0x00, 0x00,
      0x00, 0x01, 0xE0, 0x06, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x40, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x08, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x07, 0xFB, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x66, 0xC6, 0x2A, 0x9A, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x01, 0xFC,
      0x00, 0x00, 0x00, 0x0F, 0xF0, 0x00, 0x00, 0x00, 0x78, 0x40, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00,
      0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x78, 0x08, 0x00, 0x00, 0x00, 0x7C, 0x04, 0x80, 0x00, 0x00,
      0x7C, 0x02, 0x00, 0x00, 0x00, 0x7E, 0x01, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x80, 0x00, 0x00, 0x3F,
      0x00, 0x40, 0x00, 0x00, 0x1F, 0x00, 0x20, 0x00, 0x00, 0x1F, 0x80, 0x10, 0x00, 0x00, 0x0F, 0x80,
      0x00, 0x00, 0x00, 0x7E, 0x00, 0x24, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x50,
      0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x1F, 0x02, 0x00, 0x00, 0x00,
      0x7C, 0x18, 0x00, 0x00, 0x01, 0xF0, 0xE0, 0x00, 0x00, 0x0F, 0x87, 0x00, 0x00, 0x00, 0x3E, 0x38,
      0x00, 0x00, 0x00, 0xF9, 0xC0, 0x00, 0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x0F, 0xF0, 0x00, 0x00,
      0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00,
      0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xA6, 0xC6,
      0x2D, 0xBE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0xF0, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x07, 0xF0,
      0x7E, 0x00, 0x00, 0x00, 0x01, 0xFE, 0x1F, 0xE3, 0xFC, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x7F, 0xCF,
      0xF8, 0x00, 0x00, 0x00, 0x39, 0xF3, 0x9F, 0x39, 0xF0, 0x00, 0x00, 0x00, 0xE3, 0xEC, 0x3E, 0xC3,
      0xE0, 0x00, 0x00, 0x01, 0x87, 0xB0, 0x7F, 0x07, 0x80, 0x00, 0x00, 0x02, 0x1F, 0xC1, 0xFC, 0x1F,
      0x00, 0x00, 0x00, 0x00, 0x3F, 0x03, 0xF0, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x07, 0xC0, 0x7C,
      0x00, 0x00, 0x00, 0x00, 0xF8, 0x0F, 0x80, 0xF0, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x3F, 0x03, 0xE0,
      0x00, 0x00, 0x00, 0x07, 0xC0, 0x7C, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x0F, 0x80, 0xF8, 0x0F, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0x01, 0xF0, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x07, 0xE0, 0x7C, 0x00,
      0x00, 0x00, 0x00, 0xF8, 0x0F, 0x80, 0xF0, 0x00, 0x20, 0x00, 0x00, 0x3E, 0x03, 0xE0, 0x7C, 0x00,
      0x00, 0x00, 0x00, 0x7C, 0x07, 0xC0, 0xF8, 0x40, 0x00, 0x00, 0x01, 0xF0, 0x1F, 0x03, 0xE0, 0xC0,
      0x00, 0x00, 0x03, 0xE0, 0x3E, 0x07, 0xC3, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x7C, 0x0F, 0x8C, 0x00,
      0x00, 0x00, 0x0F, 0x80, 0xF8, 0x1F, 0x30, 0x00, 0x00, 0x00, 0x3E, 0x03, 0xE0, 0x3F, 0xC0, 0x00,
      0x00, 0x00, 0x7C, 0x07, 0xC0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x0F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xE6, 0xC6, 0x2C, 0x5E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x03, 0xC0, 0x00, 0x00,
      0x00, 0x3F, 0x80, 0xFE, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x3F, 0xE0, 0x00, 0x00, 0x01, 0xFF, 0x87,
      0xFE, 0x00, 0x00, 0x00, 0x39, 0xF1, 0xC7, 0xC0, 0x00, 0x00, 0x07, 0x1F, 0x30, 0x7C, 0x00, 0x00,
      0x00, 0xE1, 0xF6, 0x07, 0xC0, 0x00, 0x00, 0x04, 0x1F, 0xC0, 0xFC, 0x00, 0x00, 0x00, 0x03, 0xF8,
      0x0F, 0x80, 0x00, 0x00, 0x00, 0x3F, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x1F, 0x80, 0x00,
      0x00, 0x00, 0x3E, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x7C,
      0x03, 0xF0, 0x01, 0x00, 0x00, 0x00, 0xF8, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x1F, 0x00, 0xFC, 0x00,
      0x24, 0x00, 0x00, 0x3E, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x3F, 0x0C, 0x00, 0x00, 0x00,
      0x7C, 0x03, 0xE1, 0xC0, 0x00, 0x00, 0x07, 0xC0, 0x3E, 0x30, 0x00, 0x00, 0x00, 0x7C, 0x03, 0xF6,
      0x00, 0x00, 0x00, 0x0F, 0x80, 0x3F, 0xC0, 0x00, 0x00, 0x00, 0xF8, 0x03, 0xF0, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x1E, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xE6, 0xC6, 0x2B, 0xDE, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0x3F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0xE1, 0xF8, 0x00, 0x00, 0x00, 0x01, 0xC0, 0xFC, 0x00, 0x00,
      0x00, 0x03, 0x80, 0x7C, 0x00, 0x00, 0x00, 0x07, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x3E,
      0x00, 0x00, 0x00, 0x1E, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x3E, 0x01, 0x00, 0x00, 0x07,
      0x80, 0x07, 0xC0, 0x20, 0x00, 0x01, 0xE0, 0x00, 0xF8, 0x00, 0x00, 0x01, 0xE0, 0x00, 0xF0, 0x04,
      0x00, 0x00, 0x7C, 0x00, 0x1E, 0x00, 0x80, 0x00, 0x0F, 0x80, 0x07, 0x80, 0x00, 0x00, 0x0F, 0x80,
      0x07, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x0F, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x0E, 0x00, 0x00, 0x00,
      0x0F, 0xC0, 0x1C, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x38, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x70, 0x00,
      0x00, 0x00, 0x03, 0xF0, 0xE0, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7E,
      0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x0F, 0xC0,
      0xFF, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x3F, 0xE0, 0x00, 0x00, 0x01, 0xFF, 0x1F, 0xFE, 0x00, 0x00,
      0x00, 0x73, 0xE7, 0x0F, 0xC0, 0x00, 0x00, 0x1C, 0x79, 0xC0, 0xF8, 0x00, 0x00, 0x02, 0x0F, 0x70,
      0x1F, 0x00, 0x00, 0x00, 0x01, 0xFC, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x7C, 0x02, 0x00,
      0x00, 0x01, 0xF8, 0x01, 0xF0, 0x08, 0x00, 0x00, 0x07, 0xC0, 0x07, 0x80, 0x00, 0x00, 0x01, 0xF0,
      0x01, 0xF0, 0x04, 0x00, 0x00, 0x07, 0xC0, 0x07, 0x80, 0x00, 0x00, 0x00, 0xF8, 0x01, 0xF0, 0x00,
      0x00, 0x00, 0x3F, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x07, 0x00, 0x00, 0x00, 0x00, 0xF8,
      0x01, 0xE0, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x38, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x0E, 0x00, 0x00,
      0x00, 0x00, 0xFC, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x1F, 0xC0, 0x70, 0x00, 0x00, 0x00, 0x03, 0xFC,
      0x3C, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xBF, 0x00, 0x00, 0x09,
      0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x04, 0x80, 0x00, 0x7C,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x02, 0x40, 0x00, 0x7C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF,
      0xFC, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xE6, 0xC6, 0x2B, 0xDE, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x01, 0xFF,
      0x80, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0x00, 0x00, 0x00, 0x00,
      0x70, 0x3F, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x1E, 0x00, 0x00,
      0x00, 0x03, 0x80, 0x3E, 0x01, 0x00, 0x00, 0x00, 0xE0, 0x07, 0xC0, 0x00, 0x00, 0x01, 0xC0, 0x07,
      0x80, 0x00, 0x00, 0x03, 0xC0, 0x0F, 0x80, 0x00, 0x00, 0x03, 0x80, 0x0F, 0x80, 0x00, 0x00, 0x07,
      0x80, 0x0F, 0x80, 0x00, 0x00, 0x07, 0x80, 0x0F, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x1F, 0x00, 0x00,
      0x00, 0x0F, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x3F,
      0x00, 0x00, 0x00, 0x1F, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x1F, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x1F,
      0x01, 0xBE, 0x00, 0x00, 0x00, 0x1F, 0x03, 0x3E, 0x00, 0x00, 0x00, 0x1F, 0x8E, 0x3C, 0x00, 0x00,
      0x00, 0x1F, 0xFC, 0x7C, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x7C, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x7C,
      0x00, 0x00, 0x00, 0x07, 0x80, 0x7C, 0x00, 0x28, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x05, 0x00, 0x00,
      0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00,
      0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xC0, 0x00, 0x00, 0x00, 0x03, 0xFF,
      0xF8, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x07, 0x00, 0x18, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x66, 0xC6, 0x2B, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x28,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0,
      0x00, 0x00, 0x03, 0x83, 0xF0, 0x00, 0x00, 0x03, 0xE1, 0xF8, 0x00, 0x00, 0x03, 0xF8, 0xFC, 0x00,
      0x00, 0x03, 0xFE, 0x78, 0x00, 0x00, 0x01, 0xDF, 0xB8, 0x00, 0x00, 0x00, 0xE7, 0xDC, 0x00, 0x00,
      0x00, 0x31, 0xFE, 0x00, 0x00, 0x00, 0x08, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x04, 0x00,
      0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x02, 0x00,
      0x00, 0x01, 0xF0, 0x00, 0x10, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x90, 0x00, 0x00, 0xF8, 0x00, 0x05,
      0x00, 0x00, 0x0F, 0x80, 0x00, 0x20, 0x00, 0x00, 0xF8, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00,
      0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xA6, 0xC6, 0x2B,
      0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00,
      0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x01,
      0xFF, 0x80, 0x00, 0x00, 0x00, 0x71, 0xF8, 0x00, 0x00, 0x00, 0x1E, 0x1F, 0x00, 0x00, 0x00, 0x03,
      0x81, 0xE0, 0x00, 0x00, 0x00, 0xF0, 0x18, 0x04, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x10, 0x00, 0x00,
      0x0F, 0x80, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00,
      0x03, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x00,
      0x00, 0x7E, 0x00, 0x10, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00,
      0x07, 0x01, 0xF0, 0x00, 0x00, 0x01, 0xF0, 0x3E, 0x00, 0x20, 0x00, 0x07, 0xC0, 0xF0, 0x00, 0x00,
      0x00, 0xF8, 0x3C, 0x00, 0x00, 0x00, 0x0F, 0x8F, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xC0, 0x00, 0x00,
      0x00, 0x0F, 0xE0, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xA6, 0xC6, 0x2B, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x78, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18,
      0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x02, 0x80, 0x00, 0x00, 0x1F,
      0x00, 0x08, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0xFF,
      0xFF, 0x80, 0xA0, 0x00, 0x00, 0x1F, 0x00, 0x02, 0x80, 0x00, 0x00, 0xF8, 0x00, 0x0A, 0x00, 0x00,
      0x07, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x02, 0x00, 0x00, 0x00,
      0x07, 0xC0, 0xE0, 0x00, 0x00, 0x00, 0xF0, 0x38, 0x00, 0x00, 0x00, 0x3E, 0x0E, 0x00, 0x00, 0x00,
      0x07, 0xC3, 0x80, 0x00, 0x00, 0x00, 0xF8, 0xE0, 0x00, 0x00, 0x00, 0x1F, 0xF0, 0x00, 0x00, 0x00,
      0x03, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x1E, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0C, 0xE6, 0xC6, 0x2C, 0x5E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x0F,
      0xF0, 0x07, 0xE0, 0x00, 0x00, 0x01, 0x9F, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x31, 0xF0, 0x07, 0xC0,
      0x00, 0x00, 0x06, 0x1F, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x81, 0xE0, 0x0F, 0x80, 0x10, 0x00, 0x00,
      0x07, 0xC0, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x07, 0x80, 0x3E,
      0x00, 0x00, 0x00, 0x00, 0xF8, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x3C, 0x00, 0x00, 0x00,
      0x00, 0xF8, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x0F,
      0xC0, 0x00, 0x00, 0x00, 0x1F, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x1F, 0x80, 0x00, 0x00,
      0x00, 0x1E, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x0D,
      0xF0, 0x60, 0x00, 0x00, 0x03, 0xE3, 0x9F, 0x0C, 0x00, 0x00, 0x00, 0x3F, 0xF1, 0xF1, 0x80, 0x00,
      0x00, 0x03, 0xFC, 0x1F, 0x30, 0x00, 0x00, 0x00, 0x3F, 0x81, 0xFE, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x68, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6,
      0xC6, 0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x01, 0xC0, 0x00, 0x00, 0x03, 0xFF, 0xE0, 0x7C,
      0x00, 0x00, 0x01, 0xF0, 0x70, 0x0F, 0x80, 0x00, 0x00, 0x70, 0x1E, 0x00, 0xF0, 0x00, 0x00, 0x1C,
      0x07, 0x80, 0x1E, 0x00, 0x00, 0x03, 0x80, 0xF0, 0x01, 0xC0, 0x00, 0x00, 0x78, 0x3E, 0x00, 0x38,
      0x00, 0x00, 0x0F, 0x0F, 0x80, 0x07, 0x00, 0x00, 0x00, 0xE1, 0xF0, 0x00, 0xC0, 0x00, 0x00, 0x00,
      0x3E, 0x00, 0x38, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x07, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0xC0,
      0x00, 0x00, 0x00, 0x3E, 0x00, 0x38, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x0E, 0x00, 0x00, 0x00, 0x00,
      0xF8, 0x01, 0x80, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x70, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x1C, 0x00,
      0x00, 0x00, 0x00, 0x7C, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x81, 0xC0, 0x00, 0x00, 0x00, 0x00,
      0xF0, 0x70, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x03, 0xE7, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x7D, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x01,
      0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x10, 0xA6, 0xC6, 0x2E, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C,
      0x03, 0x80, 0x1C, 0x00, 0x00, 0x00, 0x03, 0xFF, 0x80, 0xF8, 0x07, 0xC0, 0x00, 0x00, 0x03, 0xFF,
      0xF0, 0x3F, 0x00, 0xF8, 0x00, 0x00, 0x01, 0xF8, 0x38, 0x07, 0xE0, 0x0F, 0x00, 0x00, 0x00, 0x70,
      0x1E, 0x01, 0xFC, 0x01, 0xE0, 0x00, 0x00, 0x1C, 0x07, 0xC0, 0x3F, 0x80, 0x1C, 0x00, 0x00, 0x03,
      0x80, 0xF0, 0x07, 0xE0, 0x03, 0x80, 0x00, 0x00, 0x78, 0x3E, 0x01, 0xFC, 0x00, 0x70, 0x00, 0x00,
      0x0F, 0x0F, 0x80, 0x3F, 0x00, 0x0C, 0x00, 0x00, 0x00, 0xE1, 0xF0, 0x07, 0xE0, 0x03, 0x80, 0x00,
      0x00, 0x00, 0x3E, 0x00, 0xF8, 0x00, 0x70, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x1F, 0x00, 0x0C, 0x00,
      0x00, 0x00, 0x01, 0xF0, 0x03, 0xE0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x7C, 0x00, 0x60,
      0x00, 0x00, 0x00, 0x07, 0xC0, 0x0F, 0x80, 0x18, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x03, 0xF0, 0x07,
      0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x7E, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x1F, 0xC0,
      0x70, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x06, 0xF8, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC1, 0x8F,
      0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0xE1, 0xF1, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x38,
      0x3E, 0x70, 0x00, 0x00, 0x00, 0x00, 0x03, 0xEE, 0x07, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F,
      0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xE0, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x20, 0x00, 0x00, 0x0F, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x66, 0xC6, 0x2C, 0x1E, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x07, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x03, 0xE0, 0x3F, 0xE0,
      0x00, 0x00, 0x03, 0xFC, 0x1F, 0xF0, 0x00, 0x00, 0x01, 0x9F, 0x07, 0x00, 0x00, 0x00, 0x00, 0xC3,
      0xC3, 0x80, 0x00, 0x00, 0x00, 0x60, 0xF1, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x3E, 0xE0, 0x00, 0x00,
      0x00, 0x00, 0x07, 0xB0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x04, 0x80, 0x00, 0x00, 0x0F,
      0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x08, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x40,
      0x00, 0x00, 0x01, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0xCF, 0x00, 0x00, 0x80, 0x00, 0x00, 0x0C,
      0x78, 0x00, 0x00, 0x00, 0x00, 0x06, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x03, 0x03, 0xC0, 0x00, 0x00,
      0x00, 0x01, 0x80, 0xF0, 0x00, 0x00, 0x00, 0x30, 0xC0, 0x3C, 0x00, 0x00, 0x00, 0x1E, 0x60, 0x0F,
      0x80, 0x00, 0x00, 0x07, 0xF0, 0x01, 0xE0, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x78, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x1E, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x78, 0x0F, 0x00, 0x00,
      0x00, 0x00, 0x0F, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xE1, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x3F,
      0xF0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x0B, 0xE6, 0xC6, 0x2B, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x0E, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x1F, 0x00, 0x00, 0x00,
      0x1F, 0xC0, 0x1F, 0x00, 0x00, 0x00, 0x7F, 0xE0, 0x1F, 0x00, 0x00, 0x00, 0xE3, 0xE0, 0x1F, 0x00,
      0x00, 0x01, 0xC1, 0xF0, 0x0F, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x0F, 0x00, 0x00, 0x00, 0x00, 0xF0,
      0x0F, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x0E, 0x01, 0x00, 0x00, 0x00, 0x0F, 0x01, 0xC0, 0x00, 0x00,
      0x00, 0x0F, 0x81, 0xC0, 0x00, 0x00, 0x00, 0x0F, 0x83, 0x80, 0x20, 0x00, 0x00, 0x00, 0xF0, 0x70,
      0x04, 0x80, 0x00, 0x00, 0x1F, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x38, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0x38, 0x00, 0x80, 0x00, 0x00, 0x01, 0xEE, 0x00, 0x10, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x02,
      0x00, 0x00, 0x00, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x07,
      0x80, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x40, 0x00,
      0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x01, 0xF0, 0xFC,
      0x00, 0x00, 0x00, 0x03, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x03,
      0xFF, 0xC0, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xA6, 0xC6,
      0x2C, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0C, 0x00, 0x00, 0x00, 0x01, 0xFE, 0x07, 0x80, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xE0, 0x00,
      0x00, 0x00, 0x1F, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0xC0,
      0xF9, 0x80, 0x00, 0x00, 0x00, 0x18, 0x00, 0x60, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x38, 0x00, 0x00,
      0x00, 0x00, 0x3C, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x03, 0x83, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x01, 0xC0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x60, 0x00, 0x78, 0x00, 0x00, 0x00, 0x18, 0x00,
      0x0F, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x01, 0xFF, 0x00, 0x1C, 0x00, 0x00,
      0x00, 0x7F, 0xFC, 0x03, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xE0, 0xC0, 0x00, 0x00, 0x07, 0x3F, 0xFF,
      0xF8, 0x00, 0x00, 0x01, 0x80, 0x7F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x01, 0xE0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x09, 0x66, 0xC6, 0x2A, 0x9C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x01, 0xC0, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x0F, 0x00,
      0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x0F, 0x02, 0x40, 0x00,
      0x00, 0x07, 0x01, 0x40, 0x00, 0x00, 0x07, 0x00, 0xA0, 0x00, 0x00, 0x07, 0x00, 0x50, 0x00, 0x00,
      0x07, 0x00, 0x24, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x01, 0xE0,
      0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x12, 0x00, 0x00, 0x1E, 0x00, 0x0A,
      0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x12, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00,
      0x01, 0xE0, 0x00, 0x28, 0x00, 0x00, 0xE0, 0x00, 0x18, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x01,
      0xC0, 0x00, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x03, 0xC0, 0x00, 0x00, 0x00,
      0x01, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xE6, 0xC6, 0x2C, 0xDE,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00,
      0x00, 0x00, 0x07, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x01, 0xE0, 0x00, 0x00,
      0x00, 0x1C, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00,
      0x70, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x01, 0xC0,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x09, 0x66, 0xC6, 0x2A, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x0D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x0E, 0x01, 0x80, 0x00, 0x00,
      0x03, 0x80, 0xA0, 0x00, 0x00, 0x03, 0x80, 0x48, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x1E,
      0x00, 0x90, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x78, 0x01, 0x40, 0x00, 0x00, 0x38, 0x00,
      0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00,
      0x00, 0x70, 0x00, 0x00, 0x00, 0x01, 0x80, 0x02, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x0F,
      0x00, 0x05, 0x00, 0x00, 0x07, 0x00, 0x02, 0x80, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00,
      0x04, 0x80, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x08, 0x00, 0x00, 0x70, 0x00, 0x00,
      0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x03,
      0xC0, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xE6, 0xC6, 0x2C, 0xDE, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00,
      0x00, 0x00, 0x7E, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xC0, 0x0F, 0x00, 0x00, 0x00, 0x01,
      0xFF, 0xFC, 0x3E, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x07, 0xC1, 0xFF,
      0xF8, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x3F, 0xF0, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x07, 0xE0, 0x00,
      0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xA0, 0x00, 0x00,
    /* Size: 22732 bytes */
    static const unsigned char TestFont_index[] = {
      0x00, 0x00, 0x00, 0x90, 0x05, 0x10, 0x10, 0x00, 0x41, 0xC0, 0xC8, 0xC2, 0x4D, 0x06, 0x6A, 0x0D,
      0x70, 0x1E, 0x28, 0x42, 0xD0, 0x8F, 0xF1, 0x2C, 0x62, 0x72, 0x85, 0x09, 0x8A, 0x5A, 0x17, 0x02,
      0x31, 0x8C, 0x69, 0xF8, 0xE5, 0xF1, 0xEA, 0x64, 0x11, 0xC8, 0x9A, 0x92, 0x1C, 0x26, 0x2C, 0x50,
      0x5C, 0xA7, 0xF1, 0x56, 0x32, 0xBC, 0xE5, 0xB8, 0xCB, 0xA0, 0x18, 0x3C, 0x32, 0x0E, 0x69, 0xF0,
      0xE0, 0xA1, 0xD6, 0x33, 0xCC, 0xE7, 0xF2, 0xD0, 0x83, 0x22, 0x0E, 0x47, 0x02, 0x93, 0xC5, 0x2C,
      0x9A, 0x68, 0x15, 0x02, 0xEA, 0x49, 0xD5, 0x79, 0x2C, 0x80, 0x5B, 0x46, 0xBB, 0x3D, 0x83, 0x1B,
      0x1E, 0x76, 0x5F, 0x4C, 0xFB, 0x5A, 0xC2, 0x37, 0x03, 0x71, 0xFC, 0xE9, 0xD5, 0xDC, 0xE3, 0xD0,
      0xD7, 0xB2, 0x8F, 0x87, 0x5F, 0x4F, 0x3F, 0x2B, 0x7E, 0xFE, 0xFF, 0x52, 0x05, 0x54, 0x1A, 0x78,
      0x47, 0xF0, 0xD3, 0x62, 0x07, 0xC4, 0xFF, 0x8C, 0x2B, 0x1C, 0xA6, 0x3E, 0x2C, 0x87, 0xA9, 0x39,
      0x12, 0x9F, 0x65, 0xC4, 0x4C, 0x59, 0x9A, 0x2D, 0x38, 0x5E, 0x78, 0xD4, 0xFA, 0xCA, 0x0A, 0xD4,
      0x3C, 0x28, 0xE7, 0x52, 0xB4, 0xA7, 0xB1, 0x53, 0x52, 0xAE, 0x6D, 0x6B, 0x3A, 0xE9, 0x75, 0xE8,
      0x2C, 0x23, 0x00
    /* Size: 179 bytes */
    const ILI9341_t3_font_t TestFont = {
        TestFont_index,
        0,
        TestFont_data,
        1,
        0,
        32,
        126,
        0,
        0,
        15,
        7,
        7,
        5,
        7,
        6,
        0,
        10
    I'll try to take a look at the sources of ILI9341_t3, maybe I'll find cause of the problem, but I wrote this editor almost for whole day and I'm a little bit tired
    Best regards -- Spook.
    Senior Member Projectitis's Avatar
    Feb 2018
    New Zealand
    141
    Hi guys,
    I'm working on memory-buffer based rendering for T3.5/3.6. I already have methods for anti-aliased lines and triangles, and alpha-supported bitmap blitting from in a range of colour formats. I'm now moving on to fonts.
    I've found mention of an extension to BDF (v2.3) that supports a "greymap". As far as I can tell the differences are that there are an extra header value to specify bpp, and then each pixel is represented by more than just a single bit. between 1, 2, 4 and 8 bpp are supported for up to 256 alpha levels. Even 4 levels (2 bits would improve visual font quality).
    My problem is that I can't find any sort of tool that generates BDF 2.3 on Windows 10 from ttf or another font format.
    Note: On windows the Font Forge option to generate bitmap fonts (including BDF) is grayed out/disabled for some reason.
    EDIT:
    Ok: Figured it out with Font Forge
    1) Element > Bitmap strikes available...
    2) Generate bitmaps of each glyph in various sizes
    3) Generate. BDF is now available.
    Feb 2018
    New Zealand
    141
    If anyone wants to generate BDF using FontForge in the future:
    Reduce font character set:
    1) Load the font TTF (or other)
    2) Select the characters you want to keep
    3) Edit > Select > Invert selection
    4) Encoding > Detach and remove Glyphs
    5) Encoding > Compact
    Generate the bitmap sets that you want:
    2) Enter the size of the font and the bpp like this: 10@2 (this is 10pt @2bpp) or 12@4 (this is 12pt @4bpp) etc. Example: I have been using 10@2,11@2,12@2,14@2,16@2 in the "Pixel Sizes" field
    3) Click [OK] to generate the bitmap strikes of each glyph in various sizes
    4) Use "View > ## pixel bitmap" options to view the bitmap strikes that were generated
    5) You can click on each one and edit them individually if they aren't perfect
    5) File > Generate Fonts. Select "No outline font" and "BDF", then hit [Generate]. A BDF file for each size will be generated.
    Feb 2018
    New Zealand
    141
    This looks like it's going to be pretty straight forward. I'm about 90% through converting Paul's bdf_to_c to python, and making the changes to support anti-aliased fonts. The data structure is the same as ILI9341_t3_font_t, but uses 'reserved' for bits_per_pixel. This is identified by the version number 23 (for 2.3). Normally ILI9341_t3_font_t have version=1.
    @spook - it looks like you might have to add anti-alias support to your tool soon
    Feb 2018
    New Zealand
    141
    I realise I'm just talking to myself, but I'll do it anyway
    Finished getting anti-aliased BDF fonts to encode into ILI9341_t3_font_t now. Now just testing and debugging. As above, anti-alias BDF fonts are packed into the exact same structure as the 1bpp versions used now. The version indicates that anti-aliasing is used (version=1 is original 1bpp, version=23 is nbpp), and the lower 2 bits of the reserved byte indicate the bpp (0=1pp, 1=2bpp, 2=4bpp and 3=8bpp).
    In my libraries I've typedef'd ILI9341_t3_font_t as packedbdf_t, as I thought it strange to name the type after a specific display and a specific version of teensy, when it can be used by any "Packed BDF" is pretty much what this is!
    19,922
    Just curious, have you worked on the Teensy-side code for these fonts?
    When you have a pixel that isn't 100% opaque, do you read from the ILI9341's memory and try to alpha blend? Or just assume the background is a fixed color, so everything is write-only to the frame buffer?
    Feb 2018
    New Zealand
    141
    Hi Paul - at this stage all the drawing functions in my library work on an in-memory framebuffer (so at the moment it's T3.5 and T3.6 only). That makes blending miles easier, and means the library can theoretically support any display (just need to write an adapter with a few key methods). I also have plans to support a quarter-size framebuffer (half the width and half the height) and have an idea of how to upscale this automatically to a display using DMA. This results in a 38k framebuffer that could theoretically work with T3.2 also (normally the framebuffer for a 320x240 @16bpp display is ~154k)
    Feb 2018
    New Zealand
    141
    Quote Originally Posted by spook View Post
    So 1 doesn't repeat last row, but the one, which follows. There are no indications, that repetitions 6 or 7 were used for different purposes, code simply reads count of repetitions and adds 2, so that 0 equals 2 repetitions, ..., 7 equals 9 repetitions.
    @Spook - just a note in case you or anyone else ever comes back to this: Even though the rendering code doesn't care if the repetitions are greater than 8 (6+2), the code that Paul has written to convert BDF to ILI9341_t3_font_t does limit the number of repetitions to a maximum of 8. So if your font editor is exporting to ILI9341_t3_font_t it would be best to also limit the number of repetitions to this also See bdf_to_ili9341.c at line 201.
    Feb 2018
    New Zealand
    141
    This is the part where you fetch address of the character in data. You pick (font->bits_index) bits starting from (bitoffset) bit from (font->index) and then increment font->data by this value. But since font->data is unsigned char *, pointer arithmetics would suggest, that addresses of characters are in bytes, not bits (and therefore characters must be byte-aligned). Fetching encoding from the data starting from bit 0 would also suggest that.
    No need, this is confirmed. So characters must be aligned to byte boundaries and character offsets (indices) must be expressed in bytes, not bits
    @Spook - you've already confirmed this, but yes each value in the index is actually a byte offset, not a bit offset. I can confirm that Paul's code pads each glyph to a byte boundary, and the the index is created using a byte offset.
    Feb 2018
    New Zealand
    141
    Packed BDF (ILI9341_t3_font_t) format specification, instructions and scripts for creating anti-aliased (and 1bpp) fonts here:
    https://github.com/projectitis/packedbdf
