quad problems with 2 audio shields and teensy 3.2
ShawnDecker
New member
I am running into audio problems doing the 2 audio shield w. teensy 3.2 setup.
I am using the standard test code example, included at the end of this post.
I have removed the pin 15 capacitors on each shield
I have done all the mods to the second shield described in the sparkfun tutorial (linked from the quad page):
I get the message playing file 1 & playing file 2.
The 1/2 channel card works fine. Nothing at all on the 3/4 channel card. There appears to be no data on pin 15. If I temporarily short the pin 22 pad to the pin 15 pad, I get channels 1/2 playing on the 3/4 shield, as you would expect. I built two different boards - each with the same problem. I also tried a modified board I had successfully used in the past - this also didn't work.
I also tried setting pin 15 to output mode (not in the example).
I've tried running at 96 Mhz and also 72 Mhz.
Has something changed re. the support for the Teensy 3.2?
Here is my code. Thanks to anyone who has some ideas!
Shawn
AudioPlaySdWav           playSdWav1;
AudioPlaySdWav           playSdWav2;
AudioOutputI2SQuad       audioOutput;
AudioConnection          patchCord1(playSdWav1, 0, audioOutput, 0);
AudioConnection          patchCord2(playSdWav1, 1, audioOutput, 1);
AudioConnection          patchCord3(playSdWav2, 0, audioOutput, 2);
AudioConnection          patchCord4(playSdWav2, 1, audioOutput, 3);
AudioControlSGTL5000     sgtl5000_1;
AudioControlSGTL5000     sgtl5000_2;
#define SDCARD_CS_PIN    10
#define SDCARD_MOSI_PIN  7
#define SDCARD_SCK_PIN   14
  AudioMemory(20);
  pinMode(15, OUTPUT);
  sgtl5000_1.setAddress(LOW);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.85);
  sgtl5000_2.setAddress(HIGH);
  sgtl5000_2.enable();
  sgtl5000_2.volume(0.85);
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
    // stop here, but print a message repetitively
    while (1) {
  AudioMemory(20);
    while (1) {
oops - looks like a bad paste on the code. Here it is again:
// Quad channel output test
// Play two WAV files on two audio shields.
// TODO: add info about required hardware connections here....
// Data files to put on your SD card can be downloaded here:
//   [URL]http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html[/URL]
// This example code is in the public domain.
#include <SerialFlash.h>
// Use these with the Teensy 3.5 & 3.6 SD card
//#define SDCARD_CS_PIN    BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN  11  // not actually used
//#define SDCARD_SCK_PIN   13  // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN    4
  AudioMemory(20);
    while (1) {
Hello ShawnDecker,
We seem to have the exact same issue, did you find any solutions?
We have tried several codes: one that is similar to yours and an other generating four sine waves with different frequencies that were dispatched between the four outputs (thus one sine wave per output, the code is below).
What we do not understand is that the code works half the time which leads to think that it is an hardware issue rather than a software.
We should also specify that we did the mods necessary to stack the two audio shields and that we do not have any shorts on the solders that we made ^^
Thank you in advance for your time and hopefully for your solution ;)
Here is the code reading files from the SD card:
AudioPlaySdWav           playSdWav1;     //xy=116,79
AudioPlaySdWav           playSdWav2;//xy=118,155
AudioMixer4              mixer1;         //xy=345,69
AudioMixer4              mixer2; //xy=347,134
AudioMixer4              mixer3; //xy=347,200
AudioMixer4              mixer4; //xy=348,265
AudioOutputI2SQuad       i2s_quad1;      //xy=542,162
AudioConnection          patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection          patchCord2(playSdWav1, 1, mixer2, 0);
AudioConnection          patchCord3(playSdWav2, 0, mixer3, 0);
AudioConnection          patchCord4(playSdWav2, 1, mixer4, 0);
AudioConnection          patchCord5(mixer1, 0, i2s_quad1, 0);
AudioConnection          patchCord6(mixer2, 0, i2s_quad1, 1);
AudioConnection          patchCord7(mixer3, 0, i2s_quad1, 2);
AudioConnection          patchCord8(mixer4, 0, i2s_quad1, 3);
AudioControlSGTL5000     sgtl5000_1;     //xy=601,433
AudioControlSGTL5000     sgtl5000_2;     //xy=605,387
  AudioMemory(120);
  sgtl5000_1.volume(0.5);
  sgtl5000_1.setAddress(HIGH);
  sgtl5000_2.volume(0.5);
  sgtl5000_2.setAddress(LOW);
mixer1.gain(0,0.5);
mixer2.gain(0,0.5);
mixer3.gain(0,0.5);
mixer4.gain(0,0.5);
    while (1) {
  if (playSdWav1.isPlaying() == false) {
    Serial.println("Start playing1");
    playSdWav1.play("SDTEST2.WAV");
    delay(10); // wait for library to parse WAV info
 if (playSdWav2.isPlaying() == false) {
    Serial.println("Start playing2");
    playSdWav2.play("SDTEST1.WAV");
Here is the code generating sine waves on each channel:
AudioSynthWaveformSine   sine1;          //xy=192,76
AudioSynthWaveformSine   sine2;
AudioSynthWaveformSine   sine3;          //xy=192,76
AudioSynthWaveformSine   sine4;//xy=196,112
AudioOutputI2SQuad       i2s_quad1;      //xy=438,93
AudioConnection          patchCord1(sine1, 0, i2s_quad1, 0);
AudioConnection          patchCord2(sine2, 0, i2s_quad1, 1);
AudioConnection          patchCord3(sine3, 0, i2s_quad1, 2);
AudioConnection          patchCord4(sine4, 0, i2s_quad1, 3);
AudioControlSGTL5000     sgtl5000_2;     //xy=361,211
AudioControlSGTL5000     sgtl5000_1;     //xy=363,172
    AudioMemory(12);
  sine1.frequency(200);
  sine2.frequency(600);
   sine3.frequency(400);
  sine4.frequency(500);
