Results 1 to 5 of 5
Thread: Control input voltage to Teensy
    Nov 2018
    5
    I have a circuit composed of a series of Op Amps acting as buffers and integratirs to amplify a small input signal. The final output is meant to be sent to a Teensy 3.2, but it is always between -0.5V and 0.5V. This would damage my Teensy since the input range for this model is between 0V to 3.3V.
    Does this mean I need to create a positive offset? how can I possibily create one?
    Feb 2014
    Colmar, France
    2,056
    The "state of the art" solution would use an op amp as an adder circuit.
    Nov 2018
    5
    Thanks! I will give it a try
    18,654
    The safest way involves using an opamp powered by only 3.3V. That means needed a rail-to-rail output type if you want to use the full range. But then you at least know the opamp won't accidentally drive the pin hard to a large positive or negative voltage during startup, shutdown, or if something happens like a very fast transition on the input voltage - conditions where the opamp is momentarily not controlled by stable feedback and can briefly output almost anything.
    Nov 2018
    5
    Thanks, it brings up
