Results 1 to 3 of 3
Thread: Teensy 3.5 Hardware Serial
    Nov 2018
    Brisbane
    2
    Hi All,
    I have been struggling for a number of hours trying to get my Teensy 3.5 communicating to an Arduino over hardware serial.
    To ensure it was not (well less likely) a software error I stripped my programs down to a simple serial print (Arduino) and serial receive (Teensy) as seen below. (I tried using the example Teensy code too.)
    I have quadruple checked my wiring between the two and continuity checked between the RX, TX and TX, RX pins of the Arduino, Teensy respectably. I have also had other devices communicating with the Arduino over the serial port in question.
    I have tried writing from the Teensy to the Arduino and even tried another Teensy both to no avail.
    The Teensy is running at 96MHZ if that matters.
    Any help is much appreciated!
    //this is the Teensy 3.5 code
      Serial1.begin(9600);
      Serial.println("Setup Finished");
      if(Serial1.available()> 0){
        Serial.write(Serial1.read());
    //this is the Arduino mega code
      Serial1.print("data");
      Serial.println("Data Sent to Teensy");
    18,691
    Looks like it ought to work.
    Can you show us a photo of how the wires are actually connected. I know you've already checked, but maybe we'll notice something if you show a photo?
    Nov 2018
    Brisbane
    2
    Cheers for getting back so quickly!
    I just realised I've had the reference card out by 180deg...
    Everything's working now.
