Need Help with 4051 Mux and Audio Library
Hi there I'm having trouble integrating a CD4051 mux with 6 pot inputs into my teensy 3.2 with audio library.
In the gui I have six sine oscillators multiplied by 6 sine LFOs acting as amplitude modulators.
The pots should control the frequency of each of the LFOs
All that is happening is that the 6th pot is controlling all the frequencies and the pin outputs on the Teensy stay stuck on the that particular high/low config.
So I'm not sure how to fix that, Im having trouble understanding how to use the mux with the library.
#include <SerialFlash.h>
AudioSynthWaveformSine   sine11;         //xy=78,576
AudioSynthWaveformSine   sine10;         //xy=81,477
AudioSynthWaveformSine   sine6;          //xy=82,619
AudioSynthWaveformSine   sine5;          //xy=89,531
AudioSynthWaveformSine   sine12;         //xy=93,674
AudioSynthWaveformSine   sine4;          //xy=101,425
AudioSynthWaveformSine   sine8;          //xy=107,236
AudioSynthWaveformSine   sine1;          //xy=110,20
AudioSynthWaveformSine   sine3;          //xy=109,308
AudioSynthWaveformSine   sine2;          //xy=115,166
AudioSynthWaveformSine   sine9;          //xy=128,356
AudioSynthWaveformSine   sine7;          //xy=130,76
AudioEffectMultiply      multiply6;      //xy=248,625
AudioEffectMultiply      multiply2;      //xy=266,182
AudioEffectMultiply      multiply5;      //xy=266,526
AudioEffectMultiply      multiply4;      //xy=273,428
AudioEffectMultiply      multiply1;      //xy=291,47
AudioEffectMultiply      multiply3;      //xy=292,290
AudioMixer4              mixer1;         //xy=477,74
AudioMixer4              mixer2;         //xy=497,412
AudioSynthWaveform       waveform13;     //xy=508,734
AudioMixer4              mixer3;         //xy=673,266
AudioOutputI2S           i2s1;           //xy=892,291
AudioConnection          patchCord1(sine11, 0, multiply5, 1);
AudioConnection          patchCord2(sine10, 0, multiply4, 1);
AudioConnection          patchCord3(sine6, 0, multiply6, 0);
AudioConnection          patchCord4(sine5, 0, multiply5, 0);
AudioConnection          patchCord5(sine12, 0, multiply6, 1);
AudioConnection          patchCord6(sine4, 0, multiply4, 0);
AudioConnection          patchCord7(sine8, 0, multiply2, 1);
AudioConnection          patchCord8(sine1, 0, multiply1, 0);
AudioConnection          patchCord9(sine3, 0, multiply3, 0);
AudioConnection          patchCord10(sine2, 0, multiply2, 0);
AudioConnection          patchCord11(sine9, 0, multiply3, 1);
AudioConnection          patchCord12(sine7, 0, multiply1, 1);
AudioConnection          patchCord13(multiply6, 0, mixer2, 2);
AudioConnection          patchCord14(multiply2, 0, mixer1, 1);
AudioConnection          patchCord15(multiply5, 0, mixer2, 1);
AudioConnection          patchCord16(multiply4, 0, mixer2, 0);
AudioConnection          patchCord17(multiply1, 0, mixer1, 0);
AudioConnection          patchCord18(multiply3, 0, mixer1, 2);
AudioConnection          patchCord19(mixer1, 0, mixer3, 0);
AudioConnection          patchCord20(mixer2, 0, mixer3, 1);
AudioConnection          patchCord21(mixer3, 0, i2s1, 0);
AudioControlSGTL5000     sgtl5000_1;     //xy=856,37
float ampPot0Smooth = 0.0;
float ampPot0Diff = 0.0;
int muxA = 3;
int muxB = 4;
int muxC = 5;
  AudioMemory(20);
  sgtl5000_1.enable();
  pinMode(muxA, OUTPUT);
  pinMode(muxB, OUTPUT);
  pinMode(muxC, OUTPUT);
  sine1.frequency(160);
  sine2.frequency(180);
  sine3.frequency(192);
  sine4.frequency(240);
  sine5.frequency(256);
  sine6.frequency(320);
  sine1.amplitude(0.4);
  sine2.amplitude(0.4);
  sine3.amplitude(0.3);
  sine4.amplitude(0.2);
  sine5.amplitude(0.2);
  sine6.amplitude(0.2);
  sine7.frequency(0.1);
  sine8.frequency(0.1);
  sine9.frequency(0.1);
  sine10.frequency(0.1);
  sine11.frequency(0.1);
  sine12.frequency(0.1);
  sine7.amplitude(0.9);
  sine8.amplitude(0.9);
  sine9.amplitude(0.9);
  sine10.amplitude(0.9);
  sine11.amplitude(0.9);
  sine12.amplitude(0.9);
  mixer1.gain(0, 1.0);
  mixer1.gain(1, 1.0);
  mixer1.gain(2, 1.0);
  mixer1.gain(3, 0.0);
  mixer2.gain(0, 1.0);
  mixer2.gain(1, 1.0);
  mixer2.gain(2, 1.0);
  mixer2.gain(3, 0.0);
  mixer3.gain(0, 1.0);
  mixer3.gain(1, 1.0);
  mixer3.gain(2, 0.0);
  mixer3.gain(3, 0.0);
  float ampPot0 = (float)analogRead(A19) / 1023.0;
  ampPot0Diff = ampPot0 - ampPot0Smooth;
  ampPot0Smooth = ampPot0Smooth + (ampPot0Diff * 0.01f);
      digitalWrite(muxA, LOW); // Channel 0
    digitalWrite(muxB, LOW);
    digitalWrite(muxC, LOW);
    delayMicroseconds(50);
    sine7.frequency(ampPot0Smooth * 10);
    digitalWrite(muxA, HIGH); // Channel 1
    sine8.frequency(ampPot0Smooth * 10);
    digitalWrite(muxA, LOW); // Channel 2
    digitalWrite(muxB, HIGH);
    sine9.frequency(ampPot0Smooth * 10);
    digitalWrite(muxA, HIGH); // Channel 3
    sine10.frequency(ampPot0Smooth * 10);
    digitalWrite(muxA, LOW); // Channel 4
    digitalWrite(muxC, HIGH);
    sine11.frequency(ampPot0Smooth * 10);
    digitalWrite(muxA, HIGH); // Channel 5
    sine12.frequency(ampPot0Smooth * 10);
  AudioNoInterrupts();
  AudioInterrupts();
Looks like you're only reading the value from the 4051 once per loop. I think you need to do analogRead(19) (and the smoothing code) each time you change the channel of the 4051 (six times per loop in total).
