Results 1 to 4 of 4
Thread: Arduino Mega 2560 to Teensy++2.0 - Transition advice
    Nov 2018
    7
    Using a Mega, I wrote simple Arduino sketch...just a sequential list of 18 relay and 9 LED activations...and tested it on the prototype circuit. Works fine.
    I needed to hardwire and wanted to keep the pinned Mega for development, so got a Teensy 2. Looks perfect. But after reading the Startup stuff, thought I'd share the pin plan and output info just to get a nod from others (I'm a novice at all this, and this is first Arduino project and first Teensy).
    All pins will be simple output, HIGH/LOW. No more than 4 pins active at one time, and longest pin "on" time will be 4 seconds.
    Does the proposed pin plan attached look OK?
Name:	TEENSY PIN PLAN for GUNS.jpg
    1,018
    If you don't need analog inputs, you could use, for example, pins 38-45 and pin 17 for digital outputs instead of pins 28-36. This would save you having to connect any of the interior pins.
    Pete
    Nov 2018
    7
    Pete
    Yes, thanks. I was trying to keep those pins open, but this will end up being a dedicated application, so you're right....just use the most convenient pins.
    Nov 2018
    7
    Sealing up a Teensy
    New sketch tested on pinless Teensy2 with voltmeter to follow pin activations. All good. Amazing, considering I barely know what I'm doing.
    All low voltage - 12VDC - hobby R/C stuff.
    Now need to wire and seal against moist environment with light splash possible.
    Advice /feedback on approach appreciated.
    The following is based on forum info, except the Plasti-Dip...must have missed that.
    Plan for Teensy: see attached drawing.
    Plan for relay modules (https://www.amazon.com/dp/B01HCFJC0Y...iss_dp_t_asn):
    Stabilize wires with bead of hot glue.
    Overspray complete module and wires at entry with clear Plasti-Dip Spray
    ( https://www.amazon.com/Performix-112...p%2Bcolor&th=1)
    Thank you.
Name:	SEALING TEENSY 2.jpg
