Results 1 to 5 of 5
Thread: USB connecter dettached from my Teensy 3.2
    Nov 2018
    2
    Hi. I'm a new forum member. I searched the forum and searched the FAQ for a similar issue but did not find one. Sorry if I missed it.
    The USB connector on my Teensy 3.2 just "fell off". I was applying pressure to connect a USB cable to the board when the USB connector detached from the board. The connector was not pried up - it simply detached from the board in the direction of connector insertion.
    Any recourse? I'm not sure if its possible to re-solder this part to the board - the pins appear to be in satisfactory condition, but with the big pads under the connector, I see no way to re-flow the solder.
    Thanks,
    - Homarne
    Senior Member crees's Avatar
    Dec 2016
    Utah
    126
    it happens. I have taught robotics classes using the 32u4 chip (from Bangood) and have had a handful of usb connectors pop off. however all of my teensies have been very well built and have had no issues
    If you feel it was do to a defect I would contact the seller and see if they can swap it out.
    7,603
    There are posts on getting USB back online. Typically using the bottom pads - there is an OSH board IIRC that solders to them and mounts with a fresh connector.
    Should come up in a search with Bing/Google - seems it may be linked in the Wiki-Coming-Please-link-worthy-posts thread
    indeed thread search for connector hit :: https://forum.pjrc.com/threads/28866...ll=1#post75302
    That links to this :: https://forum.pjrc.com/threads/19336...ll=1#post24468
    Doesn't have the OSHPark board there
    2,467
    Thanks for posting this. It actually just happened to me but haven't got around to do a search yet on repairing.
    Nov 2018
    2
    @defragster - thanks much - that should do the trick!
