Teensy3.6: Is Pin 15/CS0/Touch an Irregular Analog Pin?
Hello -- first post here, and a fairly new teensy user.
I've built a MIDI controller using a Teensy 3.6 and the usbMIDI library where I'm using pins 14-19 as analog inputs using photoresistors. All of them work fine, except for pin 15 which I've noted also serves as a CS0/Touch pin. I've swapped out the photoresistor with known working ones, tried the existing circuit with alternate Teensies, quadruple checked my code, and can't seem to find the issue. I'm curious if this pin is special for any reason and I need to declare it differently as an analog input.
My implementation for this pin is exactly the same as the other 5. My code is long but relevant references are to 'newPhotoPinReading1', and 'photoPin1'.
Thank you for any insight!
/*In order to use the usbMIDI library, the teensy must be designated as a MIDI device (or combination) under
the Tools menu, USB Type.
#include <Bounce.h>
//Constant Variables
//The channel to send MIDI messages on
const int channel = 1;
//LED Pins
const int ledPin0 = 2;
const int ledPin1 = 3;
const int ledPin2 = 4;
const int ledPin3 = 5;
const int ledPin4 = 6;
const int ledPin5 = 7;
//Pot Pins
const int potPin0 = 33;
const int potPin1 = 34;
const int potPin2 = 35;
const int potPin3 = 36;
const int potPin4 = 37;
const int potPin5 = 38;
//Photoresistor Pins
const int photoPin0 = 14;
const int photoPin1 = 15;
const int photoPin2 = 16;
const int photoPin3 = 17;
const int photoPin4 = 18;
const int photoPin5 = 19;
//Changing Variables
//Pot Readings
int potSensorReading0;
int potSensorReading1;
int potSensorReading2;
int potSensorReading3;
int potSensorReading4;
int potSensorReading5;
//Photo Readings
int photoPinReading0;
int photoPinReading1;
int photoPinReading2;
int photoPinReading3;
int photoPinReading4;
int photoPinReading5;
//use this to compare to previous reading to account for inaccurate readings
int newPhotoPinReading0;
int newPhotoPinReading1;
int newPhotoPinReading2;
int newPhotoPinReading3;
int newPhotoPinReading4;
int newPhotoPinReading5;
//Used for blinking
int ledPinState0 = LOW;
int ledPinState1 = LOW;
int ledPinState2 = LOW;
int ledPinState3 = LOW;
int ledPinState4 = LOW;
int ledPinState5 = LOW;
//Used to create a counter
unsigned long previousMillis0 = 0;
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
unsigned long previousMillis3 = 0;
unsigned long previousMillis4 = 0;
unsigned long previousMillis5 = 0;
//values for fadeWithoutDelay
int value0, value1, value2, value3, value4, value5;
//The interval between blinks to be set by the pot position
long intervalLED0 = 0;
long intervalLED1 = 0;
long intervalLED2 = 0;
long intervalLED3 = 0;
long intervalLED4 = 0;
long intervalLED5 = 0;
pinMode(ledPin0, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
pinMode(ledPin5, OUTPUT);
pinMode(potPin0, INPUT);
pinMode(potPin1, INPUT);
pinMode(potPin2, INPUT);
pinMode(potPin3, INPUT);
pinMode(potPin4, INPUT);
pinMode(potPin5, INPUT);
pinMode(photoPin0, INPUT);
pinMode(photoPin1, INPUT);
pinMode(photoPin2, INPUT);
pinMode(photoPin3, INPUT);
pinMode(photoPin4, INPUT);
pinMode(photoPin5, INPUT);
if (usbMIDI.read()) {
processMIDI();
unsigned long currentMillis0 = millis();
unsigned long currentMillis1 = millis();
unsigned long currentMillis2 = millis();
unsigned long currentMillis3 = millis();
unsigned long currentMillis4 = millis();
unsigned long currentMillis5 = millis();
// delay(2);
Fade Code
Fade Code
Fade Code
potSensorReading0 = analogRead(potPin0);
int period0 = 5000;
int displace0 = 500;
//displace = potSensorReading0;
period0 = map(potSensorReading0, 0, 1023, 0, 5000);
value0 = 128 + 127 * cos(2 * PI / period0 * currentMillis0);
//value0 = 128+127*cos(2*PI/period*(displace-currentMillis0));
analogWrite(ledPin0, value0);
newPhotoPinReading0 = analogRead(photoPin0);
bool bigChange0 = false;
if (newPhotoPinReading0 - photoPinReading0 > 150 || newPhotoPinReading0 - photoPinReading0 < -150) {
bigChange0 = true;
bigChange0 = false;
if (photoPinReading0 != newPhotoPinReading0 && bigChange0 == true) {
photoPinReading0 = newPhotoPinReading0;
//delay(2);
if (newPhotoPinReading0 > 900) {
//MIDI Controllers 102-127 are undefined
//usbMIDI.sendControlChange(control, value, channel);
usbMIDI.sendControlChange(108, newPhotoPinReading0, channel);
// delay(2);
potSensorReading1 = analogRead(potPin1);
int period1 = 5000;
int displace1 = 500;
//displace1 = potSensorReading0;
period1 = map(potSensorReading1, 0, 1023, 0, 5000);
value1 = 128 + 127 * cos(2 * PI / period1 * currentMillis1);
//value1 = 128+127*cos(2*PI/period1*(displace1-currentMillis1));
analogWrite(ledPin1, value1);
newPhotoPinReading1 = analogRead(photoPin1);
bool bigChange1 = false;
if (newPhotoPinReading1 - photoPinReading1 > 150 || newPhotoPinReading1 - photoPinReading1 < -150) {
bigChange1 = true;
bigChange1 = false;
if (photoPinReading1 != newPhotoPinReading1 && bigChange1 == true) {
photoPinReading1 = newPhotoPinReading1;
//delay(2);
if (newPhotoPinReading1 > 900) {
usbMIDI.sendControlChange(109, newPhotoPinReading1, channel);
//delay(2);
potSensorReading2 = analogRead(potPin2);
Serial.println(potSensorReading2);
int period2 = 5000;
int displace2 = 500;
//displace2 = potSensorReading2;
period2 = map(potSensorReading2, 0, 1023, 0, 5000);
value2 = 128 + 127 * cos(2 * PI / period2 * currentMillis2);
//value2 = 128+127*cos(2*PI/period2*(displac2-currentMillis2));
analogWrite(ledPin2, value2);
newPhotoPinReading2 = analogRead(photoPin2);
bool bigChange2 = false;
if (newPhotoPinReading2 - photoPinReading2 > 150 || newPhotoPinReading2 - photoPinReading2 < -150) {
bigChange2 = true;
bigChange2 = false;
if (photoPinReading2 != newPhotoPinReading2 && bigChange2 == true) {
photoPinReading2 = newPhotoPinReading2;
//delay(2);
if (newPhotoPinReading2 > 900) {
usbMIDI.sendControlChange(110, newPhotoPinReading2, channel);
//delay(2);
Blink Code
Blink Code
Blink Code
potSensorReading3 = analogRead(potPin3);
intervalLED3 = potSensorReading3;
//delay(5);
if (currentMillis3 - previousMillis3 >= intervalLED3) {
// save the last time you blinked the LED
previousMillis3 = currentMillis3;
// if the LED is off turn it on and vice-versa:
if (ledPinState3 == LOW) {
ledPinState3 = HIGH;
ledPinState3 = LOW;
digitalWrite(ledPin3, ledPinState3);
newPhotoPinReading3 = analogRead(photoPin3);
bool bigChange3 = false;
if (newPhotoPinReading3 - photoPinReading3 > 150 || newPhotoPinReading3 - photoPinReading3 < -150) {
bigChange3 = true;
bigChange3 = false;
if (photoPinReading3 != newPhotoPinReading3 && bigChange3 == true) {
photoPinReading3 = newPhotoPinReading3;
//delay(2);
if (newPhotoPinReading3 > 900) {
usbMIDI.sendControlChange(111, newPhotoPinReading3, channel);
//delay(2);
potSensorReading4 = analogRead(potPin4);
intervalLED4 = potSensorReading4;
//delay(5);
if (currentMillis4 - previousMillis4 >= intervalLED4) {
previousMillis4 = currentMillis4;
if (ledPinState4 == LOW) {
ledPinState4 = HIGH;
ledPinState4 = LOW;
digitalWrite(ledPin4, ledPinState4);
newPhotoPinReading4 = analogRead(photoPin4);
bool bigChange4 = false;
if (newPhotoPinReading4 - photoPinReading4 > 150 || newPhotoPinReading4 - photoPinReading4 < -150) {
bigChange4 = true;
bigChange4 = false;
if (photoPinReading4 != newPhotoPinReading4 && bigChange4 == true) {
photoPinReading4 = newPhotoPinReading4;
//delay(2);
if (newPhotoPinReading4 > 900) {
usbMIDI.sendControlChange(112, newPhotoPinReading4, channel);
//delay(2);
potSensorReading5 = analogRead(potPin5);
intervalLED5 = potSensorReading5;
//delay(5);
if (currentMillis5 - previousMillis5 >= intervalLED5) {
previousMillis5 = currentMillis5;
if (ledPinState5 == LOW) {
ledPinState5 = HIGH;
ledPinState5 = LOW;
digitalWrite(ledPin5, ledPinState5);
newPhotoPinReading5 = analogRead(photoPin5);
bool bigChange5 = false;
if (newPhotoPinReading5 - photoPinReading5 > 150 || newPhotoPinReading5 - photoPinReading5 < -150) {
bigChange5 = true;
bigChange5 = false;
if (photoPinReading5 != newPhotoPinReading5 && bigChange5 == true) {
photoPinReading5 = newPhotoPinReading5;
//delay(2);
if (newPhotoPinReading5 > 900) {
usbMIDI.sendControlChange(113, newPhotoPinReading5, channel);
Serial.print("pot 0 = ");
Serial.println(potSensorReading0);
Serial.print("pot 1 = ");
Serial.println(potSensorReading1);
Serial.print("pot 2 = ");
Serial.print("pot 3 = ");
Serial.println(potSensorReading3);
Serial.print("pot 4 = ");
Serial.println(potSensorReading4);
Serial.print("pot 5 = ");
Serial.println(potSensorReading5);
Serial.print("photoSensor 0 = ");
Serial.println(newPhotoPinReading0);
Serial.print("photoSensor 1 = ");
Serial.println(newPhotoPinReading1);
Serial.print("photoSensor 2 = ");
Serial.println(newPhotoPinReading2);
Serial.print("photoSensor 3 = ");
Serial.println(newPhotoPinReading3);
Serial.print("photoSensor 4 = ");
Serial.println(newPhotoPinReading4);
Serial.print("photoSensor 5 = ");
Serial.println(newPhotoPinReading5);
delay(50);
void processMIDI(void) {
byte type, channel, data1, data2, cable;
// fetch the MIDI message, defined by these 5 numbers (except SysEX)
type = usbMIDI.getType(); // which MIDI message, 128-255
channel = usbMIDI.getChannel(); // which MIDI channel, 1-16
data1 = usbMIDI.getData1(); // first data byte of message, 0-127
data2 = usbMIDI.getData2(); // second data byte of message, 0-127
cable = usbMIDI.getCable(); // which virtual cable with MIDIx8, 0-7
// uncomment if using multiple virtual cables
//Serial.print("cable ");
//Serial.print(cable, DEC);
//Serial.print(": ");
// print info about the message
int ccChange = random(5, 100);
switch (type) {
case usbMIDI.NoteOff: // 0x80
Serial.print("Note Off, ch=");
Serial.print(channel, DEC);
Serial.print(", note=");
Serial.print(data1, DEC);
Serial.print(", velocity=");
Serial.println(data2, DEC);
case usbMIDI.NoteOn: // 0x90
//usbMIDI.sendControlChange(controllerA1, ccChange, channel);
Serial.print("Note On, ch=");
Serial.print("ccChange is: ");
Serial.println(ccChange);
case usbMIDI.AfterTouchPoly: // 0xA0
Serial.print("AfterTouch Change, ch=");
case usbMIDI.ControlChange: // 0xB0
Serial.print("Control Change, ch=");
Serial.print(", control=");
Serial.print(", value=");
case usbMIDI.ProgramChange: // 0xC0
Serial.print("Program Change, ch=");
Serial.print(", program=");
Serial.println(data1, DEC);
case usbMIDI.AfterTouchChannel: // 0xD0
Serial.print("After Touch, ch=");
Serial.print(", pressure=");
case usbMIDI.PitchBend: // 0xE0
Serial.print("Pitch Change, ch=");
Serial.print(", pitch=");
Serial.println(data1 + data2 * 128, DEC);
case usbMIDI.SystemExclusive: // 0xF0
// Messages larger than usbMIDI's internal buffer are truncated.
// To receive large messages, you *must* use the 3-input function
// handler. See InputFunctionsComplete for details.
Serial.print("SysEx Message: ");
printBytes(usbMIDI.getSysExArray(), data1 + data2 * 256);
case usbMIDI.TimeCodeQuarterFrame: // 0xF1
Serial.print("TimeCode, index=");
Serial.print(data1 >> 4, DEC);
Serial.print(", digit=");
Serial.println(data1 & 15, DEC);
case usbMIDI.SongPosition: // 0xF2
Serial.print("Song Position, beat=");
Serial.println(data1 + data2 * 128);
case usbMIDI.SongSelect: // 0xF3
Serial.print("Sond Select, song=");
case usbMIDI.TuneRequest: // 0xF6
Serial.println("Tune Request");
case usbMIDI.Clock: // 0xF8
Serial.println("Clock");
case usbMIDI.Start: // 0xFA
Serial.println("Start");
case usbMIDI.Continue: // 0xFB
Serial.println("Continue");
case usbMIDI.Stop: // 0xFC
Serial.println("Stop");
case usbMIDI.ActiveSensing: // 0xFE
Serial.println("Actvice Sensing");
case usbMIDI.SystemReset: // 0xFF
Serial.println("System Reset");
default:
Serial.println("Opps, an unknown MIDI message type!");
void printBytes(const byte *data, unsigned int size) {
while (size > 0) {
byte b = *data++;
if (b < 16) Serial.print('0');
Serial.print(b, HEX);
if (size > 1) Serial.print(' ');
size = size - 1;
