Results 1 to 12 of 12
Thread: 3.6 D+ and D- pins
    Dec 2018
    5
    3.6 D+ and D- pins
    Hi everyone, first post over here.
    I'm designing a midicontroller with a teensy 3.6, this time I am putting a USB B in the front panel without and extension cable, directly to pcb. With 3.2 I had access to pins D+ and D-, but in 3.6 this pins are for a secondary port, isnt It?
    So, are there USB data pins of the primary port available? Which ones?
    Feb 2014
    Colmar, France
    2,329
    On the Teensy 3.6 there are D+ and D- pads for the primary USB port (below the primary USB connector). Then there are the D+ and D- holes (near to pins 2 to 4), which are for the secondary (high speed, host) USB port.
    Dec 2018
    5
    Thanks a lot for the fast answer, so unfortunately I have no way to route it in the pcb without cabling...maybe the extension cable is my only solution by now.
    Feb 2014
    Colmar, France
    2,329
    Perhaps use pogo pins?
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,060
    But its the hub port pins you want for USB MIDI out... they have through holes
    Dec 2018
    5
    I would prefer not to use this ones, they are quite expensive here and I dont trust that much this pins for being in the road
    Dec 2018
    5
    The last time I used 3.6 I have MIDI out on its own conector, not host
    Dec 2016
    Montreal, Canada
    2,964
    dielectric grease is good for pogo pin setups
    Feb 2013
    1,060
    Quote Originally Posted by oddson View Post
    Sorry... misread.
    19,718
    Quote Originally Posted by Cosmonaut View Post
    These pins in the red circles have identical USB device functionality. The are the same primary USB port on 3.6 as you had on 3.2.
    These pins in the blue circle are the secondary USB host port.
    Jan 2019
    2
    dear sir.
    Dose Teensy 2.0++ have the D+\D- pin to connect identical USB device?
    Feb 2014
    Colmar, France
    2,329
    Quote Originally Posted by iplaywind View Post
    dear sir.
    Dear sir. "Dose" you not have had a look onto the Teensy reference page of the PJRC website (https://pjrc.com/teensy/pinout.html)? There you could see that there are no additional USB pins or pads on the Teensy 2.0++.
