Results 1 to 6 of 6
Thread: asking for kind help and support
    Oct 2018
    italy
    3
    first I would like to thank you in advance for your kind and valuable help. Here is my question I am trying to use the library made by for wavelet transform applcation for viberation data to detect annomalies and fault more specifically for industrial bearing. But when I tried to compile the liberery for Teensy 3.6 using Arduino 1.8.5 I got an error as i mention below. all the liberery as well the implimenation files are made of C code what i mean using .c. anyone who can suggest me the solution? I guess the problem is with the linker and compiler.
    // here is the sample code to test simple with simple imput data
    wave_object obj;
    wt_object wt;
    double *inp, *out, *diff;
    int N, i, J;
    char *name = "db4";
    obj = wave_init(name);// Initialize the wavelet
    N = 14; //Length of Signal
    inp = (double*)malloc(sizeof(double)* N); //Input signal
    out = (double*)malloc(sizeof(double)* N);
    diff = (double*)malloc(sizeof(double)* N);
    //wmean = mean(temp, N);
    for (i = 0; i < N; ++i) {
    inp[i] = i;
    Serial.println(inp[i]);
    J = 1; //Decomposition Levels
    wt = wt_init(obj, "dwt", N, J);// Initialize the wavelet transform object
    Serial.println(wt->siglength);
    setDWTExtension(wt, "sym");// Options are "per" and "sym". Symmetric is the default option
    setWTConv(wt, "direct");
    dwt(wt, inp);// Perform DWT
    //DWT output can be accessed using wt->output vector. Use wt_summary to find out how to extract appx and detail coefficients
    for (i = 0; i < wt->outlength; ++i) {
    Serial.println(wt->output[i]);
    idwt(wt, out);// Perform IDWT (if needed)
    // Test Reconstruction
    for (i = 0; i < wt->siglength; ++i) {
    diff[i] = out[i] - inp[i];
    Serial.println(absmax(diff, wt->siglength)); // If Reconstruction succeeded then the output should be a small value.
    Serial.println("FIN");
    Serial.flush();
    double absmax(double *array, int N) {
    double max;
    int i;
    max = 0.0;
    if (fabs(array[i]) >= max) {
    max = fabs(array[i]);
    return max;
    // here are the Generated error when I tried to compiled
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-closer.o): In function `_close_r':
    closer.c.text._close_r+0xc): undefined reference to `_close'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-lseekr.o): In function `_lseek_r':
    lseekr.c.text._lseek_r+0x12): undefined reference to `_lseek'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-readr.o): In function `_read_r':
    readr.c.text._read_r+0x12): undefined reference to `_read'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-fstatr.o): In function `_fstat_r':
    fstatr.c.text._fstat_r+0x10): undefined reference to `_fstat'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-isattyr.o): In function `_isatty_r':
    isattyr.c.text._isatty_r+0xc): undefined reference to `_isatty'
    Error compiling for board Teensy 3.6.
    Feb 2014
    Colmar, France
    2,584
    And where is the library? Do not see any #include in your code...
    1,454
    When I compile that code for T3.6, I do not get any of the errors you've listed. I get this lot:
    sketch_dec03a: In function 'void loop()':
    sketch_dec03a:5: error: 'wave_object' was not declared in this scope
       wave_object obj;
    sketch_dec03a:6: error: 'wt_object' was not declared in this scope
       wt_object wt;
    sketch_dec03a:9: warning: ISO C++ forbids converting a string constant to 'char*'
       char *name = "db4";
    sketch_dec03a:10: error: 'obj' was not declared in this scope
    sketch_dec03a:10: error: 'wave_init' was not declared in this scope
    sketch_dec03a:21: error: 'wt' was not declared in this scope
    sketch_dec03a:21: error: 'wt_init' was not declared in this scope
    sketch_dec03a:23: error: 'setDWTExtension' was not declared in this scope
    sketch_dec03a:24: error: 'setWTConv' was not declared in this scope
    sketch_dec03a:25: error: 'dwt' was not declared in this scope
    sketch_dec03a:31: error: 'idwt' was not declared in this scope
    There's no setup function either.
    Pete
    Oct 2018
    italy
    3
       wave_object obj;
       wt_object wt;
       char *name = "db4";
    Pete
    Dear Pete I would like to appreciate for your queeck response. In the full program I included the setup function and the liberery function for detail information here is the full skech program
    #include <string.h>
    #include <math.h>
    #include <Arduino.h>
    #include "wavelib.h"
    pinMode(ledpin,OUTPUT);
    wave_object obj;
    wt_object wt;
    int N, i, J;
    char *name = "db4";
    inp[i] = i;
    Serial.flush();
    double max;
    int i;
    max = 0.0;
    return max;
    Oct 2018
    italy
    3
    I include the library function in the full sketch and I define setup function default
    #include <string.h>
    #include <math.h>
    wave_object obj;
    wt_object wt;
    int N, i, J;
    char *name = "db4";
    inp[i] = i;
    Serial.flush();
    double max;
    int i;
    max = 0.0;
    return max;
    1,454
    Now it doesn't compile because it can't find wavelib.h
    What is wavelib.h and where is it?
    Pete
