Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 88 of 88
Thread: TeensyStep - How to switch from 1 speed to another
  1. #76
    I Did some more tests and found that estop (in master branch) works only in one direction:
    #include "TeensyStep.h"
    Stepper motor(22, 41);
    RotateControl RotCtrl(5, 1000);
    StepControl StpCtrl(5, 1000);
      motor
      .setMaxSpeed(-2000)
      .setAcceleration(2000);
      RotCtrl.rotateAsync(motor);
      RotCtrl.emergencyStop();
      motor.setTargetRel(300);    // works
      StpCtrl.move(motor);
      delay(2000);
      motor
      .setMaxSpeed(2000)
      motor.setTargetRel(-300);    // does not work: moves into wrong direction
    void loop() {}
  2. #77
    Germany
    460
    EDIT2: I did some more tests: the 3rd code block of #21 does not work.
    I tried this but it seems to work as it should. Here the LA output. (The peaks shown in the third trace are generated directly after the stop commands)
    This is already fixed in the DevTimer branch. Can you give it a try? it also includes the re implementation of the PullInSpeed you requested above...
    Here the traces (I did reduce the delay between the two blocks from 2s to 0.5s to get a more compact display)
  3. #78
    I will try to give some examples... Here my observations. The following works in master branch but not in dev-timer:
    Stepper motor(48, 47);
    RotateControl controller(5, 1000);
      motor
      .setMaxSpeed(124)
      .setAcceleration(198);
      controller.rotateAsync(motor);
      delay(2000);
      controller.stop();
      motor
      .setMaxSpeed(-124)
      delay(2000);
      controller.stop();
    void loop() {}
    The next code block works also in dev-timer:
      motor
      .setMaxSpeed(124)
      .setPullInSpeed(200);
      delay(2000);
      controller.stop();
      motor
      .setMaxSpeed(-124);
      delay(2000);
      controller.stop();
    void loop() {}
    The following does not work in dev-timer:
      motor
      .setMaxSpeed(124)
      delay(2000);
      controller.stop();
      motor
      .setMaxSpeed(-124)
      delay(2000);
      controller.stop();
    void loop() {}
    And finally: this moves the motor, but pullin does not override the acceleration (again dev-timer):
      motor
      .setMaxSpeed(124)
      delay(2000);
      controller.stop();
    void loop() {}
  4. #79
    Germany
    460
    Thanks again for finding all those bugs! Very helpful indeed.
    It might be easier to continue this discussion on GitHub. I opened an issue here: https://github.com/luni64/TeensyStep/issues/47
  5. #80
    Nov 2013
    17
    Hi Luni
    I also posted in another thread but this one might be more applicable.
    I wonder if you could give me some advice on my project?
    I have a carriage on a 6m long guide. The carriage is pulled by a 8Nm stepper power by a 48v supply. The stepper has a 1:2 reduction and the looped belt has a ratio of 1:0.6. The carriage will move about 400mm per revolution of the motor.
    The objective:
    I have to accelerate the carriage in the first 2m to 8m/s then maintain that for 2m and then decelerate for the last 2m. This is done both ways.
    I am having problems conceptualizing how to use the library to achieve this. If the acceleration could be specified for a distance or a duration, then it could be done.
    Any suggestions will help please.
  6. #81
    On my machine I do the following:
    StepControl controller(5, 1000);
    int motor_steps_per_rev = 200;
    int motor_microstepping = 4;
    int pulley_teeth = 28;
    int pulley_pitch = 3;    // in mm
    int travel = 800;        // travel in mm
    int speed = 200;         // speed in mm per second
    int acceleration = 500;  // mm/s to be reached in 1 sec of acceleration starting from zero
    int steps_per_mm = motor_steps_per_rev * motor_microstepping / pulley_teeth / pulley_pitch;
      motor
      .setMaxSpeed(speed * steps_per_mm)
      .setAcceleration(acceleration * steps_per_mm)
      .setTargetRel(travel * steps_per_mm);
      // move motor
    Hope that helps...
  7. #82
    Nov 2013
    17
    @JPK, I got the calibration sorted thanks. My question is more related to getting the acceleration over a shorter time than what is achievable at the moment. I just included the setup information to make my case as clear as possible.
    The situation is this, if you give a move command that is 6000mm away the library move will accelerate to get to maximum speed at the 3000mm mark and then deccelarate to stop at 6000mm.
    What I need is to move to 6000mm but accelerate to max speed at 2000mm then travel at max speed until 4000mm and the decelerate to stop at 6000mm.
  8. #83
    Germany
    460
    I can give you a more detailed answer later today but I think all you need to do is calculate the acceleration you need for your movement.
    Standard kinematic formulas are (out of my head without verifying)
    v^2 = 2as, where a = acceleration, v = velocity and s = distance.
    This gives:
    a = v^2/2s
    Insert v=4000mm, s = 2000mm which gives you the required acceleration. Transform that from mm/s^2 to steps/s^2 and use the result as parameter for setAcceleration(). Then setting the target to 6000mm and start the movement should be all which is required. For the way back set the target to 0 and start the movement.
  9. #84
    Germany
    460
    This should do what you want:
    // since you know how to transform from mm to steps we can as well
    // assume that 1 step = 1mm
    int s = 6000;         // total distance
    int s_a = 2000;       // accleration distance
    int v = 10000;        // target speed
    int a = v*v/(2*s_a);  // acceleration
    StepControl controller;
    Stepper motor(0,1);
        motor
        .setMaxSpeed(v)
        .setAcceleration(a);
        motor.setTargetAbs(s);  // up
        controller.move(motor);
        motor.setTargetAbs(0);  // back
    Nov 2013
    17
    Ah I see the picture a bit clearer now. My understanding of the acceleration function was a bit screwed. Thank a lot I will try this in the morning
  11. #86
    Nov 2013
    17
    @Luni
    This works very well thanks. Just to confirm that I have my calculations right please.
    I have 2.5 step per mm so if I run at 11000 for speed it will be
    11000 / 2.5 = 4400 mm/sec when at full speed.
    4400 * 3600 = 15.84 km/h
    Do I have this right?
  12. #87
    Germany
    460
    Yes that looks OK.
    Remark: When you are unsure it is always good to add the units to the calculation. You can then easily spot errors.
    (11000 stp/sec) / (2.5 stp/mm) = 4400 mm/sec
    (4400 mm/sec) / (1000 mm/m) = 4.4 m/sec
    (4.4 m/sec) * (3600 sec/h) = 15'840 m/h = 15.84 km/h
  13. #88
    Nov 2013
    17
    Thanks Luni I appreciate the help
