Results 1 to 21 of 21
Thread: Teensyduino 1.45 Released
    Administrator Paul's Avatar
    Oct 2012
    338
    Teensyduino 1.45 has been released.
    The main new feature is support for Arduino 1.8.8.
    The only change since 1.45-beta2 was commenting the 256 MHz overclock lines in boards.txt, as Frank B suggested.
    9,955
    Quote Originally Posted by Paul View Post
    Changes since Teensyduino 1.44
    Support for Arduino 1.8.8
    Updated libraries: i2c_t3, Snooze
    Teensy 3.6 overclock to 256 MHz (Frank B)
    Fix serial begin() lockup if framing error received in FIFO when end() called
    Audio add AudioControlTLV320AIC3206 (Chip Audette)
    Teensy Loader icon added for Gnome desktop on Linux
    Changes since Teensyduino 1.45-beta1
    Add 256 MHz Teensy 3.6 to Tools > CPU Speed menu
    Fix asm in delayMicroseconds on Teensy LC (Frank B)
    Audio: Fix ADAT output with 168 MHz (Frank B)
    … The only change since 1.45-beta2 was commenting the 256 MHz overclock lines in boards.txt, as Frank B suggested.
    <edit>: and the cool thing is TyCommander still works
    Dec 2018
    Netherlands
    2
    I'm afraid some stuff is broken for the 8-bit series of controllers:
    - Teensy 2.0(++) worked fine with Arduino 1.8.7 + Teensyduino 1.44
    - the hardware definitions in Teensyduino 1.45 are probably corrupted because I only get the 32-bit operating speeds with the Teensy 2 boards.
    20,684
    Can't reproduce the problem here. Looks fine when I try. Here's a screenshot.
    Maybe I tried the wrong way? Any chance you could be more specific about the problem? Maybe show a screenshot, so we can actually see the same problem you're seeing?
    Germany NRW
    5,679
    Works for me, too.
    9,955
    Never had any Teensy_2 - but IDE board select does show the choices like post #4
    9,955
    Paul: Have you changed the factory boot test Blink code to present the Teensy Type to the SerMon Teensy_ports indication? It seems that would work as a diagnostic since the IDE supports that now - I asked as that was released with TD update and not sure if it got answered?
    TD 1.45 didn't get the change for usb_init_serialnumber() to return MCU Ser# when -1 was the result of one time serial # reading? @crees left code he saw working but I never tried it - and this K66 PROTO board could use it.
    POST :: Custom-Teensy-Write-Once-Memory-quot-Burn-quot-Direction-needed
    <edit>: I just tested that on the K66 PROTO board and it works to have Serial # for TyCommander … mostly :: 1313158531-Teensy
    On Power up plug in and AFTER reprogramming TyCommander shows that as the Serial#.
    BUT - on transition with TyComm RESET or Upload with reset it reverts to showing:: 4294967295-Teensy until it restarts. And that confuses TyComm as it expects Serial# continuity. Seems the bootloader chip returns the chip's one time write Serial # when it gets control?
    20,684
    Paul: Have you changed the factory boot test Blink code...
    No, and I'm not planning to mess with the test fixtures we use, at least not anytime soon. This sort of update is pretty much at the bottom of my priority list right now.
    Senior Member crees's Avatar
    Dec 2016
    Utah
    174
    interesting. I have the same issue hitting reset on tycommander. However if I hit reset twice I get the board back again the way it should. This issue will add some complexity to custom teensy boards. I have some ideas on a work around but will need to do some tesing
    9,955
    @Paul : I can see that being low import - might help newbies, and risky to change the tested and working system without extensive testing.
    @crees : Same process - I removed the code … I posted on the TyComm thread to see if koromix has an idea to fix the transition through reset change. Best thing would be to implement a write to the one time area.
    Dec 2016
    Utah
    174
    Arduino / teensyduino doesn’t seem to have issue with the load / reset and the board comes back with the expected ID. Be interesting to see what tycomm thread has in regards to this.
    Dec 2018
    Netherlands
    2
    Hi all, sorry... it took me a while to get back on my reported issue.
    Apperently it was me. I did a clean GNU/Linux install on a laptop and copied my ~/Arduino folder over.
    Maybe there were incompatible remnants in there. Now that I reverted to Arduino 1.8.7 + Teensyduino 1.44, I can no longer reproduce the behavior with Arduno 1.8.8 and Teensyduino 1.45.
    Member gimpo's Avatar
    Mar 2018
    Munich
    51
    It works very well for me, but... again that noising java exception when starting the Arduino IDE for the first time (i.e. after running TeensyduinoInstall.linux64).
    The graphic is messed at the first start. I've tested it again on a fresh new installation of IDE 1.8.8 on Ubuntu 16.04.
    Again that exception when setting the serial port:
    Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
    at processing.app.EditorLineStatus.setSerialPort(Edit orLineStatus.java:136)
    After setting the port for programming the Teensy 3.2 (e.g. /dev/tty/ACM0), the problem don't arise anymore, even after restarting the IDE more times.
    So seems that the program needs the port to be set in order to not block the thread refreshing the graphic interface. Anyway, it's a minor bug.
    Dec 2015
    LA
    133
    On mac 10.14.2, Arduino 1.8.8, runs great, no problems, no warnings.
    thanks
    273
    Quote Originally Posted by gimpo View Post
    same/similar error here on a new computer with windows 10. If I change the size of the window, the surface will be displayed again normally. Prior to the Teensyduino installation Arduino loaded normal.
    	at processing.app.EditorLineStatus.setSerialPort(EditorLineStatus.java:136)
    	at processing.app.EditorLineStatus.paintComponent(EditorLineStatus.java:101)
    	at javax.swing.JComponent.paint(JComponent.java:1056)
    	at javax.swing.JComponent.paintChildren(JComponent.java:889)
    	at javax.swing.JComponent.paint(JComponent.java:1065)
    	at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1047)
    	at javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
    	at javax.swing.JComponent.paintToOffscreen(JComponent.java:5217)
    	at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1579)
    	at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1502)
    	at javax.swing.RepaintManager.paint(RepaintManager.java:1272)
    	at javax.swing.JComponent.paint(JComponent.java:1042)
    	at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39)
    	at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79)
    	at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116)
    	at java.awt.Container.paint(Container.java:1978)
    	at java.awt.Window.paint(Window.java:3906)
    	at javax.swing.RepaintManager$4.run(RepaintManager.java:842)
    	at javax.swing.RepaintManager$4.run(RepaintManager.java:814)
    	at java.security.AccessController.doPrivileged(Native Method)
    	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
    	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
    	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
    	at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
    	at javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
    	at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
    	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
    	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
    	at java.awt.EventQueue.access$500(EventQueue.java:97)
    	at java.awt.EventQueue$3.run(EventQueue.java:709)
    	at java.awt.EventQueue$3.run(EventQueue.java:703)
    	at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
    	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
    	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
    	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
    	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
    	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
    	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
    Mar 2018
    Munich
    51
    So, I'm not the only one seeing it!
    Anyway, a minor bug.
    20,684
    Yup, it's a bug. Already fixed in the 1.46 betas, if you want to grab the installer from msg #2 in the huge beta test thread.
    273
    Can confirm it's fixed in 1.46-beta5.
    Dec 2016
    5
    Quote Originally Posted by HWGuy View Post
    Please what's is the link for 1.46-beta5 ?
    9,955
    post #2 on this thread Teensy-4-0-First-Beta-Test
    Latest Beta now #9
    Dec 2016
    5
    Latest Beta now #9
    got it, many thanks
