Results 1 to 2 of 2
Thread: The way to enable SPH0645LM4H with Teensy 3.2
    Mar 2018
    10
    I have brought SPH0645LM4H from TAOBAO with 48Yuan(~$7). And I have tried to enable it with Teensy 3.2. Below is the way to test and enable it.
    Hardware part:
    1. You should know the hole is on the back of the component and module. When you test your hardware, please shout to the back.
    This picture comes from the datasheet.
    This picture comes from this link https://learn.adafruit.com/adafruit-...eakout/pinouts
    2. Hardware connection
    Teensy 3.2 SPH0645LM4H
    GND SEL
    D23 LRCL
    D13 DOUT
    D9 BCLK
    GND GND
    3.3V 3V
    3. You can test with Try File > Examples > Audio > Recorder. After download it to your Teensy. You should see the waveform of LRCL/BCLK which is output from Teensy. And waveform in DOUT which is send by mems. This is a suggestion from PaulStoffregen. And I have confirm this with my oscilloscope. You can find this suggestion from this link. https://forum.pjrc.com/threads/40858...ut-board/page2
    After hardware checking, you can be sure the module you buy is OK. And below code can send you voice from MEMS to your PC.
    Software Part:
    AudioInputI2S            i2s1;           //xy=223,84
    AudioOutputUSB           usb1;           //xy=435,172
    AudioConnection          patchCord1(i2s1, 0, usb1, 0);
       AudioMemory(80);
    After plug Teensy to you PC via USB, you can hear the sound from mic.
    Feb 2017
    259
    You might find this thread interesting: https://forum.pjrc.com/threads/47010...?highlight=i2s
