Sample Based Synth Using SD card and Polyphony??
tshoats
New member
Hello i was wondering is it possible to use the Teensy 3.6 to create a sample instrument that triggers the samples via midi keyboard to its proper chromatic scale. For example lets say i wanted to add pads, leads, and synth sounds to a sd card. I would somehow get each sample note (C, E, F, F#..etc) Then put all those on a sd card. Then trigger these samples and notes appropriately when using the midi library. I guess my question is, How many of these sounds can I trigger or play at once without latency or glitch issues. For a full fledge sample instrument, Im thinking i might need a powerful board to achieve this??
Something like WAV Trigger, not sure.
