Results 1 to 2 of 2
Thread: how to mate the audio card to teensy 3.6
    On this page
    https://www.pjrc.com/store/teensy3_audio.html
    There is a diagram of the audio card mounted on top of the teensy. Not clear to me how the pinouts align. Does anyone have more details/pictures of this process?
    Leor
    3,451
    The Teensy 3.5/3.6 mounts directly on top of (or underneath) the audio card using the first 14 pins on each side. All of the pins that the audio card uses are exactly the same as the first set of pins in the 3.5/3.6. The last 10 pins on each side of the Teensy 3.5/3.6 are not connected to the audio card.
    There is the back row of 5 pins in the Teensy 3.2 that got relocated in the Teensy 3.5/3.6, but the audio card does not use them (nor have holes to connect them).
    While the audio card has a micro-SD card reader, you will get faster performance if you use the reader on the Teensy 3.5/3.6.
