Results 1 to 14 of 14
Thread: Teensyduino ide installation issue
    Dec 2018
    8
    Hi
    I just installed teensyduino, only for it to start with error messages and rest of gui invisible. GUI elements only became visible when the mouse went over them.
    Initial startup of teensduino:
    Error Messages (screenshot taken after mouse on all gui elements to make them visible)
    Prior to installing the teensyduino, the arduio ide started without these errors and all gui visible.
    System Details:
    Teensyduino version: 1.45
    Arduino IDE version: 1.8.8
    OS: Windows 10 home
    Arduino Location: D:\additional apps\arduino-1.8.8
    Arduino has portable folder setup see: https://www.arduino.cc/en/Guide/PortableIDE
    Teensyduino was installed with WIFI off and antivirus turned off
    Teensy LC has not yet been inserted due to ide errors
    Feb 2014
    Colmar, France
    2,600
    Did you try a non-portable installation with Arduino’s standard installer?
    Dec 2018
    8
    Just tried arduino's standard installer (non-portable) followed by the teensyduino installer. Although the gui now worked, the same error messages turned up.
    Error messages screenshot:
    Full error messages:
    Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
    	at processing.app.EditorLineStatus.setSerialPort(EditorLineStatus.java:136)
    	at processing.app.EditorLineStatus.paintComponent(EditorLineStatus.java:101)
    	at javax.swing.JComponent.paint(JComponent.java:1056)
    	at javax.swing.JComponent.paintChildren(JComponent.java:889)
    	at javax.swing.JComponent.paint(JComponent.java:1065)
    	at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1047)
    	at javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
    	at javax.swing.JComponent.paintToOffscreen(JComponent.java:5217)
    	at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1579)
    	at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1502)
    	at javax.swing.RepaintManager.paint(RepaintManager.java:1272)
    	at javax.swing.JComponent.paint(JComponent.java:1042)
    	at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39)
    	at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79)
    	at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116)
    	at java.awt.Container.paint(Container.java:1978)
    	at java.awt.Window.paint(Window.java:3906)
    	at javax.swing.RepaintManager$4.run(RepaintManager.java:842)
    	at javax.swing.RepaintManager$4.run(RepaintManager.java:814)
    	at java.security.AccessController.doPrivileged(Native Method)
    	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
    	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
    	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
    	at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
    	at javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
    	at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
    	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
    	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
    	at java.awt.EventQueue.access$500(EventQueue.java:97)
    	at java.awt.EventQueue$3.run(EventQueue.java:709)
    	at java.awt.EventQueue$3.run(EventQueue.java:703)
    	at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
    	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
    	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
    	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
    	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
    	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
    	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
    26,223
    Ok, I believe I see what's causing the NullPointerException.
    Here's an attempt to fix it. To install this, extract the ZIP file to get pde.jar. Then copy it to the "lib" folder inside Arduino, replacing the pde.jar that's already present.
    Please let me know if this solve the error?
    Attached Files Attached Files
    Dec 2018
    8
    This solves the problem - everything now loads correctly with no errors
    Thank you
    26,223
    Does it also solve the problem when used in portable mode?
    Dec 2018
    8
    Solves the problem for both the installed and portable.
    Thank you
    Oct 2013
    5
    Wanted to say that I also had this issue on a Windows 10 machine, Arduino version 1.8.8 installed as the Windows exe rather than as a Windows 10 App.
    This fix also worked for me.
    Banned
    Jan 2019
    Australia
    16
    Had the same problem on Windows 7 and this fix sorted it.
    Feb 2019
    1
    I had the same issue and this fixed it for me too.
    Steve
    It worked for me too. It was a long and frustrating path to here because I started with the Win10 app before I found the app version of Arduino was not supported. Then I had to find this thread.
    I for one think that a big RED note in the Teensyduino download page would be in order that first cautioned about the app version of Arduino and then pde.jar fix.
    Fred
    Mar 2019
    2
    I just got the same issue and patching lib/pde.jar fixed it.
    Any chance the Teensyduino installer could be updated to use the right lib/pde.jar? Thanks!
    Nov 2015
    17
    Quote Originally Posted by Prism View Post
    Ditto here. Installed Arduino IDE on a fresh Win 10 install, and then Teensyduino, and ran into the same issue. The new pde.jar fixed it.
    26,223
    Just a quick followup here. This issue is fixed in 1.46-beta10.
    https://forum.pjrc.com/threads/55471...o-1-46-Beta-10
