Results 1 to 19 of 19
Thread: Help with List of Teensy Eurorack modules
    Mar 2013
    132
    I am exploring OSC (Open Sound Control) integration with Eurorack Modules. My starting point is developing a list of modules that build on Teensy 3.x.
    Could you please help me by adding modules you know of that I haven't found:
    Closed:
    https://malekkoheavyindustry.com/product/varigate-8/ Varigate-8
    https://www.zetaohm.com FLXS1
    http://doboz.audio/tsnm3u/ TSNM
    Open:
    https://github.com/kbob/drum-machine Drum Machine
    https://github.com/mxmxmx/eurotrash_mkII/wiki/build EuroTrash mk II
    https://github.com/TomWhitwell/RadioMusic Radio Music
    https://github.com/TomWhitwell/Chord-Organ Chord Organ
    https://github.com/jakplugg/Dodeca Magpie Dodeca
    https://github.com/mxmxmx/O_C Ornament and Crime
    http://neutron-sound.com/noa.html Orgon Accumulator
    http://www.cutlasses.co.uk/tech/glitch-delay/ Glitch Delay
    https://github.com/cutlasses/AudioFreeze Audio Freeze
    https://github.com/cutlasses/Kronos Kronos
    http://www.cutlasses.co.uk/music-demo/the-teensy-trio/
    https://github.com/jamescarruthers/audioplayground Teensy Audio Playground
    24,225
    Heard of this one just a few days ago. No idea if or when they'll sell any.
    https://github.com/PatternAgents/TheVoid
    24,225
    Here's a few more that are currently in the queue to appear on the website blog.
    http://little-scale.blogspot.com/201...-mediator.html
    https://little-scale.blogspot.com/20...en-cv.html?m=1
    https://hackaday.io/project/99863-ma...-audio-devices
    This is a modular-like project
    https://forum.pjrc.com/threads/53681...l=1#post188935
    https://hackaday.io/project/160626-p...al-synthesizer
    This one isn't technically modular synth, and my understanding is it's only MIDI at this point, but a synth version might be in the works?
    https://conductivelabs.com/product/t...r-w-usb-cable/
    Stargazer isn't modular - pretty much the opposite, but is using a Teensy as the synth engine.
    https://www.moffenzeefmodular.com/stargazer
    Mar 2013
    132
    Thanks Paul. Somehow I overlooked the Euroshield as well.
    Senior Member houtson's Avatar
    Aug 2015
    Scotland
    175
    Came across this 8 voice FM synth module by hallmark on muff https://github.com/hallmar/Eurorack-...e/master/Polyg
    sounds excellent https://www.youtube.com/watch?v=QhJZ...ature=youtu.be
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    933
    for the list: Teensy eurorack Step Divider
    https://github.com/mortonkopf/Teensy...g-step-divider
    24,225
    Quote Originally Posted by mortonkopf View Post
    I really like the DIY nature of this built with wires!
    If we were to show this on the blog (hopefully that's ok?) how would you describe the purpose of this module? You know... you people with some general knowledge of electronics but not modular syntheis and specifically what a "step divider" does?
    Apr 2013
    London, uk
    933
    Hi Paul,
    I will put video up in the next day or two and link it from the git repo if that helps. In the meantime: step divider is a utility module, it doesn't produce sound on its own, it takes an incoming clock, and uses that to sync other modules to subdivisions of time. so you can send a clock to trigger another sound, such as a drum, or another sequencer, at every nth step of the original. So, say, every second beat, or fourth beat. IF you use odd numbers in the divider, you start to get some groove.
    Now, if you start to rotate that subdivision on each clock input, things get interesting in the world of modulation. This divider moves the step division along each time also, so it rotates around the divisions. Or, you can push the button and have it regular.
    This is a module for those that know their rack, as although it has voltage clamping on the clock input for over voltage protection, it only uses diodes on the clock outs.
    Apr 2013
    London, uk
    933
    Teensy eurorack simple drum module:
    https://github.com/mortonkopf/Teensy_simple_drum
    Here is a short video of the drum module with the step divider
    https://www.youtube.com/watch?v=7iTxoKPSAh0
    Sep 2019
    Sevilla, Spain
    55
    Sweet Sixteen (eurorack module based on Teensy, derivative work from 16n),
    16 channels of:
    -midi & CV & i2C controller,
    -CV to midi & CV to i2C converter,
    -attenuator
    https://github.com/M4ngu/Sweet-Sixteen
    Nov 2015
    199
    VEGA by Faselunare (www.faselunare.com)
    4 voices 6HP digital drum module
    samples+synth+fx
    Final design will be different from the video
    and uses teensy 4.1
    Available after summer 2020
    https://www.youtube.com/watch?v=6mTy1SDbm98
    Portland
    63
    Temps Utile, clocky cousin of the Ornament and Crime Temps-Utile
    Senior Member fdaniels's Avatar
    Oct 2020
    Ostwestfalen, Germany
    109
    Shameless self promotion: https://dmachinery.net/modules/triples/
    Apr 2013
    London, uk
    933
    Prok drum modules:
    https://prok.co.uk/pages/eurorack/
    Bassdrum, Snare, Hi-Hat and Hand Clap.
    May 2018
    131
    Another one: it's MicroDexed (DX7 FM synthesis) for a Eurorack:
    https://m.youtube.com/watch?v=JrZnEHhoTDk
    https://codeberg.org/nervousapps/Mic...oussupermother
    Apr 2013
    London, uk
    933
    very impressive 16n fader controller for cv control of eurrack modules:
    https://www.youtube.com/watch?v=RWA2...ature=emb_logo
    open source:
    https://github.com/16n-faderbank
    Sep 2019
    Sevilla, Spain
    55
    TUKRA
    eurorack trigger sequencer with audio and midi,
    sound demo:
    detailed info here:
    https://www.tesseractmodular.com/eurorack-modules/tukra
    Mar 2013
    Austin, TX
    110
    My Delaydelus 2 was semi modular, with CV i/o and is open source. It's no longer for sale though.
Tags for this Thread
