Results 1 to 5 of 5
Thread: making a measure class
    Nov 2018
    tassie
    15
    hi again
    I am thoroughly enjoying this learning.
    Dancing along to the beats from the teensy well it does get a little monotonous after a few bars.
    i would like to make a Measure class that plays a array of patterns at the touch of the same buttons if the machine is put into that different state.
    in the arduino ide i have created a new tab named Measure.h
    #ifndef Measure_h
    #define Measure_h
    //#include <Arduino.h>
    class Measure {
    public:
           Measure();
    in this class i will define all the variables and methods i need for the class. i know there is nothing in it for now. I shall probably just copy and paste much of the code from the main. such as voice parameters and boolean arrays, and the current samples so that each measure can have a different pattern, currentSample and drum voice parameters.
    in the arduino ide i have created a new tab named Measure.cpp
    #include "Measure.h"
    Measure::Measure()
      //do stuff here like define initial pattern and starting drum parameters and starting sample to play
    // copy paste relevant functions from main code.
    i want to then create an array of 8 objects of this Measure class. Problem arise when i uncomment
    //#include <Measure.h> line.
    Measure
    #include <WS2812Serial.h>
    //WAV Files
    #include "AudioSampleData.h"
    AudioPlayMemory          sound1;//bd
    AudioPlayMemory          sound2;//sd
    AudioPlayMemory          sound3;//hh
    AudioPlayMemory          sound4;//tom
    AudioSynthSimpleDrum     drum4;
    AudioSynthSimpleDrum     drum2;
    AudioSynthSimpleDrum     drum3;
    AudioSynthSimpleDrum     drum1;
    float freqSettings[24] = {65.4, 98.0, 130.8, 164.8, 196.0, 261.6, 329.6, 392.0,
                              523.5, 659.2, 784, 1046.5, 1568.0, 2093.0, 2637.0, 3136.0, 4186.0, 5274.0, 6272.0, 8500.0,
                              10000.0, 11000.0, 12000.0, 14000.0
    #define NUMFREQS sizeof(freqSettings)
    int drumFreqCount[4] = {3, 0, 8, 12};
    int drumLengthCount[4] = {15, 3, 4, 2};
    int drumSecondMixCount [4] = {0, 0, 10, 0};//increments of .1
    int drumPitchModCount [4] = {6, 10, 0, 5};
    AudioMixer4              mixer1;
    AudioMixer4              mixer2;
    AudioMixer4              mixer3;
    AudioOutputAnalogStereo  dacs1;
    AudioConnection          patchCord1(sound1, 0, mixer2, 0);//bd
    AudioConnection          patchCord2(sound2, 0, mixer2, 1);//hh
    AudioConnection          patchCord3(sound3, 0, mixer2, 2);//sd
    AudioConnection          patchCord6(sound4, 0, mixer2, 3);//tom
    AudioConnection          patchCord4(drum4, 0, mixer1, 3);
    AudioConnection          patchCord5(drum2, 0, mixer1, 1);
    AudioConnection          patchCord7(drum3, 0, mixer1, 2);
    AudioConnection          patchCord8(drum1, 0, mixer1, 0);
    AudioConnection          patchCord9(mixer2, 0, mixer3, 1);
    AudioConnection          patchCord10(mixer1, 0, mixer3, 0);
    AudioConnection          patchCord11(mixer3, 0, dacs1, 0);
    AudioConnection          patchCord12(mixer3, 0, dacs1, 1);
    //variables
    static uint16_t bpm = 120;
    static uint16_t rez = 4;// smallest musical time
    static uint16_t tempo = (double)((60000) / (bpm * rez));
    static uint32_t next;
    static uint16_t beat = 0;
    static uint16_t voiceSelect = 0;
    static uint8_t current_kick_sample = 0;
    static uint8_t current_snare_sample = 0;
    int Val;
    /*---------------------------------LEDs------------------------------------------*/
    const int numled = 19;
    const int pin = 10;
    byte drawingMemory[numled * 3];
    DMAMEM byte displayMemory[numled * 12];
    WS2812Serial leds(numled, displayMemory, drawingMemory, pin, WS2812_GRB);
    #define RED    0xFF0000
    #define GREEN  0x00FF00
    #define BLUE   0x0000FF
    #define YELLOW 0xFFFF00
    #define PINK   0xFF1088
    #define ORANGE 0xE05800
    #define WHITE  0xFFFFFF
    #define BLACK 0X000000
    /*--------------------------------BUTTONS------------------------------------------*/
    //buttons
    byte buttons [] = {12, 24, 25, 26, 27, 28, 29, 30, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9};// THE PIN THE BUTTONS ARE ON,
    #define NUMBUTTONS sizeof(buttons)
    byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
    byte previous_keystate[NUMBUTTONS], current_keystate[NUMBUTTONS];
    #define DEBOUNCE 15  // button debouncer, how many ms to debounce,
    /*----------------------------------drum patterns----------------------------------*/
    boolean pattern [8][16] = {{0, 0, 0, 0, 0, 0, 0, 0 , 0, 0, 0, 0, 0, 0, 0, 0},
    int machineState = 0;
      leds.begin();
      // audio library init
      AudioMemory(20);
      next = millis() + 1000;
      AudioNoInterrupts();
      //button setup
      for (byte i = 0; i < NUMBUTTONS; i++)
        pinMode(buttons[i], INPUT);
        digitalWrite(buttons[i], HIGH);
      /*-------------------------------set up pots---------------------------------------*/
      Val = analogRead(A0);
      /*---------------------------------Initialise drum voices--------------------------*/
      //drum setup
      changeDrumParameters();
      mixer1.gain(0, 0.4);
      mixer1.gain(1, 0.4);
      mixer1.gain(2, 0.4);
      mixer1.gain(3, 0.4);
      //sample setups
      mixer2.gain(0, 0.4);
      mixer2.gain(1, 0.7);
      mixer2.gain(2, 0.1);
      mixer2.gain(3, 0.4);
      AudioInterrupts();
    /*--------------------------ok here we go------------------------------------------*/
      //inputs
      byte thisSwitch = thisSwitch_justPressed();
      if (thisSwitch < 16 && machineState == 1)
        pattern[voiceSelect][thisSwitch] = !pattern[voiceSelect][thisSwitch];
        if (machineState == 0)
          switch (thisSwitch)
              if (voiceSelect >= 0 && voiceSelect <= 4)
              case 0:
                if (drumFreqCount[voiceSelect] > 0)
                  drumFreqCount[voiceSelect]--;
              case 1:
                if (drumFreqCount[voiceSelect] < NUMFREQS - 1)
                  drumFreqCount[voiceSelect]++;
              case 2:
                if (drumLengthCount[voiceSelect] > 1)
                  drumLengthCount[voiceSelect]--;
              case 3:
                if (drumLengthCount[voiceSelect] < 20)
                  drumLengthCount[voiceSelect]++;
              case 4:
                if (drumSecondMixCount [voiceSelect] > -20)
                  drumSecondMixCount [voiceSelect]--;
              case 5:
                if (drumSecondMixCount [voiceSelect] < 20)
                  drumSecondMixCount [voiceSelect]++;
              case 6:
                if (drumPitchModCount [voiceSelect] > -9)
                  drumPitchModCount [voiceSelect]--;
              case 7:
                if (drumPitchModCount [voiceSelect] < 9)
                  drumPitchModCount [voiceSelect]++;
            case 8:
              voiceSelect = 0;
              drum1.noteOn();
            case 9:
              voiceSelect = 1;
              drum2.noteOn();
            case 10:
              voiceSelect = 2;
              drum3.noteOn();
            case 11:
              voiceSelect = 3;
              drum4.noteOn();
            case 12:
              voiceSelect = 4;
                current_kick_sample = (current_kick_sample + 1) % 16;
                select_kick_sample();
            case 13:
              voiceSelect = 5;
                current_snare_sample = (current_snare_sample + 1) % 16;
                select_snare_sample();
            case 14:
              voiceSelect = 6;
              sound3.play(AudioSampleHihat);
            case 15:
              voiceSelect = 7;
              sound4.play(AudioSampleTomtom);
      if (thisSwitch == 16)
        leds.setPixel(16 + machineState, BLACK);
        machineState = (machineState + 1) % 3;
        leds.setPixel(16 + machineState, ORANGE);
        leds.show();
      /*----------------------------------drum patterns-clear----------------------------*/
      if (thisSwitch == 17)//clear all
        for (uint8_t  i = 0; i < 8; i++)
          for (uint8_t  j = 0; j < 16; j++)
            pattern[i][j] = 0;
      /*-----------------------------------sequencer-------------------------------------*/
      static uint32_t num = 0;
      if (millis() >= next)
        int Val = analogRead(A0);
        bpm = map(Val, 0, 1023, 40, 250);
        Serial.print(bpm);
        Serial.println("     ");
        Serial.print("machineState is : ");
        Serial.println(machineState);
        leds.setPixel(beat, BLACK);
        leds.show();
        beat = num % 16;
        if (beat % 4 == 0)
          leds.setPixel(beat, RED);
          leds.setPixel(beat, BLUE);
        for (uint8_t i = 0; i < 16; i++)
          if (pattern[voiceSelect][i])
            leds.setPixel(i, GREEN);
        leds.show();
        if (pattern[0][beat])
          drum1.noteOn();
        if (pattern[1][beat])
          drum2.noteOn();
        if (pattern[2][beat])
          drum3.noteOn();
        if (pattern[3][beat])
          drum4.noteOn();
        if (pattern[4][beat])
        if (pattern[5][beat])
        if (pattern[6][beat])
        if (pattern[7][beat])
        num++;
        next = millis() + tempo;
    void select_kick_sample() {
      switch (current_kick_sample) {
        case 0:
          sound1.play(AudioSampleKick);
        case 1:
          sound1.play(AudioSampleKick_01);
        case 2:
          sound1.play(AudioSampleKick_02);
        case 3:
          sound1.play(AudioSampleKick_03);
        case 4:
          sound1.play(AudioSampleKick_04);
        case 5:
          sound1.play(AudioSampleKick_05);
        case 6:
          sound1.play(AudioSampleKick_06);
        case 7:
          sound1.play(AudioSampleKick_07);
        case 8:
          sound1.play(AudioSampleKick_08);
        case 9:
          sound1.play(AudioSampleKick_09);
        case 10:
          sound1.play(AudioSampleKick_10);
        case 11:
          sound1.play(AudioSampleKick_11);
        case 12:
          sound1.play(AudioSampleKick_12);
        case 13:
          sound1.play(AudioSampleKick_13);
        case 14:
          sound1.play(AudioSampleKick_14);
        case 15:
          sound1.play(AudioSampleKick_15);
        case 16:
          sound1.play(AudioSampleKick_16);
    void select_snare_sample() {
      switch (current_snare_sample) {
        case 0:
          sound2.play(AudioSampleSnare);
        case 1:
          sound2.play(AudioSampleSnare_01);
        case 2:
          sound2.play(AudioSampleSnare_02);
        case 3:
          sound2.play(AudioSampleSnare_03);
        case 4:
          sound2.play(AudioSampleSnare_04);
        case 5:
          sound2.play(AudioSampleSnare_05);
        case 6:
          sound2.play(AudioSampleSnare_06);
        case 7:
          sound2.play(AudioSampleSnare_07);
        case 8:
          sound2.play(AudioSampleSnare_08);
        case 9:
          sound2.play(AudioSampleSnare_09);
        case 10:
          sound2.play(AudioSampleSnare_10);
        case 11:
          sound2.play(AudioSampleSnare_11);
        case 12:
          sound2.play(AudioSampleSnare_12);
        case 13:
          sound2.play(AudioSampleSnare_13);
        case 14:
          sound2.play(AudioSampleSnare_14);
        case 15:
          sound2.play(AudioSampleSnare_15);
        case 16:
          sound2.play(AudioSampleSnare_16);
    byte thisSwitch_justPressed()
      byte thisSwitch = 255;
      check_buttons();  //check the switches &amp; get the current state
      for (byte i = 0; i < NUMBUTTONS; i++) {
        current_keystate[i] = justpressed[i];
        if (current_keystate[i] != previous_keystate[i]) {
          if (current_keystate[i]) thisSwitch = i;
        previous_keystate[i] = current_keystate[i];
      return thisSwitch;
    /*-------------------------------PROGRAM THE DRUM SOUND PARAMETERS-----------------*/
    void changeDrumParameters()
      drum1.frequency(freqSettings[drumFreqCount[0]]);
      drum1.length(drumLengthCount[0] * 100);
      drum1.secondMix(drumSecondMixCount [0] * 0.1);
      drum1.pitchMod(drumPitchModCount [0] * 0.1);
      drum2.frequency(freqSettings[drumFreqCount[1]]);
      drum2.length(drumLengthCount[1] * 100);
      drum2.secondMix(drumSecondMixCount [1] * 0.1);
      drum2.pitchMod(drumPitchModCount [1] * 0.1);
      drum3.frequency(freqSettings[drumFreqCount[2]]);
      drum3.length(drumLengthCount[2] * 100);
      drum3.secondMix(drumSecondMixCount [2] * 0.1);
      drum3.pitchMod(drumPitchModCount [2] * 0.1);
      drum4.frequency(freqSettings[drumFreqCount[3]]);
      drum4.length(drumLengthCount[3] * 100);
      drum4.secondMix(drumSecondMixCount [3] * 0.1);
      drum4.pitchMod(drumPitchModCount [3] * 0.1);
    /*-----------------------------------CHECK BUTTONS---------------------------------*/
    void check_buttons()
      static byte previousstate[NUMBUTTONS];
      static byte currentstate[NUMBUTTONS];
      static long lasttime;
      byte index;
      if (millis() < lasttime) {
        lasttime = millis(); // we wrapped around, lets just try again
      if ((lasttime + DEBOUNCE) > millis()) {
        return; // not enough time has passed to debounce
      // ok we have waited DEBOUNCE milliseconds, lets reset the timer
      for (index = 0; index < NUMBUTTONS; index++)
        justpressed[index] = 0;       // when we start, we clear out the "just" indicators
        justreleased[index] = 0;
        currentstate[index] = digitalRead(buttons[index]);   // read the button
        if (currentstate[index] == previousstate[index]) {
          if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
            // just pressed
            justpressed[index] = 1;
          else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
            // just released
            justreleased[index] = 1;
          pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
        //Serial.println(pressed[index], DEC);
        previousstate[index] = currentstate[index];   // keep a running tally of the buttons
    Nov 2018
    tassie
    15
    i hope i have followed the forum rules.... i didnt post complete code - omitting only reams of sample data generated by wave to sketch.
    9,060
    I read this and left unfound was the nature and detail of what this means :: "Problem arise ..."
    Were there build error messages or something showing the nature of the problem?
    20,323
    Quote Originally Posted by r00n View Post
    You need to use quotes for this include, not angle brackets.
    Use of <Measure.h> means the file Measure.h is to be found only in a library, not as part of your program.
    Next time you post a program for us to look at, please copy and paste it back into an empty Arduino window and click Verify. If it doesn't verify, please take a moment to delete or comment out the *many* lines that don't compile because something is missing. YOU are the one familiar with your own code, so please do this before you ask others to look at it.
    Nov 2018
    tassie
    15
    will do this for sure. I hate to waste anyone's time, including my own.
    the problem is solved thanks.
