Results 1 to 3 of 3
Thread: Potentiometer Q. Teensy 3.2 and existing electronics
    Dec 2018
    Silver Spring, MD
    1
    Hi all, New here and hoping to get a bit of guidance. I am working on a program that will use a teensy to turn on an android box in the car to power a simple carputer. I have sorted how to get the device to turn on and now i'm working on a way to get the screen to go into standby. I have accomplished this using a simple switch sensor, but now i cant find a place to mount the sensor. The screen in my car opens and closes, its a 2004 RX-8. I found out that the OEM system uses a potentiometer for screen position, and other users have replaced the entire system with arduino and tapped this pot for screen position. Essentially what i want to do is tell the teensy, the screen is up or its down. I think i sorted the code part. I will include below and you guys can tell me if you see something weird or that could be better.
    The question is, can i connect the middle pin of the pot directly to the teensy analog pin in parallel with the existing electronics? The current setup controls opening and closing the screen, so i want to keep that working. my thought was to just pigtail a lead from the existing wiring to the teensy, and then read the pot positions and alter the code accordingly for open and closed positions. I guess what i'm asking is, do all 3 leads from the pot need to be connected to the teensy for it to work, or if it has power and ground from somewhere else can i still get a signal?
    Below is my code in case anyone wants to take a look.
    THANKS,
    RON
    // Constant Variables for comparison
    const int HoodClosedValue = 950; //suspected pot value for closed
    const int HoodPosTolerance = 10; //tolerance stolen from somewhere else
    const int HoodOpen = 1; //defined placeholder because there is
    //more than one open position
    const int HoodClosed = 0; // only one closed position
    // CurrentState is the new read state from the pot from Nav Hood
    // Old State is the previous state stored in memory
    // these values are compared and if a change is registered
    // the standby button is pressed. (actualy a virtual button)
    int HoodState = 0; //used for initial hood pos function
    int CurrentState = 0; //stored value for now
    int OldState = 0; //stored value for previous
    // 3 second delay before device turn on
    delay(3000);
    // pinMode(2, INPUT_PULLUP);
    // pin 2 is the nav hood sensor, old setup to test functionality
    pinMode(1, OUTPUT);
    // Power button input to android box
    digitalWrite(1, LOW);
    //pulse to turn device on
    pinMode(1, INPUT_PULLUP);
    //Release of power button
    delay(30000);
    // Gives 23 seconds for device to boot
    // This is the check to see if hood is intitially up or down
    // If open this does nothing, and loop starts after
    // matching the old and new state for loop
    HoodState=analogRead(A9);
    if (HoodState < (HoodClosedValue-HoodPosTolerance)) {
    OldState=HoodOpen;
    // This records the oldstate as open for the loop
    // If closed, this puts device into standby mode
    else {
    pinMode(1, OUTPUT);
    delay(300);
    // this records the oldstate as closed for loop
    // functionality of standby feature
    OldState=HoodClosed;
    //Checks current hood position
    CurrentState = HoodOpen;
    else {
    CurrentState = HoodClosed;
    // If position has changed since intialization
    // this pulses standby button
    if (CurrentState != OldState) {
    pinMode(1, OUTPUT);
    delay(300);
    OldState=CurrentState;
    delay(2000);
    2,028
    Quote Originally Posted by Capt.Ron View Post
    IMO, yes that seems the best: one outside pin goes to 3.3V, the other outside pin goes to ground, the middle pin goes to ADC (any Ax pin)
    Any outside electronics needs care (voltage > 5V may destroy T3.2)
    Feb 2014
    Colmar, France
    2,191
    I allow to add from the NXP application note: For stable conversion by the Teensy's integrated delta-sigma ADCs, the potentiometer's impedance should be less or equal than 10kOhm and a 10-100nF capacitor should be added between the wiper and GND.
