I am working on a project using a Teensy 3.6 that requires use of multiple I2C interfaces, hence I have converted the libraries I am using from Wire.h to i2c_t3.h
My problem is in converting the 'Adafruit_L3GD20_U' library provided by Adafruit for their IMU LSM303DLHC_L3GD20 (9 DOF) to use with i2c_t3. Found here: https://learn.adafruit.com/adafruit-9-dof-imu-breakout/software
I have includes to i2c_t3, but the library header file uses the TwoWire data type.
Adafruit_L3GD20_U.h partial code (found in full from the link above)
The error message I receive is as follows:
In file included from F:\Documents\Work\Hardware projects\Sensors\IMU_LSM303DLHC_L3GD20\IMU_LSM303DLHC_L3GD20.ino:4:0:
F:\Documents\Arduino\libraries\Adafruit_L3GD20_U-master/Adafruit_L3GD20_U.h:110:65: error: 'TwoWire' has not been declared
bool begin ( gyroRange_t rng = GYRO_RANGE_250DPS, TwoWire *theWire=&Wire);
F:\Documents\Arduino\libraries\Adafruit_L3GD20_U-master/Adafruit_L3GD20_U.h:110:83: error: could not convert '& Wire' from 'i2c_t3*' to 'int*'
From what I understand, the TwoWire type does not exist in i2c_t3 and needs changing to work with the i2c_t3 library, but I don't know how to go about doing this having spent time doing research.
Any help is appreciated, I have reasonable experience writing and editing libraries, but this lower level communication stuff is my weakness!
Also this is my first forum post, so I apologise in advance if anything is not clear. I can provide more information if necessary.
Full Adafruit Adafruit_L3GD20_U.h Code:
class Adafruit_L3GD20_Unified : public Adafruit_Sensor
public:
Adafruit_L3GD20_Unified(int32_t sensorID = -1);
bool begin ( gyroRange_t rng = GYRO_RANGE_250DPS, TwoWire *theWire=&Wire); //The problem is on this line
void enableAutoRange ( bool enabled );
bool getEvent ( sensors_event_t* );
void getSensor ( sensor_t* );
This is a library for the L3GD20 GYROSCOPE
Designed specifically to work with the Adafruit L3GD20 Breakout
----> https://www.adafruit.com/products/1032
These sensors use I2C or SPI to communicate, 2 pins (I2C)
or 4 pins (SPI) are required to interface.
products from Adafruit!
Written by Kevin "KTOWN" Townsend for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#ifndef __L3GD20_H__
#define __L3GD20_H__
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#include <Adafruit_Sensor.h>
#include <i2c_t3.h>
I2C ADDRESS/BITS AND SETTINGS
#define L3GD20_ADDRESS (0x6B) // 1101011
#define L3GD20_POLL_TIMEOUT (100) // Maximum number of read attempts
#define L3GD20_ID (0xD4)
#define L3GD20H_ID (0xD7)
// Sesitivity values from the mechanical characteristics in the datasheet.
#define GYRO_SENSITIVITY_250DPS (0.00875F)
#define GYRO_SENSITIVITY_500DPS (0.0175F)
#define GYRO_SENSITIVITY_2000DPS (0.070F)
REGISTERS
typedef enum
{ // DEFAULT TYPE
GYRO_REGISTER_WHO_AM_I = 0x0F, // 11010100 r
GYRO_REGISTER_CTRL_REG1 = 0x20, // 00000111 rw
GYRO_REGISTER_CTRL_REG2 = 0x21, // 00000000 rw
GYRO_REGISTER_CTRL_REG3 = 0x22, // 00000000 rw
GYRO_REGISTER_CTRL_REG4 = 0x23, // 00000000 rw
GYRO_REGISTER_CTRL_REG5 = 0x24, // 00000000 rw
GYRO_REGISTER_REFERENCE = 0x25, // 00000000 rw
GYRO_REGISTER_OUT_TEMP = 0x26, // r
GYRO_REGISTER_STATUS_REG = 0x27, // r
GYRO_REGISTER_OUT_X_L = 0x28, // r
GYRO_REGISTER_OUT_X_H = 0x29, // r
GYRO_REGISTER_OUT_Y_L = 0x2A, // r
GYRO_REGISTER_OUT_Y_H = 0x2B, // r
GYRO_REGISTER_OUT_Z_L = 0x2C, // r
GYRO_REGISTER_OUT_Z_H = 0x2D, // r
GYRO_REGISTER_FIFO_CTRL_REG = 0x2E, // 00000000 rw
GYRO_REGISTER_FIFO_SRC_REG = 0x2F, // r
GYRO_REGISTER_INT1_CFG = 0x30, // 00000000 rw
GYRO_REGISTER_INT1_SRC = 0x31, // r
GYRO_REGISTER_TSH_XH = 0x32, // 00000000 rw
GYRO_REGISTER_TSH_XL = 0x33, // 00000000 rw
GYRO_REGISTER_TSH_YH = 0x34, // 00000000 rw
GYRO_REGISTER_TSH_YL = 0x35, // 00000000 rw
GYRO_REGISTER_TSH_ZH = 0x36, // 00000000 rw
GYRO_REGISTER_TSH_ZL = 0x37, // 00000000 rw
GYRO_REGISTER_INT1_DURATION = 0x38 // 00000000 rw
} gyroRegisters_t;
OPTIONAL SPEED SETTINGS
typedef enum
GYRO_RANGE_250DPS = 250,
GYRO_RANGE_500DPS = 500,
GYRO_RANGE_2000DPS = 2000
} gyroRange_t;
RAW GYROSCOPE DATA TYPE
/** Encapsulates a single raw data sample from the sensor. */
typedef struct gyroRawData_s
/** The X axis data. */
int16_t x;
/** The Y axis data. */
int16_t y;
/** The Z axis data. */
int16_t z;
} gyroRawData_t;
* Driver for the Adafruit L3GD20 3-Axis gyroscope.
public:
/** Raw sensor data from the last successful read event. */
gyroRawData_t raw;
private:
void write8 ( byte reg, byte value );
byte read8 ( byte reg );
gyroRange_t _range;
int32_t _sensorID;
bool _autoRangeEnabled;
/* Non Unified (old) driver for compatibility reasons */
typedef gyroRange_t l3gd20Range_t;
typedef gyroRegisters_t l3gd20Registers_t;
* Encapsulates a single XYZ data sample from the sensor.
typedef struct l3gd20Data_s
/** Data from the X axis. */
float x;
/** Data from the Y axis. */
float y;
/** Data from the Z axis. */
float z;
} l3gd20Data;
/// @private
public:
Adafruit_L3GD20(int8_t cs, int8_t mosi, int8_t miso, int8_t clk);
Adafruit_L3GD20(void);
bool begin ( l3gd20Range_t rng=GYRO_RANGE_250DPS, byte addr=L3GD20_ADDRESS );
void read ( void );
l3gd20Data data; // Last read will be available here
private:
void write8 ( l3gd20Registers_t reg, byte value );
byte read8 ( l3gd20Registers_t reg );
uint8_t SPIxfer ( uint8_t x );
byte address;
l3gd20Range_t range;
int8_t _miso, _mosi, _clk, _cs;
