mark.winger
I am using a teensy 3.5 to build a midi controller with scribble strips.
Using the adafruit st7735 libraries to control the 1.8" tft shield for prototyping.
It appears that no matter what pin I use for tft_cs in the tft object it always uses pin 10. (used graphicstest.ino as sample). I started with:
#define TFT_CS 10
#define TFT_RST 9 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC 8
The created and array for TFT_CS:
int SelectDisplay[DISPLAY_COUNT] = {21, 22};
Then initialized this way:
for (int i = 0 ; i < DISPLAY_COUNT; i++)
tft = new Adafruit_ST7735(SelectDisplay, TFT_DC, TFT_RST);
tft->initR(INITR_BLACKTAB); // Init ST7735S chip, black tab
No matter what pins I use for select, the initR clears the first display when I initialize the second and I cannot display to it. If I set DISPLAY_COUNT to 1 it works fine. I don't have an oscilloscope available see what the signal lines are doing.
Why does this happen? Do I need to use other pins for DC and Reset as well?
Mark
#define TFT_CS 10
#define TFT_DC 8
Mark
