Hi everyone.
I'm working on a project and I'm using the Snooze library to put my Teensy 3.2 on sleep mode. I am using the RTC module to wake it up and I am doing some testing.
What I have found so far is that the RTC module is not running while the Teensy is sleeping.
Basically I am powering my project from a 5V power supply. I have soldered the small crystal for the RTC module. I am using USB to debug my project
and most importantly I am writing sleeping time in the EEPROM to check what was stored when it went to sleep and what is the current time before sleeping.
So basically I have noticed that the difference between when it goes to sleep and it wakes up is of a few seconds due to my project running and not 10 minutes like
it should be. Because if I put it to sleep at 20.00 then when it wakes up the current time should be greater than 20.10 at most but it isn't. It's just a couple of seconds later
due to other code running before the time is printed on my laptop. So why is this happening? Anyone has got an idea?
