Results 1 to 9 of 9
Thread: Disconnect Pin in Software
    Dec 2018
    3
    Is there any way to have a pin disconnected via software?
    I've built a PCB for a LED strip project but realised I may need to use a serial port pin for the strip's data signal due to interrupt issues. If I simply add a jumper wire from the new pin over to the old, is there a way (via software) to stop the original pin interfering with the signal? Ultimately, I could probably just cut out the original pin's connector but I'm just trying a less destructive approach first.
    Thanks!
    Feb 2014
    Colmar, France
    2,174
    Possible. Depends a little from which pin. The chapter 10 of the Teensy 3.2 and 3.5 processor reference manuals and chapter 11 for the T 3.6 explains the pin signal multiplexing and gives hints on how to set the corresponding pin multiplexer register to the Alt0 function which in most cases is a passive high-z mode.
    7,576
    Is this the right answer?
    ... use INPUT_DISABLE to put the pin back to a mode where the digital circuitry (with slight leakage current) is turned off.
    Feb 2014
    Colmar, France
    2,174
    That’s probably a right answer but the OP wouldn’t learn as much from that as if he had studied the reference manual...
    7,576
    Quite right on learning … though so many manuals I find it easier to read the forum and the code. _DISABLE probably isn't in the manual but something PJRC codified to restore the power up 'passive high-z' state.
    For inquiring minds look at :: ...\hardware\teensy\avr\cores\teensy3\pins_teensy. c for void pinMode(uint8_t pin, uint8_t mode) where this happens:
    else { // INPUT_DISABLE
    			*config = 0;
    Dec 2018
    3
    Thanks for the answers, I appreciate the help.
    Even I agree on the learning - Having an answer with an explanation is always preferred as the problem is often not knowing where to start looking. In this case, I wasn't sure if it was a question primarly about Teensy, MCUs or basic electronics.
    Dec 2016
    Montreal, Canada
    2,915
    why would you jump a wire? some pins have multiple capabilities, like using the same pin for the led strip and serial
    by changing it’s MUX config
    Dec 2018
    3
    It's because the Non-Blocking WS2812 LED Library requires using a HW serial port.
    Dec 2016
    Montreal, Canada
    2,915
    ahh ok reread custom pcb with bad pin location, makes sense
    by default all pins are in a low power disabled state (hi-z) so don’t need to configure the “dummy pin”. just a wire jumper should do it and run library as normal
