Solved? |
Issue |
Who's working on it |
Comment |
DSP vector math lib, #356 |
fix in beta7, testing needed |
DMA problems, #412 |
SPI example crashes if infinite loop after result, #125 |
can't reproduce |
SAI2 clock issue, #519 |
random() wrong output, #566 |
IntervalTimers called twice, low performance, #830, #880 #884, #1164, #1180, #1182, #1183,only 2 of 4 |
arm errata 838869, #1191, |
IntervalTimer priority() not implemented, #261 |
TRNG config, #1074, #642, |
power off program requires 13 sec recovery, #370 |
audio programs sometimes block auto-reboot, #1394, #1433, |
Arduino IDE unresponsive at times, #1376, #1377, #1379, #1385, #1417, #1432, |
PC unable to boot with BIOS post "partial" while Teensy4 connected, #409 |
slow USB enumeration with Amazon Basics hub, #1426, #866, , |
USB doesn't work at low clocks, #913, #916, #1070 |
DMA & cache trouble, #1061-1062, |
NIC-301 settings? #1065, |
F() and PSTR() in both C & C++ |
PROGMEM issue with ILI9341_t4, #1158, |
CPU speed set may not be switching IPG safely, but how? |
bootloader to use low power modes |
Arduino serial monitor doesn't freeze when autoscroll turned off, #1154, |
Arduino serial monitor can't copy remaining text to clipboard after device disconnects & window is disabled, #1154, |
HardwareSerial RTS/CTS |
I believe implemented needs testing |
USB MIDI |
DMAChannel |
edma works, tested with only one channel so far (frank b) - it needs attention with cache!! |
Tested |
arm_math.h |
manitou |
see post #85 and post #204 |
USB keyboard |
USB mouse |
USB joystick |
USB flightsim |
USB MTP |
USB MIDI name override |
USB Touchscreen |
USB Audio |
USB RawHID |
C++ stdlib functions? |
SPIFIFO - is anything really using this? |
Pls test |
pulseIn |
Frank B |
depends on exact micros() ** micros() exact now |
Pls test |
shiftIn |
Frank B |
Pls test |
shiftOut |
Frank B |
Done |
random |
manitou |
is sequence same for same seed vals? |
analogWrite gracefully handles 0, 255, 256, negative & other illegal values |
testing needed (most cases look ok) |
Wire - recovery from hung bus |
Wire - slave mode |
Fixed |
Wire -SetSCL/setSDA support Wire1 pins on sd card pins |
KurtE |
fixed: PR #14 |
Old - more in place |
SPI |
minimal code in beta3 |
Fixed |
SPISettings not used, clock fixed at 12.5 MHz, #428 |
some support in beta7 (thanks Manitou) |
AVR GPIO register emulation |
AVR SPI register emulation |
AVR TWBR register emulation |
Adafruit ILI3941 doesn't compile, AVR emulation needed, #537 |
Sparkfun Teensyview not compiling, #545 |
Ethernet |
needs IPAddress.cpp |
SoftwareSerial |
Have similar using FlexIO system |
OctoWS2811 |
ILI9341_t3 |
KurtE's PR#52 to the lib supports T4 |
WS2812Serial |
AltSoftSerial |
not ported, #999, |
CapacitiveSensor |
in beta6, testing needed |
DmxSimple |
FreqCount |
FreqMeasureMulti |
PulsePosition |
MIDI |
ShiftPWM |
Snooze |
TeensyThreads, working, #496 |
TimerThree |
Tlc5940 |
fault after coremark using 50000, msg #117 |
Prevent Fault Edit Post #651 |
Shutdown when temperature is "critical" (?) (added by Frank B) |
Add events for temperature is "hot" + "cold" again (?) (added by Frank B) |
Tools > Optimize "Fastest + pure-code" fails, maybe gcc bug? |
VGA library |
Solved? |
Does bootloader & 15-sec restore process work with all possible default FlexRAM settings in HW_OCOTP_MISC_CONF0? Can all 1s setting brick Teensy4? |
Fast printing to Serial Monitor causes Java out of heap memory exception (Windows, Raspberry Pi), #2769, #2772, |
Fixed |
SPI1 & SPI2 support, #2404, #2409, #2482, #2488, #2493, #2518, |
SPI signal drive strength, #2500, |
NO USB option doesn't compile, #2538, |
Touchsceeen lib, #2550, |
WIP |
yield() performance issue, #2559, |
KurtE |
See posting #3244 PR #379 |
post-linker check needed for ITCM+DTCM > 512K |
USB benchmarks: #2597, #2602, #2626, #2628, #2717, #2730, #2756, |
CPU benchmarks: #2725, #2729, |
SdFat issues, #2685, #2755, #3135 |
Java heap memory exception: Windows, Mac, Raspberry Pi, #2746, #2772, #2776, #2778, |
2804 : after TeensyDuino install if T4 prior board - it is not set on starting |
issue reading MP3115 pressure sensor with Wire library, #2999, #3006, #3019 (workaround), |
WavFilePlayer issue with BUILTIN_SDCARD, #3008, |
SD lib datalogger issue, #3135, |
AudioLib PT8211 fails #3413, |
AUdioLib for PT8211 broke with TD1.46 - can't test? |
Lost USB on Sketch Run |
UncannyEyes loses USB on Run unless..See posts#3699 - 3701, 3710-3744, & 3772. |
DMAMUX defs wrong, #4079, |
Solved? |
Issue |
Comment |
