Page 10 of 174 FirstFirst ... 8 9 10 11 12 20 60 110 ... LastLast
Results 226 to 250 of 4350
  1. #226
    20,682
    I've uploaded 1.46-beta5. Links are on msg #2. I also left the 1.46-beta4 links in places, since put this one together in a hurry. Hopefully it works ok. Rolls up the many small edits to files, and attachInterrupt, (hopefully) improved C++ constructors, tone, EventResponder, MillisTimer and yield().
    I need to step away for several hours. Will be back later this afternoon.
  2. #227
    4,207
    Enjoy your day and get some R&R, I hope.
  3. #228
    2,231
    @manitou -
    Guess I can't sleep - too much goes on when I wake up
    Thanks for the files. By the way I tried running the CMSIS Neural Network library but it needed two additional files:
    arm_const_structs.h
    arm_common_tables.h
    I just copied these from the main cmsis GitHub page but not sure it they are correct for your version.
    OK, thanks. I updated the dsp.zip file (ref post #204)
  4. #229
    2,366
    C compilation issue
    In a previous post I show a sketch that sets the Audio PLL
    It has the following lines
    #define CCM_ANALOG_PLL_AUDIO_NUM_MASK ((uint32_t)((1<30)-1))
    #define CCM_ANALOG_PLL_AUDIO_DENOM_MASK ((uint32_t)((1<30)-1))
    needs to be replaced by
    #define CCM_ANALOG_PLL_AUDIO_NUM_MASK (((1<29)-1))
    #define CCM_ANALOG_PLL_AUDIO_DENOM_MASK (((1<29)-1))
    otherwise the fractional PLL does not work as expected
  5. #230
    5,562
    Thanks Paul, Hopefully for next beta I will have more serial support ready. Have some stuff in place to start doing reads, but looks like I need to get better understanding of the FIFO stuff and initializing it, which is not a bad thing to do anyway. Looks like the FIFO register actually has the sizes of the TX and RX fifos for each one. I probably need to set the watermark register values. Also not clear if the ISR should use the STAT values to control RX/TX or the FIFO register... So have some experimenting to do.
    Looks like the test run shows a vtable being created and init as the dump shows non zero values, so looks promising.
  6. #231
    2,231
    Upgraded to 1.46-beta5.
    Using GPS PPS on pin 12 with attachInterrupt(), I measured crystal drift for 24mhz crystal (-3.2 ppm) and 32khz crystal (-4.7 ppm) using free running GPT timer in gpsgpt.ino. I'm not sure what the crystal specs are ...
    Even with beta5 (on 32-bit linux with 1.8.8), I still have to push program button after upload to get the IDE serial monitor to come to life ??
  7. #232
    4,207
    PWMServo Library
    Tested the sweep example with the scope on pins 0, 1, 2, and 3.
    1. On pins 0 and 1 the signal starts low goes when the sweep starts and the pulse widens from right to left as the sweep angle increases and then decreases as the angle decrease.
    2. On pins 2 and 3 this is reversed. The signal starts high goes low as the pulse starts and as the sweep angle increases the pulse width increases from right to left and decrease left to right as the angel decreases
    3. With sketch not running pins 0,1 are low while 2,3 are high.
    4. The frequency is 50khz with a period of 20ms
    Is this the way it should be?
    EDIT: Just repeated the sweep test on a T3.5 and looks 1 and 3 match.
  8. #233
    Dec 2016
    Montreal, Canada
    3,116
    You can use this for fast toggling of LED:
    GPIO2_DR_TOGGLE |= (1UL << 3);
  9. #234
    Germany NRW
    5,679
    I'd like to add delayNansoseconds(uint32_t).
    https://github.com/PaulStoffregen/co...f279114e4b6b53
    It is useful for short wait-times. Could be used for PulseIn etc.
    No very exact, but at least it is useful for delays of about half a microsecond or less, which is not that easy now.
  10. #235
    2,231
    coremarkish plot
    T4 beta (1050)
    Changed CPU speed in startup.c (set_arm_clock()) for coremark compiled Fastest (-03).
    MHz   Iterations/sec power (ma)
     24      96.78        36.2
    120     485.2         49.9
    288    1165           62.4
    396    1602           67.6
    600    2427.4         94.1
    About 4 iterations/MHz.
    Unsurprisingly, similar to EVKB tests
    EDIT: 8/14/19 production T4 (1062) CoreMark power & temperature -O3
    MHz   Iterations/sec power(ma) temp ℃
     24     123.4         35.4      36.67
    120     494.6         53.7      40.35
    180     742.1         54.9      41.58
    288    1188.3         68.1      44.04
    396    1632.9         77.4      45.26
    528    2177.4         85.7      47.11
    600    2474.4        105.5      50.79
    If you run at 528 MHz or lower, the CPU runs at a slightly lower voltage (1.15V instead of 1.25V), which really reduces the power consumption. At 24 MHz or lower the voltage is 0.95V (see hardware/teensy/avr/cores/teensy4/clockspeed.c). MCU temperature measured with tempmonGetTemp().
    See NXP's 1060 power consumption
  11. #236
    4,207
    Crystal Drift
    Using @manitou gptgps.ino sketch to measure crystal drift I got somewhat different results:
    Clock         manitou         mjs513
    24mhz         -3.2            -16.3
    32khz         -4.7             28.7
  12. #237
    Germany NRW
    5,679
    PWMServo Library
    Do you mean 50Hz? 50Hz is perfect for servos (if I remember correctly after ~25yrs when I used them)
    50Hz would match the 20ms, too..
  13. #238
    9,945
    Installed TD 1.45b5 and 2 prior sketches working without change! I see setup entry millis jumped to 300+ and Serial online about 100 ms later too. I killed that annoying usb "status =" debug spew.
    Paul - Koromix sent me a version of TyCommander that recognizes Teensy 4.0 - can now issue reboot and bootloader commands. I've sent him verbose feedback for his review - not hit UPLOAD yet.
    >> Is there any unique twist to bootloader uploading versus Teensy 3.x's? Or is same exchange fully maintained through the bootloader chip?
    Since I had IntervalTimer to trigger WFI I set it to 2 us trigger and am seeing 498095 _isr calls/sec to inc a volatile global. Cut down the 21M loop/sec to 9.5 million.
    With IntTimer_isr running I started a print of a string of the alphabet each loop() - 63 letters with a newline, cycles A-Z ... except first 'Z' string is a \t so you can see it fly by.
    That drops the loop count to a mere 25K - which means 1,580,800 Bytes/sec out to SerMon? TyComm and T_sermon about the same - maybe a few more from T_sermon - but seems pegged on Windows.
    It times the 1 second interval with a elapsedMillis, toggles the LED and puts the micros to debug.print - it trigger +/- 10 us with clock resolution
    So the Serial Throughput is good - and not affected by the interval timer.
    It did lead to this JAVA HEAP Memory issue though:JavaHeapSpace.txt
    manitou - did you have the same Button needed upload with the sketch I linked? Or the one here? What OS? If so that is unique - maybe Paul can see something in a Loader Verbose log?
  14. #239
    9,945
    That looks nice Frank. The T_LC doesn't have a cycleCounter - but other T_3.x's do - would be nice to have that on at setup() for supported units??
  15. #240
    9,945
    coremarkish plot
     24      96.78        36.2
    120     485.2         49.9
    288    1165           62.4
    396    1602           67.6
    600    2427.4         94.1
    Yeah - but I want BARE METAL !!!! … oh wait … it's the same ? … but Arduino is for kids.
  16. #241
    Mar 2016
    Portland, OR
    537
    50 Hz is still the "standard" for servos.
  17. #242
    4,207
    @FrankB
    Yes I did, as you pointed out. Wanted to attach a servo to the board but all my servos are 5v and not sure what the signal is - don't want to short the T4.
    I agree with dragster on this. To go along the same lines maybe we should have a nanos() to go with millis and mircos?
  18. #243
    Germany NRW
    5,679
    Raspberry Pi:
    https://www.eembc.org/benchmark/repo...460&suite=CORE
    1.86 CoreMark / MHz, 1303.78 CoreMark @ 700MHz (-O2)
  19. #244
    Mar 2016
    Portland, OR
    537
    @FrankB
    The servo shouldn't have feedback over the signal line - I use a 3.3V signal to drive servos and power them anywhere from 5V to over 7.2V (high voltage servos) just fine with a Teensy 3.6.
  20. #245
    4,207
    Thanks Brian. Time to go dig out a servo. Have to remember where I put them all now
  21. #246
    5,562
    Hardware Serial: Currently trying to debug Serial.read(). Currently not getting an interrupt when data should arrive on data pin.
    Not sure yet if my configuration stuff for the LPUART or maybe the IO pin configuration stuff.
    SerialX::begin stat:c00000 ctrl:0 fifo:c00011 water:0
      FIFO sizes: tx:4 rx:4
      Watermark tx:2, rx: 2
        stat:800000 ctrl:2c0000 fifo:c00099 water:20002
    I have some new configuration stuff going on for FIFO and WATER... Current debug info shown above, where I believe that the
    Uart has fifo sizes of 4 and I tried to configure the water marks for 2 2 and enabled fifo...
    Still need to update the write part of ISR to stuff out as many bytes as possible... But trying to figure out why I am not getting any Serial inputs...
    tatic BUFTYPE tx_buffer1[SERIAL1_TX_BUFFER_SIZE];
    static BUFTYPE rx_buffer1[SERIAL1_RX_BUFFER_SIZE];
    const HardwareSerial::hardware_t UART6_Hardware = {
    	IRQ_LPUART6, &IRQHandler_Serial1,
    	CCM_CCGR3, CCM_CCGR3_LPUART6(CCM_CCGR_ON),
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03, // pin 0
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_02, // pin 1
    	2, // page 473
    	2, // page 472
    HardwareSerial Serial1(&IMXRT_LPUART6, &UART6_Hardware, tx_buffer1, SERIAL1_TX_BUFFER_SIZE,
    	rx_buffer1,  SERIAL1_RX_BUFFER_SIZE);
    Currently the code only changes the MUX configuration for the pins... (I have not changed this part). Looking at changes put into Wire, wonder if I need to update the
    actual pin definition. That is Should I also have pointers to: IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03 ...
    Or wondering if we should simply have the hardware definition here say it is pin 0, and then look up both: IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03 and IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03
    Especially if we have s setTX and setRX for multiple pins... I think I am leaning that way...
    Thoughts?
  22. #247
    Germany NRW
    5,679
    @FrankB
    Let's see what Paul says. If he accepts the PR, I'll add it for T3.x, and try nanos(). But delayNanoseconds() will be pretty inaccurate for slow F_CPUs. On the other hand +- 200ns are better than nothing
  23. #248
    Dec 2016
    Montreal, Canada
    3,116
    does that mean you could control leds/servos raw without using timers if the nanosecs are pretty accurate on T4?
  24. #249
    Germany NRW
    5,679
    LOL. You can measure the speed of light using servos, then.
    I didn't have enough beer to understand the (your) context
    I remember I wrote a servo controller for the C64 using wait-loops in assembler. uhh.. long ago..
    edit: ok..got it.. took long i meant shiftout which is too fast without delay, not pulsein..
  25. #250
    2,231
    Raspberry Pi:
    At the end of this file https://github.com/manitou48/DUEZoo/...aster/perf.txt I have some coremarkish numbers for MCU's that I have known...
