Page 113 of 175 FirstFirst ... 13 63 103 111 112 113 114 115 123 163 ... LastLast
Results 2,801 to 2,825 of 4368
Thread: Teensy 4.0 First Beta Test
  1. #2801
    11,837
    Msg #6 covers what I saw - adds at the end ...
    FWIW - the lps_test ran overnight - Serial send seems fast and clean to uninterrupted PC
    Was still running at ~210 lps since fresh restart - it is now in the ~170 range with firefox/sublime text open and active.
    These errors are all to be expected and recorded:
    > _____MISSED lines____ #2 {cpl=34} count=100000001, lines/sec=214334
    #3 was dos box Buffer copy
    #4 not in new buffer - safe to assume it showed new digit : #4 {cpl=35} count=1000000001
    > _____MISSED lines____ #5 {cpl=36} count=1, lines/sec=205467 // count=10 in same buffer
    > _____MISSED lines____ #6 {cpl=28} count=101, lines/sec=205467
    > _____MISSED lines____ #7 {cpl=29} count=1001, lines/sec=205467
    > _____MISSED lines____ #8 {cpl=30} count=10001, lines/sec=205467
    > _____MISSED lines____ #9 {cpl=31} count=100001, lines/sec=205467
    > _____MISSED lines____ #10 {cpl=32} count=1000001, lines/sec=234264
    > _____MISSED lines____ #11 {cpl=33} count=10000001, lines/sec=216293
    > _____MISSED lines____ #12 {cpl=34} count=100000001, lines/sec=207797
    #13 not shown happened when I copied the dos box buffer
    9000 lines in dos box buffer when just copied
    #33616971[4K] : __>> count=3864923157, lines/sec=197043 << >4> Good lines=____114
    #33617850[4K] : __>> count=3865023168, lines/sec=209016 << >4> Good lines=____114
    #41328017[4K] : __>> count=463256201, lines/sec=217812 << >12> Good lines=117____
    #41328872[4K] : __>> count=463356261, lines/sec=217812 << >12> Good lines=117____
    #41329726[4K] : __>> count=463456203, lines/sec=218953 << >12> Good lines=117____
    <update> :
    >> multitasking OS seems to be more lossy than Teensy T4 at these rates - but that may just be because T4 is not supporting the 'availableForWrite()' to halt transmission when client gets busy:
    > opened EDGE browser and that caused data glitch again - I have 7 EDGE windows open with a combined 38 web pages in tabs
    > And opening each EDGE window to count the open tabs caused 3 data glitches with no apparent reason
    > came back and the lps_test.exe had exited with NO ERROR - not sure if I did that? - then just reran it and it picked up on a buffer boundary with no T4 restart and no reported data glitch on starting.
    #50115385[4K] : __>> count=1478669116, lines/sec=195738 << >15> Good lines=____114
    #50116264[4K] : __>> count=1478769127, lines/sec=194467 << >15> Good lines=____114
    Got a BARRAGE of FAILS on PC in use … went from #15 errors to #96 where there was utter garbage in the buffer in two batches - then back to normal operation:
    #9062402[4K] : __>> count=2675641990, lines/sec=206023 << >6> Good lines=113____
    > _____MISSED lines____ #7 {cpl=305}
    XHdi%xZ lyRƻ╬O)ⁿ.╖εJ≡3╦tw▐7
  2. #2802
    2,669
    edit:
    @mjs513: run test on T3.6 with build-in SDHC (TEST_DRV = 1) got the same rc=1 error
    OK will investigate
    cmd13 did not work properly (too many checks!)
    modified code update GitHub
    and SDHC is now working for both T3.6 and T4b2
    re USBHost on T4: I know that USB-T4 is only working for USB_Serial. we may have to wait for Paul to implement USB_DISABLED, or do I miss something ?
  3. #2803
    New York
    5,373
    Just did a grepwin of both T3 and T4 cores the only delta's I see is that its not defined in usb_dev.h which may or my not be an issue. But seems to be in the other files (at least its there). Someone may need to confirm my observations. This was really quick and dirty.
  4. #2804
    Germany NRW
    6,910
    Not sure if it is an issue, but every time after installing a new Teensyduino version, it switches to Teensy 3.6 as default, which is a bit confusing
    The USB updates work quite well.
  5. #2805
    Germany NRW
    6,910
    Java exceptions:
    I got these often in the last days - with a program that does only (USB-)print a few lines at startup, and after that, nothing. The execptions occured when compling the new program. It has > 12K lines in a single *.ino and large libraries like audio, MP3 and AAC (and it had really a LOT of warnings :-( - the builder prints to stdout/stderr which then gets redicrected to arduino?)
    After that, only a restart of arduino helped. May be, the root-cause of these exceptions has nothing to do with the monitor or serial...
  6. #2806
    11,837
    Not sure if it is an issue, but every time after installing a new Teensyduino version, it switches to teensy 3.6 as default, which is be a bit confusing
    Indeed FrankB - It does switch away from BETA T4 on each install - catches me each time with a 'bad hex' lecture from TeensyLoader. I assume this is worthy of the msg #6 list - probably just that it really isn't a 'shipping product' yet.
    Indeed USB seems stable and fast - thinking of putting my lps_test.exe on a second unused computer to run with T4B1 board. - then update that with USB changes as offered maybe integrate similar receive testing in same sketch/exe combo.
    About to add update notes to #2801 above - multitasking OS seems to be more lossy than Teensy T4 at these rates - but that may just be because T4 is not supporting the 'availableForWrite()' to halt transmission when client gets busy:
    Going to add 2801 : availableForWrite needed and 2804 : Teensy T4 not default Board after install.
  7. #2807
    6,959
    Sorry, maybe I am missing something. Which USB port are we talking about?
    That is I believe there are two USB ports.
    a) The one that you use to talk to the Host computer... The one which configuring the Teensy for USB_Serial, or Keyboard....
    b) The second USB port which we are configuring as a Host, currently in USBHost_t36 library, which we also have working on the host support code for (Keyboards, Mice, joysticks, some bluetooth, Midi, Serial).
    I believe we are talking about the b) part? I know that some of the underlying stuff on the T4 is different than the T3.6, but @Paul put in some translations and the like in the usbhost_t36\utility\imxrt_usbhs.h file which I believe translates the T3.6 USB Host definitions into the T4 versions.
  8. #2808
    11,837
    If this USB port - Paul noted my find in post #6 issues: USB_DISABLED doesn't build.
  9. #2809
    2,669
    Confusion is on my side.
    I was talking about USBHost port on T4b2, where I can plug-in an USB stick.
    As is, I cannot get it working.
    Code does not pass mscInit(); or better while(!msDrive1.available());
    Seems that my setup (HW or SW) is missing something.
    @mjs513: on which system did you get uSDFS (TEST_DRV = 2) working?
  10. #2810
    6,959
    @WMXZ and @mjs513 -
    Are you just using your stuff or do you still need the MSC stuff changed from the zip file?
    Will try to take a look.
  11. #2811
    2,669
    @WMXZ and @mjs513 -
    OK,
    I got it working, some sort of.
    Updated GitHub now (Had to add some statements into my msc interface)
    @KurtE
    You still need msc library (from zip file) installed into your Arduino library folder
    I said: got it working some sort of, because the uSDFS_test program only runs when USBHOST_PRINT_DEBUG is enabled in USBHost_t36.h
    without that program crashes at different places. Seems to be a timing issue
    ( I use A_1.8.8 with TD_1.47beta1) so it may not be (for sure is not) latest Version.
  12. #2812
    6,959
    @KurtE
    Do I still need to copy his version of files into your library (ones like diskio.c?)
    WinMerge does show they are not the same...
    So far I have not tried to copy in these files... Did try running with a couple of different thumb drives and I just see:
    Test uSDFS
    2:/
    Change drive
    Create a new subdirectories.
    mkDir Ascii: Failed with rc=12.
  13. #2813
    New York
    5,373
    Did I type something wrong, Test_Drv = 0 or 1 works, 2 does not.....sorry for the confusion
  14. #2814
    New York
    5,373
    Test uSDFS
    2:/
    Change drive
    @KurtE and @WMXZ
    Just retested with test_drv=0 and SD Card reader in the USBhost port and it identified it no problem and the data was correct. This was the same reader that didn't work in previous testing.
    Doesn't read USB sticks that I have but they are kind of old ones - Sony Cruz 4gb and a Microcenter 2gb one. Not sure the format on them - they should be FAT32's.
    Still now sure what do with wwatson's library - do I copy those files over to the your library that it tells me to replace or is all I need is the massstorage.h file?
  15. #2815
    11,837
    I scanned the WMXZ github readme - it said 'MSC lib was required - but copy of files not needed'
    or to quote: "needs MSC library (https://forum.pjrc.com/threads/55821...er-Experiments) (no need to copy files over from MSC library to uSDFS library)"
  16. #2816
    22,123
    Yup. For now, USB Serial is the only one that works. I'm intentionally keeping the USB code simpler by not supporting any others, even just completely disabling the USB port. Will do MIDI, Audio, and all the others later, after the remaining stuff on USB serial gets done...
    Receiving data isn't optimized yet. Support for serialEvent is also missing. I want to do those before expanding the USB code.
    I'm also planning another round of substantial optimizations on transmitting. The timeout for concluding the PC isn't listening might need to increase, since we're also to overwhelm most Windows software.
    Still thinking about how I want to do availableForWrite(). There's a long-standing and very subtle bug on Teensy3's availableForWrite(), where an auto flush occurs between the time availableForWrite() promises a certain amount of space and the user later writes, expecting it to be non-blocking. I want to come up with a better strategy on T4 to completely avoid that rare but very difficult case. That's why availableForWrite() remains undone.
    But if the timeout code is being triggered because we're too fast for PC-side software, we really need a longer timeout rather than requiring use of availableForWrite() for non real-time applications.
    However, at this moment my top priorities are looking into the CP2104 phantom power startup problem (just dug out my Adafruit CP2104 board this morning) and a bootloader update to fix the bugs with the 15 second restore process. There may also be another minor bootloader bug affecting USB descriptors. All 3 operating systems seem to ignore it (as far as I can tell), but still ought to get fixed.
  17. #2817
    11,837
    Paul - startup halting isn't hard - doesn't take anything but 3v3 on a pin (with enough current). Teensy or CP2104 - only difference is drive strength - and if the UART sense inactivity and drops current drive. It may be that I even had a 3.3V wire that did it - though of course if I did that it should have had a resistor inline to limit current.
    As noted I was seeing just over 20 mA from T_3.1 - my olde PL2303 only seemed to have a max drive of 9mA - and it seemed would sense no activity and drop the current - the Teensy doesn't do this as the meter held steady and the T_3.6 was at 19 mA where my cheap meter would peak and drop off as it eventually got around to reading and updating the display for the CP2104. Either of those T_3.x pins was enough perhaps with Rx or Tx connected because both seemed to be held at 3v3 - though the Rx line was more like 3.19 volts than 3.3 where Tx Stop is held.
  18. #2818
    11,837
    I hooked up the T4B1 board to my i7 SurfaceBook and it is running 'similarly' - was connected direct to USB3 port and chattered not once but often 2-3 times on startup with missed data \n alignment. But an unpowered USB2 hub inline and that didn't change it - so the OS/Hardware timing to the port must affect it - it does run lps-test.exe okay for long stretches at similar speed 160-170K l/sec and sometime like i7 desktop even 200 to 220K for periods. Some oddities with the exe reading/buffering - it does just quit without posting an error like I have seen on my desktop at times - but restarting EXE and not the T4 picks up … Test could use some refinement as the USB stack gets improved but am not able to 'see' any pattern or trouble.
  19. #2819
    2,534
    Re: FastLED
    updated FastLED testing post, adding pin defs for T4B2 with fast GPIO.
  20. #2820
    2,669
    Test uSDFS
    2:/
    Change drive
    NO you dont't copy the diskio et al. files over from MSC library to uSDFS.
    the uSDFS diskio.c is already prepared for MSC. copying could impact spi and usdhc functionality
    concerning your TEST_DRV=2 run, could you please activate the USBHost debugging print uncommenting #define USBHOST_PRINT_DEBUG in USBHost_t36.h
    In may case, this made the access to USBdisk without errors (in my case I used a HTrust uSD adapter)
    my hunch is that the USBHost or better the USB MassStorageDriver in MSC needs to be slowed down, or have better wait for reply/ready functions.
  21. #2821
    6,959
    Thanks @WMXZ,
    I sort of figured that I did not need to copy those files, as I saw that you had made several changes to them.
    As per your previous post, I had turned on the debug printing code in USBHost_t36 but did not see any output from the debug messages of it... them, on either the T4B2 nor T3.6.
    I have tried using a couple of different thumb drives. One is an old Cruzer 1GB which I had Windows reformat yesterday, and the other was a new 8GB enfain, which had never been used before.
    Now that I am thinking about it, I used your version of the test app, not the one from the MSC library. Probably need the MSC library as it defines some objects from the USBHost library...
    Will try again.
    EDIT: This time things are being output, so making progress.
    On T4B2
    Test uSDFS
    2:/
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20005000
    periodictable = 20005000
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 0C 09 00 10 00 11 01 02 00 01
        VendorID = 090C, ProductID = 1000, Version = 1100
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: SMI Corporation
    enumeration:
    Product: USB DISK
    enumeration:
    Config data length = 32
    enumeration:
    Configuration Descriptor:
      09 02 20 00 01 01 00 80 FA
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 02 08 06 50 00
        Interface = 0
        Number of endpoints = 2
        Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 80(Bulk Only)
      07 05 81 02 00 02 FF
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 255
      07 05 02 02 00 02 FF
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
    enumeration:
    msController claim this=200055A0
    Descriptor 4 = INTERFACE
    09 04 00 00 02 08 06 50 00 07 05 81 02 00 02 FF 07 05 02 02 00 02 FF
    endpointType = 2
    numendpoint=2
    endpointIn=81
    endpointOut=2
    packet size in (msController) = 512
    packet size out (msController) = 512
    polling intervalIn = 255
    polling intervalOut = 255
    new_Pipe
    new_Pipe
    Descriptor 5 = ENDPOINT
    control CallbackIn (msController)
    00 00 00 00 00 00 00 00
    msController CallbackOut (static)
    msController CallbackIn (static)
    transfer->qtd.token = 0
    transfer->qtd.token = 80
    ERROR Followup
        remain on followup list
    Mount: Failed with rc=1.
    Goes better on T3.6...
    Test uSDFS
    2:/
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 4
    USBHS_PERIODICLISTBASE = 1FFF4000
    periodictable = 1FFF4000
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 81 07 06 54 00 02 01 02 03 01
        VendorID = 0781, ProductID = 5406, Version = 0200
    enumeration:
    enumeration:
    Manufacturer: SanDisk
    enumeration:
    Product: U3 Cruzer Micro
    enumeration:
    Serial Number: 00007080C0732B8C
    enumeration:
    enumeration:
      09 02 20 00 01 01 00 80 2F
        NumInterfaces = 1
        Interface = 0
      07 05 81 02 00 02 00
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 02 02 00 02 00
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
    enumeration:
    msController claim this=1FFF45A0
    09 04 00 00 02 08 06 50 00 07 05 81 02 00 02 00 07 05 02 02 00 02 00
    endpointType = 2
    numendpoint=2
    endpointIn=81
    endpointOut=2
    polling intervalIn = 0
    polling intervalOut = 0
    new_Pipe
    new_Pipe
    01 00 00 00 00 00 00 00
    Change drive
    Create a new file /Ascii/HELLO12.TXT.
    Write some text lines. (Hello world!)
    Close the file.
    Open same file /Ascii/HELLO12.TXT.
    Get the file content.
    Hello world!
    Second Line
    Third Line
    Fourth Line
    Habe keine Phantasie
    Close the file.
    open binary file
    write file
    close file
    Binary test done
    Open root directory.
    Directory listing...
       <dir>  System Volume Information
       <dir>  Ascii
       <dir>  Binary
    Test completed.
    sizeof Device = 36
    sizeof Pipe = 96
    power up USBHS PHY
     reset waited 4
    Will try to debug some now...
    EDIT 3 - Looks like WWatson uploaded a new zip file for MSC with fixes in it... Need to figure out what parts need to go where...
    Kurt
  22. #2822
    New York
    5,373
    @KurtE and @WMXZ
    Sorry not going to be of much help today. Got the 1060evk board yesterday afternoon and been trying to debug CANFD. Seems like I can get it to work on the SDK finally and got the register mapping. Redid the T4 sdk lib so now have the same register mappings on the T4 as on the SDK but the T4 is being stubborn - nothing coming in to the T4 or being transmitted. Will get there
    Good luck.
  23. #2823
    22,123
    Yup, I've got it happening here.
    Investigating now. It's starting to look like I'm going to need to make another board rev to fix this.
  24. #2824
    11,837
    indeed. Though given the nature of it … glad it is fixable.
  25. #2825
    11,837
    Kurt
    That is posted here : USB-Mass-Storage-Driver-Experiments
    Updated OP on that thread to add pointer as well.
