Page 157 of 173 FirstFirst ... 57 107 147 155 156 157 158 159 167 ... LastLast
Results 3,901 to 3,925 of 4311
Thread: Teensy 4.0 First Beta Test
  1. #3901
    2,193
    Did some more testing this morning with that clock generator chip especially between 60-70 Mhz. Looks like I would limit it to 68 or 70Mhz.
    Re: FreqCount on T4 with quad timer
    I too did some testing with Adafruit clock generator (Si5351A). For my T4B2R, the frequency count is accurate to about 65 mhz as measured against the T4's crystal. @65mhz frequency error is about -22 ppm, but @66mhz error is -73 ppm. @50mhz errors is -20.5 ppm, and @1mhz it is -20 ppm. With GPS PPS, i measured my T4B2R frequency error (24mhz crystal) at -11 ppm, so that suggests the Adafruit generator's crystal has an error of -31 ppm (spec says generator's 25mhz crystal is accurate to within 30 ppm).
    I also tested the generator with T3.6 (-6 ppm) FreqCount library, and those tests also showed my Adafruit generator crystal has frequency error of -31 ppm. I also confirmed that T3* can count accurately up to 65 mhz, as documented by Paul in his youtube demo, see
    https://forum.pjrc.com/threads/47983...l=1#post160470
    Curious that both T4 and T3 frequency counting is good up to 65 mhz. Is there some fundamental IC characteristic that determines counting threshold or capacitance/hysteresis of input or ?? A shorter common ground jumper between the T4 and the T3.2 controlling the generator helps.
    With a 7" ground jumper and 70 mhz PWM
          67656628
          67655729
          67657627
    with 2" jumper
          69526989
          69525509
          69535055
    As noted in previous posts, a single T4 with its PWM output jumpered to its counter input can count a 75 mhz PWM input.
    EDIT: Using GPS PPS, i measured Adafruit generator 25mhz crystal frequency error to be -31.2 ppm.
    EDIT 2: the T3* FreqCount uses LPTMR, and the 65 mhz is a limit of the 16-bit timer rollover (intervaltimer checks for rollover every 1000 us, so max external clock rate would be 65mhz) With another sketch, I can count up to 132.5 MHz, see
    https://forum.pjrc.com/threads/54711...l=1#post212014
  2. #3902
    New York
    4,101
    @manitou
    The one thing that i haven't tried is turning hysterisis on for pin 9. But anyway using 8" jumpers i am seeing the following using the updated FreqCount lib sketch:
    @10
    10000080
    10000081
    10000081
    10000081
    @20
    20000163
    20000162
    20000163
    @25
    25000200
    25000201
    25000200
    25000200
    @60Mhz
    60000473
    60000473
    60000472
    @65mhz
    65000513
    65000515
    65000515
    65000514
    @70
    66455620
    66455038
    66449752
    66430449
    Other than at 70Mhz it seems to consistently giving me overshoot of *7.9e-8 percent error between the clock generator and the T4. ‬
  3. #3903
    May 2016
    219
    Just in case you are not aware - many/most SI5351 (used in the Adafruit module) libraries provide a calibration function for the XTAL oscillator. You only need to calibrate at one frequency, ie it's a ppm calibration. Of course you need a "gold" standard, I calibrate against the WWV freq standards at 5 or 10 MHz, and routinely get calibration to 1 Hz at the XTAL frequency.
    I use the Adafruit module all over the place. The SI5351 is a fantastic little chip - with abysmal documentation .
    Example from the (overly complex) https://github.com/etherkit/Si5351Arduino
    set_correction()
     * set_correction(int32_t corr, enum si5351_pll_input ref_osc)
     * corr - Correction factor in ppb
     * ref_osc - Desired reference oscillator
     *     (use the si5351_pll_input enum)
     * Use this to set the oscillator correction factor.
     * This value is a signed 32-bit integer of the
     * parts-per-billion value that the actual oscillation
     * frequency deviates from the specified frequency.
     * The frequency calibration is done as a one-time procedure.
     * Any desired test frequency within the normal range of the
     * Si5351 should be set, then the actual output frequency
     * should be measured as accurately as possible. The
     * difference between the measured and specified frequencies
     * should be calculated in Hertz, then multiplied by 10 in
     * order to get the parts-per-billion value.
     * Since the Si5351 itself has an intrinsic 0 PPM error, this
     * correction factor is good across the entire tuning range of
     * the Si5351. Once this calibration is done accurately, it
     * should not have to be done again for the same Si5351 and
     * crystal.
    I can give you links to easier to use libraries...
  4. #3904
    2,193
    Quote Originally Posted by DerekR View Post
    Re: generator frequency correction
    Thanks. Though not really a T4 issue, the Adafruit generator library has a fractional option for multiplying the 25mhz clock for the PLL. So using
    clockgen.setupPLL(SI5351_PLL_A, 20, 20*31, 1000000); // ppm fix
    I can correct for the -31 ppm error in my Adafruit generator.
  5. #3905
    New York
    4,101
    TeensyThreads Help
    I think I got Teensy Threads library working (Tests.ino says everything is OK ) with the T4 - not 100% sure I did it right and I do have a question if someone could help:
    Question: How do you get an unused_isr? in the current thread lib it has:
    if (save_svcall_isr == unused_isr) save_svcall_isr = 0;
    but there is no unused_isr function in Teensy4 core but I did find an unused_interrupt_vector but its only in startup.c. Just as a test I just did:
      // commandeer the SVCall & SysTick Exceptions
      save_svcall_isr = _VectorsRam[11];
      //if (save_svcall_isr == unused_isr) save_svcall_isr = 0;
    Question 2: Not sure I did this one right but need verification...
    Was:
     * Stop using the SysTick interrupt and start using
     * the IntervalTimer timer. The parameter is the number of microseconds
     * for each tick.
     * Implementation strategy suggested by @tni in Teensy Forums; see
     * https://forum.pjrc.com/threads/41504-Teensy-3-x-multithreading-library-first-release
    int Threads::setMicroTimer(int tick_microseconds)
      // lowest priority so we don't interrupt other interrupts
      context_timer.priority(255);
      // start timer with dummy fuction
      if (context_timer.begin(context_pit_empty, tick_microseconds) == 0) {
        // failed to set the timer!
        return 0;
      currentUseSystick = 0; // disable Systick calls
      // get the PIT number [0-3] (IntervalTimer overrides IRQ_NUMBER_t op)
      int number = (IRQ_NUMBER_t)context_timer - IRQ_PIT_CH0;
      // calculate number of uint32_t per PIT; should be 4.
      // Not hard-coded in case this changes in future CPUs.
      const int width = (PIT_TFLG1 - PIT_TFLG0) / 4;
      // get the right flag to ackowledge PIT interrupt
      context_timer_flag = &PIT_TFLG0 + (width * number);
      attachInterruptVector(context_timer, context_switch_pit_isr);
      return 1;
    Converted to:
        return 0;
      for (int i = 0; i < 4; i++)
        if (IMXRT_PIT_CHANNELS[i].TFLG == 0)
    		int number = i;
      //int number = (IRQ_NUMBER_t)context_timer - IMXRT_PIT_CHANNELS[0];
      return 1;
    	return 0;
    EDIT: ok - setMicros does not work... Pretty sure this conversionis wrong:
    I hate timers Not really
    EDIT1: Could also be the context switcher that is the assembly language file which I know nothing about.
  6. #3906
    20,559
    I've uploaded 1.47-beta5. As always, links on msg #2.
    This version will update your T4 bootloader to 1.05, which is the version we plan to ship when we release Teensy 4.0 "real soon now". 1.05 fixes a bug where the red LED would blink (indicating no USB connectivity - like a charge-only cable) when Windows would use USB suspend to save power. Now the LED remains on, indicating good USB.
    An obscure bug where printing binary data to the Arduino Serial Monitor when in native "Teensy Port" mode could sometimes stall the serial monitor window has also been fixed.
    1.47-beta5 also includes Kurt & Mike & Tim, to FreqCount, ST7735_t3 and minor fixes in the Audio library.
  7. #3907
    New York
    4,101
    @PaulStoffregen
    Just downloaded and installed 1.47-beta5 on Windows 10 x64 with no problem. Saw the bootloader updating and out of curiosity checked the log
    08:23:52.731 (loader): Bootloader upgrade: 0.04 -> 1.05
    . On new load always seems to load T3.2 as the selected board. Did a quick retest of FreqCount since I had it still set up from yesterday and changes did still work - always happy when things work. Now back to playing with Teensy Threads.
    Hope all is well.
  8. #3908
    Aug 2017
    125
    @PaulStoffregen
    Installed a fresh copy of Arduino 1.8.9 and TD 1.47B5. I was compiling one of my test programs that use the time library and got an error.
    So I tried compiling 'TimeRTC.ino' and it gave the same error below:
    Arduino: 1.8.9 (Linux), TD: 1.47-beta5, Board: "Teensy 4.0, Serial, Fastest, US English"
    /home/wwatson/arduino-1.8.9/arduino-builder -dump-prefs -logger=machine -hardware /home/wwatson/arduino-1.8.9/hardware -hardware /home/wwatson/.arduino15/packages -tools /home/wwatson/arduino-1.8.9/tools-builder -tools /home/wwatson/arduino-1.8.9/hardware/tools/avr -tools /home/wwatson/.arduino15/packages -built-in-libraries /home/wwatson/arduino-1.8.9/libraries -libraries /home/wwatson/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o3std,keys=en-us -ide-version=10809 -build-path /tmp/arduino_build_964940 -warnings=none -build-cache /tmp/arduino_cache_9678 -verbose /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/examples/TimeRTC/TimeRTC.ino
    /home/wwatson/arduino-1.8.9/arduino-builder -compile -logger=machine -hardware /home/wwatson/arduino-1.8.9/hardware -hardware /home/wwatson/.arduino15/packages -tools /home/wwatson/arduino-1.8.9/tools-builder -tools /home/wwatson/arduino-1.8.9/hardware/tools/avr -tools /home/wwatson/.arduino15/packages -built-in-libraries /home/wwatson/arduino-1.8.9/libraries -libraries /home/wwatson/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o3std,keys=en-us -ide-version=10809 -build-path /tmp/arduino_build_964940 -warnings=none -build-cache /tmp/arduino_cache_9678 -verbose /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/examples/TimeRTC/TimeRTC.ino
    Using board 'teensy40' from platform in folder: /home/wwatson/arduino-1.8.9/hardware/teensy/avr
    Using core 'teensy4' from platform in folder: /home/wwatson/arduino-1.8.9/hardware/teensy/avr
    Detecting libraries used...
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_964940/sketch/TimeRTC.ino.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time /tmp/arduino_build_964940/sketch/TimeRTC.ino.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire /tmp/arduino_build_964940/sketch/TimeRTC.ino.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /tmp/arduino_build_964940/sketch/TimeRTC.ino.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/DateStrings.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/Time.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/utility /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/Wire.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/utility /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/utility /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireKinetis.cpp -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/utility /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/utility/twi.c -o /dev/null
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC/DS1307RTC.cpp -o /dev/null
    Generating function prototypes...
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /tmp/arduino_build_964940/sketch/TimeRTC.ino.cpp -o /tmp/arduino_build_964940/preproc/ctags_target_for_gcc_minus_e.cpp
    /home/wwatson/arduino-1.8.9/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_964940/preproc/ctags_target_for_gcc_minus_e.cpp
    Compiling sketch...
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/precompile_helper /home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_964940 /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -x c++-header -O3 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_964940/pch/Arduino.h -o /tmp/arduino_build_964940/pch/Arduino.h.gch
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O3 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/tmp/arduino_build_964940/pch -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /tmp/arduino_build_964940/sketch/TimeRTC.ino.cpp -o /tmp/arduino_build_964940/sketch/TimeRTC.ino.cpp.o
    Compiling libraries...
    Compiling library "Time"
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O3 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/tmp/arduino_build_964940/pch -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/DateStrings.cpp -o /tmp/arduino_build_964940/libraries/Time/DateStrings.cpp.o
    /home/wwatson/arduino-1.8.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O3 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/tmp/arduino_build_964940/pch -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire -I/home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/Time.cpp -o /tmp/arduino_build_964940/libraries/Time/Time.cpp.o
    /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/DateStrings.cpp: In function 'char* monthStr(uint8_t)':
    /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/DateStrings.cpp:76:66: error: 'strcpy_P' was not declared in this scope
         strcpy_P(buffer, (PGM_P)pgm_read_word(&(monthNames_P[month])));
    /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/DateStrings.cpp: In function 'char* dayStr(uint8_t)':
    /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time/DateStrings.cpp:90:61: error: 'strcpy_P' was not declared in this scope
        strcpy_P(buffer, (PGM_P)pgm_read_word(&(dayNames_P[day])));
    Using library Time at version 1.5 in folder: /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Time
    Using library Wire at version 1.0 in folder: /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/Wire
    Using library DS1307RTC at version 1.4.1 in folder: /home/wwatson/arduino-1.8.9/hardware/teensy/avr/libraries/DS1307RTC
    Error compiling for board Teensy 4.0.
    I searched for 'strcpy_P' in the compiler libs but did not find it.
    I changed line 20 in 'DateStrings.cpp' to this:
    #if defined(ESP8266) || defined(ARDUINO_ARCH_ESP32) || defined(__IMXRT1062__)
    It compiled ok after that.
    Can't wait for the T4 release
  9. #3909
    5,421
    Time/DateStrings.cpp - Not sure why the changes were made that were made...
    That is, that section of code:
    #ifndef strcpy_P
    #define strcpy_P(dest, src) strcpy((dest), (src))
    In June a PR changed the #if from: #ifndef ESP8266
    To: #ifdef ESP8266
    So before that change all other platforms checked for existence of strcpy_P to only exp8266 ???
    Then later PR, was needed to get ESP32 to work again, which you pulled in on July 4th...
    Maybe that whole #if defined ... Should just be removed? Again wonder of needed for T3.x? or is this some differences in which version of compiler that is used?
  10. #3910
    9,695
    Installed TD_1.47b5. Install ran FINE! Win 10 - Malwarebytes and Windows Defender Security active. IDE and TeensyLoader closed - Found no Orphaned Teensy Processes!
    Did a PURGE of sketchbook\libraries into sketchbook\T4_libraries to make sure I was using nothing not part of the install!
    Current sketches were ST7789 based:
    PROBLEM : Adafruit_GFX
    >> Had to restore "T:\tCode\libraries\Adafruit_GFX" [AFAIK] KurtE version of this library as the one in Teensy\AVR FAILS!
    Multiple libraries were found for "Adafruit_GFX.h"
    Used: T:\tCode\libraries\Adafruit_GFX
    Not used: T:\Ard186t4b2\hardware\teensy\avr\libraries\Adafru it_GFX
    Two recent sketches - both using TWIN ST7789's compile and run fine on latest T4 with this install of TD1.47b5!
    @mjs513: with the T4 in BETA - the changes to make the T4 a 'default'/known device are not yet connected AFAIK - that is why each new install still reverts to T_3.2
    >> Oh and yes the T4 tested with got a BOOTLOADER update and is running well
    10:17:45.354 (loader): Bootloader upgrade: 0.04 -> 1.05
    10:17:45.356 (loader): flash, block=0, bs=1024
    10:17:45.356 (loader): flash, block=1, bs=1024
    10:17:45.556 (loader): remote cmd from 1404: "status"
    10:17:48.677 (loader): Bootloader update: 34% of estimated 8 seconds, wait=27
    10:17:48.787 (loader): Bootloader update: 35% of estimated 8 seconds, wait=28
    10:17:48.788 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    10:17:48.789 (ports 2): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#00093c64#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    10:17:48.789 (ports 2): found_usb_device, loc=usb:0/140000/0/8/7    Port_#0007.Hub_#0006
    10:17:48.789 (ports 2): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
    10:17:48.789 (ports 2): found_usb_device, devinst=0000001d
    10:17:48.789 (ports 2): add: loc=usb:0/140000/0/8/7, class=HID, vid=16C0, pid=0478, ver=0105, serial=00093c64, dev=\\?\usb#vid_16c0&pid_0478#00093c64#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    10:17:48.803 (ports 2): hiddev_from_devinst_list: iface=0
    10:17:48.805 (ports 2): found_usb_device complete
    10:17:48.806 (ports 2): usb_add: usb:0/140000/0/8/7  [no_device] (Teensy) Bootloader
    10:17:48.897 (loader): Bootloader update: 36% of estimated 8 seconds, wait=29
    10:17:48.897 (loader): Bootloader update finished, 2.9 seconds
    10:17:48.897 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.05
    10:17:48.897 (loader): flash, block=0, bs=1024, auto=1
    10:17:48.897 (loader):  gauge old value = 0
    10:17:48.909 (loader): flash, block=1, bs=1024, auto=1
    10:17:48.910 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    And for TTS files {had to run in firefox as it won't run in EDGE} :: https://lingojam.com/MicrosoftSamOnline
    This online tool lets you generate a Microsoft Sam style voice (not the exact original) that you can play and download easily.
  11. #3911
    9,695
    Paul: Is that NEW that a 'Programming Progress' or other status update - like 'Updating Bootloader' pops up as Top Window during TLoader activity?
    Also :: A 15 Second Restore with New Bootloader - No problem! No complaints from Windows - T4 returned to 'Blink Sketch' and IDE was OPEN and did Upload without any grief!
    TIMING > looks like about 15 seconds for Button initiate and 14 Seconds for Restore and device arrival? Based on :: '10:44:09' >> '10:44:38'
    10:44:09.911 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    10:44:09.912 (ports 2): remove: loc=usb:0/140000/0/8/7
    10:44:09.912 (ports 2): usb_remove: usb:0/140000/0/8/7
    10:44:09.912 (ports 2): nothing new, skipping HID & Ports enum
    10:44:09.931 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    10:44:09.931 (ports 2): nothing new, skipping HID & Ports enum
    10:44:09.935 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    10:44:09.935 (ports 2): nothing new, skipping HID & Ports enum
    10:44:11.551 (ports 2): purge, name=COM33 (Teensy 4-Beta2) Serial, loc=usb:0/140000/0/8/7, age=1.638 sec
    10:44:11.951 (ports 2): callback C1A9
    10:44:13.972 (ports 2): callback C1A9
    10:44:16.049 (ports 2): callback C1A9
    10:44:18.061 (ports 2): callback C1A9
    10:44:20.088 (ports 2): callback C1A9
    10:44:22.106 (ports 2): callback C1A9
    10:44:24.125 (ports 2): callback C1A9
    10:44:26.141 (ports 2): callback C1A9
    10:44:28.198 (ports 2): callback C1A9
    10:44:30.253 (ports 2): callback C1A9
    10:44:31.836 (loader): Verbose Info event
    10:44:32.267 (ports 2): callback C1A9
    10:44:34.322 (ports 2): callback C1A9
    10:44:36.378 (ports 2): callback C1A9
    10:44:38.274 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    10:44:38.275 (ports 2): nothing new, skipping HID & Ports enum
    10:44:38.298 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    10:44:38.299 (ports 2): found_usb_device, id=\\?\usb#vid_16c0&pid_0486#6052840#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    10:44:38.299 (ports 2): found_usb_device, loc=usb:0/140000/0/8/7    Port_#0007.Hub_#0006
    10:44:38.299 (ports 2): found_usb_device, devinst=0000001f
    10:44:38.299 (ports 2): found_usb_device, hwid=USB\VID_16C0&PID_0486&REV_0279
    10:44:38.299 (ports 2): add: loc=usb:0/140000/0/8/7, class=USB, vid=16C0, pid=0486, ver=0279, serial=6052840, dev=\\?\usb#vid_16c0&pid_0486#6052840#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    10:44:38.300 (ports 2): hiddev_from_devinst_list: iface=1
    10:44:38.301 (ports 2): found_usb_device complete
    10:44:38.302 (ports 2): usb_add: usb:0/140000/0/8/7  [no_device] (Teensy 4-Beta2) RawHID
    10:44:38.557 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    10:44:38.557 (ports 2): callback C1A9
    10:44:38.558 (ports 2): update_usb_device, devinst list change, old had 2, new has 5
    10:44:38.558 (ports 2): hiddev_from_devinst_list: iface=1
    10:44:38.559 (ports 2):   00000023: path=\\?\hid#vid_16c0&pid_0486&mi_01#8&826c72&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    10:44:38.559 (ports 2): hid, found devinst=00000021
    10:44:38.560 (ports 2): hid, found devinst=00000023
    10:44:38.560 (ports 2): usb_add: usb:0/140000/0/8/7  hid#vid_16c0&pid_0486 (Teensy 4-Beta2) RawHID
    10:44:38.697 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    10:44:38.698 (ports 2): nothing new, skipping HID & Ports enum
  12. #3912
    1,155
    Just a heads up.
    I installed beta 5 over top of beta 4 and then compiled a test of an audio microphone test sketch which I had successfully compiled 5 minutes previously with beta 4 for the T4B2.
    Beta 5 gives these errors.
    "C:\\arduino-1.8.9_1.47_b5\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Audio\\output_i2s.cpp" -o nul
    Error while detecting libraries included by C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp
    "C:\\arduino-1.8.9_1.47_b5\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\arduino-1.8.9_1.47_b5\\hardware\\teensy\\avr\\libraries\\Audio\\output_i2s2.cpp" -o nul
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:547:2: error: #elif without #if
     #elif 0 && (defined(__IMXRT1052__) || defined(__IMXRT1062__) )
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:615:2: error: #endif without #if
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp: In static member function 'static void AudioOutputI2Sslave::config_i2s()':
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:507:2: error: 'SIM_SCGC6' was not declared in this scope
      SIM_SCGC6 |= SIM_SCGC6_I2S;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:507:15: error: 'SIM_SCGC6_I2S' was not declared in this scope
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:508:2: error: 'SIM_SCGC7' was not declared in this scope
      SIM_SCGC7 |= SIM_SCGC7_DMA;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:508:15: error: 'SIM_SCGC7_DMA' was not declared in this scope
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:509:15: error: 'SIM_SCGC6_DMAMUX' was not declared in this scope
      SIM_SCGC6 |= SIM_SCGC6_DMAMUX;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:512:6: error: 'I2S0_TCSR' was not declared in this scope
      if (I2S0_TCSR & I2S_TCSR_TE) return;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:513:6: error: 'I2S0_RCSR' was not declared in this scope
      if (I2S0_RCSR & I2S_RCSR_RE) return;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:517:2: error: 'I2S0_MCR' was not declared in this scope
      I2S0_MCR = I2S_MCR_MICS(0);
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:517:27: error: 'I2S_MCR_MICS' was not declared in this scope
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:518:2: error: 'I2S0_MDR' was not declared in this scope
      I2S0_MDR = 0;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:521:2: error: 'I2S0_TMR' was not declared in this scope
      I2S0_TMR = 0;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:522:2: error: 'I2S0_TCR1' was not declared in this scope
      I2S0_TCR1 = I2S_TCR1_TFW(1);  // watermark at half fifo size
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:522:28: error: 'I2S_TCR1_TFW' was not declared in this scope
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:523:2: error: 'I2S0_TCR2' was not declared in this scope
      I2S0_TCR2 = I2S_TCR2_SYNC(0) | I2S_TCR2_BCP;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:525:2: error: 'I2S0_TCR3' was not declared in this scope
      I2S0_TCR3 = I2S_TCR3_TCE;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:526:2: error: 'I2S0_TCR4' was not declared in this scope
      I2S0_TCR4 = I2S_TCR4_FRSZ(1) | I2S_TCR4_SYWD(31) | I2S_TCR4_MF
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:529:2: error: 'I2S0_TCR5' was not declared in this scope
      I2S0_TCR5 = I2S_TCR5_WNW(31) | I2S_TCR5_W0W(31) | I2S_TCR5_FBT(31);
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:532:2: error: 'I2S0_RMR' was not declared in this scope
      I2S0_RMR = 0;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:533:2: error: 'I2S0_RCR1' was not declared in this scope
      I2S0_RCR1 = I2S_RCR1_RFW(1);
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:534:2: error: 'I2S0_RCR2' was not declared in this scope
      I2S0_RCR2 = I2S_RCR2_SYNC(1) | I2S_TCR2_BCP;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:536:2: error: 'I2S0_RCR3' was not declared in this scope
      I2S0_RCR3 = I2S_RCR3_RCE;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:537:2: error: 'I2S0_RCR4' was not declared in this scope
      I2S0_RCR4 = I2S_RCR4_FRSZ(1) | I2S_RCR4_SYWD(31) | I2S_RCR4_MF
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:540:2: error: 'I2S0_RCR5' was not declared in this scope
      I2S0_RCR5 = I2S_RCR5_WNW(31) | I2S_RCR5_W0W(31) | I2S_RCR5_FBT(31);
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:543:36: error: 'PORT_PCR_MUX' was not declared in this scope
      CORE_PIN23_CONFIG = PORT_PCR_MUX(6); // pin 23, PTC2, I2S0_TX_FS (LRCLK)
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:598:2: error: 'i2s' was not declared in this scope
      i2s->TX.MR = 0;
    In file included from C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\cores\teensy4/core_pins.h:32:0,
                     from C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\cores\teensy4/wiring.h:38,
                     from C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\cores\teensy4/WProgram.h:45,
                     from C:\Users\Peter\AppData\Local\Temp\arduino_build_165994\pch\Arduino.h:6:
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:600:30: error: 'tsync' was not declared in this scope
      i2s->TX.CR2 = I2S_TCR2_SYNC(tsync) | I2S_TCR2_BCP;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\cores\teensy4/imxrt.h:7420:39: note: in definition of macro 'I2S_TCR2_SYNC'
     #define I2S_TCR2_SYNC(n)  ((uint32_t)(n & 3)<<30) // 0=async 1=sync with receiver
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio\output_i2s.cpp:609:30: error: 'rsync' was not declared in this scope
      i2s->RX.CR2 = I2S_RCR2_SYNC(rsync) | I2S_TCR2_BCP;
    C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\cores\teensy4/imxrt.h:7399:39: note: in definition of macro 'I2S_RCR2_SYNC'
     Used: C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\SD
     #define I2S_RCR2_SYNC(n)  ((uint32_t)(n & 3)<<30) // 0=async 1=sync with trasmitter
     Not used: C:\arduino-1.8.9_1.47_b5\libraries\SD
    Using library Audio at version 1.3 in folder: C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Audio
    Using library SPI at version 1.0 in folder: C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\SPI
    Using library SD at version 1.2.2 in folder: C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\SD
    Using library SerialFlash at version 0.5 in folder: C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\SerialFlash
    Using library Wire at version 1.0 in folder: C:\arduino-1.8.9_1.47_b5\hardware\teensy\avr\libraries\Wire
    The code is:
    AudioInputI2S            i2s1;           //xy=61.66667938232422,103.66667175292969
    AudioMixer4              mixer1;         //xy=192,116
    AudioEffectDelay         delay1;         //xy=343,69
    AudioMixer4              mixer2;         //xy=489,247
    AudioOutputI2S           i2s2;           //xy=632,246.6666717529297
    AudioConnection          patchCord1(i2s1, 0, mixer1, 0);
    AudioConnection          patchCord2(i2s1, 1, mixer1, 1);
    AudioConnection          patchCord3(mixer1, delay1);
    AudioConnection          patchCord4(mixer1, 0, mixer2, 1);
    AudioConnection          patchCord5(delay1, 0, mixer2, 0);
    AudioConnection          patchCord6(mixer2, 0, i2s2, 0);
    AudioConnection          patchCord7(mixer2, 0, i2s2, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=76.66667175292969,28.333333015441895
      AudioMemory(100);                               //  <----- moved this line to here
      while(!Serial);
      Serial.println("Begin Initialization...");
                                                      //  <----- from here
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.8);
      sgtl5000_1.micGain(0);
      mixer1.gain(0,0.4);
      mixer1.gain(1,0.4);
      mixer2.gain(0,0.4);
      mixer2.gain(1,0.3);
      delay1.delay(0,100);
      Serial.println("... Initialization Complete!");
      static int volume;
      int n = analogRead(15);
      if (n != volume) {
        volume = n;
        sgtl5000_1.volume(n / 1024.);
    I have since tried this with a fresh install of Arduino 1.8.9 with beta 5 and it gives the same errors.
    I'll try to sort it out a bit later this afternoon.
    Pete
  13. #3913
    1,155
    I have made a quick workaround to the problem. There is an #if statement in beta4 Audio/output_i2s.cpp which was removed in beta5 but the matching #elif and #endif are still there.
    I have just added the #if back in and the sketch compiles again - it still doesn't work, but that's a different kettle of fish.
    void AudioOutputI2Sslave::config_i2s(void)
    //>>> PAH Add the #if back in for now
    #if defined(KINETISK)
    Pete
  14. #3914
    2,193
    BUILTIN_SDCARD on T4B2R no longer working.
    I was testing beta5, and SD example listfiles failed for my BUILTIN_SDCARD on my T4B2R. At first I thought it was beta5, but on another host with beta4, listfiles still failed. I then tried my older T4B2 board with beta5 and BUILTIN_CARD listfiles worked ok on that earlier T4 ... sigh. I'm not aware of any physical trauma to the T4B2R other than pulling the audio shield in and out over the last few weeks. listfiles works on uSD on the audio shield. I've never pulled out the MCU board or messed with the ribbon.
    thoughts?
  15. #3915
    New York
    4,101
    thoughts?
    Just tested with the T4B2R. Getting a initialization failed error. This happens whether you specify the BUILTIN_SDCARD or specify the actual pins. I also downloaded the SD lib from the GitHub library and reinstalled the SD library and it still fails. Something strange is going on - that always worked - sd logger used to fail on me.
  16. #3916
    9,695
    Works on the T4B2R breakout I have. More than a few files 210 lines including subdirs.
    <EDIT>:: Confirmed to work as well with same SD card on T4BM with white wire on POGO SD breakout with Button program of same compiled sketch … three times.
    NOTE:: my sketchbook libraries folder has one entry as noted above - adafruit_GFX - any chance there are conflicts on trouble machines?
    "T:\\Ard186t4b2\\hardware\\teensy/../tools/teensy_post_compile" -file=listfiles.ino "-path=T:\\TEMP\\arduino_build_252223" "-tools=T:\\Ard186t4b2\\hardware\\teensy/../tools/" -board=TEENSY40
    Used: T:\Ard186t4b2\hardware\teensy\avr\libraries\SD
    Not used: T:\Ard186t4b2\libraries\SD
    Using library SD at version 1.2.2 in folder: T:\Ard186t4b2\hardware\teensy\avr\libraries\SD
    Using library SPI at version 1.0 in folder: T:\Ard186t4b2\hardware\teensy\avr\libraries\SPI
    "T:\\Ard186t4b2\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "T:\\TEMP\\arduino_build_252223/listfiles.ino.elf"
    Sketch uses 32368 bytes (1%) of program storage space. Maximum is 2031616 bytes.
    I've unseated the T4 a few times - added some POGO's - but never disconnected the ribbon AFAIK.
    >> "T:\Ard186t4b2\hardware\teensy\avr\libraries\SD\ex amples\listfiles\listfiles.ino" with :: const int chipSelect = BUILTIN_SDCARD;
    Initializing SD card...initialization done.
    SYSTEM~1/
    	INDEXE~1		76
    	WPSETT~1.DAT		12
    ADC4PI~1.BIN		131072000
    ADC~2173.BIN		131072000
    D_00001.DAT		32768000
    D_00002.DAT		32768000
    D_00003.DAT		32768000
    D_00004.DAT		32768000
    D_00005.DAT		0
    D_00006.DAT		32768000
    D_00007.DAT		32768000
    D_00008.DAT		32768000
    NEWFILE.TXT		0
    SDTEST3.WAV		13617358
    SDTEST4.WAV		17173152
    TDINER8.WAV		2058994
    SDTEST1.WAV		16787550
    SDTEST2.WAV		16425698
    MVVHV/
    	DATES.TXT		966
    	HP250E~1.PNG		228285
    		TEAMVI~2.EXE		8220568
    	PICS/
    		061618~1.JPG		172386
    		070818~1.JPG		169893
    		427613~1.JPG		165863
    		511953~1.JPG		105978
    		910976~1.JPG		465615
    		BACKPI~1.JPG		1378892
    		MVVHOP~1.JPG		161238
    		WI2WA.PNG		49484
    D_00009.DAT		32768000
    D_00010.DAT		32768000
    done!
  17. #3917
    New York
    4,101
    @defragster
    The Adafruit_GFX lib is @KurtE's updated version - didn't install the version in Teensyduino. Local copy in my library folder. The SPI Library does have @KurtE's changes incorporated. No open PRs from Kurt's branch.
    Reinstalled SPI library from GitHub just in case and made sure the SD Card was seated securely. So now it is working:
    DATALOG.TXT		26152
    SYSTEM~1/
    	INDEXE~1		76
    	WPSETT~1.DAT		12
    ASCII/
    	HELLO13.TXT		69
    OPERAT~1.WAV		772140
    2001/
    	CALCUL~1.WAV		426300
    	COMPLE~1.WAV		276460
    	DANGER~1.WAV		372892
    	ENOUGH~1.WAV		513388
    	FUNCTI~1.WAV		237356
    	ONE_MO~1.WAV		202236
    	OPERAT~1.WAV		772140
    	SORRY_~1.WAV		791164
    	STOP.WAV		200844
    FLAC/
    	T1_1024.FLA		9802802
    BERLIN~1.FLA		30401785
    CHRIST~1.AAC		3177823
    ODD.MP3		21430
    ODD1.MP3		46888
    ZARATH~1.MP3		489461
    ODD1.WAV		553004
    CALCUL~1.WAV		426300
    BINARY/
    	TEST03.BIN		4096
    done!
  18. #3918
    9,695
    @mjs513 - Good you are seeing function!
    Seems that AdaFruit_GFX needs to be confirmed and added to installer.
    All else on my system was from installer and that was good
    <edit>: Paul BTW - that means I updated two other T4BM's to the new bootloader in post #3916. They were both the same time - 2.7 secs IIRC.
  19. #3919
    5,421
    @mjs513, @defragster, ... my version of Adafruit_GFX - Should now read Adafruit's version, as my few changes to the library were awhile ago and they were all pulled in by Lady Ada and new releases have been made since then.
    In fact I have been running on their current stuff for awhile as my version was cloned into my <arduino sketches>/libraries folder and the library manager thought my version was out of date and I let it update to current released stuff.
  20. #3920
    1,155
    @Frank B: I tried imxrt-size.exe today (with TD beta5) and it didn't output anything. It turns out that _teensy_model_identifier is 0x24 instead of 0x23. imxrt-size only prints info if the model is 0x23. I changed that in your code and recompiled it with cygwin and now it works.
    Pete
  21. #3921
    9,695
    Pete - did it still show good numbers for the segments?
    @KurtE - downloading https://github.com/adafruit/Adafruit-GFX-Library to put in my local libraries to confirm that it has your changes to the better.
    >> confirmed using Adafruit-GFX-Library-master.zip properly renamed into Used: T:\tCode\libraries\Adafruit_GFX builds and runs the ST7789 examples
    @manitou - did you get a working SD ListFiles?
  22. #3922
    1,155
    It reports a wild number for DTCM.
    ITCM :  63616 B	(48.54% of  128 KB)
    DTCM : 451264 B	(344.29% of  128 KB)   <<< 344% ?
    OCRAM:  33792 B	(12.89% of  256 KB)
    Flash: 499616 B	(31.76% of 1536 KB)
    Sketch uses 499616 bytes (24%) of program storage space. Maximum is 2031616 bytes.
    Global variables use 548672 bytes (52%) of dynamic memory, leaving 499904 bytes for local variables. Maximum is 1048576 bytes.
    I've been playing around trying to get my channel vocoder to compile on the T4. It uses a lot of memory for arrays of samples. When I declare them to be PROGMEM the above output changes to this:
    DTCM :  33472 B	(25.54% of  128 KB)
    Flash: 499600 B	(31.76% of 1536 KB)
    Sketch uses 499600 bytes (24%) of program storage space. Maximum is 2031616 bytes.
    Global variables use 130880 bytes (12%) of dynamic memory, leaving 917696 bytes for local variables. Maximum is 1048576 bytes.
    Using PROGMEM somehow reduced DTCM by 417,792 bytes without adding them anywhere else. It looks like the DTCM total is included in Flash so that moving data from DTCM to flash (with PROGMEM) doesn't affect the total.
    Pete
  23. #3923
    20,559
    Those limits look like the fixed sizes from the early 1052-based beta hardware.
    On 1062, OCRAM is always 512K, and we now automatically allocate the other 512K between ITCM and DTCM. ITCM is allocated as whatever your code uses, rounded up to the nearest 32K boundary. The rest of that 512K is all DTCM.
    Flash support was increased to 1984K as well.
  24. #3924
    9,695
    That is something FrankB did for 1052 not revisted since until el_supremo's update.
    I've never tracked all the ins and outs of what's split where. Then what is PROGMEM and other and what CODE stays on Flash - all not PROGMEM? is pulled into RAM at load time?
  25. #3925
    20,559
    Here's a CPU speed benchmark I've been using. Tonight I finally took a few moments to clean it up, add some comments in the code, and run the test on several boards (see the readme file).
    https://github.com/PaulStoffregen/RSA_signature_speed
