Page 160 of 174 FirstFirst ... 60 110 150 158 159 160 161 162 170 ... LastLast
Results 3,976 to 4,000 of 4340
Thread: Teensy 4.0 First Beta Test
  1. #3976
    20,606
    Last night I cleaned up the I2S code, testing on both Teensy 3.6 and 4.0.
    Right now I'm working on putting the native SD code back to polling mode. It's working great on Teensy 3.6 with the audio lib (as it used to in version 1.45), but that breaks it on Teensy 4.0. So far, I can't figure out why...
    Today is my first day since release where we're not frantically shipping orders. I hope to clean the rest of the immediate software issue up later today.
  2. #3977
    2,202
    Re: WavFilePlayer and BUILTIN_SDCARD
    Yeah, a few weeks back I tried to figure out how to get SD lib to do polling again, even just polling on DMA done, but it was above my pay grade.
    Good work on getting the T4 out to the world.
  3. #3978
    Dec 2015
    LA
    129
    What is a 'section type conflict' that shows up with 1.47-beta5 only on T4
    PROGMEM const int mphTable[] = {
    0,100,90,80,75,60,
    4,1,1,1,1,1,
    5,1,1,1,1,1,
    6,1,1,1,1,1,
    7,1,1,1,1,3,
    8,1,1,2,2,5,
    9,1,1,3,4,7,
    10,1,2,4,5,9,
    11,2,4,5,7,9,
    12,3,5,7,8,10,
    13,4,6,8,9,12,
    14,5,8,9,9,13,
    15,7,9,10,10,14,
    16,8,9,11,11,16,
    17,9,10,12,12,17,
    18,9,11,13,13,18
    PROGMEM const char *toplineTABLE[]={
    "error",
    "BATTERY",
    "AUTO",
    "MODE",
    "ADJUST FRONT",
    "ADJUST BACK",
    "ADJUST AUTO",
    "MOVE TO MID GR2",
    "SETTINGS"
      gearfromMphTable(12,2);
    int gearfromMphTable(int thespeed, int rpmoffset){
      int thegear;
      thegear=pgm_read_word_near(mphTable+(thespeed-3)*6+rpmoffset); //for table with rpms in first row, starting with 4mph in second
      return thegear;
    RESULT:
    T4issue_PROGRAM:21: error: toplineTABLE causes a section type conflict with mphTable
    /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_modified_sketch_22662/T4issue_PROGRAM.ino:2:19: note: 'mphTable' was declared here
    I found some information here: https://forum.pjrc.com/threads/54711...l=1#post197693 but no solution.
    Last edited by bicycleguy; 08-11-2019 at 07:18 PM. Reason: cut n paste error & only on T4
  4. #3979
    New York
    4,121
    It is essentially a memory fault error where PROGMEM somehow is going into the wrong section of memory on the T4. T4 memory is rather confusing to me but from what I understand on the T4 there are 4 blocks of memory:
    - ITCM (@0x0, 256KB fast RAM, uncached) is 256KB and intended for code.
    - DTCM (@0x20000000, 256Kb fast RAM, uncached) is intendeded for data,
    - OTCM (@0x20200000, 512 KB RAM connected via a slower bus, can be cached) for data,
    - Flash, @0x60000000, size defined by the external chip for code & data, can be cached.
    - inbuilt devices
    curtesy of @Frank B.
    But if you haven't figure it out the correct format your progmem block is:
    const char *const toplineTABLE[] PROGMEM = {
    got that from going to the Arduino Progmem help page.
  5. #3980
    May 2015
    386
    Not sure if itís feasible or maybe you even already have a tool similar to rustís cargo crater tool their development team uses to test releases. Basically it tryís to compile thousands of libraryís In The cargo library and seís how many have errors and the get a list. Maybe you have such a tool not to check not if it functions correctly but if I gives build errors?
  6. #3981
    20,606
    Quote Originally Posted by DaQue View Post
    Yes, I wrote such a script 2 years ago. Recently updated it for Teensy 4.0.
    https://github.com/PaulStoffregen/Ve...uino_Libraries
  7. #3982
    Dec 2015
    LA
    129
    - inbuilt devices
    Wow, I really don't understand that callout or the array of strings method on the Arduino PROGMEM help page, but it compiles and seems to work. I'll investigate further, thanks!
  8. #3983
    3,273
    Quote Originally Posted by bicycleguy View Post
    In the 8-bit AVR systems (such as the Arduino Uno), data space is rather limited, and things in read-only flash memory (i.e. the program) are not in the same address space as the data pointers. So if you have a bunch of strings or a table of constant values, you might want to put that read only table in the flash memory, and then use special functions to copy that string or data from the program space to the data space when you need the string/number, and then when you are done, you reuse the space.
    On ARM systems, the data and program are in the same address space. So you don't need the functions, but you want to use the const keyword so that the compiler/linker puts that table into read-only flash memory, and not the read-write data space. In Teensy 3, the PROGMEM macro was empty, but in Teensy 4, it uses an __attribute__ to tell the linker that the stuff needs to be linked so it is in lower memory. This is because while they share the same address space, the lower and upper memories for the Teensy 4 have different characteristics.
  9. #3984
    20,606
    Must admit, I've also been stuck on this for many hours. I believe I finally got it working. Here's the changes.
    https://github.com/PaulStoffregen/SD...44a1fe94fecae5
    Most of this commit is just putting the old polling code back, and commenting out the DMA+interrupt code.
    The tricky part threw me for so long was the MIX_CTRL register. Teensy 3.6's SDHC controller doesn't have this register at all. If you look at the register list (page 2005-2006 in the K66 manual), there's a hole at offset 0x48. Teensy 4.0 does have this register, at offset 0x48. Interestingly, neither of them has anything documented at offset 0x4C...
    On Teensy 3.6, the 4 data line drivers seem to become input or output based on the XFERTYP bit DTDSEL, which happens inside the SDHC_CMD_Do() function. On Teensy 4.0, it seems you also need to write to the (seemingly redundant) MIX_CTRL bit DTDSEL, before starting the command.
    Hopefully nobody will ever need to mess with this. But here's a message about the problem just in case I or you or anything else runs across this again.
    I'm listening to the WavFilePlayer running on Teensy 4.0 with the SD card on the breakout board socket.
  10. #3985
    2,202
    Well done. I installed your latest SD lib and confirmed WavFilePlayer with BUILTIN_SDCARD worked on T4 and T3.5. Also confirmed listfiles example worked. Whew.
  11. #3986
    20,606
    On new load always seems to load T3.2 as the selected board.
    I'm fixing this now. Will upload 1.47-beta6 later today.
    Looking to finalize 1.47 on Monday.
  12. #3987
    New York
    4,121
    Not a problem Paul. Know you have had your hands full
    Anyway, downloaded the SD Lib changes you made and Datalogger and Dumpfile are both now working again on the T4B2R. Great work on finding the problem.
  13. #3988
    Dec 2015
    LA
    129
    @wwatson
    Quote Originally Posted by wwatson View Post
    Installed a fresh copy of Arduino 1.8.9 and TD 1.47B5. I was compiling one of my test programs that use the time library and got an error.
    So I tried compiling 'TimeRTC.ino' and it gave the same error below:
    I searched for 'strcpy_P' in the compiler libs but did not find it.
    I changed line 20 in 'DateStrings.cpp' to this:
    #if defined(ESP8266) || defined(ARDUINO_ARCH_ESP32) || defined(__IMXRT1062__)
    It compiled ok after that.
    Can't wait for the T4 release
    Same issue with TimeLib.h on Teensy 3.2 and Teensy 4 with 1.47-beta5. Worked on 1.46
    thanks
    Last edited by bicycleguy; 08-11-2019 at 11:30 PM. Reason: added 3.2 and version info
  14. #3989
    20,606
    > Adafruit_GFX - new version from AdaFruit works for compiling on T4 - at least against the ST7789 code I tested - where the beta 5 version did not
    I've pulled in the latest Adafruit_GFX. I did a quick test with their Adafruit_ILI9341 lib, on Teensy 3.2 and 4.0. Seems to work fine.
    Going to package up 1.47-beta6 shortly. Hoping you can try some other displays tonight or tomorrow.
    > i2s (?) bad #ifdef led to compile breakage
    Fixed.
    > After install first Arduino startup returned to T_3.2, not last used T4.
    Fixed.
    Also fixed (hopefully) all the remaining "Beta2" to now say Teensy 4.0, like with detecting the boards in the Ports menu. 1.47-beta6 will also show a real image of the Teensy 4.0 hardware, rather than this chip picture we've see for so long.
  15. #3990
    Nov 2017
    Belgium
    108
    In beta5, output_i2s.cpp is missing line 507
    void AudioOutputI2Sslave::config_i2s(void)
    #if defined(KINETISK) //<-- missing
    	SIM_SCGC6 |= SIM_SCGC6_I2S;
    which prevents it from compiling.
  16. #3991
    20,606
    Fixed
    https://github.com/PaulStoffregen/Ti...e0836b037a58b2
  17. #3992
    20,606
    Quote Originally Posted by neurofun View Post
    Fixed. Code is on github. Will package up beta6 soon....
  18. #3993
    9,797
    Paul - also for release ::
    >> what of ...\hardware\teensy\avr\cores\teensy4\debug\printf.h and #define PRINT_DEBUG_STUFF
    Not sure if anything else would have to get resolved for release version?
    NOTE: When you turn that off there will be warnings last seen in the Fault_Handler code from the debug print gone missing.
    >> ...\hardware\teensy\avr\cores\teensy4\startup.c :: void HardFault_HandlerC(unsigned int *hardfault_args) {
    But will that code be #ifdef out for a NULL handler? that perhaps just does this?
    	if ( F_CPU_ACTUAL >= 600000000 )
    		set_arm_clock(100000000); // 100 or 200 or 300?
    	while (1) asm ("WFI");
    >> and there this is unused code :: void PJRCunused_interrupt_vector(void)
    >> Also unused in startup.c :: __attribute__((weak)) void userDebugDump(){
  19. #3994
    20,606
    I've uploaded 1.47-beta6. Links on msg #2.
    Please give this a try, on Teesny 4.0 and also on older boards. Is anything still broken?
    You may notice I pruned the USB Type and Optimize menus. As those things are implemented on Teensy 4.0, will add them back. They're just commended in boards.txt, so easy to uncomment if you want them.
    I'm going to try porting a couple more libs, and of course fix any more bugs that turn up. Really want to wrap up 1.47 tomorrow, so we have a stable release with Teensy 4.0 support.
    If you have a moment to give 1.47-beta6 a try, please let me know if there's any other bugs I really should fix before releasing it tomorrow?
  20. #3995
    20,606
    I turned off the Serial4 debug printing for 1.47-beta6.
    https://github.com/PaulStoffregen/co...fa000e59119b07
    Yup, already fixed.
    https://github.com/PaulStoffregen/co...70fa73f8ed13f9
  21. #3996
    9,797
    Yup, already fixed.
    Cool - will do a clean install of 1.8.9 and 1.47 ...
  22. #3997
    9,797
    Did a fresh UNZIP of IDE 1.8.9 and then TD 1.47b6. To confirm my sketchbook\libraries folder is EMPTY
    First couple of things okay so far then ...
    What's up with : "arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3\e xamples\graphicstest\graphicstest.ino"
    .. and same with "arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3\e xamples\DemoSauce\DemoSauce.ino"
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\TEMP\\arduino_build_408666/pch" "-IT:\\arduino-1.8.9t4\\hardware\\teensy\\avr\\cores\\teensy4" "-IT:\\arduino-1.8.9t4\\hardware\\teensy\\avr\\libraries\\SPI" "-IT:\\arduino-1.8.9t4\\hardware\\teensy\\avr\\libraries\\ILI9341 _t3" "T:\\TEMP\\arduino_build_408666\\sketch\\graphicst est.ino.cpp" -o "T:\\TEMP\\arduino_build_408666\\sketch\\graphicst est.ino.cpp.o"
    In file included from T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3\e xamples\graphicstest\graphicstest.ino:18:0:
    T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoNotFull()':
    T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.h:320:9: error: 'KINETISK_SPI0' was not declared in this scope
    sr = KINETISK_SPI0.SR;
    T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoEmpty()':
    T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.h:328:9: error: 'KINETISK_SPI0' was not declared in this scope
    T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.h:374:68: error: 'SPI_PUSHR_EOQ' was not declared in this scope
    KINETISK_SPI0.PUSHR = d | (pcs_data << 16) | SPI_PUSHR_CTAS(1) | SPI_PUSHR_EOQ;
    Using library SPI at version 1.0 in folder: T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\SPI
    Using library ILI9341_t3 at version 1.0 in folder: T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\ILI9341_t3
    Error compiling for board Teensy 4.0.
    Update>> installed & tested ' #include "Adafruit_ILI9341.h" ' : Paul noted he tested that and T4 works with that ili9341
    Using library Adafruit_GFX at version 1.5.6 in folder: T:\arduino-1.8.9t4\hardware\teensy\avr\libraries\Adafruit_GFX
    Using library Adafruit_ILI9341 at version 1.5.1 in folder: T:\tCode\libraries\Adafruit_ILI9341
    > Looking at the <XPT2046_Touchscreen.h> - for TouchTestIRQ.ino - oddly without touch the SPI SCLK LED is flickering?
  23. #3998
    Dec 2015
    LA
    129
    I can confirm that RSL_VNA, and a bunch of ILI9341_t3.h based programs run on T3.5 (touchpoint, graphicstest, demosauce ...) and compile on 4.0
    Teensy_Convolution_SDR didn't compile on T3.6 or t4 as it requires a little fooling around with libraries I didn't have time to do.
    All of the older programs I tested worked with beta6 and at least compiled with T4.
    Have an issue where serial.write(0x04); works but serial.write(0x00) on T4 gives 'call of overloaded 'write(int)' is ambiguous' which can be fixed with a (uint8_t) cast
    Overall beta5 was a no-go for me but beta6 seems respectable.
  24. #3999
    New York
    4,121
    @defragsrer
    Not at computer now but did $KurtEs PR get pulled in for the 9441_t3 lib? If not it won't work.
  25. #4000
    9,797
    @defragsrer
    I'm suspecting it did not get pulled in - was hoping KurtE might be online and see this to confirm.
    >> Nothing OPEN for @KurtE - one closed July 2nd ?? :: https://github.com/PaulStoffregen/SP...3Aopen+is%3Apr
    @bicycleguy - any chance you have a sketchbook\libraries copy of a WIP SPI on your system?
    <EDIT> from post #4003 - not SPI but ILI9341_t3 ?
    >> @bicycleguy - is there a local libraries version of WIP ILI9341_t3 in sketchbook?
