Page 3 of 166 FirstFirst 1 2 3 4 5 13 53 103 ... LastLast
Results 51 to 75 of 4128
Thread: Teensy 4.0 First Beta Test
  1. #51
    9,037
    err...no... "hot" fires before critical. So, the user can react to "hot". critical is _really_ critical. And with a reset, all pins get disabled, so, in a sensitve application, the user can add pullups/pulldonws to ensure a secure shutdown-state. This is needed anyway, because during startup the pins are not enabled, too.
    That looks Cool Frank … err … Hot … Warm … : too many words :: Okay - so Frank is seeing 'hot' what I called 'Warning' - then Critical == hot Shutdown temp.
  2. #52
    Germany NRW
    5,679
    :-) I use "cold" - > "hot" -> "critical"
    Critical is too late to do anything.. and we don't want a crash, a stackoverflow or another bug here, or a delay(1000000) .. so please no usercode for "critical"!
    On the other hand, "hot" can be free for anything ..
  3. #53
    Dec 2016
    Montreal, Canada
    3,021
    Tim, just got mine an hour or so ago, gonna have to clean up the sphagetti wiring test stuff i did with the t3.x/lc units on my desk and figure out what i can help with hehe
  4. #54
    Senior Member+
    New York
    3,684
    That looks Cool Frank err Hot Warm : too many words :: Okay - so Frank is seeing 'hot' what I called 'Warning' - then Critical == hot Shutdown temp.
    Ok - just woke up from my nap "HOT-WARNING" is what I would be the "HIGH Temp" threshold where "CRITICAL - HOT SHUTDOWN TEMP" would be what the manual refers to as "PANIC" temp. We can set these thresholds appropriately - just have to decide.
    As Tim said in his post, I want to the temperature monitor working first - "NO THROTTLING" - just the hooks for the interrupts that will let us decide what we what to do. Then we can put it into the startup code to have it run continuously.
    Now with all that said - after doing a little more homework:
    The panic threshold is a special programmable threshold in that if the temperature increases above this value and the temperature-panic-reset interrupt is enabled in the System Reset Controller, the hardware will assume that software no longer has control over the thermal situation and will initiate a reset of the chip.
    see page 2983. Also, on reset:
    The SRSR is a write to one clear register which records the source of the reset events for the chip. The SRC reset status register will capture all the reset sources that have occurred.
    and it just so happens on temperature reset "tempsense_rst_b" bit is set in the SRC Reset Status Register (SRC_SRSR). So on startup the bit can be tested and then just HALT.
    Now - see what happens when I get some sleep.
  5. #55
    20,312
    I've put the first beta installer on msg #2.
    Hopefully no big software surprises, though it does have the boards.txt which is missing from github, and a build of Teensy Loader that recognizes the new board. The actual protocol is pretty much identical to Teensy 3.6 - just using a new ID number in the HID report descriptor. One other minor change is the linker scripts now put an ID symbol into the .elf files and Teensy Loader now uses that to figure out which board was intended. If that new symbol is missing, it falls back to the same old guessing based on stack starting address (the reason we had to leave 8 bytes unused on Teensy 3.5), so it should still be fully compatible with all existing compiled .elf files.
    I had hoped to do much more before posting this, and I will soon, but here's a very rough first version!
    The core library is still filled with printf output. It's sent to Serial4, so if you have a USB-serial cable, or another Teensy running File > Examples > Teensy > USB_Serial > USBtoSerial, connect its receive pin to Teensy4's pin 17 output to see the many printf messages. Baud rate is 115200.
    USB Serial is sadly still not very stable, and so far I've only tested with Linux - so it may not work at all on Windows & Mac. I also still have a small pile of unpublished I2C & SPI code sitting here. Will do more on this tonight and hopefully put up another beta installer before more beta boards arrive.
  6. #56
    Senior Member+
    New York
    3,684
    Just installed a clean copy of Arduino 1.8.8 and installed the T4 Beta-1 of Teensyduino. No problems on the on installing Teensyduino and compiling the Blink sketch - no errors Running a windows 10(x64) home edition version 1809. The T4 is identified as Teensy 4 - Beta1. Let the games begin.
    Mike
  7. #57
    9,037
    TeensyDuino version 1.46 beta 1 installed on/over a copy of IDE 1.88, it worked.
    Did BLINK as Third Sketch and it does Verify with No Warning or Error - Half RAM?:
    Sketch uses 5648 bytes (0%) of program storage space. Maximum is 1572864 bytes.
    Global variables use 10608 bytes (4%) of dynamic memory, leaving 251536 bytes for local variables. Maximum is 262144 bytes.
    Cool - For T4 Debug Out - based on Post #3 Serial4 is :: PIN 17/A3 UART3_TX
    Fun Indeed … with the first two open IDE sketches::
    First sketch Verify is ugly as 'device specific' things don't exist as the Debug_t3 open looked for them: GPIOC_PTOR, UART2_C2, SIM_SCGC(???)
    <edit> - T4 MCU's won't have bitbanding access like with :: GPIOC_PTOR
    Second includes freemem() from forum : warning about 'usb_transmit', error "undefined reference to `_sbrk'"
  8. #58
    Germany NRW
    5,679
    Oh... it'll be exciting. DHL has announced a new arrival time. Monday. That's exciting because Monday (dec, 31) is only half a working day here. Usually, only in the morning, before noon we work on this day.. not all, but most of us. Tuesday is a holiday and nobody works. Well, maybe I get the T4 Monday... (Which would be awesome, but I can't believe it...)
  9. #59
    2,086
    i compiled with new teensyduino on 1.8.8. I don't think fpu is correct in boards.txt. it reads -mfpu=fpv4-sp-d16 -fsingle-precision-constant
    probably should be -mfpu=fpv5-d16
    Not sure how to handle single-precision-constant, since T4 fpu does both double and single precision in hardware.
  10. #60
    Dec 2016
    Montreal, Canada
    3,021
      static uint32_t reflash = millis();
      (void)reflash;
    it seems declaring static variables as opposed to local vars throws errors
    C:\Users\Tony\Documents\Arduino\BETA-T4/BETA-T4.ino:7: undefined reference to `__cxa_guard_acquire'
    C:\Users\Tony\Documents\Arduino\BETA-T4/BETA-T4.ino:7: undefined reference to `__cxa_guard_release'
  11. #61
    9,037
    Works like this - something more to do with the assignment of the millis() return?:
      uint32_t ii;
      static uint32_t jj;
      ii = reflash;
      ii++;
      jj = ii;
      jj++;
  12. #62
    Dec 2016
    Montreal, Canada
    3,021
    This works:
      static uint32_t reflash = 20000UL;
      (void)reflash;
    so it seems millis() is fine to set a scoped local but not a scoped static
    EDIT:
    micros() has same behaviour.
    EDIT2: I can replicate this with a simple function return:
      static uint32_t reflash = test();
      (void)reflash;
    uint32_t test() {
      return 1234UL;
    C:\Users\Tony\AppData\Local\Temp\arduino_build_504252\sketch\BETA-T4.ino.cpp.o: In function `loop':
    Error compiling for board Teensy 4-Beta1.
    As simple as it is I don't think it's pointing to an issue of millis/micros, something else causing it
    most google searches say add a library flag "-lstdc++" in the makefile to fix the issue
  13. #63
    2,086
    compiling coremark, i too get sbrk error
    arduino-1.8.8/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu/libc.a(lib_a-sbrkr.o): In function `_sbrk_r':
    sbrkr.c:(.text._sbrk_r+0xc): undefined reference to `_sbrk'
  14. #64
    Dec 2016
    Montreal, Canada
    3,021
    ok i added a compiler flag in boards.txt
    teensy4b.build.flags.cpp=-fno-exceptions -felide-constructors -std=gnu++14 -fno-threadsafe-statics -Wno-error=narrowing -fno-rtti
    that seems to compile
    now if you look at the demo:
      pinMode(13, OUTPUT);
      (void)reflash;
      if ( millis() - reflash > 500 ) {
        reflash = millis();
        //    digitalWrite(13, !digitalRead(13)); <------------------------ digitalread doesnt work?
        static bool flip;
        digitalWrite(13, flip = !flip);
    toggling a bool to flash the led every millis() interval is fine. I'm not sure if digitalRead is working because led just stays on forever when uncommented
  15. #65
    9,037
    Wondering how much work it was to get this much to work ... this past YEAR! ... not to mention the purchasing and the EE part and making PCB's … before all the issues get posted … Thanks Paul for working to make this tame and usable.
    Nothing in mailbox or recorded to post office yet ... just looking around with Verify ...
    Paul ... I opened Verbose on Loader and still seeing repeat 'callback' on my Win 10 - I closed Teensy_ports and they stopped - if msgs not likely relevant to T4 can they get disabled?:
    // ... about 15 pages ...
    16:45:14.740 (ports 2): callback C12C
    16:45:16.757 (ports 2): callback C12C
    16:45:17.456 (loader): remote connection 1332 closed
    <EDIT> WORKED for me too adding to build.flags >> -fno-threadsafe-statics
  16. #66
    9,037
    That is in :: T:\arduino-1.8.8T4_146\hardware\teensy\avr\cores\teensy4\libc .c
    Swapping/commenting out the first line and replacing it allows it to compile:
    //extern unsigned long _ebss;
    char *__brkval = (char *)&_ebss; // TODO: put heap into OCRAM, not DTCM
  17. #67
    Dec 2016
    Montreal, Canada
    3,021
    coremark running
    647120
    2K performance run parameters for coremark.
    647810 us 13072680
    CoreMark Size    : 666
    Total ticks      : 13069010
    Total time (secs): 13.069010
    Iterations/Sec   : 2295.506699
    Iterations       : 30000
    Compiler version : 5.4.1 20160919 (release) [ARM/embedded-5-branch revision 240496]
    Compiler flags   :
    Memory location  : STACK
    seedcrc          : 0xe9f5
    [0]crclist       : 0xe714
    [0]crcmatrix     : 0x1fd7
    [0]crcstate      : 0x8e3a
    [0]crcfinal      : 0x5275
    Correct operation validated. See readme.txt for run and reporting rules.
    CoreMark 1.0 : 2295.506699 / 5.4.1 20160919 (release) [ARM/embedded-5-branch revision 240496]  / STACK
    .... done
    done
    Thanks Tim, I used the same line though
    /*extern*/ unsigned long _ebss;
  18. #68
    20,312
    The memory usage info is wrong for program size, maybe ram too. Correct info can be found in the .sym file.
    For now, we're using the fixed partition of the RAM as 128K ITCM (code that isn't "progmem"), 128K DTCM (variables & strings that aren't progmem) and 256K OCRAM (currently not used at all, but soon dmamem and malloc/net). Later we'll switch to automatically sizing ITCM to fit the compiled code, fixed size for OCRAM, and DTCM taking the rest.
  19. #69
    Dec 2016
    Montreal, Canada
    3,021
    #include "circular_buffer.h"
    Circular_Buffer<uint32_t, 8> cb;
    Circular_Buffer<uint32_t, 8, 100> cba;
    #include "coremark.h"
      uint32_t arr[5] = { 1, 2, 3, 4, 5 };
      cba.push_back(arr, 5);
      cb.push_back(0x1234);
      (void)reflash;
        reflash = millis();
        static bool flip;
        Serial4.println("Toggled Led");
        Serial4.println(cb.peek());
        //    Serial4.println("coremark running\n");
        //    Serial4.println(micros());
        //    mainCoreMark();
        //    Serial4.println("done\n");
        uint32_t arr[5];
        cba.pop_front(arr, 5);
        for ( uint8_t i = 0; i < 5; i++ ) {
          Serial4.print(arr[i]); Serial4.print(" ");
        } Serial4.println();
    CB/CBA works on T4 both circular and array versions, without warnings or errors
    It uses the algorithm c++ library
  20. #70
    Senior Member+
    New York
    3,684
    Tried running a eigen library test and after incorporating Tim's sbrk fix and Tony's -cxa fix and manitou's -mpu change the only error received was as follows:
    f:\arduino-1.8.8\hardware\tools\arm\arm-none-eabi\include\c++\5.4.1\type_traits:38:28: fatal error: bits/c++config.h: No such file or directory.
    type_traits is called from wiring.h. There is a c++config.h file but in arduino-1.8.8\hardware\tools\arm\arm-none-eabi\include\c++\5.4.1\arm-none-eabi\armv7e-m\bits and up level in F:\arduino-1.8.8\hardware\tools\arm\arm-none-eabi\include\c++\5.4.1\arm-none-eabi\bits. Do we need it? or which copy to we link too?
    EDIT: Problem was changing this -mfpu=fpv4-sp-d16 -fsingle-precision-constant to -mfpu=fpv5-sp-d16. When I put it back that error disappeared. I also forgot to get rid of -lstdc++ now I am left with:
    undefined reference to `operator new[](unsigned int)'
  21. #71
    Dec 2016
    Montreal, Canada
    3,021
    I tested the listed non standard AVR functions on the list, they match the outputs as expected
        float f_val = 123.67942;
        char outstr[15];
        dtostrf(f_val, 7, 5, outstr);
        Serial4.println(outstr);
        long  a = 10000000;
        char buffer[50];
        ltoa(a, buffer, 16); // here 2 means binary
        Serial4.printf("value = %s\n", buffer);
        char output[40];
        uint32_t tmp = 0x12345678;
        ultoa(tmp, output, 16);
        Serial4.println(output);
    T3.2 monitor:
    value = 989680
    12345678
  22. #72
    Dec 2016
    Montreal, Canada
    3,021
    Mike, I don't know which version you have or if you messed up the build file but im using bolderflight Eigen library on github, it wouldn't compile though because of the operator new error:
     undefined reference to `operator new(unsigned int)'
    however i added 3 lines AFTER the demo's includes:
    #include <Eigen.h>     // Calls main Eigen matrix class library
    #include <Eigen/LU>             // Calls inverse, determinant, LU decomp., etc.
    using namespace Eigen;    // Eigen related statement; simplifies syntax for declaration of matrices
    #include <stdlib.h> // for malloc and free
    void * operator new(size_t size) {
      return malloc(size);
    void operator delete(void* ptr) {
      if (ptr) free(ptr);
    it compiles without warnings or errors
    T3.2 monitor shows:
    nrow: 6
    ncol: 6
    0.112775, 0.048292, -0.313197, -0.067979, 0.238543, 0.096648,
    -0.002733, -0.177438, 1.128800, 0.750399, -1.283369, -0.084223,
    0.645583, 0.189010, -1.758835, -1.095649, 2.438091, 0.718835,
    -0.613755, -0.359209, 2.150181, 1.179505, -2.575186, -0.930255,
    0.504728, 0.085257, -0.751615, -0.277679, 1.106807, 0.128982,
    -0.107398, 0.104756, 0.108780, 0.094344, -0.231374, 0.222546,
  23. #73
    Senior Member+
    New York
    3,684
    Interesting Tony,
    Just reinstalled teensyduino did Tim's fix for sbrk and your fix
    and that's it. I added in those lines to bolderflight's eigentest example which is what you ran but I am still getting the error on
    . Not sure I could have messed up.
    I did a verify on our coremark file and your CBA, both compiled without errors. Same for Brian's ublox library.
    EDIT> this problem seems like deja vu where I ran into it another time and can't remember if it was related to newlib or newlib-nano.
  24. #74
    9,037
    Prior post ...
    Just a hack to get the compiler happy ...
    Interesting Tony,
    ... Tim's fix for sbrk
    - copied there also was Paul's TODO note where the HEAP needs get relocated - and it somehow doesn't like the former expression that evolves from this.
    T:\arduino-1.8.8T4_146\hardware\teensy\avr\cores\teensy4\imxr t.ld:
    74: _ebss = ADDR(.bss) + SIZEOF(.bss);
  25. #75
    2,086
    FWIW, a few weeks back working on NXP EVK eval board, I got this bits/c++config.h error when trying to use the Arduino tool chain to test gcc 5.4.1 on EVKB programs. Eventually I fetched a fresh 5.4.1 tool chain from GNU and the problem disappeared.
