Page 33 of 173 FirstFirst ... 23 31 32 33 34 35 43 83 133 ... LastLast
Results 801 to 825 of 4311
Thread: Teensy 4.0 First Beta Test
  1. #801
    New York
    4,102
    Yes, I provided setClockFreq snippet (post #454). If you look at the ref manual, the CCR DIV is treated as +2, so if DIV is 0, peripheral clock is divided by 2. If DIV is 1, clock is divided by 3 ... So if you want the clock divided by 8, you put 6 in the CCR DIV field.
    Thanks Tom, and for the explanation, getting tired of looking at that manual. Too many posts, think I agree with Frank - need sub-forums.
    The discrete SPI dividers for 75 mhz are 2,3,4,5 .... which gives SPI CLK of 37.5, 25, 18.75 ... the setClockFreq algorithm picks the divider less than or equal to user-requested frequency
    Noticed I ran a test sketch and put in various clock frequencies just to see.
  2. #802
    2,196
    Maybe Ethernet? I just tried to compile Ethernet udpntp example, i get compile errors, undefined reference to `vtable for IPAddress', but I have other domestic chores in the next few hours ...
    This vtable error is some sort of C++ thingee above my old C skills. Here is the simplest program that gets compile errors on T4, works on T3.2. (I believe i have copied in stream.cpp and WString.cpp into my T4 core folder)
    #include <IPAddress.h>
    IPAddress ip(192, 168, 1, 15);
      while(!Serial);
      Serial.println(ip);
    Last edited by manitou; 01-16-2019 at 09:43 AM. Reason: further simplify test sketch
  3. #803
    2,333
    Other things to be done: set/get time, start and sync HPRTC and test alarm, core set-time logic
    Added alarm on LPRTC (official manual does not give information but CMSIS/Keil etc give other addresses)
    OK, got Alarm firing
    AND
    LPRTC Alarm can indeed be used to restart program after "Turn off System Power" command
    Without additional actions (clock etc) consumption drops from 80 mA while running to 25 mA while System Power Off.
  4. #804
    2,196
    AND
    Excellent! I was looking at doing that this morning. But you have left too much to the imagination ... can you post/github your demo code?
  5. #805
    Germany NRW
    5,679
    SPI: What was the reason to choose 7? (528000000/7) isn't 2 much better?
    I'd really really like to change this... would be better for everything. SD for example can't reach 25MHz now, because ther is one slightly higher 25.1 MHZ - the next step is 18.8 MHz.
    With 2 we could have 24MHz - so..why this 7?
    Edit: Just tested with SD - works.
    I'd like to add a function that allows to set this. This would be most flexible.
  6. #806
    2,333
    Here it comes.
    #include <time.h>
      int  tm_sec;
      int tm_min;
      int tm_hour;
      int tm_mday;
      int tm_mon;
      int tm_year;
      int tm_wday;
      int tm_yday;
      int tm_isdst;
    // following routines are based on http://howardhinnant.github.io/date_algorithms.html
    struct tm seconds2tm(uint32_t tt)
    { struct tm tx;
      tx.tm_sec   = tt % 60;    tt /= 60; // now it is minutes
      tx.tm_min   = tt % 60;    tt /= 60; // now it is hours
      tx.tm_hour  = tt % 24;    tt /= 24; // now it is days
      tx.tm_wday  = ((tt + 4) % 7) ;      // Sunday is day 0
      tt += 719468;
      uint32_t era = (tt >= 0 ? tt : tt - 146096) / 146097;
      uint32_t doe = (tt - era * 146097);                             // [0, 146096]
      uint32_t yoe = (doe - doe/1460 + doe/36524 - doe/146096) / 365; // [0, 399]
      uint32_t yy = (yoe) + era * 400;
      uint32_t doy = doe - (365*yoe + yoe/4 - yoe/100);            // [0, 365]
      uint32_t mp = (5*doy + 2)/153;                               // [0, 11]
      uint32_t dd = doy - (153*mp+2)/5 + 1;                        // [1, 31]
      uint32_t mm = mp + (mp < 10 ? 3 : -9);                       // [1, 12]
      tx.tm_year=yy + (mm <= 2);
      tx.tm_mday=dd;
      tx.tm_mon=mm;
      return tx;
    uint32_t tm2seconds(struct tm tx)
      uint32_t yy = tx.tm_year;
      uint32_t mm = tx.tm_mon;
      uint32_t dd = tx.tm_mday;
      yy -= mm <= 2;
      uint32_t era = (yy >= 0 ? yy : yy-399) / 400;
      uint32_t yoe = (yy - era * 400);      // [0, 399]
      uint32_t doy = (153*(mm + (mm > 2 ? -3 : 9)) + 2)/5 + dd-1;  // [0, 365]
      uint32_t doe = yoe * 365 + yoe/4 - yoe/100 + doy;         // [0, 146096]
      uint32_t tt = era * 146097 + (doe) - 719468;
      tt *= (24*3600);
      tt += (tx.tm_hour*60+tx.tm_min)*60+tx.tm_sec;
      return tt;
    // see also https://github.com/manitou48/teensy4/blob/master/rtc.ino
    #define SNVS_DEFAULT_PGD_VALUE (0x41736166U)
    #define SNVS_LPSR_PGD_MASK                       (0x8U)
    #define SNVS_LPSRTCMR      (IMXRT_SNVS.offset050)
    #define SNVS_LPSRTCLR      (IMXRT_SNVS.offset054)
    #define SNVS_LPTAR        (IMXRT_SNVS.offset058)
    #define SNVS_LPCR_SRTC_ENV_MASK         (0x1U)
    #define SNVS_LPCR_SRTC_ENV(x)           (((uint32_t)(((uint32_t)(x)) << 0U)) & SNVS_LPCR_SRTC_ENV_MASK)
    #define SNVS_LPCR_LPTA_EN_MASK          (0x2U)
    #define SNVS_LPCR_LPTA_EN(x)            (((uint32_t)(((uint32_t)(x)) << 1U)) & SNVS_LPCR_LPTA_EN_MASK)
    #define SNVS_LPCR_MC_ENV_MASK           (0x4U)
    #define SNVS_LPCR_MC_ENV(x)             (((uint32_t)(((uint32_t)(x)) << 2U)) & SNVS_LPCR_MC_ENV_MASK)
    #define SNVS_LPCR_LPWUI_EN_MASK         (0x8U)
    #define SNVS_LPCR_LPWUI_EN(x)           (((uint32_t)(((uint32_t)(x)) << 3U)) & SNVS_LPCR_LPWUI_EN_MASK)
    #define SNVS_LPCR_SRTC_INV_EN_MASK      (0x10U)
    #define SNVS_LPCR_SRTC_INV_EN(x)        (((uint32_t)(((uint32_t)(x)) << 4U)) & SNVS_LPCR_SRTC_INV_EN_MASK)
    #define SNVS_LPCR_DP_EN_MASK            (0x20U)
    #define SNVS_LPCR_DP_EN(x)              (((uint32_t)(((uint32_t)(x)) << 5U)) & SNVS_LPCR_DP_EN_MASK)
    #define SNVS_LPCR_TOP_MASK              (0x40U)
    #define SNVS_LPCR_TOP(x)                (((uint32_t)(((uint32_t)(x)) << 6U)) & SNVS_LPCR_TOP_MASK)
    #define SNVS_LPCR_PWR_GLITCH_EN_MASK    (0x80U)
    #define SNVS_LPCR_PWR_GLITCH_EN(x)      (((uint32_t)(((uint32_t)(x)) << 7U)) & SNVS_LPCR_PWR_GLITCH_EN_MASK)
    #define SNVS_LPCR_LPCALB_EN_MASK        (0x100U)
    #define SNVS_LPCR_LPCALB_EN(x)          (((uint32_t)(((uint32_t)(x)) << 8U)) & SNVS_LPCR_LPCALB_EN_MASK)
    #define SNVS_LPCR_LPCALB_VAL_MASK       (0x7C00U)
    #define SNVS_LPCR_LPCALB_VAL(x)         (((uint32_t)(((uint32_t)(x)) << 10U)) & SNVS_LPCR_LPCALB_VAL_MASK)
    #define SNVS_LPCR_BTN_PRESS_TIME_MASK   (0x30000U)
    #define SNVS_LPCR_BTN_PRESS_TIME(x)     (((uint32_t)(((uint32_t)(x)) << 16U)) & SNVS_LPCR_BTN_PRESS_TIME_MASK)
    #define SNVS_LPCR_DEBOUNCE_MASK         (0xC0000U)
    #define SNVS_LPCR_DEBOUNCE(x)           (((uint32_t)(((uint32_t)(x)) << 18U)) & SNVS_LPCR_DEBOUNCE_MASK)
    #define SNVS_LPCR_ON_TIME_MASK          (0x300000U)
    #define SNVS_LPCR_ON_TIME(x)            (((uint32_t)(((uint32_t)(x)) << 20U)) & SNVS_LPCR_ON_TIME_MASK)
    #define SNVS_LPCR_PK_EN_MASK            (0x400000U)
    #define SNVS_LPCR_PK_EN(x)              (((uint32_t)(((uint32_t)(x)) << 22U)) & SNVS_LPCR_PK_EN_MASK)
    #define SNVS_LPCR_PK_OVERRIDE_MASK      (0x800000U)
    #define SNVS_LPCR_PK_OVERRIDE(x)        (((uint32_t)(((uint32_t)(x)) << 23U)) & SNVS_LPCR_PK_OVERRIDE_MASK)
    #define SNVS_LPCR_GPR_Z_DIS_MASK        (0x1000000U)
    #define SNVS_LPCR_GPR_Z_DIS(x)          (((uint32_t)(((uint32_t)(x)) << 24U)) & SNVS_LPCR_GPR_Z_DIS_MASK)
    #define SNVS_LPSR_LPTA                  (0x1U)
    void rtc_init()
    { CCM_CCGR2 |= CCM_CCGR2_IOMUXC_SNVS(CCM_CCGR_ON);
      SNVS_LPGPR = SNVS_DEFAULT_PGD_VALUE;
      SNVS_LPSR = SNVS_LPSR_PGD_MASK;
      // ? calibration
      // ? tamper pins
      SNVS_LPCR &= ~SNVS_LPCR_LPTA_EN_MASK; // clear alarm
      while (SNVS_LPCR & SNVS_LPCR_LPTA_EN_MASK);
      SNVS_LPTAR=0;
      SNVS_LPCR |= 1;             // start RTC
      while (!(SNVS_LPCR & 1));
    extern void *__rtc_localtime;
    void rtc_set_time(uint32_t secs)
    { //uint32_t secs = 1547051415;
      SNVS_LPCR &= ~1;   // stop RTC
      while (SNVS_LPCR & 1);
      SNVS_LPSRTCMR = (uint32_t)(secs >> 17U);
      SNVS_LPSRTCLR = (uint32_t)(secs << 15U);
    uint32_t rtc_secs() {
      uint32_t seconds = 0;
      uint32_t tmp = 0;
      /* Do consecutive reads until value is correct */
      do
      { seconds = tmp;
        tmp = (SNVS_LPSRTCMR << 17U) | (SNVS_LPSRTCLR >> 15U);
      } while (tmp != seconds);
      return seconds;
    void rtc_stopAlarm()
      SNVS_LPSR |= 1;
    void rtc_isr(void)
      SNVS_LPSR |= 1;
      Serial.println("Alarm");
      asm("DSB"); // needed? what does it
    void rtc_initAlarm(uint32_t prio=13)
      attachInterruptVector(IRQ_SNVS_IRQ, rtc_isr);
      NVIC_SET_PRIORITY(IRQ_SNVS_IRQ, prio*16); // 8 is normal priority
      NVIC_DISABLE_IRQ(IRQ_SNVS_IRQ);
    void rtc_setAlarm(uint32_t alarmSeconds)
    {   uint32_t tmp = SNVS_LPCR; //save control register
        /* disable SRTC alarm interrupt */
        rtc_stopAlarm();
        SNVS_LPTAR=alarmSeconds;
        while(SNVS_LPTAR != alarmSeconds);
        NVIC_ENABLE_IRQ(IRQ_SNVS_IRQ);
        SNVS_LPCR = tmp | SNVS_LPCR_LPTA_EN_MASK; // restore control register and set alarm
        while(!(SNVS_LPCR & SNVS_LPCR_LPTA_EN_MASK));
    uint32_t rtc_getAlarm()
      return SNVS_LPTAR;
    void doShutdown(void)
      SNVS_LPCR |=(1<<6);
      while (!Serial);
      Serial.println("Start");
      rtc_init();
      if((uint32_t)&__rtc_localtime> (rtc_secs()+10))
        rtc_set_time((uint32_t)&__rtc_localtime);   //LPSRTC will start at 0 otherwise
      rtc_initAlarm(13);
      static int count=0;
      struct tm tx;
      uint32_t t0 = rtc_secs();
      tx=seconds2tm(t0);
      uint32_t t1 = tm2seconds(tx);
      Serial.printf("%d %d : ",t0,t1);
      Serial.printf("%4d-%02d-%02d %02d:%02d:%02d - %d\n",
                    tx.tm_year,tx.tm_mon,tx.tm_mday, tx.tm_hour,tx.tm_min,tx.tm_sec,
                    tx.tm_wday);
      count++;
      if(count==50)
        Serial.println("Stop");
        rtc_setAlarm(t0+60);
        Serial.printf("Alarm: ");  Serial.println(rtc_getAlarm());
        Serial.println("Shutdown");
        doShutdown();
        Serial.println("Reset");
  7. #807
    Germany NRW
    5,679
    Yup. I'll create a pullrequest for a additional function. I really hope Paul accepts it 3 would allow 58.7 Mhz.
    PLL2 528000000 *
    2 3 4 5 6 7 8 CBCMR LPSPI
    1 264000000 176000000 132000000 105600000 88000000 75428571,4 66000000
    2 132,0 88,0 66,00 52,80 44,00 37,71 33,00
    3 88,0 58,7 44,00 35,20 29,33 25,14 22,00
    4 66,0 44,0 33,00 26,40 22,00 18,86 16,50
    5 52,8 35,2 26,40 21,12 17,60 15,09 13,20
    6 44,0 29,3 22,00 17,60 14,67 12,57 11,00
    7 37,7 25,1 18,86 15,09 12,57 10,78 9,43
    8 33,0 22,0 16,50 13,20 11,00 9,43 8,25
    9 29,3 19,6 14,67 11,73 9,78 8,38 7,33
    10 26,4 17,6 13,20 10,56 8,80 7,54 6,60
    11 24,0 16,0 12,00 9,60 8,00 6,86 6,00
    12 22,0 14,7 11,00 8,80 7,33 6,29 5,50
    13 20,3 13,5 10,15 8,12 6,77 5,80 5,08
    14 18,9 12,6 9,43 7,54 6,29 5,39 4,71
    15 17,6 11,7 8,80 7,04 5,87 5,03 4,40
    255 1,0 0,7 0,52 0,41 0,35 0,30 0,26
    256 1,0 0,7 0,52 0,41 0,34 0,29 0,26
    257 1,0 0,7 0,51 0,41 0,34 0,29 0,26
    Attached Files Attached Files
  8. #808
    2,196
    You should be able to run SPI at 37.5 mhz (ask for 40 mhz in spisettings). Paul made the choice of 528000000/7. It could be a smaller divider. On the EVKB SDK tests we were using 528000000/5, max SPI clock of 52.8 mhz. The setClockFrequency code is hardcoded with 528000000/7, so that would need to changed with variables or define's. base clock is set in SPI.cpp
    CCM_CBCMR = (CCM_CBCMR & ~(CCM_CBCMR_LPSPI_PODF_MASK | CCM_CBCMR_LPSPI_CLK_SEL_MASK)) |
    CCM_CBCMR_LPSPI_PODF(6) | CCM_CBCMR_LPSPI_CLK_SEL(2);
    PODF is divider -1
  9. #809
    Germany NRW
    5,679
    Yes i've seen the / 7 - it's simple to use the CBCMR register-value instead. Then, the user has the _chance_ to change it.. without modifiying the SPI library.
    In addition a small function to change the CBCMR LPSPI, and all is perfect.
  10. #810
    New York
    4,102
    Hey Frank. Just made your change changed PDOF to 1 and the divider to 2 in spi settings. Th measured clk freq is 29.41Mhz vs 25.41mhz at current settings.
    Ok, missed your post.
    EDIT: just checked with 3. No real difference in the frequency of 29.41
    EDIT: At 60Mhz getting 57.14Mhz, Mosi waveform looks good as well.
  11. #811
    Germany NRW
    5,679
    I've posted a table ..
    Edit: With excel sheet.
  12. #812
    9,707
    That math looks better Frank - more options at the ~30 MHz sweetspot - and possibilities on the higher end. Nice to have a steady background clock versus on F_CPU or F_BUS - how many htings would change that do feed off the PLL clock? Will that let T4 UART Serial get over 5.33 MBaud?
  13. #813
    New York
    4,102
    Adafruit_ILI9341
    Starting looking at the adafruit library and was wondering if someone could explain to me what the advantages are of doing this instead of setting the pins. Guessing its faster:
        clkport     = portOutputRegister(digitalPinToPort(_sclk));
        clkpinmask  = digitalPinToBitMask(_sclk);
        mosiport    = portOutputRegister(digitalPinToPort(_mosi));
        mosipinmask = digitalPinToBitMask(_mosi);
        *clkport   &= ~clkpinmask;
        *mosiport  &= ~mosipinmask;
    These are of course are throwings errors for conversion.
  14. #814
    20,576
    Oh, that wasn't ever meant to be any sort of official decision. It was just something I did very quickly, so we could have a minimal-but-working SPI library to start testing.
  15. #815
    20,576
    Yup, it's faster.
    On many of these Adafruit libs that do direct I/O, we're going to have to deal with the GPIO registers now being only 32 bits. Fortunately in the last few years many other boards have appeared that have 32 bit registers, so most of the libs now have stuff in place. The situation isn't as terrible as a few years ago when everything assumed I/O registers must be 8 bits.
    Of course, on Teensy 3.x the GPIO registers were also 32 bits. But there are 2 important differences. The main one is the M4's bitband. On Teensy 3.x, these functions do not give you the actual GPIO register address, but rather the bitband address for just 1 pin. The bitband allows any size access, even though the data is only in the lowest bit, so this ancient code that assumes all GPIO is 8 bit registers is perfectly happy talking to the bitband. Using the bitband also solves non-atomic read-modify-write bugs that Adafruit is probably unaware exist, which libraries doing read-modify-write for different bits in the same registers, from interrupts, can cause havoc. I really miss the bitband.
    The other difference on Teensy 3.x is the GPIO registers do allow 8 bit access. You'll just write to the low 8 bits, and the upper 24 bits remain unchanged.
    Sadly, NXP made the GPIO only 32 bits in this new chip, and ARM didn't put the bitband into M7. I believe most of these Adafruit libs using this direct GPIO access can be ported pretty easily. The main problem is going to be they probably have #ifdef checks that make the registers 8 bits for Teensy 3.x.
  16. #816
    Germany NRW
    5,679
    This value has to be choosen carefully, I think...
    Please shout if I say something wrong: SD-Cards want initialization with 400Khz, and they accept 25MHz for datatransfer. 25.1Mhz are probably fine, too.
    I've tried 1MHz initialization with two cards, and they work, but probably not all cards are happy with that..
    Now, this can be important: If we have TWO SPI in the future, we just can't change this clock - it affects both SPIs.
    If we have ONE SPI, no problem - then, we can calculate the best value for each transaction.
    So... Paul... ONE or TWO?
  17. #817
    New York
    4,102
    Actually other than setting up the pins not sure they are doing anything else with them in terms of graphics. The display commands and writes link back to Adafruit GFX library. Taking a quick look have to sort it out - nothing straight forward.
  18. #818
    New York
    4,102
    CAPACITIVE SENSOR LIBRARY
    Initial testing:
    1. Doesn't work on a T3.2, tried as a test
    2. On the T4, it does work sort of. By this I mean the values changes as I touch the copper foil, and change depending on how long I hold my finger down or how much of my finger touches the foil. But - the readings come out about ever 2000 ms vs the 15 in your video (yes I looked). Using 1M resistor for send and 1k for receive (couldn't find any 4.7Ms.
    3. Even without anything attached readings were 2secs apart.
    Have not looked at the code yet just wanted to report the results so far.
    EDIT: In all honesty the resistors aren't soldered to the foil, I have foil that is conductive on both sides so I just taped them down. I did measure the resistance from the foil to the other side of the resistor and did read 1M and 1K.
  19. #819
    New York
    4,102
    @Paul
    ADAFRUIT ILI9341 and GFX Libraries
    Just visited the Adafruit GitHub pages for those two libraries. Looks like there was a update a couple-three months ago that add 32-bit reg support. Essentially they re-worked their libraries. You may want to update the Teensyduino versions. Going to download and take a look at the updated libararies.
    Mike
    UPDATE: GOOD NEWS. The updated Adafruit library works with the T4 - attached a ILI9341 and ran the graphicstest sketch - worked with no changes to the library. Thanks for the hint Paul.
    ILI9341 Test!
    Display Power Mode: 0x94
    MADCTL Mode: 0x48
    Pixel Format: 0x5
    Image Format: 0x80
    Self Diagnostic: 0xC0
    Benchmark                Time (microseconds)
    Screen fill              2253160
    Text                     107910
    Lines                    1024400
    Horiz/Vert Lines         183970
    Rectangles (outline)     117020
    Rectangles (filled)      4676300
    Circles (filled)         525140
    Circles (outline)        448120
    Triangles (outline)      233750
    Triangles (filled)       1516370
    Rounded rects (outline)  216620
    Rounded rects (filled)   4648490
    Done!
    Don't have anything to compare it too so if someone else would like to post. going to run a few more tests but have to go do something now.
  20. #820
    2,196
    SPI.cpp work to do:
    I ran SPI test with SerialFlash on T3.4 and T4. Despite T4 clock running at 37 mhz and T3.2 only at 30 mhz, the T3.2 did faster page reads than T4 (83 us vs 129us). T3 SPI lib is optimized to use FIFO so there are 16-bit transfers with small interframe gap (76ns). The T4 SPI still needs to be optimized, since it does simple byte transfers with 260 ns interframe gap. So T4 SPI needs to use its FIFO and/or 16 or 32-bit frame size. Also SPI.cpp needs T4 support of async/DMA transfer.
    EDIT: Kurt had pending pull-request (now merged) to use FIFO. I need to re-run SerialFlash test ...
  21. #821
    Senior Member xxxajk's Avatar
    Nov 2013
    Buffalo, NY USA
    528
    @PaulStoffregen Don't forget the SPI pull...
  22. #822
    New York
    4,102
    Well, can no longer update my previous post on testing the libraries, but I just tried to load a bitmap example and the image did not load. As you all probably know it uses PROGMEM. The image format is set up as:
    const PROGMEM uint16_t dragonBitmap[DRAGON_WIDTH * DRAGON_HEIGHT] = {
      0XFFFF, 0XFFFF, 0XFFFF, 0XFFFF, 0XFFFF, 0XFFFF, 0XFFFF, 0XFFFF, 0XFFFF,
    I don't think there is a problem with the format or space. Just checking before digging into the code
    EDIT:
    Got an interesting error when I was trying to load purple.c gimp image:
    f:/arduino-1.8.8-t4/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: region `DTCM' overflowed by 37568 bytes
  23. #823
    Dec 2016
    Montreal, Canada
    3,070
    I'm almost done with a library for watchdog. It will enable a watchdog output on pins 19 or 20 that after a watchdog reboot will keep the pin states LOW until an actual user reset is applied. I also added callback support, trying to finish it off soon
  24. #824
    Dec 2016
    Montreal, Canada
    3,070
    Here it is, I also wrote a basic example of the usage, it depends on the definitions in the cores pull request i submitted yesturday for imxrt.h
    https://github.com/tonton81/Watchdog_t4
  25. #825
    Germany
    533
    IntervalTimer
    Would it be possible to have the channel member of the IntervalTimer protected instead of private? The old "cast to IRQ_Number" trick doesn't work anymore since the T4 only has one IRQ for all channels.
