Page 46 of 175 FirstFirst ... 36 44 45 46 47 48 56 96 146 ... LastLast
Results 1,126 to 1,150 of 4368
  1. #1126
    2,574
    Pretty sure the config setups are right. Works for any pin combination that does not include pin 0. Really must be missing something obvious. Been through the RM more times than I care to count
    I think you noted core_pins.h had wrong PIN0_PADCONFIG
    #define CORE_PIN0_PADCONFIG	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_02
    #define CORE_PIN1_PADCONFIG	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_03
    I presume you are testing with corrected version (github is still wrong). (Failing that, maybe try it with the wrong config???)
  2. #1127
    5,552
    Yep - saw that and fixed it a while ago. Even if they are switched the pad config is the same anyway so it shouldn't matter.
  3. #1128
    12,218
    Quote Originally Posted by xxxajk View Post
    Have you tried the following to reduce temp and power consumption instead?
    while(1) __asm__ volatile ("wfi");
    That will put the cpu core to sleep, but allow it to do anything important, which will only be interrupts.
    Post #1111 I noted : "I already did a test of 'wfi' - sleepCPU() - and it wasn't clear ... first the line before it printed about 20 times - then a small edit and I don't know that it worked so will revisit it. "
    My goal was to be able to find some useful postmortem info and return it - I should probably find something to read on that so far I'm just poking road kill with a stick.
    Paul already does a reg dump, but I was hoping to link to a user func() to allow user to present their personal data and structures - this worked on T_3.x. So far making a call() can just die hard - but my 'micros blink without delay' has run these past hours though all serial output ceased before it got to that code.
    Indications are interrupts are halted in the fault state - systick_isr is not counting. Serial# output stalls until pushed? And the 'wfi' feedback was odd - but that would be useful to put system in minimal state until it was attended to.
    One goal would be to allow Software Auto Upload without button - that was working on T_3.x, but only because of PJRC had found the magic 'keep serial moving' actuators.
  4. #1129
    7,453
    Is there an open PR to fix this?
  5. #1130
    5,552
    Just created one so hopefully Paul catches it before beta8.
  6. #1131
    7,453
    Yep, here is the example for using pin 0 and pin 1 (just the setup part):
    #include "Enc_Layer.h"
    #include "defines.h"
    enc_config_t mEncConfigStruct;
    uint32_t mCurPosValue;
      while(!Serial && millis() < 4000);
      delay(2000);
      CCM_CCGR2 |= CCM_CCGR2_XBAR1(CCM_CCGR_ON);   //turn clock on for xbara1
      CORE_PIN0_CONFIG = 0x01;  //Select mux mode: ALT3 mux port for pins 2/3
                                // 0x01 for pins 0 or 1
      CORE_PIN2_CONFIG = 0x03;  //0x03=Input Path is determined by functionality,
                                //0x13 for 1 enabled
      CORE_PIN0_PADCONFIG = 0x10B0;  //pin pad configuration
      CORE_PIN2_PADCONFIG = 0x10B0;
      //set as input
      IOMUXC_XBAR1_IN17_SELECT_INPUT = 0x00;  //set both pins as input
      IOMUXC_XBAR1_IN06_SELECT_INPUT = 0x00;
      /* XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarIn21, kXBARA1_OutputEnc1PhaseAInput);
       * XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarIn22, kXBARA1_OutputEnc1PhaseBInput);
       * XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputIomuxXbarIn23, kXBARA1_OutputEnc1Index);
       * These are the SDK settings
       * kXBARA1_OutputEnc1PhaseAInput   = 66|0x100U,   // XBARA1_OUT66 output assigned to ENC1_PHASE_A_INPUT
       * kXBARA1_OutputEnc1PhaseBInput   = 67|0x100U,   // XBARA1_OUT67 output assigned to ENC1_PHASE_B_INPUT
       * kXBARA1_OutputEnc1Index         = 68|0x100U,   // XBARA1_OUT68 output assigned to ENC1_INDEX
       * kXBARA1_OutputEnc1Home          = 69|0x100U,   // XBARA1_OUT69 output assigned to ENC1_HOME
       * kXBARA1_OutputEnc1Trigger       = 70|0x100U,   // XBARA1_OUT70 output assigned to ENC1_TRIGGER
       * kXBARA1_InputIomuxXbarInout06   = 6|0x100U,    // IOMUX_XBAR_INOUT06 output assigned to XBARA1_IN6 input.
       * kXBARA1_InputIomuxXbarInout07   = 7|0x100U,    // IOMUX_XBAR_INOUT07 output assigned to XBARA1_IN7 input.
       * kXBARA1_InputIomuxXbarInout08   = 8|0x100U,    // IOMUX_XBAR_INOUT08 output assigned to XBARA1_IN8 input.
      xbar_connect(17, 66);
      xbar_connect(6, 67);
      Serial.print("IOMUXC_GPR_GPR6: "); Serial.println(IOMUXC_GPR_GPR6, BIN);
      delay(5000);
      //Phase A => pin3
      //Phase B => pin2
        /* Initialize the ENC module. */
        ENC_GetDefaultConfig(&mEncConfigStruct);
        ENC_Init(&mEncConfigStruct);
        ENC_DoSoftwareLoadInitialPositionValue(); /* Update the position counter with initial value. */
    uint32_t old_position = 0;
    void loop(){
      /* This read operation would capture all the position counter to responding hold registers. */
      mCurPosValue = ENC_GetPositionValue();
      if(mCurPosValue != old_position){
        /* Read the position values. */
        Serial.printf("Current position value: %ld\r\n", mCurPosValue);
        Serial.printf("Position differential value: %d\r\n", (int16_t)ENC_GetHoldPositionDifferenceValue());
        Serial.printf("Position revolution value: %d\r\n", ENC_GetHoldRevolutionValue());
      old_position = mCurPosValue;
    Again in this case for XBAR 17... The line:
    Should be:
      IOMUXC_XBAR1_IN17_SELECT_INPUT = 0x01;  //set both pins as input
    Page 910 PDF
  7. #1132
    7,453
    FLEXIO - Uart Transmit update
    Again not sure if anyone is interested (yet).
    But now have some more of the stuff built into the underlying class. Things like mapping the IO pin to the FLex mode. Setting the correct clock gate.
    Also stated playing with some of the Baud rate generation. Right now code is assuming that the clock passed in is something like: 480M/16
    Which is sort of the defaults:
    That is FlexIO1 can be gated from(PLL4, PLL3_PFD2, PLL5, PLL3_SW_CLK) default to PLL3_SW_Clk)
    then divide by value of CDCDR[FLEXIO1_CLK_PRED] (default 2) and divided by CDCDR[FLEXIO1_CLK_PODF] (default 8)
    Not sure if I should try setting any of these values and/or look for their current values if the user for example asks for BAUD...
    If I am looking at the Clock setups about page 986
    PLL4 = 786.43
    PLL3_PFD2 = 508.24
    PLL5=649.52
    PLL3= 480
    Not sure if this is correct?
    Attached Files Attached Files
  8. #1133
    Germany NRW
    6,920
    I have to copy the dmasettings twice:
    dmatx = dmasettings[0];
    Nothing else helps - not asm("dmb"), not ("dsb"), not ("isb"), ..all three combined do not help, too. I even tried a delay.
    Dmatx is in normal RAM, which is not cached.
    I found this only by accident, after hours of trying to identify the problem that restarting the autorefresh always started with the last chunk of data.
    As soon I had this line twice, accidentally, it suddenly worked..
    Anybody got an idea?
    Yes, me !
    https://github.com/PaulStoffregen/co...f1a413465d6e8d
  9. #1134
    Germany NRW
    6,920
    Kurt, Paul merged my pull request that fixes at least the PFDs
    . PLL3 / PFD settings are correct (on github). the others - don't know.
  10. #1135
    5,552
    Should be:
    Page 910 PDF
    Hey Kurt
    That did the trick. Just checked the reference and you are absolutely correct. Think its the only pin that I tested that has xbar1 as 1 for input. All the other pins were 0. Tested it and it worked no problem.
    Told you it was going to be something obvious . Just needed another pair of eyes I guess. Have to figure out a way to put this all into some sort of structure so I don't screw it up again.
    On another note - Paul incorporated the pad change I mentioned earlier
  11. #1136
    5,552
    PLL4 = 786.43
    PLL3_PFD2 = 508.24
    PLL5=649.52
    PLL3= 480
    Just gave this a try but confused again. Looks like you are transmitting on pin2? But not sure what baud rate you are transmitting at? Saw I post that said 7575757. I attempted to tie pin 2 on the T4 to pin 0 on the T3.2 with USB to serial but nothing was showing in the monitor? Suggestions.
  12. #1137
    7,453
    Current code should now be near 115200, the is a #define for desired baud. But may depend on how close the system is to the pll3 setting above,0
  13. #1138
    5,552
    I know I posted some clock values... with Frank changes to the PFDs:
    System Clock: 600000000
    IPG Clock: 150000000
    Semc Clock: 200000000
    RTC Clock: 32768
    USB1pll Clock: 480000000
    Peripheral Clock: 24000000
    Osc Clock: 24000000
    Arm Clock: 1200000000
    Usb1PllPfd0 Clock: 720000000
    Usb1PllPfd1 Clock: 664615368
    Usb1PllPfd2 Clock: 508235292
    Usb1PllPfd3 Clock: 454736826
    Usb2Pll Clock: 24000000
    SysPll Clock: 528000000
    SysPllPfd0 Clock: 351999990
    SysPllPfd1 Clock: 594000000
    SysPllPfd2 Clock: 396000000
    SysPllPfd3 Clock: 297000000
  14. #1139
    7,453
    Thanks guys - If you have tried the code I posted and nothing coming out... My guess is you have not synced up to core project, as I needed to update some of the macros in imxrt.h for setting some of the fields. It only updated 16 bit values not the full 32 values... So Some of the registers were not properly updated.
    Examples debug output to Serial:
    Offset to SHIFTBUFNIS 780
    Enable flexio clock
    pin 2 maps to: 20000aa0, port: 401ac000 pin 4
    timer index: 0 shifter index: 0 mask: 1
    Before configure flexio
    CCM_CDCDR: 33f71f92
    VERID:2100404 PARAM:1 CTRL:1 PIN: 10
    SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=0
    SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0
    SHIFTSDEN:0 SHIFTSTATE=0
    SHIFTCTL:30402 0 0 0
    SHIFTCFG:32 0 0 0
    TIMCTL:1c00401 0 0 0
    TIMCFG:2222 0 0 0
    TIMCMP:f81 0 0 0
    End Setup
    The value like TIMCTL 1c00401 was not correct so nothing came out.
    Currently updating the code to hopefully support ISRs to do work. Trying to do a quick and dirty way for multiple objects to ask to be notified if an ISR happens....
    As soon as this is semi functional, will then take some of the top level sketch code and put into a high level object based off stream...
    Then start adding in the RX part
    Edit: Thinks Mike for printing out the different actual clocks... Now just need to figure out how these names translate to names like PLL3 or PLL4
  15. #1140
    5,552
    Yeah - that is pretty much was what I was seeing when I ran it.
    For the clock frequencies I copied a lot of what was in clock.c into a sketch just as a test case for me to check things out with. Was actually the first thing I did with the T4 as a test. So the sketch is a mess. But its called Blink_T4 in my WIP GitHub repository - maybe it will help sort out the clock names - never went back to do that - moved on after that. The link is: https://github.com/mjs513/WIP/tree/master/T4%20helpers
  16. #1141
    22,512
    Paul, do you plan any important changes to audio stream?
    Depends on what you mean by "important".
    My plan is to keep the API identical. However, some places in the library use ugly shortcuts, like assuming the offset from block to buffer is 8 bytes. Will probably break those places and need to update them with something better.
    Would be really great if we could use the GPU on a future T4.2 .. would make everything graphics-related so much better..
    The 1052 chip you have now has the 2D GPU. Or it's supposed to have it. So far I have not had any time to try using it.
    The GPU offers a fairly small feature set, mostly just image copy with optional alpha blend & colorspace transform, but it can do all those at 1 pixel per clock (maybe F_BUS?)
  17. #1142
    22,512
    Would be perfect if there were some early hooks - before and after USB init. Setup() is too late - all objects get initialized before Setup().
    I believe we have 2 hooks in Teensy 3.x startup.
    void startup_early_hook(void)
    void startup_late_hook(void)
    The first is very early before the PLLs or static C variables initialized, mainly for taking control of the watchdog. The second is after C++ constructors but before setup().
    Are these 2 good enough? Do we need a 3rd, maybe before constructors but after PLLs running and static variables initialized? Before USB, after USB, etc? Do we need 4, 5 or even more?!
    Whatever ends up being done, I'd like to have the same names and roughly similar places in the startup process on Teensy 3 & 4.
  18. #1143
    22,512
    I'm planning to do something along these lines later in 2019, using a combination of code on the iMXRT and special support in the bootloader.
    Sorry, can't talk about these plans right now - other than to let you know I do have something in mind for later this year, so all this debug printing stuff currently in the fault handler should be considered only temporary.
  19. #1144
    22,512
    @manitou - Any chance you could adapt coremarkish to use buffers in OCRAM? But leave the stack in DTCM. Either malloc() or DMAMEM allocate in OCRAM. Really looking to benchmark the performance impact of the different cache settings in the MPU.
  20. #1145
    2,574
    I'll take a look. I haven't looked that closely at the coremark code. i'll look at linpack benchmark too, big float/double arrays.
  21. #1146
    5,552
    @manitou - think there is setting you can change in core_portme.h (#ifndef MEM_LOCATION
    #define MEM_LOCATION "STACK"
    #endif), just don't know what the other settings are or what would need to be updated for T4
  22. #1147
    2,574
    coremark has a configurable MEM_METHOD (static, heap, stack). Not a big difference in iterations/second with T4@600mhz
             STACK   MALLOC
    Faster   2295.2  2290.6
    Fastest  2426.7  2426.2
    linpack 100x100 float  (mflops)
    Faster    161.5   152.6
    Fastest   166.7   157.1
    This is with stock beta7.
    On EVKB@600mhz (-O3), coremark gets 2439.2 iterations/sec, adding SCB_DisableDCache() drops to 2437.9.
  23. #1148
    12,218
    I figured the current was just a placeholder - given the printed values aren't shown with names Interesting there are capabilities/plans to add further support.
    I looked a bit and I found a snippet on Community.NXP that looks to express the same dumped values - only with labels. I'll see if I can't clean the following up enough to offer the named replacement for a Pull Request - maybe with a couple of bit checks and notes on the fault regs. The T4 seems less usable for calling user code than the T3 after a fault - at least the one I picked. Faults don't seem to be a plague - so I'll try to do this and then get back to the other stuff I was doing on T3 for debug.
    User_uiv:: irq
    stacked_r0 :: 2000073C
    stacked_r1 :: 2000073C
    stacked_r2 :: 00000061
    stacked_r3 :: 00C00000
    stacked_r12 :: FFFFFFFF
    stacked_lr :: 600011CB
    stacked_pc :: 6000127E
    stacked_psr :: 21010000
    _CFSR :: 00000400
    _HFSR :: 40000000
    _DFSR :: 00000000
    _AFSR :: 00000000
    _BFAR :: 00000000
    _MMAR :: 00000000
    PJRC > irq 3
    00000000
    00000000
    00000000
    00000000
    40000000
    00000004
    00000000
    21010000
    6000127E
    600011CB
    FFFFFFFF
    00C00000
    00000061
    2000073C
    2000073C
  24. #1149
    Germany NRW
    6,920
    yes i know.
    ? what did you eat? I want the same..
    One additional after all PLLs and USB are initialized.
        while (millis() < 20) ; // wait at least 20ms before starting USB
        usb_init();
                          <- here
        analog_init();
        pwm_init();
    Or none, if you decide to add the code in question to the core.
  25. #1150
    Germany NRW
    6,920
    Yes,Yeah, I saw that. Of course I meant with the corresponding interface to the outside....
    I didn't really look either.
    Really useful would be a color-LUT, a translation table that allows a 256 to 65536 colors lookup and output without needing a buffer for the output.. Do you have any idea if we can use any existing device for it? A cool DMA-trick? Anything? Or, can we we use the existing GPU for it?
