Page 9 of 174 FirstFirst ... 7 8 9 10 11 19 59 109 ... LastLast
Results 201 to 225 of 4339
Thread: Teensy 4.0 First Beta Test
  1. #201
    20,597
    Thanks to everyone for so much awesome testing in the last several hours!
    I've updated msg #6 with a few new issues, and I deleted many that are fixed (and confirmed fixed). Things are moving fast & this thread is growing long. If you find an issue or see something reports that's not yet on msg #6, please add it (if you have "plus" user access to edit messages).
    I'm going to take several hours off this evening for New Year's... will be back in the early hours of 2019, to get onto fixing the C++ vtables and constructor stuff and other issues.
    Happy New Year to everyone!!
  2. #202
    9,773
    Wow - you are doing awesome work and reading and collecting details! I just saw you found my post #117 note - I'll update as it seems to be any time it is over 10 seconds testing iterations.
    Have a good night - and a happy New Year.
  3. #203
    Feb 2014
    Colmar, France
    2,535
    Happy new year to everybody and best wishes for a prosperous 2019! (New year has already arrived in France)
  4. #204
    2,201
    Double and single precision floating point looks good.
    Linpack 100x100 mflops
                   double    float
        T4@600mhz   71.4     166.3   gcc -O3
        M7@600mhz   66.97    125.5   ARM CC -O3
      T3.6@256mhz    2.85     41.1   Fastest
      T3.6@180mhz    2.13     28.4   Faster
      T3.2@120mhz    0.65      1.0   Faster  no FPU
      adaM4F@120mhz  1.4      20.1   SAMD51
      STM32L4@80mhz  0.88     15.4   dragonfly -O2
    dsp.zip contains files to support M7 DSP (arm_math.h v1.5.1) on Teensy 4. I tested with a DSP benchmark.
    DSP FFT benchmark  1024  radix4 REVERSEBITS 0  (microseconds)
                    q15     q31      f32
      T4@600mhz     77.4    147.0     87.0    gcc -O2     arm_math.h v1.5.1
      M7@600mhz     77.4    147.8     88.0    gcc -O3     arm_math.h v1.5.1 SDK
      M7@600mhz     74.5    126.9     95.6    ARM GCC -O3   arm_math.h v1.5.1
    T3.6@256mhz    291.7    720.4    424.7    Faster    v1.5.3
    T3.6@240mhz    311.2    768.8    453.0    Faster    v1.5.3
    T3.6@180mhz    463.1   1215.2    703.7    Faster    v1.1.0
    T3.6@180mhz    414.7   1010.7    598.2    Faster    v1.5.3
    T3.5@120mhz    784.7   1947.9   1079.8    Faster    v1.1.0
    T3.5@120mhz    658.5   1577.9    919.5    Faster    v1.5.3
    K64F@120mhz    635.7   1273.8    827.2    ARM GCC -O3   arm_math.h v1.4.5
    T3.2@120mhz    869.8   2498.5  18182.5    Faster   v1.1.0
    adaM4F@120mhz  701.3   1756.1    781.0    Faster   v1.1.0   SAMD51
    STM32L4@80mhz  917.3   1953.8   1150.4    Faster   v1.4.5
    Floating-point intensive Kalman filter update
    Kalman filter update time
                     microseconds
        T4@600mhz         80
        M7@600mhz         99
      T3.6@256mhz        176
      T3.6@180mhz        248
      T3.5@120mhz        351
      T3.2@120mhz       3396
      adaM4F@120mhz      361
      STM32L4@80mhz      535
      mega2560@16mhz   30272
     float math lib (trig) lat,lon to UTM
                     microseconds
        T4@600mhz          4.2
        M7@600mhz          5
      T3.6@180mhz         27
      T3.5@120mhz         39
      T3.2@120mhz        448
      ESP32@240mhz        33
      adaM4F@120mhz       35
      STM32L4@80mhz       60
      mega2560@16mhz    3408
               float interpolate (us)  8x8 to 70x70
                   bilinear  bicubic
    T3.2@120mhz      18773    223109
    T3.5@120mhz       1944     26618
    T3.6@180mhz       1294     16712
    T4@600mhz          255      6406
    adaM4F@120        1905    207326
    ESP32@240mhz      1983    114813
    STM32L4@80mh      2897     37962
    mandelbrot   (mops)
                       float  double
        T4@600mhz      230.1   119.3
      T3.6@180mhz       80.4     2.4
      T3.5@120mhz       49.5     1.1
      T3.2@120mhz        1.2     0.8
      adaM4F@120mhz     42.9     1.6
      STM32L4@80mhz     32.2     0.9
    whetstone   (MIPS)
                       float  double
        T4@600mhz     1694.9  1351.4
        M7@600mhz      939.7   543.6   NXP 1062 SDK
        M7@600mhz     1123.6   510.2   NXP 1052 mbed
      T3.6@180mhz      438.6    34.6
      T3.5@120mhz      189.4    16.2
      T3.2@120mhz       20.9    13.0
      adaM4F@120mhz     90.8    12.3
      STM32L4@80mhz     48.4     6.4
  5. #205
    2,345
    Happy New Year also from my side.
    Trying to understand the generation of I2S_MCLK
    (new terminology and too many options makes live somewhat difficult (without 1 GHz logic analyser, have only 250 MHz on single channel), so must work displaying bit-clock)
  6. #206
    2,201
    Bottom side (smt) and right side (through hole) pads:
    Your pin table seems to suggest I can get to pin 30 (for GPT PPS test) from the top side with one of the through-hole pads ... which pad? Or does that just refer to the end holes for VBAT etc.
    Could i use XBAR to route pin 30 to another edge pin? (I haven't really figured out XBAR yet)
    thanks and Happy New Year
  7. #207
    20,597
    Nope, sorry pin 30 is only on the bottom side. It's the one closest to the 3.3V through-hole pin.
  8. #208
    Germany NRW
    5,679
    I've updated FastCRC - compiles without hardwaresupport, and tables instead. Same for __SAM3X8E__
    @Paul, please update the lib
    Edit: Where can I find a list which shows which targets
    a) need #include <avr/pgmspace.h>
    b) need #include <pgmspace.h>
    c) don't want it
  9. #209
    2,201
    I ran stock FastCRC (using 16K buffer)
         CRC Benchmark
         F_CPU: 396 MHz, length: 16384 Bytes.   really 600 mhz
         Maxim (iButton) FastCRC:   Value:0xF6, Time: 200 us (655.36 mbs)
         Maxim (iButton) builtin:   Value:0xF6, Time: 1200 us (109.23 mbs)
         MODBUS FastCRC:    Value:0x7029, Time: 330 us (397.19 mbs)
         MODBUS builtin:    Value:0x7029, Time: 1580 us (82.96 mbs)
         XMODEM FastCRC:    Value:0x98D9, Time: 450 us (291.27 mbs)
         XMODEM builtin:    Value:0x98D9, Time: 1890 us (69.35 mbs)
         MCRF4XX FastCRC:   Value:0x4A29, Time: 330 us (397.19 mbs)
         MCRF4XX builtin:   Value:0x4A29, Time: 270 us (485.45 mbs)
         KERMIT FastCRC:    Value:0xB259, Time: 80 us (1638.40 mbs)
         Ethernet FastCRC:  Value:0x1271457F, Time: 700 us (187.25 mbs)
    T4 compile of FastCRC benchmark doesn't find util/crc16.h, so i copied crc16.h into the lib folder to get it to compile.
    I had also tested FastCRC (table-driven) on EVKB eval board, see EVKB tests. T4 has a hardware CRC32 (fixed poly), i did some testing on the EVKB board (crc32 16384 bytes 183 us 716.24 mbs (90 MBs))
    EDIT: implemented hardware CRC32 (part of DCP) on T4 beta, 381 MBs for 16K buffer. See post #1600
  10. #210
    Germany NRW
    5,679
    Oh.. thanks for the hint, i'll test&fix it.
  11. #211
    20,597
    I've added these on github.
    https://github.com/PaulStoffregen/co...981018849e9b14
  12. #212
    Germany NRW
    5,679
    ..was about doing the same thanks!
  13. #213
    Germany NRW
    5,679
    Paul i've used #if defined(__IMXRT1052__) || defined(__IMXRT1060__) - is that ok for other libs, too? Or will there be a more general __IMXRT__ ? - additional?
  14. #214
    Germany NRW
    5,679
    Found my many years old interrupt-tester which was used to test if unused interrupts work.
    They work on IMXRT, too
    #define NVIC_STIR           (*(volatile uint32_t *)0xE000EF00)
    #define NVIC_TRIGGER_INTERRUPT(x)  NVIC_STIR=(x);
    volatile int chk;
    void softISR() {
      chk = 1;
      digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
      Serial.println("...OK.");
    #if 0
    //const unsigned char swInterrupts[] = {33,39,44,53,54,55,56,57,58,59,67,68,69,70,71,72,91,92,93,94,95,96,98,102,108,109,IRQ_SOFTWARE+16/*,IRQ_SOFTWARE+17*/,0};
    #else
     const unsigned char swInterrupts[] = {IRQ_Reserved1, IRQ_Reserved2, IRQ_Reserved3, IRQ_Reserved5, IRQ_Reserved6, IRQ_Reserved9, IRQ_Reserved10,  IRQ_Reserved13, 0};
      delay(600);
      pinMode(LED_BUILTIN, OUTPUT);
      Serial.println("Reserved Interrupt tester");
      unsigned char n = 0;
      while (swInterrupts[n] > 0) {
        int interrupt = swInterrupts[n];
        Serial.printf("%d (%d)",interrupt, interrupt - 16);
        _VectorsRam[interrupt] = softISR;
          NVIC_ENABLE_IRQ(interrupt - 16);
        chk = 0;
        //Trigger swi this way :
        // NVIC_SET_PENDING(interrupt - 16);
        //Or this way (faster):
        NVIC_TRIGGER_INTERRUPT(interrupt - 16);
        delay(50);
        if (!chk) Serial.println("...NOT OK.");
        n++;
      Serial.println("Done.");
      while(1){;}
    void loop() {}
    It also shows, that NVIC_SET_PENDING and NVIC_TRIGGER_INTERRUPT are working.
    As you see in the list, some "reserved" numbers are missing - shall I rename them? IRQ_SOFTWARE is missing, too. I'd use the last, IRQ_Reserved13.
  15. #215
    2,201
    Here's a hack sketch for "attachInterrupt" for T4 pin 12 (GPIO B0_01 on GPIO2). Teensy 3 attachInterrupt has macros for generating ISRs with function table ... more study rerquired
    // GPS PPS on pin 12  GPIO2 1  B0_01
    #include "Arduino.h"
    volatile uint32_t ticks;
    void pinisr() {
      GPIO2_ISR |= 1 << 1; // clear interrupt
      ticks++;
      while (GPIO2_ISR & (1 << 1)); // wait for clear
      while (!Serial);
      delay(3000);
      Serial.println("starting");
      pinMode(12, INPUT);
      GPIO2_ICR1 |= 2 << 2; // rising on pin 1
      GPIO2_EDGE_SEL = 0;  // not both
      attachInterruptVector(IRQ_GPI02_0_15, pinisr);
      NVIC_ENABLE_IRQ(IRQ_GPI02_0_15);
      GPIO2_IMR |= 1 << 1; // pin 1 interrupt enable
      static uint32_t prev = 0;
      if (ticks != prev) {
        Serial.println(ticks);
        prev = ticks;
    Having micros() resolution at only 10 us is also messing up my GPS PPS sketches
    EDIT: corrected the sketch above to wait for interrupt pin to clear.
  16. #216
    2,345
    did following code to set to set SAI1 MCLK
    // this should be corrected in imxrt.h (from 1F to 3F)
    #define CCM_CS1CDR_SAI3_CLK_PODF(n)		((uint32_t)(((n) & 0x3F) << 16))
    #define CCM_CS1CDR_SAI1_CLK_PODF(n)		((uint32_t)(((n) & 0x3F) << 0))
    // this should go into imxrt.h
    #define CCM_ANALOG_PLL_AUDIO_POST_DIV_SELECT(n) ((uint32_t)(((n) & 0x03)<<19))
    #define CCM_ANALOG_PLL_AUDIO_BYPASS ((uint32_t)(1<<16))
    #define CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC(n) ((uint32_t)(((n) & 0x03)<<14))
    #define CCM_ANALOG_PLL_AUDIO_ENABLE ((uint32_t)(1<<13))
    #define CCM_ANALOG_PLL_AUDIO_POWERDOWN ((uint32_t)(1<<12))
    #define CCM_ANALOG_PLL_AUDIO_DIV_SELECT(n) ((uint32_t)((n) & ((1<<7)-1)))
    #define CCM_ANALOG_MISC2_DIV_MSB (1u<<23)
    #define CCM_ANALOG_MISC2_DIV_LSB (1u<<15)
    #define CCM_ANALOG_PLL_AUDIO_NUM_MASK ((uint32_t)((1<30)-1))
    #define CCM_ANALOG_PLL_AUDIO_DENOM_MASK ((uint32_t)((1<30)-1))
    #define CCM_CSCMR1_SAI1_CLK_SEL_MASK (CCM_CSCMR1_SAI1_CLK_SEL(0x03))
    #define CCM_CS1CDR_SAI1_CLK_PRED_MASK (CCM_CS1CDR_SAI1_CLK_PRED(0x07))
    #define CCM_CS1CDR_SAI1_CLK_PODF_MASK (CCM_CS1CDR_SAI1_CLK_PODF(0x3f))
    #define CCM_CSCMR1_SAI2_CLK_SEL_MASK (CCM_CSCMR1_SAI2_CLK_SEL(0x03))
    #define CCM_CS2CDR_SAI2_CLK_PRED_MASK (CCM_CS2CDR_SAI2_CLK_PRED(0x07))
    #define CCM_CS2CDR_SAI2_CLK_PODF_MASK (CCM_CS2CDR_SAI2_CLK_PODF(0x3f))
    #define CCM_CSCMR1_SAI3_CLK_SEL_MASK (CCM_CSCMR1_SAI3_CLK_SEL(0x03))
    #define CCM_CS1CDR_SAI3_CLK_PRED_MASK (CCM_CS1CDR_SAI3_CLK_PRED(0x07))
    #define CCM_CS1CDR_SAI3_CLK_PODF_MASK (CCM_CS1CDR_SAI3_CLK_PODF(0x3f))
    void set_audioClock(int nfact = 27, int32_t mult=0, uint32_t div=1)
      CCM_ANALOG_PLL_AUDIO = 0;
      //CCM_ANALOG_PLL_AUDIO |= CCM_ANALOG_PLL_AUDIO_BYPASS;
      CCM_ANALOG_PLL_AUDIO |= CCM_ANALOG_PLL_AUDIO_ENABLE;
      CCM_ANALOG_PLL_AUDIO |= CCM_ANALOG_PLL_AUDIO_POST_DIV_SELECT(2); // 0: 1/4; 1: 1/2; 0: 1/1
      CCM_ANALOG_PLL_AUDIO |= CCM_ANALOG_PLL_AUDIO_DIV_SELECT(nfact);
      CCM_ANALOG_PLL_AUDIO_NUM   = mult & CCM_ANALOG_PLL_AUDIO_NUM_MASK;
      CCM_ANALOG_PLL_AUDIO_DENOM = div  & CCM_ANALOG_PLL_AUDIO_NUM_MASK;
      const int div_post_pll = 1; // other values: 2,4
      CCM_ANALOG_MISC2 &= ~(CCM_ANALOG_MISC2_DIV_MSB | CCM_ANALOG_MISC2_DIV_LSB);
      if(div_post_pll>1)
        CCM_ANALOG_MISC2 |= CCM_ANALOG_MISC2_DIV_LSB;
      if(div_post_pll>3)
        CCM_ANALOG_MISC2 |= CCM_ANALOG_MISC2_DIV_MSB;
    void sai1_setClock(int n1, int n2)
      CCM_CCGR5 |= CCM_CCGR5_SAI1(CCM_CCGR_ON);
      IOMUXC_GPR_GPR1 |= (IOMUXC_GPR_GPR1_SAI1_MCLK_DIR | IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL(0));
      // clear SAI1_CLK register locations
      CCM_CSCMR1 &= ~(CCM_CSCMR1_SAI1_CLK_SEL_MASK);
      CCM_CS1CDR &= ~(CCM_CS1CDR_SAI1_CLK_PRED_MASK | CCM_CS1CDR_SAI1_CLK_PODF_MASK);
      CCM_CSCMR1 |= CCM_CSCMR1_SAI1_CLK_SEL(2); // &0x03 // (0,1,2): PLL3PFD0, PLL5, PLL4,
      CCM_CS1CDR |= CCM_CS1CDR_SAI1_CLK_PRED(n1-1); // &0x07
      CCM_CS1CDR |= CCM_CS1CDR_SAI1_CLK_PODF(n2-1); // &0x3f
    void sai1_configurePorts(int iconf=0)
      CORE_PIN23_CONFIG = 3;  //1:MCLK
      CORE_PIN21_CONFIG = 3;  //1:RX_BITCLK
      CORE_PIN20_CONFIG = 3;  //1:RX_FS
      CORE_PIN7_CONFIG  = 3;  //1:RX_DATA0
      CORE_PIN8_CONFIG  = 3;  //1:RX_DATA1
      CORE_PIN9_CONFIG  = 3;  //1:RX_DATA2
      CORE_PIN32_CONFIG = 3;  //1:RX_DATA3
    extern "C" void setup() {
      Serial.println("T4_test");
      sai1_configurePorts();
      int fs = 192000;
      int fs_mclk = fs*256; // 49.152 MHz
      int c0, c1, c2;
      int n1, n2;
      n1 = 4; // to ensure that input to last divisor (i.e. n2) is < 300 MHz
      n2 = 4;
      // e.g. 49.152 = 32.768*24 / (n1*n2)
      c0 = 32;
      c1 = 768;
      c2 = 1000;
      // Note: c0+c1/c2 must be between 27 and 54 ()
      set_audioClock(c0,c1,c2);
      sai1_setClock(n1,n2);
    extern "C" void loop() {
    (used from main.cpp, therefore extern "C")
    problem encountered was that before setting dividers the fields must be erased. (obviously in hindsight)
    not sure what the future API of setting PLL's clock speed is, I simply provide a sketch as example.
    two macros in imxrt.h are slightly off (pull request submitted) and others are missing.
  17. #217
    New York
    4,116
    @manitou -
    Guess I can't sleep - too much goes on when I wake up
    Thanks for the files. By the way I tried running the CMSIS Neural Network library but it needed two additional files:
    arm_const_structs.h
    arm_common_tables.h
    I just copied these from the main cmsis GitHub page but not sure it they are correct for your version.
    The sketch I used to test CMSIS-NN ran one time. Made a minor change to get timing when I reloaded wound up loosing the USB - had to reload a different sketch and tap the button once to get it to recognize the usb port on windows again. Related to USB issue or something else now 100% sure.
    EDIT: If you want to give it a try: https://github.com/mjs513/CMSIS-NN--...for-Teensy-3.6. Just copy the CMSIS-NN to your library folder
  18. #218
    20,597
    I've added attachInterrupt() and tone() on github.
  19. #219
    5,432
    Happy New Year!
    I now have a version of HardwareSerial that is working with buffering data and using ISR to output
    Not saying it is perfect yet. Right now trying to enable more parts of my branch to get Serial1.read()... stuff to work as well.
    With the SerialX output code, I am trying to uncomment the code that is to handle the inverted Interrupt priority issue. That is Serial1.write() is called and Buffer is full, and the code is running at a higher priority than the HardwareSerial Interrupt, so to not hang, the loop puts the data output...
    Current problem is that the function: nvic_execution_priority
    We used for Teensy 3.x is not defined...
    Also currently I have hard coded the interrupt priority as one #define in HardwareSerial.cpp. Will probably do like my other branch and put a field into the hardware structure, so each Serial object can have their own priority...
    But if anyone wishes to play along, the code is up at: https://github.com/KurtE/cores/tree/...HardwareSerial
    Only need HardwareSerial.h and .cpp...
    Hopefully more parts working later today
  20. #220
    20,597
    I've committed a fix for the issue where digitalRead() always returns 0 when the pin is output mode. Now digitalRead() works in all cases and lets you read the actual state, even in output mode.
    https://github.com/PaulStoffregen/co...656013c9810b94
  21. #221
    20,597
    Probably fine to just copy the one from teensy3.
  22. #222
    20,597
    EDIT: I made a first attempt at fixing C++ constructors. Here's the commit on github.
    https://github.com/PaulStoffregen/co...4c9141369b3de1
    So far only did a quick test with this code.
    #include "debug/printf.h"
    class myclass {
      public:
      myclass() {
        printf("myclass constructor\n");
      void test() {
        printf("myclass test\n");
    myclass myinst;
      myinst.test();
      digitalWrite(3, HIGH);
      delay(1500);
      digitalWrite(3, LOW);
      delay(1500);
    @Kurt - Do you have any quick test cases handy for the constructor & vtable issues? Going to take a break for a few hours - then look at that issue later today and make a beta5 installer when it's fixed. A couple small test cases would save me a little time if you have any ready to go.
  23. #223
    New York
    4,116
    @PaulStoffregen
    Was testing your attachinterrupt addition but the MPU9250 sketch I use, happens to use class constructors, etc. Before your class constructor fix it would loose the usb consistently. After, both class constructors work as well as attaching interrupt. I used pin 1. Going to test with the BME280 library just as a double and will post the update here.
    Oh for anyone pulling the attachinterrupt update, don't forgot to update your imxrt.h file as well
    Just thought you like to know.
    UPDATE: Just tested the BME280 library and the constructor again works that was causing issues yesterday.
  24. #224
    5,432
    Hi Paul,
    I think this one should do it... That is this one would fault until I made constructor to be const... Also my hardware Serial...
    This should have the code in place that at the start dumps the variable so you can see it was all 0's...
    class TestSerial : public Stream {
      public:
        TestSerial() {state_ = 0;};
        virtual int available(void);
        virtual int peek(void);
        virtual void flush(void);
        virtual size_t write(uint8_t c);
        virtual int read(void);
        using Print::write;
        size_t nonVirtualfunc(uint8_t c);
        uint8_t state_;
    int TestSerial::available(void) {return 0;}
    int TestSerial::peek(void){return 0;}
    void TestSerial::flush(void) {return;}
    size_t TestSerial::write(uint8_t c) {
      state_ = state_? 0 : 1;
     digitalWrite(13, state_);
     return 0;
    size_t TestSerial::nonVirtualfunc(uint8_t c) {
     return 0;
    int TestSerial::read(void){return 0;}
    TestSerial ts;
      while ( !Serial && millis() < 600 ) {
        if ( 0 == ARM_DWT_CYCCNT &&  0 == ARM_DWT_CYCCNT ) {
      //    SOME_SERIAL.println( "   ARM_DEMCR_TRCENA done!" );
          ARM_DEMCR |= ARM_DEMCR_TRCENA;
          // ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA; // turn on cycle counter << THIS LINE NOT NEEDED
      Serial.println("Test begun");
      uint16_t cb = sizeof(TestSerial);
      Serial.printf("Test Serial: %x Size:%d ", (uint32_t)&ts, cb);
      uint8_t *b = (uint8_t*)&ts;
      while (cb--)Serial.printf("%x ", *b++);
      // Now lets try Serial
      cb = sizeof(Serial);
      Serial.printf("Serial: %x Size:%d ", (uint32_t)&Serial, cb);
      b = (uint8_t*)&Serial;
      // Now lets try Serial1
      cb = sizeof(Serial1);
      Serial.printf("Serial1: %x Size:%d ", (uint32_t)&Serial1, cb);
      b = (uint8_t*)&Serial1;
      pinMode(13, OUTPUT);
      pinMode(2, OUTPUT);
      pinMode(3, OUTPUT);
      pinMode(4, OUTPUT);
      for (uint8_t i=0; i< 5; i++) {
        digitalWrite(13, HIGH);
        delay(250);
        digitalWrite(13, LOW);
        delay(250);
    uint8_t buf[]={0,1};
      digitalWrite(2, HIGH);
      //ts.write((uint8_t)0x00);  // see if we call through the virtual function
      ts.write(buf, 1);
      //ts.nonVirtualfunc(0);
      digitalWrite(2, LOW);
    20,597
    I'm running that now. Here's what I get in the serial monitor. Does this look ok? (sorry... have only a few min before I have to leave)
    /tmp/arduino_modified_sketch_321946/sketch_jan01a.ino Jan  1 2019 07:56:11
    Test begun
    Test Serial: 2000201c Size:16 8 0 0 20 0 0 0 0 e8 3 0 0 0 0 0 0
    Serial: 20000a94 Size:16 3c 5 0 20 0 0 0 0 e8 3 0 0 0 0 0 0
    Serial1: 200009d0 Size:24 d0 0 0 20 0 0 0 0 e8 3 0 0 0 0 0 0 0 80 19 40 58 12 0 60
    I'm about to package up beta5. Even if this isn't perfect, maybe a step in the right direction?
