defragster
Senior Member+
this is CAN2.0 legacy on CAN3. FD not implemented yet, everything you see in stream is CAN2.0 only atm.
This validates the hardware is working and connected properly, Mike’s SDK does T4 to T4 in FD mode however they don’t seem to talk to the mcp2517fd, probably bad SDK timings or something and since both t4’s run the same sdk it’s a given it should work..
Yes - good to see that CAN2.0 legacy from T4 to T4 on CANFD bus is working across the POGO pins and hardware!
Note I have the 110 OHM resistance on the PJRC board and clipped one end - so nothing - on the other DIY breakout end right now.
