Teensy 4.0 First Beta Test
FreqMeasureMulti Fails to compile
I was able to successfully compile the serial.ino FreqMeasure example, but failed to compile the FreqMeasureMulti serial.ino example for Teensy 4-Beta2.
The Arduino IDE returned the following errors:
Error compiling for board Teensy 4-BETA2
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp: In member function 'bool FreqMeasureMulti::begin(uint32_t, uint8_t)':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:48:59: error: 'PORT_PCR_MUX' was not declared in this scope
   case 22: channel = 0; CORE_PIN22_CONFIG = PORT_PCR_MUX(4); break;
In file included from C:\Arduino189_T147B4\hardware\teensy\avr\cores\teensy4/core_pins.h:32:0,
                 from C:\Arduino189_T147B4\hardware\teensy\avr\cores\teensy4/wiring.h:38,
                 from C:\Arduino189_T147B4\hardware\teensy\avr\cores\teensy4/WProgram.h:45,
                 from C:\Users\Rober\AppData\Local\Temp\arduino_build_67275/pch/Arduino.h:6,
                 from C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.h:4,
                 from C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:27:
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:77:19: error: 'IRQ_FTM0' was not declared in this scope
  NVIC_DISABLE_IRQ(IRQ_FTM0);
C:\Arduino189_T147B4\hardware\teensy\avr\cores\teensy4/imxrt.h:8293:52: note: in definition of macro 'NVIC_DISABLE_IRQ'
 #define NVIC_DISABLE_IRQ(n)     (*(&NVIC_ICER0 + ((n) >> 5)) = (1 << ((n) & 31)))
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:78:6: error: 'FTM0_MOD' was not declared in this scope
  if (FTM0_MOD != 0xFFFF || (FTM0_SC & 0x7F) != FTM_SC_VALUE) {
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:78:29: error: 'FTM0_SC' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:29:23: error: 'FTM_SC_TOIE' was not declared in this scope
 #define FTM_SC_VALUE (FTM_SC_TOIE | FTM_SC_CLKS(1) | FTM_SC_PS(0))
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:78:48: note: in expansion of macro 'FTM_SC_VALUE'
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:29:50: error: 'FTM_SC_CLKS' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:29:65: error: 'FTM_SC_PS' was not declared in this scope
  if (FTM0_MOD != 0xFFFF || (FTM0_SC & 0x7F) != FTM_SC_VALUE) {                                                ^
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:80:3: error: 'FTM0_CNT' was not declared in this scope
   FTM0_CNT = 0;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:95:28: error: 'FTM0_C0SC' was not declared in this scope
  volatile uint32_t *csc = &FTM0_C0SC + channel * 2;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:30:26: error: 'FTM_CSC_CHIE' was not declared in this scope
 #define FTM_CSC_RAISING (FTM_CSC_CHIE | FTM_CSC_ELSA)
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:100:9: note: in expansion of macro 'FTM_CSC_RAISING'
  *csc = FTM_CSC_RAISING; // first capture is always rising
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:30:41: error: 'FTM_CSC_ELSA' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp: In member function 'void FreqMeasureMulti::end()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:173:28: error: 'FTM0_C0SC' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp: In function 'void ftm0_isr()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:180:6: error: 'FTM0_SC' was not declared in this scope
  if (FTM0_SC & FTM_SC_TOF) {
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:180:16: error: 'FTM_SC_TOF' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:189:17: error: 'FTM0_STATUS' was not declared in this scope
  uint8_t mask = FTM0_STATUS & channelmask;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp: In member function 'void FreqMeasureMulti::isr(bool)':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqMeasureMulti\FreqMeasureMulti.cpp:206:28: error: 'FTM0_C0SC' was not declared in this scope
Error compiling for board Teensy 4-Beta2.
I noticed that Paul had made modifications to FreqMeasure in January.
Also FreqCount and FreqTimer2 Failed... I'll list the errors separately below.
Let me know if this is not appropriate.
FreqCount Fails to compile.
Below are the errors returned by the Arduino IDE when compiling the FreqCount serial_output.ino example for Teensy 4-Beta2:
In file included from C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:27:0:
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\util/FreqCountTimers.h:64:4: error: #error "Unknown chip, please edit me with timer+counter definitions"
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp: In static member function 'static void FreqCountClass::begin(uint16_t)':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:44:15: error: 'counter_init' was not declared in this scope
  counter_init();
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:45:31: error: 'timer_init' was not declared in this scope
  gate_length = timer_init(msec);
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:46:19: error: 'SREG' was not declared in this scope
  uint8_t status = SREG;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:48:14: error: 'timer_start' was not declared in this scope
  timer_start();
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:50:16: error: 'counter_start' was not declared in this scope
  counter_start();
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp: In static member function 'static uint32_t FreqCountClass::read()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:64:11: error: 'SREG' was not declared in this scope
  status = SREG;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp: In static member function 'static void FreqCountClass::end()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:79:17: error: 'timer_shutdown' was not declared in this scope
  timer_shutdown();
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:80:19: error: 'counter_shutdown' was not declared in this scope
  counter_shutdown();
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp: At global scope:
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp:84:4: error: expected constructor, destructor, or type conversion before '(' token
 ISR(TIMER_ISR_VECTOR)
FrequencyTimer2 fails to compile
Below are the errors returned by the Arduino IDE when compiling the FrequencyTimer2 test.ino sketch example for Teensy 4-Beta2:
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::setPeriod(long unsigned int)':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:190:13: error: 'F_BUS' was not declared in this scope
  period *= (F_BUS / 1000000);
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:301:2: error: 'SIM_SCGC4' was not declared in this scope
  SIM_SCGC4 |= SIM_SCGC4_CMT;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:301:15: error: 'SIM_SCGC4_CMT' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:302:2: error: 'CMT_MSC' was not declared in this scope
  CMT_MSC = 0;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:303:2: error: 'CMT_PPS' was not declared in this scope
  CMT_PPS = bdiv;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:304:2: error: 'CMT_CMD1' was not declared in this scope
  CMT_CMD1 = ((period - 1) >> 8) & 255;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:305:2: error: 'CMT_CMD2' was not declared in this scope
  CMT_CMD2 = (period - 1) & 255;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:306:2: error: 'CMT_CMD3' was not declared in this scope
  CMT_CMD3 = (period >> 8) & 255;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:307:2: error: 'CMT_CMD4' was not declared in this scope
  CMT_CMD4 = period & 255;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:308:2: error: 'CMT_OC' was not declared in this scope
  CMT_OC = 0x60;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static long unsigned int FrequencyTimer2::getPeriod()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:316:12: error: 'CMT_CMD3' was not declared in this scope
  period = (CMT_CMD3 << 8) | CMT_CMD4;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:316:29: error: 'CMT_CMD4' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:317:13: error: 'CMT_PPS' was not declared in this scope
  period *= (CMT_PPS + 1);
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:318:15: error: 'CMT_MSC' was not declared in this scope
  period <<= ((CMT_MSC >> 5) & 3) + 4;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:319:13: error: 'F_BUS' was not declared in this scope
  period /= (F_BUS / 1000000);
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::enable()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:326:35: error: 'PORT_PCR_MUX' was not declared in this scope
  CORE_PIN5_CONFIG = PORT_PCR_MUX(2)|PORT_PCR_DSE|PORT_PCR_SRE;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:326:37: error: 'PORT_PCR_DSE' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:326:50: error: 'PORT_PCR_SRE' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::disable()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:332:35: error: 'PORT_PCR_MUX' was not declared in this scope
  CORE_PIN5_CONFIG = PORT_PCR_MUX(1)|PORT_PCR_DSE|PORT_PCR_SRE;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:332:37: error: 'PORT_PCR_DSE' was not declared in this scope
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:332:50: error: 'PORT_PCR_SRE' was not declared in this scope
                 from C:\Users\Rober\AppData\Local\Temp\arduino_build_13904/pch/Arduino.h:6,
                 from C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2/FrequencyTimer2.h:27,
                 from C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:30:
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::setOnOverflow(void (*)())':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:340:19: error: 'IRQ_CMT' was not declared in this scope
   NVIC_ENABLE_IRQ(IRQ_CMT);
C:\Arduino189_T147B4\hardware\teensy\avr\cores\teensy4/imxrt.h:8292:52: note: in definition of macro 'NVIC_ENABLE_IRQ'
 #define NVIC_ENABLE_IRQ(n)      (*(&NVIC_ISER0 + ((n) >> 5)) = (1 << ((n) & 31)))
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:342:20: error: 'IRQ_CMT' was not declared in this scope
   NVIC_DISABLE_IRQ(IRQ_CMT);
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In function 'void cmt_isr()':
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:351:40: error: 'CMT_MSC' was not declared in this scope
  uint8_t __attribute__((unused)) tmp = CMT_MSC;
C:\Arduino189_T147B4\hardware\teensy\avr\libraries\FrequencyTimer2\FrequencyTimer2.cpp:352:8: error: 'CMT_CMD2' was not declared in this scope
  tmp = CMT_CMD2;
@Kurt,
I'm having problem, getting updateScreenAsync(true) to work, with your ILI9341_t3n library. Is the "master" branch the right one?
Does it work, or am I doing something wrong? It's not the cache - it just don't work for me (no continous screen-update)
Can you please post a short example?
Thank you, Frank.
One possible use of GPT1 is for FreqCount (pin 25 is the external trigger). Here is a proof-of-concept (32-bit counter)
https://github.com/manitou48/teensy4/blob/master/gpt_count.ino
Jumper PWM pin 11 to 25 for testing.
GPTn can also do PWM, but NONE of the GPTn output pins are available on T4 (1050).
Hi @manitou
Just getting around to play with this now again. Was trying to get it to work on GPT2 using your code as the base - GPT2_clk is on pin 14 as alt8 - unless my eyes are getting crossed it that is right then should be easy enough to convert your sketch - but all I get is 0 as outputs - what am I missing here:
// GPT1 counter like FreqCount
// external pin is 14 GPIO_AD_B1_02 ALT8  (Frontside - A0)
// test with  PWM pin 11 jumpered to 14
// FreqCount API
static inline void counter_init(void)
  CCM_CCGR0 |= CCM_CCGR0_GPT2_BUS(CCM_CCGR_ON) ;  // enable GPT1 module
  //CCM_CCGR0 |= CCM_CCGR0_GPT2_SERIAL(CCM_CCGR_ON) ;
  GPT2_CR = 0;
  GPT2_SR = 0x3F; // clear all prior status
  GPT2_CR =  GPT_CR_CLKSRC(3);// | GPT_CR_FRR ;// 3 external clock
  //*(portConfigRegister(14)) = 8;  // ALT 1
  //CORE_PIN14_CONFIG = 8;
  IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_02 = 8;
static inline void counter_start(void)
  GPT2_CR |= GPT_CR_EN; // enable
static inline void counter_shutdown(void)
  GPT2_CR = 0;
static inline uint32_t counter_read(void)  // was uint16_t in FreqCount?
  return GPT2_CNT;
static inline uint8_t counter_overflow(void)
  return GPT2_SR & GPT_SR_ROV;
static inline void counter_overflow_reset(void)
  GPT2_SR |= GPT_SR_ROV;
volatile uint32_t count_ready, count_output, count_prev;
void tmr_callback() {
  uint32_t count = counter_read();
  //track rollover ?
  count_output = count - count_prev;
  count_prev = count;
  count_ready = 1;
IntervalTimer it1;
  while (!Serial);
  delay(2000);
  analogWriteFrequency(11, 1234);  // test jumper 11 to 25
  analogWrite(11, 128);
  counter_init();
  it1.begin(tmr_callback, 1000000);  // us
  counter_start();
  if (count_ready) {
    Serial.println(count_output);
    count_ready = 0;
Hi @manitou
I never tried it on 1062 cause my breakout board doesn't have pogo pin on pin 25. It should work with pin 25 just like it does with 1050.
i've not tried GPT2 -- GPT2 CLK pin is not listed in table in post #3? can you pogo pin 25 and try GPT1
EDIT: i think more pin magic is required, since the ALT8 config is the 2nd choice. there is another config command ... looking ....
you need to set low bit in IOMUXC_GPT2_IPP_IND_CLKIN_SELECT_INPUT (ref pg 1000)
@Kurt,
Thank you, Frank.
I will take a look, but I am away from desk, so might be in a while.
@manitou - yep it does work on pin 25 gave it a try first - Sermon shows 1234, which is what you set up for analogWriteFreq :)
I was curious so I took a look at the 1060 manual and saw what AD_B1_02 shows GPT2_CLK as alt8. So decided to give it a try since it is an edge pin. See page 490 of the RM. EDIT: also page 304
i edited my previous post ....you need to set low bit in IOMUXC_GPT2_IPP_IND_CLKIN_SELECT_INPUT (ref pg 1000)
@Frank B @mjs513 and ...
Now that I played for awhile, some of it is coming back to me.
Actually today I started playing around with st7735_t3 library to add frame buffer and async support. I have some of it working now, it is up in the fork/branch: https://github.com/KurtE/ST7735_t3/tree/FB_Asynch
In a test app for playing with, I hacked in some simple continuous update test... Which is NOT working:
void testContinuousUpdate() {
  Serial.println("Start Continuous update test");
  tft.fillScreen(ST7735_RED);
  tft.updateScreenAsync(true);
  Serial.println("After updateScreenAsync");
  while(tft.frameCount() < 10) {
  tft.fillScreen(ST7735_GREEN);
  while(tft.frameCount() < 20) ;
  tft.fillScreen(ST7735_BLUE);
  while(tft.frameCount() < 30) ;
  tft.drawRect(0,0, tft.width(), tft.height(), ST7735_BLUE);
  tft.setCursor(10, tft.height() / 2 - 4);
  tft.printf("R:%d W:%d H:%d", rotation, tft.width(), tft.height());
  while(tft.frameCount() < 35) ;
  Serial.println("Finished all frames");
  tft.endUpdateAsync();
  Serial.println("After call to endUpdateAsync");
  while (tft.asyncUpdateActive());
  Serial.println("Test completed");
The output on debug terminal...
init CS:10 DC:9 MOSI:11 SCLK:13 RST:20
 Row Start:3  Col Start: 2
Set Rotation: 0 width: 128 height: 128
Hit any key to continue
....................................Finished all frames
So I have hang to figure out at end...
BUT also the screen is all RED, never changed, after the first redraw...
Why? Probably because, I did not set the frame buffer, but instead allowed to be allocated by malloc. So there is the issue that SPI is using the data in actual memory, but the main code is updating the cache...
The first screen comes out correct, as I have code at the start of updateScreenAsync that does:
// Maybe have to flush cache to make DMA work...
if ((uint32_t)_pfbtft >= 0x20200000u) arm_dcache_flush(_pfbtft, _width*_height*2);
The problem is that is the only place it is done. So updates are not flushed out.
Question is who/where should do this again? With this small display I may see if I add a call like this to the DMA interrupt, if that will work, or will it miss caching out some of the first pixels....
EDIT: adding a flush of cache in the ISR appears to help in this case
Thank you Kurt, I'll try that when I'm back home.
I was pretty sure that it was no caching issue, but maybe I was wrong.
FREQCOUNT LIBRARY
@manitou and ….
Using got the FreqCount library working with GPT2 which uses pin 14. If you want to test it out before I do a PR I am attaching the zip file.
View attachment FreqCount.zip
Probably have to add a few notes to the examples though for the T4
EDIT: Think the max freq would be 37Mhz, approximately 1/4 IPG_CLK. I don't have a freq generator to test with just analogWriteFreq (not sure how high this can go)
@Frank B - I will try it out again on the ILI9341_t3n code base, I easily could have left the continuous stuff not working on T4 there due to frustration with the caching and the like.
The actual code snip-it I showed was my little test for the ST7735 display. Which appears to be working on it. Right now trying to also get the code in my branch/fork to compile and (maybe run) on T3.5. It does compile for T3.6. Will then do quick hook up to some boards to see what happens on those, At which time I will merge those back into my other temporary branch which has an outstanding PR into the master st7735_t3 code base.
Edit: I now have it compiling on all three...
However I now need to make it such that more than one display can be used with DMA... did not worry about it with ili9341 as only enough memory for one (although we T4), maybe 2?
@manitou
I incorporated @Frank B modified QTimer code from @TelephoneBill into the FreqCount test sketch to see what I got:
@1.5Mhz ==> 1499999
@150Khz ==> 150000
@ 15khz ==> 15000
Not to bad. Is there a way to get Qtimer up to 15Mhz?
/* FreqCount - Example with serial output
 * http://www.pjrc.com/teensy/td_libs_FreqCount.html
 * This example code is in the public domain.
#include <FreqCount.h>
  Serial.begin(57600);
  pinMode(13, OUTPUT);              //pin 13 as digital output
  //enable clocks for QTIMER3
  CCM_CCGR6 |= 0xC0000000;                    //enable clocks to CG15 of CGR6 for QT3
  //configure QTIMER1 Timer0 for test. Period = 65,536 = 436.9 uS (times 2) - rollover
  TMR3_CTRL0 = 0b0000000000100000;  // stop all functions of timer
  TMR3_SCTRL0 = 0b0100000000000001; // 0(TimerCompareFlag),1(TimerCompareIntEnable),000000,00(Capture Disabled),00000,1(OFLAG to Ext Pin)
  TMR3_CNTR0 = 0;
  TMR3_LOAD0 = 0;
  TMR3_COMP10 = 10000 -1;              // 6.7nS per clock = 66.7uS for 10,000 clocks on each half cycle
  TMR3_CMPLD10 = 10000 -1;
  TMR3_CSCTRL0 = 0b0000000001000001;  //Compare1 interrupt enable
  TMR3_CTRL0 = 0b0011000000100011;  // 001(Count rising edges Primary Source),1000(IP Bus Clock),00 (Secondart Source),
                                    // 0(Count Once),1(Count up to Compare),0(Count Up),0(Co Channel Init),011(Toggle OFLAG on Compare)
  //configure Teensy pin Compare output
  IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_00 = 1;    // QT3 Timer0 is now on pin 19
  //enable GPT1 interrupt within NVIC table
  attachInterruptVector(IRQ_QTIMER3, QT3_isr);  //declare which routine performs the ISR function
  NVIC_ENABLE_IRQ(IRQ_QTIMER3);
  FreqCount.begin(1000000);
void QT3_isr(void) {
  digitalWriteFast(13, 1);
  digitalWriteFast(13, 0);
  asm volatile("dsb");
  if (FreqCount.available()) {
    unsigned long count = FreqCount.read();
    Serial.println(count);
EDIT: Just created PR #11 to the FreqCount Library
Nice work Kurt - should be interesting if you can get it to work with 2 displays :)
I think we've talked about this before in the context of uncanny eyes. As I understand it, unlike the T3.x, the T4 only has one CS pin for DMA access. I would imagine one technique would be to manage the CS pins for the actual display, doing the digitalWrite's manually when switching displays (making sure that the DMA queue is empty), and use pin 10 for the CS pin in the library, but don't actually connect that up to the displays.
Or are you thinking of using the second SPI bus (pins 0, 1, 26, and 27)?
@manitou
@1.5Mhz ==> 1499999
@150Khz ==> 150000
@ 15khz ==> 15000
Don't you get 15 mhz with
  TMR3_COMP10 = 5 -1;
  TMR3_CMPLD10 = 5 -1;
My scope shows 37MHz with "2-1"
// PWM qtimer 3 chnl 0 pin 19  16-bit timer
//https://forum.pjrc.com/threads/54711-Teensy-4-0-First-Beta-Test?p=210440&viewfull=1#post210440
  CCM_CCGR6 |= CCM_CCGR6_QTIMER3(CCM_CCGR_ON);
  TMR3_CTRL0 = 0;  // stop  timer
  TMR3_SCTRL0 = TMR_SCTRL_OEN; // output enable
  TMR3_CNTR0 = 0;
  TMR3_LOAD0 = 0;
  TMR3_CMPLD10 = 2 - 1;
  TMR3_CSCTRL0 = TMR_CSCTRL_CL1(1);
  TMR3_CTRL0 =  TMR_CTRL_CM(1) | TMR_CTRL_PCS(8 ) | TMR_CTRL_LENGTH | TMR_CTRL_OUTMODE(3);
  IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_00 = 1;    // QT3 Timer0 on pin 19
void loop() {}
  TMR3_COMP10 = 5 -1;
Best I can do and still get the FreqCount to give me output with 1000000us is with 17 -1; which reads 8822737hz. Same for freqMeasure. Have to pull out my scope to see what I am actually getting. Running out of room on my desk....
FWIW, i added my sketch to post #3795
Hi Kurt,
I modified now your graphicstest (attached to this post).
Apart form the cache-issue (which is not really an issue, because we know how to solve it!), it stops/hangs:
ILI9341 Test!
After TFT Begin
13
Screen fill              1171
Text                     422
Lines
I've seen this in my own program, too.
  • t4_graphicstest_t3n-190722a.zip
Can probably do either: But if multiple ones on same SPI buss, you can obviously only do one at at a time using DMA...
My ST7735_t3 branch/fork updated: https://github.com/KurtE/ST7735_t3/tree/FB_Asynch
I have simple test program currently updating two displays I believe at same time:View attachment ST7735_t3_multiple-190722a.zip
Which is going through lots of the Teensyview demo screens...
I probably want to test this out a little on at least T3.6 to see that it works before I then merge it into my other fork/branch with a current PR into the master...
The code is:
  unsigned freq = 15000000; //15MHz or any other.. works up to F_BUS_ACTUAL / 2 = 75MHz (without overclocked F_BUS)
  TMR3_CMPLD10 = F_BUS_ACTUAL / 2 / freq - 1;
Edit: Verified with my scope. It show a few Hz off - might be an issue with the scope.
