Page 121 of 165 FirstFirst ... 21 71 111 119 120 121 122 123 131 ... LastLast
Results 3,001 to 3,025 of 4111
  1. #3001
    9,018
    This one is also easy. I believe it's already been covered, but just in case the answer hasn't been clear...
    This is absolutely the correct expected behavior. The ON/OFF state is maintained as long as the low-power (or "SNVS") portion of the chip has at least 1 volt.
    Yes, the only surprising thing is that the 'unplugged' Teensy has live MCU circuits powered by the UARTS so it can respond to the Power button when ( if not for the dim glow of the breakout LED ) the T4 would otherwise be assumed to be Unpowered and in no condition to maintain state.
    User case: Teensy goes Off while on USB power - without UART or vBat power unplugging and replugging would result in the T4 running normal setup() - like any Teensy.
    That just shows that UARTS on pins keep alive - there is at least one variant in those posts where USB gets ODD with current stack - those would be the important ones to make sure the code can restart/reconnect
    This one does that - when externally powered with cut traces:: From 5/19 post #2889 when using external power with VIN<>VUSB trace cut
  2. #3002
    20,301
    Conclusion: Problem is externally powered T4 doing USB output when USB is disconnected, T4 continues running - but USB stays 'offline' when cable plugged in.
    I've committed a fix for this problem.
    https://github.com/PaulStoffregen/co...28c55acb3d2b81
    USB serial communication should now properly resume when the cable is plugged back into an externally powered T4.
  3. #3003
    9,018
    Cool, I'll give it ago in next 24 hrs. An hour past time for Zzz's - up early for a day trip to Oregon - about an hour from you.
    That one I figured was recognizable and correctable in software.
  4. #3004
    20,301
    Yes, this will be "fixed" by documentation.
    You may recall I talked about being a bit reluctant to make the on/off feature available to Arduino users... months ago in the transition from 1052 (where I wired the 3.3V regulator always on) and 1062 (where all have supported on/off). It can be confusing when the hardware is "off", for whatever reason. It can be confusing when you believe you've shut off the power, but the caps don't fully discharge or microamps of current leak through the pins from something else that still has power. These are issues that will need to be documented on the troubleshooting page. Fortunately, it is pretty easy to check with a multimeter whether the power really went all the way to zero volts.
    The on/off feature is so very useful for people making battery powered projects. It would seem like quite a shame to have this in the hardware and not make it available to users.
    I tried to read through your messages again. There seems to be a lot of talk where the USB communication not restarting is mixed up with the on/off power management. Some parts I can't quite parse what you mean.
    I also see a lot of talk about an Orico Hub/Drive which unintentionally powers T4 through the host port. While that's wrong hub behavior and we may see if from other hubs, as far as T4 is concerned this is the same as if you connected external 5V power to VIN. Nothing I can do about that in the T4 hardware or software.
    Are there other outstanding issues I should investigate? Did I miss anything else in those messages?
  5. #3005
    5,034
    @Paul and @defragster - this was my b) part in the earlier message:
    b) Powered USB Hub... I am thinking this is maybe more support chip differences between the T3.6 and your T4 breakout board.
    That is if you look at the Teensy 3.5/6 schematic (https://www.pjrc.com/teensy/schematic.html)
    You will see the chip TPD3S014 (http://www.ti.com/lit/ds/symlink/tpd3s014.pdf), which I think is controlling the USB power to the host port. And it has an enable pin connected to PTE6 which has a PD resistor connected to it and which the USBHost code specifically enables int USBHost::begin()...
    I believe that the breakout boards are using a TPS055A chip? (looks like: https://www.ti.com/lit/ds/symlink/tps2058a.pdf) marking 2055a and it looks like the enable is simply tied to +5v. do not sure if there could be some voltage coming in on D+/D- or the like, which may float enable high enough?
    So my guess is if someone wanted to hardware experiment to get T4 to act like T3.6 here could try:
    1) Use same chip as T3.6 and use an IO pin with PD resistor to enable pin
    2) Try current breakout board, Disconnect pin 4 (enable) currently tied to +5v, and run a jumper to some IO pin with PD resistor... Obviously will then need to enable this pin, when a program wishes to use USB Host...
    I believe that @defragster said that this disk/hub did not power up a T3.6... So looking at differences in the hardware, it looks like for these breakout boards you chose a different support chip to limit current and that on T3.6 the enable pin was tied to an IO pin and on your breakout it is set to +5v... For me probably not an issue, but wondering what are the trade offs of the two different chips.
    That is I am thinking of ordering a batch of the breakout board I am playing with and wondering which way to go...
    Also wondering where best to place the flat ribbon connector for the SD card under the chip... But different subject
  6. #3006
    Senior Member+
    3,664
    PROPSHIELD/MPL3115A2
    I ported over the MPL code into a separate library format and tested it on the T3.5 and the T4. Again works on the T3.5 but not on the T4 for some strange reason - just hangs at the same point. The port is over on my WIP GitHub page: https://github.com/mjs513/WIP/tree/master/MPL3115 if somebody with a prop shield wants to give it a try.
    Mike
  7. #3007
    9,018
    @Paul and KurtE
    Good to know you've walked through the issues - indeed they all relate to some core powered parts powered when not 'apparent'.
    Kurt - ... - of course T_3.6 acts better - there was an MCU pin handy for better power control that makes sense now.
    Gotta run - but knowing the USB is under control with that issue fixed - and there aren't any other aspects of VamPower going to bite like brown out startup did all good
  8. #3008
    2,074
    Re: WavFilePlayer
    There has been a problem with WavFilePlayer on T3.6 with BUILTIN_SDCARD, see https://forum.pjrc.com/threads/56239...er-not-working
    I decided to test on T4B2. T4B2 WavFilePlayer example "works" from audio adapter uSD (SPI) (I don't have needed SMD resistor for codec, so i get noise through ear buds, but it appears WAV files are playing). If I use BUILTIN_SDCARD, i get no audio and serial monitor never says it's "playing". Example listfiles and other SD IO seems to work with BUILTIN_SDCARD (1.8.8/1.47-beta2)
    Can others confirm ?
    Editing play_sd_wav.h and play_sd_wav.cpp
    I aligned buffer and commented out __disable_irq() before SD.open(), and WavFilePlayer seems to be playing on T4B2 (observed with scope), fix based on following:
    https://forum.pjrc.com/threads/56355...ignment-issues
    AudioPlaySdRaw with BUILTIN_SDCARD also hangs -- works if you remove __disable_irq() before SD.open() in libraries/Audio/play_sd_raw.cpp
    maybe this pull request: https://github.com/PaulStoffregen/Audio/pull/294
    more discussions
  9. #3009
    20,301
    The ones I used on the last round of breakout boards are Digikey AE11351-ND.
    For the end plugging into the bottom side of T4, I had to put a ~90 degree kink in the blue tab by bending it over the edge of needle nose pliers.
  10. #3010
    5,034
    Mike
    Hi @mjs513 - Looks like it is hanging in Wire library... I am pretty sure I have it hooked up reasonably ...
    Ran the scanner sketch with wire...
    Scanning...
    Device found at address 0x1E  (LSM303D,HMC5883L,FXOS8700,LIS3DSH)
    Device found at address 0x20  (MCP23017,MCP23008,PCF8574,FXAS21002,SoilMoisture)
    Device found at address 0x60  (MPL3115,MCP4725,MCP4728,TEA5767,Si5351)
    done
    Scanning...
    done
    I hacked up the wireimxrt.cpp code to be able to turn on/off debug and output to Serial...
    #include "Wire.h"
    #if defined(__IMXRT1052__) || defined(__IMXRT1062__)
    #define DEBUG_WIRE
    #ifdef DEBUG_WIRE
    #define DBGPrintf Serial.printf
    #else
    void inline DBGPrintf(...) {};
    //#include "debug/printf.h"
    void TwoWire::begin(void)
            // use 24 MHz clock
            CCM_CSCDR2 = (CCM_CSCDR2 & ~CCM_CSCDR2_LPI2C_CLK_PODF(63)) | CCM_CSCDR2_LPI2C_CLK_SEL;
    	hardware.clock_gate_register |= hardware.clock_gate_mask;
            port->MCR = LPI2C_MCR_RST;
            setClock(100000);
    	hardware.sda_mux_register = hardware.sda_mux_value;
    	hardware.scl_mux_register = hardware.scl_mux_value;
    	hardware.sda_input_register = hardware.sda_input_value;
    	hardware.scl_input_register = hardware.scl_input_value;
    	hardware.sda_pad_register |= IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3);
    	hardware.scl_pad_register |= IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3);
    void TwoWire::begin(uint8_t address)
    	// TODO: slave mode
    void TwoWire::end()
    size_t TwoWire::write(uint8_t data)
    	if (transmitting || slave_mode) {
    		if (txBufferLength >= BUFFER_LENGTH+1) {
    			setWriteError();
    			return 0;
    		txBuffer[txBufferLength++] = data;
    		return 1;
    	return 0;
    size_t TwoWire::write(const uint8_t *data, size_t quantity)
    		size_t avail = BUFFER_LENGTH+1 - txBufferLength;
    		if (quantity > avail) {
    			quantity = avail;
    			setWriteError();
    		memcpy(txBuffer + txBufferLength, data, quantity);
    		txBufferLength += quantity;
    		return quantity;
    	return 0;
    uint8_t TwoWire::endTransmission(uint8_t sendStop)
    	uint32_t i=0, len, status;
    	len = txBufferLength;
    	if (!len) return 4; // no data to transmit
    	// wait while bus is busy
    	while (1) {
    		status = port->MSR; // pg 2899 & 2892
    		if (!(status & LPI2C_MSR_BBF)) break; // bus is available
    		if (status & LPI2C_MSR_MBF) break; // we already have bus control
    		// TODO: timeout...
    	DBGPrintf("m=%x\n", status);
    	// TODO: is this correct if the prior use didn't send stop?
    	//port->MSR = LPI2C_MSR_PLTF | LPI2C_MSR_ALF | LPI2C_MSR_NDF | LPI2C_MSR_SDF; // clear flags
    	port->MSR = status;
    	DBGPrintf("MSR=%lX, MFSR=%lX\n", status, port->MFSR);
    	elapsedMillis timeout=0;
    	while (1) {
    		// transmit stuff, if we haven't already
    		if (i <= len) {
    			uint32_t fifo_used = port->MFSR & 0x07; // pg 2914
    			if (fifo_used < 4) DBGPrintf("t=%ld\n", fifo_used);
    			while (fifo_used < 4) {
    				if (i == 0) {
    					DBGPrintf("start %x\n", txBuffer[0]);
    					port->MTDR = LPI2C_MTDR_CMD_START | txBuffer[0];
    					i = 1;
    				} else if (i < len) {
    					port->MTDR = LPI2C_MTDR_CMD_TRANSMIT | txBuffer[i++];
    					if (sendStop) port->MTDR = LPI2C_MTDR_CMD_STOP;
    					i++;
    				fifo_used = fifo_used + 1;
    		// monitor status
    		if (status & LPI2C_MSR_ALF) {
    			DBGPrintf("arbitration lost\n");
    			return 4; // we lost bus arbitration to another master
    		if (status & LPI2C_MSR_NDF) {
    			DBGPrintf("NACK, f=%d, i=%d\n", port->MFSR & 0x07, i);
    			// TODO: check that hardware really sends stop automatically
    			port->MCR = LPI2C_MCR_MEN | LPI2C_MCR_RTF;  // clear the FIFO
    			// TODO: is always sending a stop the right way to recover?
    			return 2; // NACK for address
    			//return 3; // NACK for data TODO: how to discern addr from data?
    		if (status & LPI2C_MSR_PLTF) {
    			DBGPrintf("bus stuck - what to do?\n");
    			return 4;
    		if (timeout > 100) {
    			DBGPrintf("status = %x\n", status);
    			timeout = 0;
    		if (sendStop) {
    			if (status & LPI2C_MSR_SDF) {
    				// master automatically sends stop condition on some
    				// types of errors, so this flag only means success
    				// when all comments in fifo have been fully used
    				uint32_t fifo = port->MFSR & 0x07;
    				if (fifo == 0) return 0;
    			if (fifo_used == 0) {
    				//digitalWriteFast(15, HIGH);
    				//delayMicroseconds(2);
    				//digitalWriteFast(15, LOW);
    				// TODO: this returns before the last data transmits!
    				// Should verify every byte ACKs, arbitration not lost
    				DBGPrintf("fifo empty, msr=%x\n", status);
    				return 0;
    uint8_t TwoWire::requestFrom(uint8_t address, uint8_t length, uint8_t sendStop)
    	uint32_t cmd=0, status, fifo;
    	while (1) {
    		// TODO: timeout...
    	DBGPrintf("idle2, msr=%x\n", status);
    	//DBGPrintf("MSR=%lX, MFSR=%lX\n", status, port->MFSR);
    	address = (address & 0x7F) << 1;
    	if (length < 1) length = 1;
    	if (length > 255) length = 255;
    	rxBufferIndex = 0;
    	rxBufferLength = 0;
    	while (1) {
    		if (cmd < 3) {
    			fifo = port->MFSR & 0x07; // pg 2914
    			//if (fifo < 4) DBGPrintf("t=%ld\n", fifo);
    			while (fifo < 4 && cmd < 3) {
    				if (cmd == 0) {
    					port->MTDR = LPI2C_MTDR_CMD_START | 1 | address;
    				} else if (cmd == 1) {
    					// causes bus stuck... need way to recover
    					//port->MTDR = LPI2C_MTDR_CMD_START | (length - 1);
    					port->MTDR = LPI2C_MTDR_CMD_RECEIVE | (length - 1);
    				cmd++;
    				fifo = fifo + 1;
    		// receive stuff
    		if (rxBufferLength < sizeof(rxBuffer)) {
    			fifo = (port->MFSR >> 16) & 0x07;
    			//if (fifo > 0) DBGPrintf("r=%ld\n", fifo);
    			while (fifo > 0 && rxBufferLength < sizeof(rxBuffer)) {
    				rxBuffer[rxBufferLength++] = port->MRDR;
    				fifo = fifo - 1;
    		// monitor status
    			DBGPrintf("got NACK\n");
    			// TODO: how to make sure stop is sent?
    		if (timeout > 250) {
    			DBGPrintf("Status = %x\n", status);
    			timeout = 0;
    		if (rxBufferLength >= length && cmd >= 3) break;
    	return rxBufferLength;
    PROGMEM
    constexpr TwoWire::I2C_Hardware_t TwoWire::i2c1_hardware = {
            CCM_CCGR2, CCM_CCGR2_LPI2C1(CCM_CCGR_ON),
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_01, // 18/A4  AD_B1_01  GPIO1.17  I2C1_SDA
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_00, // 19/A5  AD_B1_00  GPIO1.16  I2C1_SCL
    	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_01,
    	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_00,
    	IOMUXC_LPI2C1_SDA_SELECT_INPUT,
    	IOMUXC_LPI2C1_SCL_SELECT_INPUT,
    	3 | 0x10,
    	3 | 0x10,
    	1,
    	1,
            IRQ_LPI2C1
    TwoWire Wire(&IMXRT_LPI2C1, TwoWire::i2c1_hardware);
    PROGMEM
    constexpr TwoWire::I2C_Hardware_t TwoWire::i2c3_hardware = {
            CCM_CCGR2, CCM_CCGR2_LPI2C3(CCM_CCGR_ON),
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_06, // 17/A3  AD_B1_06  GPIO1.22  I2C3_SDA
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_07, // 16/A2  AD_B1_07  GPIO1.23  I2C3_SCL
    	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_06,
    	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_07,
    	IOMUXC_LPI2C3_SDA_SELECT_INPUT,
    	IOMUXC_LPI2C3_SCL_SELECT_INPUT,
    	1 | 0x10,
    	1 | 0x10,
    	2,
    	2,
            IRQ_LPI2C3
    TwoWire Wire1(&IMXRT_LPI2C3, TwoWire::i2c3_hardware);
    PROGMEM
    constexpr TwoWire::I2C_Hardware_t TwoWire::i2c4_hardware = {
            CCM_CCGR6, CCM_CCGR6_LPI2C4_SERIAL(CCM_CCGR_ON),
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_13, // 25/A11  AD_B0_13  GPIO1.13  I2C4_SDA
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_12, // 24/A10  AD_B1_12  GPIO1.12  I2C4_SCL
    	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_13,
    	IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B0_12,
    	IOMUXC_LPI2C4_SDA_SELECT_INPUT,
    	IOMUXC_LPI2C4_SCL_SELECT_INPUT,
    	0 | 0x10,
    	0 | 0x10,
    	1,
    	1,
            IRQ_LPI2C4
    TwoWire Wire2(&IMXRT_LPI2C4, TwoWire::i2c4_hardware);
    void TwoWire::setClock(uint32_t frequency)
            port->MCR = 0;
    	if (frequency < 400000) {
    		// 100 kHz
    		port->MCCR0 = LPI2C_MCCR0_CLKHI(55) | LPI2C_MCCR0_CLKLO(59) |
    			LPI2C_MCCR0_DATAVD(25) | LPI2C_MCCR0_SETHOLD(40);
    		port->MCFGR1 = LPI2C_MCFGR1_PRESCALE(1);
    		port->MCFGR2 = LPI2C_MCFGR2_FILTSDA(5) | LPI2C_MCFGR2_FILTSCL(5) |
    			LPI2C_MCFGR2_BUSIDLE(3900);
    	} else if (frequency < 1000000) {
    		// 400 kHz
    		port->MCCR0 = LPI2C_MCCR0_CLKHI(26) | LPI2C_MCCR0_CLKLO(28) |
    			LPI2C_MCCR0_DATAVD(12) | LPI2C_MCCR0_SETHOLD(18);
    		port->MCFGR1 = LPI2C_MCFGR1_PRESCALE(0);
    		port->MCFGR2 = LPI2C_MCFGR2_FILTSDA(2) | LPI2C_MCFGR2_FILTSCL(2) |
    		// 1 MHz
    		port->MCCR0 = LPI2C_MCCR0_CLKHI(9) | LPI2C_MCCR0_CLKLO(10) |
    			LPI2C_MCCR0_DATAVD(4) | LPI2C_MCCR0_SETHOLD(7);
    		port->MCFGR2 = LPI2C_MCFGR2_FILTSDA(1) | LPI2C_MCFGR2_FILTSCL(1) |
            port->MCCR1 = port->MCCR0;
            port->MCFGR0 = 0;
            port->MCFGR3 = LPI2C_MCFGR3_PINLOW(3900);
            port->MFCR = LPI2C_MFCR_RXWATER(1) | LPI2C_MFCR_TXWATER(1);
            port->MCR = LPI2C_MCR_MEN;
    With some of the debug stuff turned on, you see it hang with status = 1300
    Before Wire Begin
    After Wire Begin
    Start MPL3115A2::init
    MPL3115A2::writeByte 60 26=4
        EndTransmission
    m=1
    MSR=1, MFSR=0
    t=0
    start c0
    NACK, f=1, i=4
    MPL Reset
    m=3000401
    MSR=3000401, MFSR=1
    t=1
    start c0
    NACK, f=1, i=3
    idle2, msr=3000701
    got NACK
    FF
    m=3000700
    MSR=3000700, MFSR=2
    t=2
    start c0
    status = 1300
    status = 1300
    status = 1300
    status = 1300
    status = 1300
    status = 1300
    status = 1300
    status = 1300
    Wonder if the last send did not do a stop, if the next send should do a start? Or should it be repeat... I am not an I2C expert!
  11. #3011
    20,301
    I've added the WavFilePlayer and MP3115 issues to the list on msg #6, so I'll remember to look at them in a couple weeks.
    I still have another day or so of work to do on the test fixture. That's taken almost all my time since Maker Faire, but it's critically important to get done now. The last ~20 beta boards are sitting here waiting for testing. Those are the last virgin boards (OTP fuses in original state from NXP) to use with the test fixture until we get the first production run.
    Next up will be more work on the bootloader and also the EEPROM library. So far, the bootloader has made 75% of the flash chip available for user code. The other 25% has been "reserved", so only the top 4K so far used to store a copy of the restore program. I'm probably going to reduce the reserved area to something like 64K to 128K. Will really depend on the EEPROM emulation, which I must confess I've been putting off because it's so difficult.
    In a couple weeks (or whenever I get EEPROM working and a new bootloader rev done) I'm going to transition to filling out the rest of the USB device code and investigating these many issues. I know it's frustrating to have issues get put on hold, but please try to put anything that's broken onto the msg #6 list.
  12. #3012
    Senior Member+
    3,664
    @KurtE - @PaulStoffregen
    Thanks for giving it a sanity check for me. Thinking it has something to do with endTransmission(false) not really being working correctly going to try and look at it a bit more as well as what you identified with
    Unfortunately I never played with I2C either so am groping in dark but maybe I can see something.
    @Paul - don't envy you working the EEPROM was looking at the EEPROM driver in the STM32duino core for the H7, argh.....
  13. #3013
    20,301
    Very well may be a bug in the Wire lib. Will look into this in a week or two, but first need to finish the test fixture, and work on the bootloader & EEPROM support.
  14. #3014
    Senior Member+
    3,664
    @Paul
    Understood - my text was that I was going to poke around a bit see if I could learn something along the way - no rush. The test fixture has to come first and then the bootloader and probably the USB. Then the EEPROM
  15. #3015
    2,074
    Mike
    MPL3115A2
    With my propshield, I first used Sparkfun lib and MPL3115A2 example -- worked on T3.2, T3.6 and T4B2 (3v3 GND SDA SCL and Wire lib). This sensor uses I2C repeated start.
    I tried your example on T4B2 and nothing printed. I then ran your sketch on T3.6 and it printed
    995.80, 33.50
    995.84, 33.50
    I2C scanner worked on T4B2
    Scanning...
    done
    sparkfun lib https://github.com/sparkfun/MPL3115A2_Breakout
    EDIT: I ran a dragonfly (Wire lib) version of Kris Winer's propshield sketch. sketch works on dragonfly and T3.6 but hangs on T4B2
  16. #3016
    Senior Member+
    3,664
    MPL3115A2
    995.80, 33.50
    995.84, 33.50
    Scanning...
    done
    @manitou - other differences in pressure and temperature values that exactly what I am seeing. I tested it with the same Sparkfun library as you.
    You made a comment about "This sensor uses I2C repeated start." I've seen that someplace before and how to handle it. Can't remember where now.
  17. #3017
    2,074
    i think T4 wire lib is handling repeated start (using Wire.endTransmission(false); ) since sensor is working with sparkfun lib. I added a note about using a Wire-lib port of Kris Winer's sketch in my previous post -- it ran on T3.6 and dragonfly, but hung on T4B2
  18. #3018
    Senior Member+
    3,664
    I agree I thought that also. The lib uses this for readByte:
    uint8_t MPL3115A2::readByte(uint8_t address, uint8_t subAddress)
      uint8_t data; // `data` will store the register data
      Wire.beginTransmission(address);         // Initialize the Tx buffer
      Wire.write(subAddress);                  // Put slave register address in Tx buffer
      Wire.endTransmission(false);       // Send the Tx buffer, but send a restart to keep connection alive
      //Wire.endTransmission(I2C_NOSTOP);        // Send the Tx buffer, but send a restart to keep connection alive
      Wire.requestFrom(address, (size_t) 1);   // Read one byte from slave register address
      data = Wire.read();                      // Fill Rx buffer with result
      return data;                             // Return data read from slave register
    As @KurtE showed in his debug it hangs on that second read. Think maybe will just wait until Paul has more time - don't want to give him any more distractions unless its critical. Will keep playing of course.
  19. #3019
    2,074
    it worked if i added a delay(1) in readByte() after Wire.endTransmission(). maybe T4 is too fast
  20. #3020
    Senior Member+
    3,664
    @manitou
    Damn. You got it! Works for me as well. I did add a delay but put it between calls to readByte….. close. You might be right that the T4 is just too fast. Wonder if we put the delay(1) in the Wire lib for endTransmission?
    Such a nice simple fix
    Thanks.
  21. #3021
    2,074
    @manitou
    Thanks.
    With the delay(1) (maybe a shorter microsecond delay will work?), the Wire adaptation (attached) of Kris Winer's propshield sketch works on T4B2, exercising all the MPU sensors. We'll need EEPROM to run the NXPMotionSense examples.
    may also need delay(1) in readBytes()
    Attached Files Attached Files
  22. #3022
    Senior Member+
    3,664
    @manitou
    A couple of years ago I converted Kris's sketch into a library format call psIMU. I did the calibration a little different that what Paul has using his calibration tool. It has two options, (1) do it each time the way Kris's sketch does it or (2) put the calibration data in a file for accel and magnetometometer using a different tool I have used for the FreeIMU library. I then have two sketches where the first one interfaces with Madgwick and Mahoney filters and the other one links to the NXPSensorFusion that Paul has. Had to rewicker that of course to get it to work but at least for now it doesn't use the EEPROM library. That will come later. Will let you know it I get it all working with T4 and Propshield.
    Like you suggested want to play with the delay a bit first.
  23. #3023
    Senior Member+
    3,664
    @KurtE and @manitou
    If I use a delayMicroseconds(150) just using MPL library it works fine. In the full sensor sketch looks like a delayMicroseconds(250) is needed for some reason. I am using 400k for clock in the sensor sketch. Anyway tested it my PSImu library using the NXPSensorFusion from Paul library and it seems to working. Have a few things to check and re-verify since its been a while since I tried it and then update the GitHub. But here is sample of the output:
    Orientation: 346.63 -0.14 0.63
    rate = 80.82 Hz
    Orientation: 346.60 -0.13 0.63
    rate = 80.82 Hz
    Orientation: 346.57 -0.13 0.65
    rate = 80.82 Hz
    EDIT: So once the EEPROM lib is done I don't think there will be a problem running the NXPMotionSense examples. But that's a test for another day.
  24. #3024
    9,018
    I ran Paul's calibration on prop shield weeks back
  25. #3025
    Senior Member+
    3,664
    Cool. I forgot about that or missed it - this thread is getting long
