Page 58 of 91 FirstFirst ... 8 48 56 57 58 59 60 68 ... LastLast
Results 1,426 to 1,450 of 2254
  1. #1426
    8,001
    @defragster - Running your version of the sketch now...
    In order to make it easier to read without magnifier, I changed setTextSize(2) instead of 1
    I just screwed up and was thinking I was plugging in my USB to Serial adapter to my PC, but instead to wall wart (power for RPI3) and for some reason the Adafruit board started to show magic smoke... So now I am going into my parts and grabbing a different converter. Maybe Sparkfun FTDI Basic 3.3v version...
    I had your version hang once... Did not have button hooked up nor other serial port... Current run > 88000
    Need to setup the sparkfun hunit... Not sure if I will put on Serial1 or Serial4...
    Kurt - see updated post above - all seems well!
    And stop using those old school fangled gadgets - just break out a Teensy or two for SerMon Echo!
    Larger font - DOH - that would be nice - Current run over 50K
    SerMon and T4 USB ODDITIES
    <edit>: Another Flakes run to 26K then I decided to unplug HUB with 3 Teensy's - SerMon and TLoader off and three windows of TyComm open - plugged in and up and running - no ODD/dead T4. And Flakes up and running at 10+K NOTE: IDE port/Teensy shows T4 and one T_3.1 but not the other T_3.1 now after the Hub cycle
    <edit> Just confirmed with Two Hubs - Amazon Basics USB 3 and a USB 2 Rosewill:
    >> Connect HUB unit with T4 and two SerMon ECHO T_3.1's running and it works.
    >> Plug/Power Each T_3.1 and Windows 'welcomes' them. Then plug the T_4 and NOTHING.
    Need to revisit this with new T4 USB update
  2. #1427
    1,874
    Sounds like probably need to have some form of timeout here... May also need to do more efficient ISR handling. Although I tried to short cut some of this stuff...
    I just added txbuf/rxbuf compare after transfer(txbuf,rxbuf,...), and changing while to use tx_count is NOT the solution, get lots of errors (but no hangs). using stock rx_count in while() seems to work error free at 20mhz or slower, but requesting 30 mhz or 40 mhz in SPISettings results in a hang. This is with flexio speed at 160mhz and using your latest from github.
      // err check jumper 2 to 3  MOSI to MISO
      for (int i = 0; i < sizeof(txbuf); i++) txbuf[i] = i;
      memset(rxbuf, 0, sizeof(rxbuf));
      assert_cs();
      SPIFLEX.transfer(txbuf, rxbuf, sizeof(txbuf));
      release_cs();
      SPIFLEX.endTransaction();
      int errs = 0;
      for (int i = 0; i < sizeof(txbuf); i++) if (txbuf[i] != rxbuf[i]) errs++;
      Serial.printf("errs %d [3] %d\n", errs, rxbuf[3]);
  3. #1428
    4,373
    But I have several of these gadgets sitting around as I needed them for testing out USBHost code... Actually the one I fried, was one I just purchased a month or so ago as Lady Ada reported that it was not working with their boards...
    @manitou - Probably for the higher speeds, I probably need to go to DMA, but as I mentioned this morning, I need to figure out what that means figuring out DMA stuff as it relates to FlexIO and only two DMAMUX_... for each FlexIO one I believe for shifters(0,1) and one for shifters(2,3) I think the example code if I am deciphering it properly is using shifters: 0, 2 and timers 0,1 (timers need to be contiguous)... I may need to hack up my library or usage to get shifters that will work.. But can be done.
    May need to do a little hacking on knowing how I wish to use these...
  4. #1429
    8,001
    Well … you have one less now - double bummer it was newest one bought for special purpose.
    Now that all sermon is TyComm I've not seen trouble - newest restart (thanks larger font) reads 102,000 and counting with falling star flakes.
    There is some perf hit early after setup() and something in IDE SerMon was triggering the T4 in a way that TyComm does not - so FlexSPI could use a touch of something to be immune to that.
  5. #1430
    19,698
    Note: I sometimes have found where I have done the start of a compile or upload and sometimes nothing really happens... Then I go back and do it again and it works...
    Most of the time I attribute it to I must have done something wrong...
    Picture isn't clear - it is a surprise - but bottom line as stated :: Ctrl+U … IDE UI DEAD for 5 to 50 seconds. TaskMan does not show HIGH use on any process. Double click on a word in CODE usually select/highlights that word … UI is non-responsive … then the word will highlight as the compile begins. No response from MENU during dead IDE UI.
    I've added this to the issue list (msg #6) as "Arduino IDE unresponsive at times" (for lack of really understanding what's happening). Trying not to get into the Arduino IDE code right now, but definitely want to remember to fix this later.
  6. #1431
    19,698
    Edit: oh, nevermind... I just saw msg #1394. Added this to the issue list (msg #6)
    @Paul. Not sure this is related to USB issues or unique to the audio library but sketches don't always upload automatically - most of the time on the first load I have to press the button.
    Is this only with programs using audio?
  7. #1432
    8,001
    Good collection of those issues. I added a note to 1379 :
    NOTE:: Setting IDE to 'use external editor' seems to stop this from happening both Ctrl+U and it seems 'Open Recent' takes only a couple second when it must parse external libs?
    Not sure if this is on the list - SerMon and T4 USB ODDITIES
    > it notes failure of T4 to 'arrive' on Windows when after other T_3.1's
    > Also different behavior from TyComm versus IDE SerMon
    BTW: with TyComm - before the unplug test for linked post 1426 - FlexSPI Flakes was over 400K, since restart back on hub it is powered up fine at 113K and counting.
  8. #1433
    Senior Member+
    2,948
    So far yes. The hanging seems to especially prevalent when the sketch fails to run properly, really noticeable when I am running the wavetable sketches that I mentioned.
    With "open recent" it does take a few seconds to open the sketch. But then again I am on my desktop with an i7 core. On the laptop it is another story.
    @Paul
    Not sure if this helps but I ran the playsynthmusic sketch (one of the ones giving me the problem) with the T4 on the breadboard so I could hook it up to the T3.2 for debugging. Sure enough, Tim's debug routing is tripping, here is the output:
    ***********IMXRT Startup**********
    test 1 -1234567 3
    CCM_ANALOG_PLL_USB1=80003000
      enable USB clocks
    CCM_ANALOG_PLL_USB1=80003040
    Increasing voltage to 1250 mV
    need to switch to alternate clock during reconfigure of ARM PLL
    USB PLL is running, so we can use 120 MHz
    Freq: 12 MHz * 100 / 2 / 1
    ARM PLL=80002042
    ARM PLL needs reconfigure
    ARM PLL=80002064
    New Frequency: ARM=600000000, IPG=150000000
    USB reset took 5 loops
    analogInit
    usb_cdc_line_coding, baud=0
    before C++ constructors
    after C++ constructors
    before setup
    usb_cdc_line_coding, baud=115200
    after setup
    status = 000
    Fault irq 3
     stacked_r0 ::  0CC20B12
     stacked_r1 ::  00020000
     stacked_r2 ::  00000030
     stacked_r3 ::  003F0030
     stacked_r12 ::  2020126A
     stacked_lr ::  0000000E
     stacked_pc ::  0000164C
     stacked_psr ::  01000056
     _CFSR ::  01000000
     _HFSR ::  40000000
     _DFSR ::  00000000
     _AFSR ::  00000000
     _BFAR ::  00000000
     _MMAR ::  00000000
    Freq: 12 MHz * 75 / 3 / 1
    ARM PLL=80002064
    ARM PLL=8000204B
    New Frequency: ARM=300000000, IPG=150000000
    Decreasing voltage to 1150 mV
  9. #1434
    19,698
    Hm.
    @Paul: What shall we do with the Design-Tool ? There are big differences.. 2nd I2S.. MQS, SPDIF-In and more..
    a) Copy it and create different versions (T3/T4)
    b) Hack the tool and make it more intelligent with a drop-down for the model
    Long-term, planning to make the gui more intelligent.
    Short-term, let's just add stuff and let the list of inputs & output grow, but keep it as a local file, not on the public website until T4 is officially released.
    I killed my audio shield.
    Wouldn't be such a problem (have replacement) if I still had long pins...
    Please email Robin and we'll get replacement hardware sent out on Monday. Even if you already put an order in, please contact Robin directly so we can send you a package by fast DHL.
    I got 10 more of those breakout boards last week. 2 are built so far, still waiting on parts for the other 8. Might as well send an extra of those, just in case.
  10. #1435
    8,001
    @Paul
    Fault irq 3
     _CFSR ::  01000000
     _HFSR ::  40000000
     _DFSR ::  00000000
     _AFSR ::  00000000
     _BFAR ::  00000000
     _MMAR ::  00000000
    Cool - code as added wasn't faulty. So far that code just replaced what Paul had with labels on the values shown - courtesy of NXP community page.
    Mike - can you catch me up - what do I need to download/install/update to run the Audio stuff and get where you are? Is it FrankB's github with Core and Audio update? Then your/other changes since then?
    <edit>:
    Mike/Frank - I get good working sound from >> "...\Audio\examples\Synthesis\Guitar\Guitar.in o"
    And from "...\examples\Synthesis\PlaySynthMusic\PlaySynthMu sic.ino" I get the same fault as Mike.
  11. #1436
    8,001
    Bounce does not work for Pin 1 (?) Can someone test this?
    Frank - what sketch - how are you seeing "doesn't work"? Never returning a connect press - or not debouncing well? I'm testing on p#23 because I have a button there and will have to move Serial1 to test on Pin 1.
    <EDIT>: it seems to be detecting my button presses on PIN#1 - I had to modify the bounce sketch to :: pinMode(BUTTON,INPUT_PULLUP);
    Since my button just goes Pin# to GND
    Mike are you using TyComm for upload and or sermon? I know Frank and luni have looked at the beta for TyComm. I tried and abandoned it at first because of odd USB - but it seems that was from mixed use - not dedicated.
  12. #1437
    Senior Member+
    2,948
    Hi Tim,
    Right now just using Frank's GitHub with the core and Audio update. Haven't put my changes in, wanted to focus on testing the changes Frank made first. Before he had the issue with his shield he said he was working on audio input. One question on the dump though, why is the ARM clock going back down to 300Mhz? also after that nothing is printed to the T3.2. The other thing is when I ran the flexcan sketch we were working on all I see are the status messages on the T3.2?
    I have been using the IDE and Sermon pretty much exclusively. I also use TyComm only for serial monitoring when I have more than one Teensy attached (just for serial monitoring though - not upload).
  13. #1438
    8,001
    Hi Tim,
    We cross posted - I just updated above - I found Frank's post and link ...
    Dropping the ARM clock was an Idea I had to drop voltage/temp and chance of MCU abuse if it faults - it isn't going anywhere - and lower MHz gets dropped voltage - especially if the fault occurred running over 600 MHz with above standard voltage it is a safety net.
    That is the base fault dump - similar to what T_3 offers - except in release builds that is turned off with "#if 0" - for now in Beta T4 that is pushed out with LED #13 blink - except I forgot to change the wait counts so the panic blink rate is slow at 300 MHz
    I'm wondering if that might be causing some USB confusion - mixing TyComm and IDE SerMon
    Trying to find another to alternate with to test first upload all TyComm. Suppose any sketch … this on faults too :: "\examples\Synthesis\pulseWidth\pulseWidth.ino "
    Mike: Using TyComm I can compile and upload GUITAR and then a BlinkMin sketch back and forth with no problem - no button.
  14. #1439
    8,001
    Mike - I got as far as the sketch with debug_tt. Line numbers will change from insertions to Audio\examples\Synthesis\PlaySynthMusic\PlaySynthM usic.ino
    It passes setup and enters loop() and on the 6th time after doing CMD_PLAYNOTE the first 5 times it finds 'if(c < 0x80)' - my line 258 shows it as 1 resulting in a 425 for d_time.
    {didn't find my way yet in Audio to know where the interrupt takes it }
    It then calls delay() and dies before it returns. I replaced that with delayMicroseconds(1000*d_time) - so it isn't the call - but the background interrupts in the lib where the fault happens?
    When the fault happens I enter 'd' on the Serial1 sermon and it calls my local sketch function where I have it dump out the Trace that follows showing the code path as recorded.
    loop256() stack var: 2001FFC4
    _:L=258: c=1
    _:L=259: d_time=425
    debug_tt:: Fault irq 3
     stacked_r0 ::  cc20b12
     stacked_r1 ::  20000
     stacked_r2 ::  30
     stacked_r3 ::  3f0030
     stacked_r12 ::  2020126a
     stacked_lr ::  e
     stacked_pc ::  2d54
     stacked_psr ::  1000056
     _CFSR ::  1000000
     _HFSR ::  40000000
     _DFSR ::  0
     _AFSR ::  0
     _BFAR ::  0
     _MMAR ::  0
     userDebugDumptt() IN debug_tt  ___
     F_CPU=300000000
     >>>> debug_fault   >>>> debug_fault   >>>> TYPE:T_4
    Debug Info:
    1 => 1	0x1	[L#260_C#1
    2 => 425	0x1A9	[L#261_C#2 _<< last func::loop
    --- Halting >>>>  'y' to continue ...
    	 'd' to call Debug_Dump()
    	 'b' Teensy Bootloader
    	 'r' Restart Teensy
    	 'z' Zero Debug logs
    Debug_Dump13() stack var: 2001FDD4
     User Custom Debug Dump. Micros==7065960
    #1: (ii=25): CycCnt 557503636	line 255	func delay(d_time) pre
    #2: (ii=24): CycCnt 557503579	line 220	func Loop Enter
    #3: (ii=23): CycCnt 557503515	line 297	func loop
    #4: (ii=22): CycCnt 557503473	line 295	func loop
    #5: (ii=21): CycCnt 557503302	line 287	func CMD_PLAYNOTE
    #6: (ii=20): CycCnt 557503243	line 220	func Loop Enter
    #7: (ii=19): CycCnt 557503179	line 297	func loop
    #8: (ii=18): CycCnt 557503137	line 295	func loop
    #9: (ii=17): CycCnt 557502966	line 287	func CMD_PLAYNOTE
    #10: (ii=16): CycCnt 557502907	line 220	func Loop Enter
    #11: (ii=15): CycCnt 557502844	line 297	func loop
    #12: (ii=14): CycCnt 557502802	line 295	func loop
    #13: (ii=13): CycCnt 557502630	line 287	func CMD_PLAYNOTE
    #14: (ii=12): CycCnt 557502571	line 220	func Loop Enter
    #15: (ii=11): CycCnt 557502508	line 297	func loop
    #16: (ii=10): CycCnt 557502466	line 295	func loop
    #17: (ii=9): CycCnt 557502294	line 287	func CMD_PLAYNOTE
    #18: (ii=8): CycCnt 557502235	line 220	func Loop Enter
    #19: (ii=7): CycCnt 557502173	line 297	func loop
    #20: (ii=6): CycCnt 557502132	line 295	func loop
    #21: (ii=5): CycCnt 557501937	line 287	func CMD_PLAYNOTE
    #22: (ii=4): CycCnt 557501872	line 220	func Loop Enter
    #23: (ii=3): CycCnt 557033613	line 209	func AudioMemoryUsageMaxReset
    #24: (ii=2): CycCnt 557033575	line 206	func AudioProcessorUsageMaxReset
    #25: (ii=1): CycCnt 557033535	line 201	func setup done
    #26: (ii=0): CycCnt 308960580	line 163	func setup
    ** lines 295 and 297 are before and after call to AudioInterrupts
  15. #1440
    8,001
    Frank / Mike:
    it dies on this memset: ...\teensy\avr\libraries\Audio\output_i2s.cpp
    void AudioOutputI2S::isr(void)
      deb_tt( 4, dest );
        debTrace_tt( (uint32_t)dest, __LINE__, "memset(dest,0,AUDIO_BLOCK_SAMPLES * 2)" );
    		memset(dest,0,AUDIO_BLOCK_SAMPLES * 2);
    		return;
    This entry 4 from :: deb_tt( 4, dest );
    Debug Info:
    1 => 1	0x1	[L#261_C#1312
    2 => 425	0x1A9	[L#262_C#1313
    4 => 536896804	0x20006524	[L#291_C#1319 _<< last func::isr
    5 => 536896804	0x20006524	[L#274_C#1318
    These entries 1 and 4 from :: debTrace_tt( (uint32_t)dest, __LINE__, "memset(dest,0,AUDIO_BLOCK_SAMPLES * 2)" );
    And entry #7 is from loop where it did the delay(d_time)
    #1: (ii=486): CycCnt 536896804	line 292	func memset(dest,0,AUDIO_BLOCK_SAMPLES * 2)
    #2: (ii=485): CycCnt 558447482	line 262	func DMA is transmitting the first
    #3: (ii=484): CycCnt 558447381	line 256	func AudioOutputI2S::isr
    #4: (ii=483): CycCnt 536896548	line 292	func memset(dest,0,AUDIO_BLOCK_SAMPLES * 2)
    #5: (ii=482): CycCnt 557576734	line 268	func DMA is transmitting the second
    #6: (ii=481): CycCnt 557576633	line 256	func AudioOutputI2S::isr
    #7: (ii=480): CycCnt 557517658	line 256	func delay(d_time) pre
    #8: (ii=479): CycCnt 557517601	line 221	func Loop Enter
    #9: (ii=478): CycCnt 557517539	line 298	func loop
    #10: (ii=477): CycCnt 557517497	line 296	func loop
    #11: (ii=476): CycCnt 557517325	line 288	func CMD_PLAYNOTE
    The example examples\Synthesis\pulseWidth\pulseWidth.ino seems to die in the same place - neither 'dest' is NULL:
    This recorded it here in DEC then HEX:: 4 => 536880044 0x200023AC [L#291_C#903 _<< last func::isr
    #1: (ii=903): CycCnt 536880044	line 292	func memset(dest,0,AUDIO_BLOCK_SAMPLES * 2)
    #2: (ii=902): CycCnt 438280737	line 262	func DMA is transmitting the first
    #3: (ii=901): CycCnt 438280636	line 256	func AudioOutputI2S::isr
    #4: (ii=900): CycCnt 536879788	line 292	func memset(dest,0,AUDIO_BLOCK_SAMPLES * 2)
    #5: (ii=899): CycCnt 437409997	line 268	func DMA is transmitting the second
    #6: (ii=898): CycCnt 437409897	line 256	func AudioOutputI2S::isr
    #7: (ii=897): CycCnt 536880044	line 292	func memset(dest,0,AUDIO_BLOCK_SAMPLES * 2)
    #8: (ii=896): CycCnt 436539249	line 262	func DMA is transmitting the first
    #9: (ii=895): CycCnt 436539149	line 256	func AudioOutputI2S::isr
    #10: (ii=894): CycCnt 436144353	line 59	func setup
  16. #1441
    Senior Member+
    2,948
    Tim/Frank
    Wow Tim, you been busy when I was sleeping after my last post. Was going to try and reread how to use you debug sketch. But the other thing I was thinking about that could be different on the installs is Frank's DMA change. Its just a thought that crossed my mind.
    Yep, I agree. Same with the IDE. Seems to happen when there is a hard fault.
    EDIT: No, that wasn't it, incorporated the change based on the pull request but still faults.
  17. #1442
    1,874
    flexio PWM
    Not that we need more PWM pins, but I decided to play with flexio PWM from SDK example
    boards/evkbimxrt1050/driver_examples/flexio/pwm
    My small T4 test sketch is at https://github.com/manitou48/teensy4.../flexiopwm.ino
    I hooked scope to pin 12, but didn't get the frequency I expected. I assumed pll3_sw_clk is running at 480mhz, but the output on pin 12 suggests 400mhz?? Maybe it's something in my flexio register config or ?? I hacked the sketch to use 400mhz.
    EDIT: ooops, my prescaler divider field already had a 1 in it, and or'ing in 4 resulted in 5 (so divider is 6), github updated. Frequency and duty look good now.
  18. #1443
    4,373
    @manitou - Flexio PWM sounds like fun. Maybe have to integrate in some time...
    Right now hacking up my set of FlexIO code to enable DMA on the SPI. Right now setting up code to try to request shifters that have different DMA channels for TX and RX, and now setting up callback... So hopefully soon will be able to get a DMA transfer to work.
    But maybe diversion - looks like it is starting to sort of snow here, for the first time this season, so want to enjoy it!
  19. #1444
    Germany NRW
    5,513
    Tim / Mike:
    Can you zip your Arduino-folder und send it to me?
    All examples still work for me.. and I have no upload-problems.
    Been on a family visit a long time today, and couldn't do much. But I would like to have a look at it now. I found a temporary solution for my audioshield problem with some wires and a new shield.
    Edit: Tim, that memset-crash.. any idea what the reason is?
  20. #1445
    Germany NRW
    5,513
    Ha !
    Just tried something and used "Optimize Debug" - now I have upload-problems and the crash, too
    Before that I had set it to "fast", which worked.
    With "Debug" :
Name:	2019-02-03 19_21_22-Start.jpg
    With "Fast" (works):
Name:	2019-02-03 19_22_31-Start.jpg
    Edit: Other issue:
    If I use "Fastest- pure code" I get :
    :\Arduino\hardware\teensy\avr\cores\teensy4\pwm.c: In function 'flexpwmFrequency':
    C:\Arduino\hardware\teensy\avr\cores\teensy4\pwm.c:107:1: error: insn does not satisfy its constraints:
    (insn 32 27 28 2 (set (reg:SI 31 s15 [orig:114 D.5835 ] [114])
            (mem/v/c:SI (reg/f:SI 2 r2 [175]) [4 F_BUS_ACTUAL+0 S4 A32])) C:\Arduino\hardware\teensy\avr\cores\teensy4\pwm.c:87 615 {*thumb2_movsi_vfp}
         (nil))
    C:\Arduino\hardware\teensy\avr\cores\teensy4\pwm.c:107:1: internal compiler error: in extract_constrain_insn, at recog.c:2246
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://gcc.gnu.org/bugs.html> for instructions.
  21. #1446
    Senior Member+
    2,948
    Frank/Tim
    Before I posted the Arduino folder (its 276mb zipped - don't think email would work) I tried to compile with Fast to see if it would work. Still get the upload problem and the crash. I created a shared folder on google drive that you can pull it down from: https://drive.google.com/drive/folde...xq?usp=sharing
    Tim, if you want to put yours there as well, have fun.
  22. #1447
    Germany NRW
    5,513
    Thank you
  23. #1448
    Germany NRW
    5,513
    Yes, it crashes with your arduino folder.
    Ok.. quick test, i deleted "your" teensy4 subfolder and copied mine.
    works.
    This is my version: https://drive.google.com/open?id=1UZ...p5yOh1BlcPvRr_
  24. #1449
    Senior Member MickMad's Avatar
    Feb 2013
    Italy
    161
    Hey there! For some reasons, I just found out this thread!
    I'm thrilled by the possibilities! This is amazing
    Is there any plan on giving out more prototypes? I would very much love to test this for use in an upcoming product!
  25. #1450
    8,001
    works.
    Frank - with your Teensy4 folder it builds as Fast' and runs to make sound.
    Glad you had enough wires to connect your new shield.
