Page 150 of 175 FirstFirst ... 50 100 140 148 149 150 151 152 160 ... LastLast
Results 3,726 to 3,750 of 4361
  1. #3726
    Germany NRW
    5,679
    Ok, I can reproduce that now.
    Creepy!
  2. #3727
    Germany NRW
    5,679
    It does not happen with GCC 6 - so simplest assumption is: Compiler/Linker Bug.
    GCC 8: Does not compile because of WireIMXRT.cpp (see above...)
    GCC7: Don't have a installation at the moment.
    So, I will not dig deeper.. makes not much sense
    Edit: "Our" gcc (5.4.1 from 2016) is quite old..but with coremark, it's the fastest so far. Maybe we should do more benchmarks with newer versions? Maybe the newer versions just don't like coremark.
  3. #3728
    4,282
    Creepy!
    Isn't it though . Wonder if it shows the same behavior with other optimizations? Oh - it does work on a T3.6 last I looked.
  4. #3729
    10,069
    Creepy!
    Yes, it is some confusion in the build>linker dropping out some needed code shown comparing the LST files.
    - thought for sure I assembled the libs from the right place … where I used them from …
    As far as the PULL request for (used) - I only mentioned that as not yet done - but ODDLY it comes from the same place in the code to some degree and wondering if that is where the dropping of this code is from.
    AFAIK @mjs513 ran into a few issues in his beta work that were similarly ODD if not the same - but it didn't hit many others that made mention.
    re @mjs crosspost - yes many other compile options not yet tried - or failed when tried … I noted that the other day as something to have tested.
  5. #3730
    Germany NRW
    5,679
    Not sure what it would be good for. I'd just accept that it is an old bug which seems to be fixed in the "newer" GCC 6
    I'd just switch to GCC 6
    p.s. I suspect that the GCC 8 problem from above("side-effects") is also just a (new) bug...
  6. #3731
    Germany NRW
    5,679
    I'm uploading my working GCC 6 directory to my google-drive- Takes a few minutes. Willl post the link here.
    Edit:
    - Download arm6.zip,
    - extract zip to Arduino/hardware/tools/arm6,
    - edit boards.txt: teensy4b2.build.toolchain=arm6/bin/ for use with T4b2 only.
    https://drive.google.com/drive/folde...2xIYUR4MU1rdzg
  7. #3732
    10,069
    Edit:
    Yikes, that is a Big ZIP - 3X TeensyDuino! Will see if it fixes my repro too.
  8. #3733
    Germany NRW
    5,679
    Oh, i see.. there is a big 5.4.1 folder inside - remaining from a test I did some months ago.. sry
    I think you can delete the 5.4.1 folder inside \arm6\lib\gcc\arm-none-eabi
  9. #3734
    4,282
    @Frank B and @defragster @KurtE
    Hope you don't mind but I just downloaded and installed your GCC 6. Ok don't get the that error anymore but without debug_tt the eyes on the two screens are distorted. Yes you can make changes with it crashing and loosing usb but:
  10. #3735
    Germany NRW
    5,679
    It's there to be downloaded I'll leave it there.
    I don't know where the distortions come from. Maybe a bug somewhere else.. the picture looks like overflows or memory corruption.
    I don't have the displays.
  11. #3736
    5,699
    @mjs513 - Maybe we should try selecting a lower SPI speed and see if that makes a difference there?
  12. #3737
    4,282
    @KurtE Tried several SPI freq lowering it down to 8Mhz but no change to the distorted image.
    Note that if I do and include debug_tt it the eyes on both screens display normally.
    It looks almost like a memory issue
  13. #3738
    10,069
    instead of debug_tt - do the prior posted sketch local copy of the Fault_Handler:
    #if 1  // TOGGLE 0 to exclude and cause BAD USB - set back to 1 and recompile to correct.
    #ifdef __cplusplus
    extern "C" {
    #if defined(__IMXRT1052__) || defined(__IMXRT1062__)
    void HardFault_HandlerC(unsigned int *hardfault_args) {
      digitalWriteFast( 13, HIGH );
      while (1);
    #ifdef __cplusplus
    } // extern "C"
    The code isn't being called - though that should run - but it shows it is a simple linkage {code movement or memory setup?} issue going to smaller code if that affects it.
    My effort to switch to arm6 doesn't work?
    It exists here as indicated?:
    "T:\arduino_1.8.9_146\hardware\tools\arm6\bin\ arm-none-eabi-g++.exe"
    But with change in boards.txt stops with this after closing and re-opening the IDE::
    "T:\\Ard186t4b2\\hardware\\teensy/../tools/arm6/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\Ard186t4b2\\hardware\\teensy\\avr\\cores\\tee nsy4" "T:\\TEMP\\arduino_build_226809\\sketch\\uncannyEy es0.ino.cpp" -o nul
    exec: "T:\\Ard186t4b2\\hardware\\teensy/../tools/arm6/bin/arm-none-eabi-g++": file does not exist
    Error compiling for board Teensy 4-Beta2.
  14. #3739
    4,282
    @defragster
    Change "arm6" to arm and it will run. I zipped the present toolchain and then copied arm6 over and renamed it to "arm". I also deleted the 5.3.1 folder.
  15. #3740
    10,069
    There is an arm folder there already?
  16. #3741
    4,282
    Yep - replaced it with the contents of arm6
    EDIT = make sure you back it up first
  17. #3742
    4,282
    @defragster - @Frank B
    Running into problem with GCC6 - Eigen library that runs fine under GCC7 is now throwing errors so sketch can not compile. Not sure if there will be an impact to anything else - at least for the T4B2
  18. #3743
    10,069
    Odd Frank B thought the new 'arm6' path with edit would make it work to use new compiler … except for the part before " … " the last part should have found the .exe?
    Doesn't sound like a good solution without more work. Not sure if Paul has any thoughts of replacing tools now? It might have seemed sensible up front with Beta to add new libs/features or updated 1062 type support . . .
    … Uncanny eyes I don't have hardware and it was noted the resultant EXE has odd but functional behavior I wouldn't see.
    … Eigen or other not working?
    Seems like the .ld and segmentation or build flags or func() decorations may need tweeked?
    Though maybe UncannyEyes just has a fault or code issue in it somewhere - though why that would exhibit as it did is odd.
    Will be interesting as the other optimize/build choices get used more.
  19. #3744
    10,069
    I just undid boards.txt back to arm\bin with unchanged TD version of gcc. I did a build without local Hard_Fault and the LST MASM file is SMALL - but AUTO Upload works, the SerMon shows proper text and the LED is blinking. The below line was commented.
    Then uncommented this and rebuilt:
    #define LIGHT_PIN_FLIP // If defined, reverse reading from dial/photocell
    the LST MASM file is still the same size and now it is failing. So that obvious difference isn't behind the issue?
    T:\tCode\T4\uncannyEyes0\uncannyEyes0.ino Jul 16 2019 17:02:07
    T4 connected Serial_tt ******* debug_tt port
    T:\tCode\T4\uncannyEyes0\uncannyEyes0.ino Jul 16 2019 17:02:07InitCreate display #Create display #Reset displaysCall init/begin func for each display
    Note: debug_tt not in use - that is just a print line in setup()
    Something very odd … but not apparently indicated by just the small lst file.
    <EDIT>
    This code is expecting 10 bit analog 1023 max value? Is this resolving to a fatal value without the #define of LIGHT_PIN_FLIP?:
    #if defined(LIGHT_PIN) && (LIGHT_PIN >= 0) // Interactive iris
      int16_t v = analogRead(LIGHT_PIN);       // Raw dial/photocell reading
    #ifdef LIGHT_PIN_FLIP
      v = 1023 - v;                            // Reverse reading from sensor
      if (v < LIGHT_MIN)      v = LIGHT_MIN; // Clamp light sensor range
      else if (v > LIGHT_MAX) v = LIGHT_MAX;
      v -= LIGHT_MIN;  // 0 to (LIGHT_MAX - LIGHT_MIN)
    #ifdef LIGHT_CURVE  // Apply gamma curve to sensor input?
      v = (int16_t)(pow((double)v / (double)(LIGHT_MAX - LIGHT_MIN),
                        LIGHT_CURVE) * (double)(LIGHT_MAX - LIGHT_MIN));
      // And scale to iris range (IRIS_MAX is size at LIGHT_MIN)
      v = map(v, 0, (LIGHT_MAX - LIGHT_MIN), IRIS_MAX, IRIS_MIN);
    #ifdef IRIS_SMOOTH // Filter input (gradual motion)
      static int16_t irisValue = (IRIS_MIN + IRIS_MAX) / 2;
      irisValue = ((irisValue * 15) + v) / 16;
      frame(irisValue);
    #else // Unfiltered (immediate motion)
      frame(v);
    #endif // IRIS_SMOOTH
  20. #3745
    4,282
    I have a optoresitor in the loop attached to pin A2 but I've run the sketch with one display with and without it attached.... besides on compile/upload it should be an issue until it runs - so it doesn't even get that far.
  21. #3746
    Germany NRW
    5,679
    Of course, it's quite possible that there are incompatibilities.
    Which errors do you get? We should fix them (if in the core), for the future. Paul will surely want to use a newer toolchain sometime later.
    The default GCC 5.4 is quite old.
  22. #3747
    4,282
    @Frank B
    Really don't remember the errors but would definitely need to be fixed if Paul updated from GCC 5.4 - not sure if he wants to do this at this point in time - a lot of regression testing would probably have to be done not only for the T4 but for the T3.x's but....
  23. #3748
    102
    I hope it's okay to ask this here, as I'm not a beta tester...
    Is there a general idea of when the T4 might be released? I have an application which could really use the CPU and RAM of the T4.
    Thanks to all those contributing their expertise to the beta testing, you're making things easy for us mere mortals who use the finished products.
  24. #3749
    10,069
    Quote Originally Posted by wcalvert View Post
    Is there a general idea of when the T4 might be released? …
    Only Paul can answer specifically - but general from prior posts plan was IIRC July 2019 - may still make it - but last post noted delivery of production PCB's was not 100% on schedule and production was starting with smaller initial batching to test the building of the little Monsters.
  25. #3750
    102
    That's awesome, thank you for the info.
