KurtE
Senior Member+
Hi Paul - Not needed for T4, but might at some point pull in
https://github.com/PaulStoffregen/USBHost_t36/pull/23
As this fixes the Mouse to work on some combo units from Microsoft and Logitech - The first fix for the gigabyte keyboards was to always set the keyboards into BOOT mode, which worked fine for all keyboards I tried. However it had the side effect on the wireless combo units of causing the Mice to also change which caused at least some of them not to work...
As related question - Have you looked at doing USB Host stuff on this board? And if so how much different is it than T3.6.
