Results 1 to 3 of 3
Thread: Invert output Teensy 2.0
    Dec 2018
    1
    Hi guys,
    I'm new on coding teensy and I want little help.
    Basically I build a Pc gamepad using a Teensy 2.0 and so far it work great. But I want to invert an input so when a button is pressed, the pc see this button deactivated.
    Since I didn't write the code, just adapted to fit my needs, I think the teensy is set in pullout and that's it!
    Anyone have an idea how I can do this, if this is possible!!
    Thanks!
    Germany NRW
    5,416
    Easiest is to edit the code.
    Unfortunately we can't say more because we have no information about it. Maybe line 2367.
    Edit: If you dont want to edit the code you can add a transistor as inverter.
    Again, not enough information about your project to say more..
    Germany NRW
    5,416
    Can you post the code?
