Results 1 to 6 of 6
Thread: USBHost_t36 working with PS4 gamepad in Teensy 3.6?
    Dec 2016
    13
    Hi all,
    Does anyone know if it is possible to work with the PS4 gamepad via Bluetooth with the "USBHost_t36" library in teensy 3.6?
    Thank you very much in advance
    5,052
    The answer is, it is probably possible. I have worked on adding Bluetooth support to the library, which I have not yet tried to merge (PM) into the release. It was working at least somewhat with PS4 controllers before, but I have not tried it in awhile. Also not clear yet best way to handle things like doing the binding of and trusting...
    Hopefully at some point in the near future I will try it out again.
    There is more details about some of the stuff I was doing in the thread: https://forum.pjrc.com/threads/49358...Host-Bluetooth
    Dec 2016
    13
    Hi KurtE,
    thank you very much for your answer, it would be very helpful if you send me some example that you have of bluetooth, to see how it is configured.
    Thank you in advance
    5,052
    As I look up at my github fork/branch of this https://github.com/KurtE/USBHost_t36/tree/Bluetooth-WIP I see it has been 8 months since I made any changes.
    You can take a look, but there were things I wanted to figure out with Paul on how much of these things should integrate.
    Example: Joystick, mouse, keyboard - Should the Bluetooth stuff here merge into the same classes and act sort of like HID clients or should we just separate them as there are several other things like binding and trusting which is specific to BT...
    Again hopefully may get back to it soon. But know he is busy with T4 work and hopefully soon many of the rest of us with be working on that as well.
    Kurt
    Dec 2016
    13
    Hello KurtE,
    It has been very helpful.
    Thanks for everything.
    dun46
    Dec 2016
    13
    Hello
    I have already tested with a PS3 "Ipega PG-9076" and it works very well.
    https://www.amazon.com/PG-9076-Wirel.../dp/B075J7YQTC
    Thank you very much for the help.
    dun46
