gimpo
Here my little contribution, hope it helps.
I bought a cheap 1.54 inch TFT display. Despite all my doubts I was able to make it working by using the standard Adafruit libs on my Teensy 3.2
Very helpful was the datasheet sent me from the vendor (see attachments): 1pcs 1.54 inch IPS tft display 220PPI 240*240 pixels SPI Serial and parallel Interface st7789v
The wiring I adopted is depicted below:
(Note: a resistor of 20 Ohm is okay for indoor usage. If you want more brightness then you can lower it to 15 Ohm or less - but I didn't measured yet the current absorption.)
Here below, a simple sketch for testing the TFT:
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library
#include <Adafruit_ST77xx.h> // just for colo defs
#define TFT_RST 2 // chip reset
#define TFT_DC 3 // tells the display if you're sending data (D) or commands (C) --> A0 or WR pin on TFT
#define TFT_MOSI 11 // Data out (SPI standard)
#define TFT_SCLK 13 // Clock out (SPI standard)
#define TFT_CS 15 // chip select (SPI standard)
int x, y;
bool toogle;
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
void setup(void) {
pinMode(23, OUTPUT);
pinMode(22, OUTPUT);
pinMode(21, OUTPUT);
digitalWrite(23, HIGH);
digitalWrite(22, HIGH);
digitalWrite(21, LOW);
tft.init(240, 240);
tft.setRotation(2);
tft.fillScreen(ST77XX_BLACK);
// up left
tft.fillRect(0, 0, 10, 10, ST77XX_BLUE);
tft.setCursor(12, 12);
tft.println("UP-LEFT");
// bottom right
tft.fillRect(tft.width() - 10, tft.height() - 10, 10, 10, ST77XX_RED);
tft.setCursor(tft.width() - 82, tft.height() - 20);
tft.println("BOTTOM-RIGHT");
// area frame
tft.drawRect(0, 0, tft.width(), tft.height(), ST77XX_GREEN);
delay(3000);
x = 0;
y = 0;
toogle = true;
for (int i = 0; i < 20; i++)
tft.fillRect(x, y, 50, 50, toogle ? ST77XX_BLUE : ST77XX_YELLOW);
tft.fillRect(190 - x, y, 50, 50, toogle ? ST77XX_RED : ST77XX_ORANGE);
x += 10;
y += 10;
toogle = toogle == true ? false : true;
