// Basic Master Callback
// This creates a simple I2C Master device which when triggered will send/receive a text
// string to/from a Slave device. It is intended to pair with a Slave device running the
// basic_slave sketch.
// Functionally this sketch is similar to the basic_master sketch, except for three things:
// 1) It uses callbacks to handle the results and errors, instead of explicitly coding such
// routines after each send/receive call.
// 2) It can optionally demonstrate background transfers by setting the NONBLOCKING flag (from
// external observation these transfers will appear similar, but the LED duration will
// be shorter as they exit immediately after initiating the transfer).
// 3) There is an added test to dump error diagnostics from the error counting system.
// Pull pin12 input low to send.
// Pull pin11 input low to receive.
// Pull pin10 input low to dump error diagnostics.
// This example code is in the public domain.
#include <i2c_t3.h>
// Memory
#define MEM_LEN 256
char databuf[MEM_LEN];
int count;
#define NONBLOCKING
pinMode(LED_BUILTIN,OUTPUT); // LED
digitalWrite(LED_BUILTIN,LOW); // LED off
pinMode(12,INPUT_PULLUP); // Control for Send
pinMode(11,INPUT_PULLUP); // Control for Receive
pinMode(10,INPUT_PULLUP); // Control for Diagnostics
// Setup for Master mode, pins 18/19, external pullups, 400kHz, 50ms default timeout
Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, 400000);
Wire.setDefaultTimeout(50000); // 50ms
// Data init
memset(databuf, 0, sizeof(databuf));
count = 0;
Wire.onTransmitDone(transmitDone);
Wire.onReqFromDone(requestDone);
Wire.onError(errorEvent);
uint8_t target = 0x66; // target Slave address
// Send string to Slave
if(digitalRead(12) == LOW)
digitalWrite(LED_BUILTIN,HIGH); // LED on
// Construct data message
sprintf(databuf, "Data Message #%d", count++);
// Print message
Serial.printf("Sending to Slave: '%s' ", databuf);
// Transmit to Slave
Wire.beginTransmission(target); // Slave address
Wire.write(databuf,strlen(databuf)+1); // Write string to I2C Tx buffer (incl. string null at end)
#if defined(NONBLOCKING)
Wire.sendTransmission(); // Transmit to Slave, non-blocking
#else
Wire.endTransmission(); // Transmit to Slave, blocking
// After send complete, callback will print result
delay(100); // 100ms delay
// Read string from Slave
if(digitalRead(11) == LOW)
// Print message
Serial.print("Reading from Slave: ");
// Read from Slave
Wire.sendRequest(target, (size_t)MEM_LEN); // Read from Slave (string len unknown, request full buffer), non-blocking
#else
Wire.requestFrom(target, (size_t)MEM_LEN); // Read from Slave (string len unknown, request full buffer), blocking
// After request complete, callback will print result
// Diagnostics - print error count summary
if(digitalRead(10) == LOW)
// Print errors
Serial.print("\n");
Serial.printf("I2C_ERRCNT_RESET_BUS: %d\n", Wire.getErrorCount(I2C_ERRCNT_RESET_BUS));
Serial.printf("I2C_ERRCNT_TIMEOUT: %d\n", Wire.getErrorCount(I2C_ERRCNT_TIMEOUT));
Serial.printf("I2C_ERRCNT_ADDR_NAK: %d\n", Wire.getErrorCount(I2C_ERRCNT_ADDR_NAK));
Serial.printf("I2C_ERRCNT_DATA_NAK: %d\n", Wire.getErrorCount(I2C_ERRCNT_DATA_NAK));
Serial.printf("I2C_ERRCNT_ARBL: %d\n", Wire.getErrorCount(I2C_ERRCNT_ARBL));
Serial.printf("I2C_ERRCNT_NOT_ACQ: %d\n", Wire.getErrorCount(I2C_ERRCNT_NOT_ACQ));
Serial.printf("I2C_ERRCNT_DMA_ERR: %d\n", Wire.getErrorCount(I2C_ERRCNT_DMA_ERR));
// uncomment to zero all errors after dumping
//for(uint8_t i=0; i < I2C_ERRCNT_DMA_ERR; i++) Wire.zeroErrorCount((i2c_err_count)i);
// Trigger after Tx complete (outgoing I2C data)
void transmitDone(void)
Serial.print("OK\n");
// Trigger after Rx complete (incoming I2C data)
void requestDone(void)
Wire.read(databuf, Wire.available());
Serial.printf("'%s' OK\n",databuf);
// Trigger on I2C Error
void errorEvent(void)
Serial.print("FAIL - ");
switch(Wire.status())
case I2C_TIMEOUT: Serial.print("I2C timeout\n"); Wire.resetBus(); break;
case I2C_ADDR_NAK: Serial.print("Slave addr not acknowledged\n"); break;
case I2C_DATA_NAK: Serial.print("Slave data not acknowledged\n"); break;
case I2C_ARB_LOST: Serial.print("Arbitration Lost, possible pullup problem\n"); Wire.resetBus(); break;
case I2C_BUF_OVF: Serial.print("I2C buffer overflow\n"); break;
case I2C_NOT_ACQ: Serial.print("Cannot acquire bus, possible stuck SDA/SCL\n"); Wire.resetBus(); break;
case I2C_DMA_ERR: Serial.print("DMA Error\n"); break;
default: break;
