Results 1 to 1 of 1
Thread: Teensy and ArtNet Multicast Issue
    Jan 2019
    1
    Long time lurker, first time poster...
    I am running a Teensy 3.6 with a Wiz850io to convert ArtNet into WS2811 Pixel Tape. Everything is hooked up, the test pattern works, and it works as expected when I send ArtNet to only the specific IP address of the Teensy. However, if I switch to a multicast for ArtNet, the Teensy no longer responds. I am using the 2.0 Ethernet Library which seems to already have the patches I have found online for adding multicast. Code is copied below.
    Any thoughts or suggestions are appreciated.
    Attached Files Attached Files
