Results 1 to 6 of 6
Thread: Adafruit Trellis and Teensy 3.2 with Audio Shield - communication problem
    Jan 2019
    4
    Hello Everybody!
    Very excited - it s my first post! I am using the trellis board/ Teensy 3.2 and the Audioshield. I wanna built a simple Sampler like: one trellis button turns on one sample (as an add on for my bass guitar)
    I wrote this simple sketch to check if trellis triggers anything. It doesnt work
    Is it an i2c issue or simply "newbiness"
    here it is
    #include <Bounce.h>
    #include <SerialFlash.h>
    #include "Flute_100kbyte_samples.h"
    AudioSynthWavetable wavetable;
    AudioOutputI2S i2s1;
    AudioMixer4 mixer;
    AudioConnection patchCord1(wavetable, 0, mixer, 0);
    AudioConnection patchCord2(mixer, 0, i2s1, 0);
    AudioConnection patchCord3(mixer, 0, i2s1, 1);
    // Trellis Zeug
    #include "Adafruit_Trellis.h"
    Adafruit_Trellis matrix0 = Adafruit_Trellis();
    Adafruit_TrellisSet trellis = Adafruit_TrellisSet(&matrix0);
    #define NUMTRELLIS 1
    #define numKeys (NUMTRELLIS * 16)
    #define INTPIN A2
    Wire.setSCL(16); // set i2c communication to other pins
    Wire.setSDA(17); // set i2c communication to other pins
    Wire.begin();// set i2c communication to other pins
    Serial.println("Trellis Demo");
    // begin() with the addresses of each panel in order
    trellis.begin(0x70);
    for (uint8_t i=0; i<numKeys; i++) {
    trellis.setLED(i);
    trellis.writeDisplay();
    delay(50);
    // then turn them off
    trellis.clrLED(i);
    delay(50);
    AudioMemory(20);
    sgtl5000_1.enable();
    sgtl5000_1.volume(0.8);
    mixer.gain(0, 0.7);
    wavetable.setInstrument(Flute_100kbyte);
    wavetable.amplitude(1);
    delay(30);
    if (trellis.justPressed(0))
    wavetable.playFrequency(261.0 );
    wavetable.amplitude(0.7);
    More failures form my past:
    I tried the i2c on the other pins too.
    I tired playing something form the SD.
    .h and .cpp data is from Examples-> Audio -> synthesis -> Wavetable -> SimpleWavetable
    Can anybody safe me from insanity?
    <3
    Feb 2017
    321
    Quote Originally Posted by hottib View Post
    It doesnt work
    Not very helpful problem statement. The code does something. Start by explaining what it does and how that is different from what you want it to do.
    Hello Everybody!
    The Audio Shield is controlled by I2C on Pins 18 & 19. So, this probably isn't a good idea.
    Member houtson's Avatar
    Aug 2015
    Scotland
    42
    When I have used trellis with the Audio Shield I've used SDA0(18) and SCL0(19) and they seem to work fine on the same i2c pins as audio shield - try removing all the wire statements
    In your sketch you also need to read the switch before you check for .justPressed like:
    if (trellis.readSwitches()) {
    if (trellis.justPressed(0)) { ....
    Paul
    Jan 2019
    4
    Problem solved!
    Hey Paul, thank you so much. You were right "trellis.readSwitches()" was missing. Now it runs beautifully. Now i m gonna solder the trellis on my Bassguitar. I let you guys know when the Project is finished.
    @gfvalvo: THX for your help!
    Hello Paul, please I also having trouble using the Teensy 3.6 with the neotrellis, it wouldn't even blink with all connections checked multiple times.
    Aug 2015
    Scotland
    42
    Hello, post a picture of what you have and also the code you are using cheers Paul
