Results 1 to 16 of 16
Thread: USBHost_T36, hosting USB MIDI devices with virtual cables (ports)?
    I'm trying to confirm if Teensy 3.6 can host USB Midi devices that have more than one virtual MIDI cable, and if so how to tell how many ports a given device has. I believe this bolded modification to the 16x16 example code will return the virtual cable:
      // Next read messages arriving from the (up to) 10 USB devices plugged into the USB Host port
      for (int port=0; port < 10; port++) {
        if (midilist[port]->read()) {
          uint8_t type =       midilist[port]->getType();
          uint8_t data1 =      midilist[port]->getData1();
          uint8_t data2 =      midilist[port]->getData2();
          uint8_t channel =    midilist[port]->getChannel();
          const uint8_t *sys = midilist[port]->getSysExArray();
          sendToComputer(type, data1, data2, channel, sys, 6 + port);
          uint8_t cable =      midilist[port]->getCable();   // should return the virtual cable of this device
          activity = true;
    Is there a limitation to the number of virtual cables that a hosted USB MIDI device can have? 16? And how can I identify how many virtual cables a device has when it is connected?
    Also, in the 16x16 example there are 10 hosted USB MIDI devices. Is this the max number or could you host more? If I connected (16) Teensy 3.6 devices, all set to 16x16 Midi mode, to a master Teensy 3.6 with USB hubs, would I have a 64x64 matrix?
    And finally, I've found some manufacturer's don't assign serial numbers to their MIDI devices. For instance the Akai LPK25 keyboard controller. If I had two of these, and connected them to the host port on a teensy 3.6, would there be a way to differentiate between the two and recognize which is which when they are disconnected and reconnected?
    Very impressed and grateful for all the hard work and open source code provided by Paul for this product.
    22,669
    Wow, so many questions. Here's quick answers...
    Quote Originally Posted by insolace View Post
    Yes, confirmed.
    You don't.
    Yes, 16.
    This limit comes from the USB MIDI spec which dedicates 4 bits to the virtual cable number, so it really can not be increased beyond 16.
    Ideally there should be a way to ask for this info, but it's currently not supported by the library. Unless you add code to parse the descriptors, you can't find out from the library how many virtual cables each device claims it supports. Nor can you query any of the other parameters from the audio class descriptors. The library just don't (yet) give you any way to ask for that info.
    USBHost_t36 is designed around the idea that you put instances in your program for each device that might connect. So if you put more than 10 instances of the MIDIDevice object, you could have more than 10.
    At some point of course there are practical limits, memory, bandwidth, CPU time to keep up with so many messages. Almost no work has been done so far to really explore or test those limits, so I really don't have any solid guidance on how far you can push this.
    Don't know what's meant by "matrix" in this question.
    As a USB device, Teensy 3.x offers "MIDIx16" meaning 16 virtual cables. There isn't any mode called "16x16" (though there are examples using this name), so again I don't quite understand your question.
    Theoretically, you could connect 16 Teensy 3.6 boards, each running MIDIx16, of course using USB hubs. Don't forget to include enough USBHub objects. Remember that most large hubs on the market are actually 2-tier networks of 4 port hubs, so for example you would probably need 3 of those USBHub objects in your code to support a typical 10 port hub.
    If you do build this and make it actually do something with so many virtual cables, I hope you'll share photos!
    Sadly, no. Regular computers face exactly the same issue with identical USB devices.
    22,669
    One further point, regarding USB bandwidth. USB has 4 transfer types, called "control", "bulk", "interrupt" and "isochronous", which have different ways of the USB host allocating the USB bandwidth. The device chooses which transfer type, the host is responsible for actually managing the bandwidth.
    USB MIDI allows use of either "bulk" or "interrupt". Almost all USB MIDI devices are designed with bulk protocol endpoints.. When you choose any of the MIDI device options in Tools > USB Type, Teensy always uses USB bulk protocol for USB MIDI.
    However, some devices on the market do use "interrupt" type. Novation Launchpad is the one which comes to mind.
    With interrupt type, a portion of the USB bandwidth is reserved. As you connect more of these devices, the reservation grows. USBHost_t36 uses a fairly simple strategy for reserved bandwidth, which is only able to reserve a little over half of all the bandwidth for interrupt protocol pipes. EHCI has a feature calls frame span traversal nodes which allows reserving more, but USBHost_t36 does not support that feature. It's very complicated, but allows 80% instead of ~50% of the bandwidth to be allocated. If you connect a very large number of devices needing interrupt pipes, eventually (around 50%) there won't be any more guaranteed bandwidth.
    The interrupt bandwidth guarantee is a theoretical calculation based on the worst possible case. But if the guarantee can't be made for the very worst case, USBHost_t36 will not recognize the device if it uses interrupt protocol pipes and all the guarantee-able bandwidth has already been promised to other devices. It doesn't matter if all the devices would still be able to work under that actual bandwidth usage scenario... the interrupt pipe bandwidth gaurantee is an absolute hard promise for certain bandwidth under the very worse possible scenario. If the promise can't be made, the device doesn't finish enumeration and can't be used.
    With bulk protocol, there are not promises on bandwidth. All bulk devices share all the available bandwidth, after the reserved devices have their option to use (or leave used) their guaranteed bandwidth. You can keep plugging in more bulk devices without worrying if they'll be rejected because bandwidth can't be promised.
    With both bulk and interrupt, if the device doesn't actually transmit or receive data, the rest of the pipes are able to use that bandwidth. But how well a large number of slower-than-480 USB devices share all the bandwidth depends on the type of hubs you use. USB 2.0 hubs (and the USB2 portion of USB3 hubs) come in 2 types: (cheap) Single-TT and (good) Multi-TT. Only the Multi-TT type hubs allow all their downstream 12 Mbit/sec devices to truly share the upstream 480 Mbit/sec connection. Most people never notice the difference, but if you really are connecting a very large number of 12 Mbit/sec USB devices and you expect many of them to push bandwidth limits, you really do need the better quality Mulit-TT type hubs to avoid bandwidth bottleneck problems.
    Fantastic response, thank you.
    Apologies for confusion, when I said 16x16 I meant MIDIx16.
    Iíve never seen a hub advertised as single or multi TT, do you know of some on the market? Is there a way to query this from the library when you create the USB Hub objects? Can you read from the library if a device is bulk or interrupt, and is there any way to monitor the feedback reservations?
    If I create a HID Keyboard instance will it play nicely with the MIDI instances?
    The USB Host port on my teensy 3.6 is reading 3.6v (coincidence?) on the 5V supply pin, not sure what I did as it was working for a while but Iíll need to order a new one before I can begin testing the new USB Host code. Iíll be sure to share pictures and code for the project as it develops, and of course questions.
    Thanks again Paul, your fast and thorough response is much appreciated.
    22,669
    I’ve never seen a hub advertised as single or multi TT, do you know of some on the market?
    Here's a photo of some I tested.
    https://twitter.com/PaulStoffregen/s...70079055761408
    More info on this page.
    https://www.pjrc.com/teensy/td_flightsim.html
    Scroll down to "Large System Guidelines".
    Yes, it is very sad that the most meaningful non-power technical spec about USB hubs is almost never mentioned in the sales info for hardly any hubs. Consumer electronics is bizarre like that.
    No.
    No, there's no API for that either.
    Yes.
    Is USBHost_t36 actually running?
    Something may be wrong if it is. But if the TPD3S014 switch is turned off, it's default state, then you would see little or no voltage.
    Searching Amazon turned up this as the only hub mentioning multi TT (transaction translator):
    7 port USB 2.0 Hi-Speed Self Powered Desktop Hub, Multi TT ( 3 PACK ) BY NETCNA https://www.amazon.com/dp/B072N6L55S..._VUGnCbD0WX6K5
    However searching google found this gem which is made by an instrument manufacturer, Elemtron. This might be the preferred hub:
    https://www.bhphotovideo.com/c/produ...BI%3A514&smp=Y
    22,669
    Simplest is to just plug hubs into Linux or Windows 10 and check. Usually in any batch of random hubs of different make/model, some will turn out to be Multi-TT protocol.
    Edit: that little 2-port one which led to the discovery of a bug deep in the USB stack was also a Multi-TT type. Here's an article I wrote about that adventure in bug hunting.
    https://www.pjrc.com/usb-hub-bug-hun...ssons-learned/
    Here's the forum thread about that hub
    Sadly, clicking in the link to Amazon on that thread shows it's no longer available.
    How do you check a hub in Linux? If itís a terminal command I can try it in OSX.
    Hereís another question, it would seem that usb midi devices with multiple virtual cables can report a name for each cable. Hereís a screenshot from Ableton Live (ignore the highlights that arenít mine), notice Virus TI, Akai MPK49, and microlite are all single devices reporting multiple virtual cables, each with a unique name (ie Virus MIDI and Virus Synth)
    http://ultimateoutsider.com/blogimag...feldlive02.png
    Is it possible to get these virtual cable names from the library? When using a teensy running MIDIx16, could we name the virtual cables that the computer sees?
    22,669
    Use "lsusb -v"
    Or something like:
    lsusb -v | grep -B7 -A7 'bDeviceProtocol.*TT'
    "TT per port" means Multi-TT.
    Ignore all the "root hub" ones, which merely represent the hardware on your motherboard.
    Iíll do this tonight when Iím back in the studio and share the results here. Maybe this will shed some light on the virtual cable names as well, Iíll leave all the synths and midi devices connected.
    22,669
    On Macintosh, the similar command line utility is "ioreg -l", but it's output is all devices not nearly as easy to use as the Linux one.
    Apple has a utility called "USB Prober". It used to come with X-Code. I'm not sure how to get it now. But here's a screenshot of how it shows the hub protocol.
    Looks like it comes with the developer packages, Iíll try to dig it up, or I could use my windows laptop if thatís easier.
    Well after following the instructions here I was able to download USB Prober. Raw output is too big for this post, so I'll post it separately.
    Here's a screenshot:
    I have 3 usb hubs, the one that came up as MTT is the cheapest of the bunch! You can find them at newegg for $8 here.
    The two listed as "Genesys Logic" are actually a single 7 port D-Link hub.
    Drilling down into the names of the virtual cables. The "Virus TI" has two virtual cables that show up in Ableton live, one is "MIDI" which goes connects to the DIN ports, and one is "SYNTH" which controls the synth. Here's what it looks like in audio midi setup:
    I'm searching the output of USB Prober for "Synth" in hex and it's nowhere to be found. The synth is also an USB audio interface with hardware inputs and outputs, as well as audio into the vocoder. Looking at the listed interfaces, #3 and #4 are likely the virtual MIDI Cables. I don't see where the labels are coming from though.
    Any ideas?
    Output:
    Super Speed device @ 0 (0x14000000): .............................................   Hub device from Apple Inc.
        Port Information:   0x061d
               Built-in Root Hub
               Captive
               Internal Device
               Connected
               Enabled
        Number Of Endpoints (includes EP0):
            Total Endpoints for Configuration 1 (unconfigured):   1
        Device Descriptor
            Descriptor Version Number:   0x0100
            Device Class:   9   (Hub)
            Device Subclass:   255
            Device Protocol:   3   (SuperSpeed)
            Device MaxPacketSize:   8
            Device VendorID/ProductID:   0x05AC/0x8007   (Apple Inc.)
            Device Version Number:   0x0198
            Number of Configurations:   1
            Manufacturer String:   0 (none)
            Product String:   0 (none)
            Serial Number String:   0 (none)
        Current configuration:   0 (unconfigured)
        Configuration Descriptor
            Length (and contents):   9
                Raw Descriptor (hex)   0000: 09 02 09 00 00 01 00 60  00
            Number of Interfaces:   0
            Configuration Value:   1
            Attributes:   0x60 (self-powered, remote wakeup)
            MaxPower:   0 mA
    Super Speed device @ 0 (0x00000000): .............................................   Hub device from Apple Inc.
               Built-in Root Hub
               Captive
               Internal Device
               Connected
               Enabled
        Device Descriptor
            MaxPower:   0 mA
    Super Speed device @ 0 (0x01000000): .............................................   Hub device from Apple Inc.
               Built-in Root Hub
               Captive
               Internal Device
               Connected
               Enabled
        Device Descriptor
            MaxPower:   0 mA
    High Speed device @ 1 (0x14100000): .............................................   Miscellaneous/Common Class device: "iBridge"
        Port Information:   0x001e
               Not Captive
               Attached to Root Hub
               Internal Device
               Connected
               Enabled
            Total Endpoints for Configuration 1 :   4
            Total Endpoints for Configuration 2 (current):   10
            Total Endpoints for Configuration 3 :   6
        Device Descriptor
            Descriptor Version Number:   0x0200
            Device Class:   239   (Miscellaneous)
            Device Subclass:   2   (Common Class)
            Device Protocol:   1   (Interface Association)
            Device MaxPacketSize:   64
            Device VendorID/ProductID:   0x05AC/0x8600   (Apple Inc.)
            Device Version Number:   0x0101
            Number of Configurations:   3
            Manufacturer String:   1 "Apple Inc."
            Product String:   2 "iBridge"
        Configuration Descriptor: .......................................   "Default iBridge Interfaces"
            Length (and contents):   469
                Raw Descriptor (hex)    0000: 09 02 D5 01 04 01 03 E0  00 08 0B 00 02 0E 01 00
                Raw Descriptor (hex)    0010: 04 09 04 00 00 00 0E 01  00 0D 0D 24 01 50 01 36
                Raw Descriptor (hex)    0020: 00 40 42 0F 00 01 01 12  24 02 01 01 02 00 00 00
                Raw Descriptor (hex)    0030: 00 00 00 00 00 03 00 00  00 09 24 03 02 01 01 00
                Raw Descriptor (hex)    0040: 01 00 0E 24 05 03 01 00  00 04 1F 00 00 00 00 00
                Raw Descriptor (hex)    0050: 09 04 01 00 01 0E 02 00  00 0E 24 01 01 43 01 81
                Raw Descriptor (hex)    0060: 00 02 00 00 00 01 00 0B  24 06 01 02 00 02 00 00
                Raw Descriptor (hex)    0070: 00 00 92 24 07 01 00 00  05 D0 02 00 38 04 00 00
                Raw Descriptor (hex)    0080: 90 7E 00 00 38 04 00 15  16 05 00 1E 15 16 05 00
                Raw Descriptor (hex)    0090: FB 42 05 00 16 73 05 00  C2 A6 05 00 67 DE 05 00
                Raw Descriptor (hex)    00a0: 80 1A 06 00 9A 5B 06 00  5E A2 06 00 91 EF 06 00
                Raw Descriptor (hex)    00b0: 1E 44 07 00 20 A1 07 00  EB 07 08 00 23 7A 08 00
                Raw Descriptor (hex)    00c0: CB F9 08 00 68 89 09 00  2A 2C 0A 00 2D E6 0A 00
                Raw Descriptor (hex)    00d0: CE BC 0B 00 35 B7 0C 00  22 DF 0D 00 40 42 0F 00
                Raw Descriptor (hex)    00e0: 47 F4 10 00 D0 12 13 00  5B CC 15 00 6A 6E 19 00
                Raw Descriptor (hex)    00f0: 80 84 1E 00 A0 25 26 00  D5 DC 32 00 40 4B 4C 00
                Raw Descriptor (hex)    0100: 80 96 98 00 92 24 07 02  00 80 02 E0 01 00 68 01
                Raw Descriptor (hex)    0110: 00 00 30 2A 00 00 68 01  00 15 16 05 00 1E 15 16
                Raw Descriptor (hex)    0120: 05 00 FB 42 05 00 16 73  05 00 C2 A6 05 00 67 DE
                Raw Descriptor (hex)    0130: 05 00 80 1A 06 00 9A 5B  06 00 5E A2 06 00 91 EF
                Raw Descriptor (hex)    0140: 06 00 1E 44 07 00 20 A1  07 00 EB 07 08 00 23 7A
                Raw Descriptor (hex)    0150: 08 00 CB F9 08 00 68 89  09 00 2A 2C 0A 00 2D E6
                Raw Descriptor (hex)    0160: 0A 00 CE BC 0B 00 35 B7  0C 00 22 DF 0D 00 40 42
                Raw Descriptor (hex)    0170: 0F 00 47 F4 10 00 D0 12  13 00 5B CC 15 00 6A 6E
                Raw Descriptor (hex)    0180: 19 00 80 84 1E 00 A0 25  26 00 D5 DC 32 00 40 4B
                Raw Descriptor (hex)    0190: 4C 00 80 96 98 00 06 24  0D 01 01 04 07 05 81 02
                Raw Descriptor (hex)    01a0: 00 02 00 09 04 02 00 01  03 01 01 00 09 21 01 01
                Raw Descriptor (hex)    01b0: 00 01 22 53 00 07 05 83  03 40 00 07 09 04 03 00
                Raw Descriptor (hex)    01c0: 01 03 00 01 00 09 21 01  01 00 01 22 7A 02 07 05
                Raw Descriptor (hex)    01d0: 85 03 00 04 07
            Number of Interfaces:   4
            Attributes:   0xE0 (self-powered, remote wakeup)
            MaxPower:   0 mA
            Interface Association   Video/Control
                First Interface   0
                Interface Count   2
                Function Class   14   (Video)
                Function Subclass   1   (Control)
                Interface Protocol   0
                Function String   4 "FaceTime HD Camera (Build-in)"
            Interface #0 - Video/Control ..............................................   "FaceTime HD Camera (Build-in, SN:CC27445PA9CGJJM1L)"
                Alternate Setting   0
                Number of Endpoints   0
                Interface Class:   14   (Video)
                Interface Subclass;   1   (Control)
                Interface Protocol:   0
                VDC (Control) Header
                    Length (and contents):   13
                        Raw Descriptor (hex)   0000: 0D 24 01 50 01 36 00 40  42 0F 00 01 01
                    bDescriptorType:   0x24
                    bDescriptorSubType:   0x1
                    Specification Version Number:   01.5
                    Device Clock Frequency (Hz):   1000000
                    Number of Video Streaming Interfaces:   1
                    Video Interface Number:   1
                VDC (Control) Input Terminal
                    Length (and contents):   18
                        Raw Descriptor (hex)    0000: 12 24 02 01 01 02 00 00  00 00 00 00 00 00 03 00
                        Raw Descriptor (hex)    0010: 00 00
                    bDescriptorSubType:   0x2
                    Terminal ID   1
                    Input Terminal Type:   0x201 (Camera Sensor)
                    Input Terminal ID:   0 [NONE]
                    Input Terminal String Index:   0 [NONE]
                    Minimum Focal Length   0
                    Maximum Focal Length   0
                    Ocular Focal Length   0
                    Controls Supported   Description
                VDC (Control) Output Terminal
                        Raw Descriptor (hex)   0000: 09 24 03 02 01 01 00 01  00
                    bDescriptorSubType:   0x3
                    Terminal ID:   2
                    Output Terminal Type:   0x101 (USB streaming)
                    Output Terminal ID:   0 [NONE]
                    Output Terminal String Index:   0 [NONE]
                VDC (Control) Processing Unit
                    Length (and contents):   14
                        Raw Descriptor (hex)   0000: 0E 24 05 03 01 00 00 04  1F 00 00 00 00 00
                    bDescriptorSubType:   0x5
                    Unit ID:   3
                    Source ID:   1
                    Digital Multiplier (100X):   0
                           Brightness
                           Contrast
                           Hue
                           Saturation
                           Sharpness
                    Processing Unit String Index:   0 [NONE]
            Interface #1 - Video/Streaming
                Alternate Setting   0
                Number of Endpoints   1
                Interface Subclass;   2   (Streaming)
                VDC (Streaming) Input Header
                        Raw Descriptor (hex)   0000: 0E 24 01 01 43 01 81 00  02 00 00 00 01 00
                    bNumFormats:   1
                    wTotalLength:   0x143 (323)
                    bEndpointAddress:   0x81
                    Capabilities (0x0)   bmInfo
                    bTerminalLink:   2
                    bStillCaptureMethod:   0 (None)
                    bTriggerSupport   0 (Not Supported)
                    bTriggerUsage   Ignored because bTriggerSupport is 0
                    bControlSize:   0x1
                    bmaControls( Format 1):   0x0
                VDC (Streaming) MJPEG Format Descriptor
                    Length (and contents):   11
                        Raw Descriptor (hex)   0000: 0B 24 06 01 02 00 02 00  00 00 00
                    bDescriptorSubType:   0x6
                    bFormatIndex:   0x1
                    bNumFrameDescriptors:   0x2
                    bmFlags   (0x0)
                    bDefaultFrameIndex:   0x2
                    bAspectRatioX:   0x0
                    bAspectRatioY:   0x0
                    bmInterlaceFlags   (0x0)
                        Interlaced Stream or Variable   No
                        Fields per frame   1
                        Field 1 first   No
                        Field Pattern   Field 1 only
                        Display Mode   Bob only
                    bCopyProtect   No Restriction
                VDC (Streaming) MJPEG Frame Descriptor
                    Length (and contents):   146
                        Raw Descriptor (hex)    0000: 92 24 07 01 00 00 05 D0  02 00 38 04 00 00 90 7E
                        Raw Descriptor (hex)    0010: 00 00 38 04 00 15 16 05  00 1E 15 16 05 00 FB 42
                        Raw Descriptor (hex)    0020: 05 00 16 73 05 00 C2 A6  05 00 67 DE 05 00 80 1A
                        Raw Descriptor (hex)    0030: 06 00 9A 5B 06 00 5E A2  06 00 91 EF 06 00 1E 44
                        Raw Descriptor (hex)    0040: 07 00 20 A1 07 00 EB 07  08 00 23 7A 08 00 CB F9
                        Raw Descriptor (hex)    0050: 08 00 68 89 09 00 2A 2C  0A 00 2D E6 0A 00 CE BC
                        Raw Descriptor (hex)    0060: 0B 00 35 B7 0C 00 22 DF  0D 00 40 42 0F 00 47 F4
                        Raw Descriptor (hex)    0070: 10 00 D0 12 13 00 5B CC  15 00 6A 6E 19 00 80 84
                        Raw Descriptor (hex)    0080: 1E 00 A0 25 26 00 D5 DC  32 00 40 4B 4C 00 80 96
                        Raw Descriptor (hex)    0090: 98 00
                    bDescriptorSubType:   0x7
                    bFrameIndex:   1
                    bmCapabilities    (0x0)
                    wWidth:   0x500 (1280)
                    wHeight:   0x2d0 (720)
                    dwMinBitRate (bps):   0x43800 (276480)
                    dwMaxBitRate (bps):   0x7e9000 (8294400)
                    dwMaxVideoFrameBufferSize (bytes):   0x43800 (276480)
                    dwDefaultFrameInterval:   0x51615 (  33.000 ms)
                    Discrete Frame Intervals supported   30
                        dwFrameInterval[1] (100 ns)   0x51615 (  33.000 ms)
                        dwFrameInterval[2] (100 ns)   0x542fb (  34.000 ms)
                        dwFrameInterval[3] (100 ns)   0x57316 (  35.000 ms)
                        dwFrameInterval[4] (100 ns)   0x5a6c2 (  37.000 ms)
                        dwFrameInterval[5] (100 ns)   0x5de67 (  38.000 ms)
                        dwFrameInterval[6] (100 ns)   0x61a80 (  40.000 ms)
                        dwFrameInterval[7] (100 ns)   0x65b9a (  41.000 ms)
                        dwFrameInterval[8] (100 ns)   0x6a25e (  43.000 ms)
                        dwFrameInterval[9] (100 ns)   0x6ef91 (  45.000 ms)
                        dwFrameInterval[10] (100 ns)   0x7441e (  47.000 ms)
                        dwFrameInterval[11] (100 ns)   0x7a120 (  50.000 ms)
                        dwFrameInterval[12] (100 ns)   0x807eb (  52.000 ms)
                        dwFrameInterval[13] (100 ns)   0x87a23 (  55.000 ms)
                        dwFrameInterval[14] (100 ns)   0x8f9cb (  58.000 ms)
                        dwFrameInterval[15] (100 ns)   0x98968 (  62.000 ms)
                        dwFrameInterval[16] (100 ns)   0xa2c2a (  66.000 ms)
                        dwFrameInterval[17] (100 ns)   0xae62d (  71.000 ms)
                        dwFrameInterval[18] (100 ns)   0xbbcce (  76.000 ms)
                        dwFrameInterval[19] (100 ns)   0xcb735 (  83.000 ms)
                        dwFrameInterval[20] (100 ns)   0xddf22 (  90.000 ms)
                        dwFrameInterval[21] (100 ns)   0xf4240 ( 100.000 ms)
                        dwFrameInterval[22] (100 ns)   0x10f447 ( 111.000 ms)
                        dwFrameInterval[23] (100 ns)   0x1312d0 ( 125.000 ms)
                        dwFrameInterval[24] (100 ns)   0x15cc5b ( 142.000 ms)
                        dwFrameInterval[25] (100 ns)   0x196e6a ( 166.000 ms)
                        dwFrameInterval[26] (100 ns)   0x1e8480 ( 200.000 ms)
                        dwFrameInterval[27] (100 ns)   0x2625a0 ( 250.000 ms)
                        dwFrameInterval[28] (100 ns)   0x32dcd5 ( 333.000 ms)
                        dwFrameInterval[29] (100 ns)   0x4c4b40 ( 500.000 ms)
                        dwFrameInterval[30] (100 ns)   0x989680 (1000.000 ms)
                        Raw Descriptor (hex)    0000: 92 24 07 02 00 80 02 E0  01 00 68 01 00 00 30 2A
                        Raw Descriptor (hex)    0010: 00 00 68 01 00 15 16 05  00 1E 15 16 05 00 FB 42
                    bFrameIndex:   2
                    wWidth:   0x280 (640)
                    wHeight:   0x1e0 (480)
                    dwMinBitRate (bps):   0x16800 (92160)
                    dwMaxBitRate (bps):   0x2a3000 (2764800)
                    dwMaxVideoFrameBufferSize (bytes):   0x16800 (92160)
                VDC (Streaming) Color Format Descriptor
                    Length (and contents):   6
                        Raw Descriptor (hex)   0000: 06 24 0D 01 01 04
                    bDescriptorSubType:   0xd
                    Color Primaries:   1 ( BT.709, sRGB (default) )
                    Transfer Characteristics:   1 ( BT.709 (default) )
                    Matrix Coefficients:   4 ( SMPTE 170M (BT.601, default) )
                Endpoint 0x81 - Bulk Input
                    Address:   0x81  (IN)
                    Attributes:   0x02  (Bulk)
                    Max Packet Size:   512
                    Polling Interval:   0 ( Endpoint never NAKs)
            Interface #2 - HID/Boot Interface
                Alternate Setting   0
                Interface Class:   3   (HID)
                Interface Subclass;   1   (Boot Interface)
                Interface Protocol:   1
                HID Descriptor
                    Descriptor Version Number:   0x0101
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                        Type:   0x22  (Report Descriptor)
                        Length (interface does not currently exist):   83
                Endpoint 0x83 - Interrupt Input
                    Address:   0x83  (IN)
                    Attributes:   0x03  (Interrupt)
                    Max Packet Size:   0x0040  (64 x 1  transactions opportunities per microframe)
                    Polling Interval:   7 (64 microframes (8 msecs) )
            Interface #3 - HID
                Alternate Setting   0
                Interface Subclass;   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                        Length (interface does not currently exist):   634
                Endpoint 0x85 - Interrupt Input
                    Address:   0x85  (IN)
                    Max Packet Size:   0x0400  (1024 x 1  transactions opportunities per microframe)
        Configuration Descriptor (current config): ......................   "Default iBridge Interfaces(OS X)"
            Length (and contents):   662
                Raw Descriptor (hex)    0000: 09 02 96 02 08 02 05 E0  00 08 0B 00 02 0E 01 00
                Raw Descriptor (hex)    0010: 06 09 04 00 00 00 0E 01  00 0E 0D 24 01 50 01 36
                Raw Descriptor (hex)    0050: 09 04 01 00 01 0E 02 00  00 0E 24 01 01 90 01 81
                Raw Descriptor (hex)    0060: 00 02 00 00 00 01 00 34  24 13 01 02 02 00 00 00
                Raw Descriptor (hex)    0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
                Raw Descriptor (hex)    0080: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
                Raw Descriptor (hex)    0090: 00 00 00 00 00 00 00 00  00 00 00 A4 24 14 01 00
                Raw Descriptor (hex)    00a0: 05 D0 02 01 00 01 00 00  4D 33 00 00 00 00 01 00
                Raw Descriptor (hex)    00b0: 02 00 00 00 00 00 00 00  00 00 00 2D 31 01 00 2D
                Raw Descriptor (hex)    00c0: 31 01 15 16 05 00 1E 15  16 05 00 FB 42 05 00 16
                Raw Descriptor (hex)    00d0: 73 05 00 C2 A6 05 00 67  DE 05 00 80 1A 06 00 9A
                Raw Descriptor (hex)    00e0: 5B 06 00 5E A2 06 00 91  EF 06 00 1E 44 07 00 20
                Raw Descriptor (hex)    00f0: A1 07 00 EB 07 08 00 23  7A 08 00 CB F9 08 00 68
                Raw Descriptor (hex)    0100: 89 09 00 2A 2C 0A 00 2D  E6 0A 00 CE BC 0B 00 35
                Raw Descriptor (hex)    0110: B7 0C 00 22 DF 0D 00 40  42 0F 00 47 F4 10 00 D0
                Raw Descriptor (hex)    0120: 12 13 00 5B CC 15 00 6A  6E 19 00 80 84 1E 00 A0
                Raw Descriptor (hex)    0130: 25 26 00 D5 DC 32 00 40  4B 4C 00 80 96 98 00 A4
                Raw Descriptor (hex)    0140: 24 14 02 80 02 E0 01 01  00 01 00 00 4D 33 00 00
                Raw Descriptor (hex)    0150: 00 00 01 00 02 00 00 00  00 00 00 00 00 00 00 2D
                Raw Descriptor (hex)    0160: 31 01 00 2D 31 01 15 16  05 00 1E 15 16 05 00 FB
                Raw Descriptor (hex)    0170: 42 05 00 16 73 05 00 C2  A6 05 00 67 DE 05 00 80
                Raw Descriptor (hex)    0180: 1A 06 00 9A 5B 06 00 5E  A2 06 00 91 EF 06 00 1E
                Raw Descriptor (hex)    0190: 44 07 00 20 A1 07 00 EB  07 08 00 23 7A 08 00 CB
                Raw Descriptor (hex)    01a0: F9 08 00 68 89 09 00 2A  2C 0A 00 2D E6 0A 00 CE
                Raw Descriptor (hex)    01b0: BC 0B 00 35 B7 0C 00 22  DF 0D 00 40 42 0F 00 47
                Raw Descriptor (hex)    01c0: F4 10 00 D0 12 13 00 5B  CC 15 00 6A 6E 19 00 80
                Raw Descriptor (hex)    01d0: 84 1E 00 A0 25 26 00 D5  DC 32 00 40 4B 4C 00 80
                Raw Descriptor (hex)    01e0: 96 98 00 06 24 0D 01 01  04 07 05 81 02 00 02 00
                Raw Descriptor (hex)    01f0: 09 04 02 00 01 03 00 01  00 09 21 01 01 00 01 22
                Raw Descriptor (hex)    0200: 0E 03 07 05 83 03 40 00  05 09 04 03 00 02 10 00
                Raw Descriptor (hex)    0210: 00 00 07 05 85 02 00 02  0A 07 05 02 02 00 02 0A
                Raw Descriptor (hex)    0220: 09 04 04 00 00 02 0D 00  0B 05 24 00 10 01 05 24
                Raw Descriptor (hex)    0230: 06 04 05 0D 24 0F 0A 00  00 00 00 EA 05 00 00 00
                Raw Descriptor (hex)    0240: 06 24 1A 00 01 33 09 04  05 00 00 0A 00 01 0C 09
                Raw Descriptor (hex)    0250: 04 05 01 02 0A 00 01 0C  07 05 86 02 00 02 00 07
                Raw Descriptor (hex)    0260: 05 04 02 00 02 00 09 04  06 00 01 03 00 01 00 09
                Raw Descriptor (hex)    0270: 21 01 01 00 01 22 7A 02  07 05 87 03 00 04 07 09
                Raw Descriptor (hex)    0280: 04 07 00 02 FF F9 11 09  07 05 05 02 00 02 00 07
                Raw Descriptor (hex)    0290: 05 88 02 00 02 00
            Number of Interfaces:   8
            Configuration Value:   2
            MaxPower:   0 mA
                First Interface   0
                Interface Count   2
                Function String   6 "FaceTime HD Camera (Build-in)"
                Alternate Setting   0
                    Terminal ID   1
                    Terminal ID:   2
                    Unit ID:   3
                    Source ID:   1
                           Brightness
                           Contrast
                           Hue
                           Saturation
                           Sharpness
                Alternate Setting   0
                        Raw Descriptor (hex)   0000: 0E 24 01 01 90 01 81 00  02 00 00 00 01 00
                    bNumFormats:   1
                    wTotalLength:   0x190 (400)
                    bTerminalLink:   2
                    bControlSize:   0x1
                Unknown SC_VIDEOSTREAMING SubType Descriptor
                    Length (and contents):   52
                        Raw Descriptor (hex)    0000: 34 24 13 01 02 02 00 00  00 00 00 00 00 00 00 00
                        Raw Descriptor (hex)    0010: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
                        Raw Descriptor (hex)    0020: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
                    bDescriptorSubType:   0x13
                    Length (and contents):   164
                        Raw Descriptor (hex)    0000: A4 24 14 01 00 05 D0 02  01 00 01 00 00 4D 33 00
                        Raw Descriptor (hex)    0010: 00 00 00 01 00 02 00 00  00 00 00 00 00 00 00 00
                        Raw Descriptor (hex)    0020: 2D 31 01 00 2D 31 01 15  16 05 00 1E 15 16 05 00
                        Raw Descriptor (hex)    0030: FB 42 05 00 16 73 05 00  C2 A6 05 00 67 DE 05 00
                        Raw Descriptor (hex)    0040: 80 1A 06 00 9A 5B 06 00  5E A2 06 00 91 EF 06 00
                        Raw Descriptor (hex)    0050: 1E 44 07 00 20 A1 07 00  EB 07 08 00 23 7A 08 00
                        Raw Descriptor (hex)    0060: CB F9 08 00 68 89 09 00  2A 2C 0A 00 2D E6 0A 00
                        Raw Descriptor (hex)    0070: CE BC 0B 00 35 B7 0C 00  22 DF 0D 00 40 42 0F 00
                        Raw Descriptor (hex)    0080: 47 F4 10 00 D0 12 13 00  5B CC 15 00 6A 6E 19 00
                        Raw Descriptor (hex)    0090: 80 84 1E 00 A0 25 26 00  D5 DC 32 00 40 4B 4C 00
                        Raw Descriptor (hex)    00a0: 80 96 98 00
                    bDescriptorSubType:   0x14
                        Raw Descriptor (hex)    0000: A4 24 14 02 80 02 E0 01  01 00 01 00 00 4D 33 00
                    Address:   0x81  (IN)
            Interface #2 - HID
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                        Length (and contents):   782
                            Raw Descriptor (hex)    0000: 05 0D 09 05 A1 01 05 0D  09 22 A1 02 05 0D 09 38
                            Raw Descriptor (hex)    0010: 75 04 95 01 81 02 09 33  15 00 25 01 75 01 95 01
                            Raw Descriptor (hex)    0020: 81 02 09 32 15 00 25 01  75 01 95 01 81 02 75 02
                            Raw Descriptor (hex)    0030: 95 01 81 01 05 01 09 30  15 00 26 FF 7F 75 10 95
                            Raw Descriptor (hex)    0040: 01 81 02 09 31 15 00 25  7F 75 08 95 01 81 02 C0
                            Raw Descriptor (hex)    0050: 05 0D 09 22 A1 02 05 0D  09 38 75 04 95 01 81 02
                            Raw Descriptor (hex)    0060: 09 33 15 00 25 01 75 01  95 01 81 02 09 32 15 00
                            Raw Descriptor (hex)    0070: 25 01 75 01 95 01 81 02  75 02 95 01 81 01 05 01
                            Raw Descriptor (hex)    0080: 09 30 15 00 26 FF 7F 75  10 95 01 81 02 09 31 15
                            Raw Descriptor (hex)    0090: 00 25 7F 75 08 95 01 81  02 C0 05 0D 09 22 A1 02
                            Raw Descriptor (hex)    00a0: 05 0D 09 38 75 04 95 01  81 02 09 33 15 00 25 01
                            Raw Descriptor (hex)    00b0: 75 01 95 01 81 02 09 32  15 00 25 01 75 01 95 01
                            Raw Descriptor (hex)    00c0: 81 02 75 02 95 01 81 01  05 01 09 30 15 00 26 FF
                            Raw Descriptor (hex)    00d0: 7F 75 10 95 01 81 02 09  31 15 00 25 7F 75 08 95
                            Raw Descriptor (hex)    00e0: 01 81 02 C0 05 0D 09 22  A1 02 05 0D 09 38 75 04
                            Raw Descriptor (hex)    00f0: 95 01 81 02 09 33 15 00  25 01 75 01 95 01 81 02
                            Raw Descriptor (hex)    0100: 09 32 15 00 25 01 75 01  95 01 81 02 75 02 95 01
                            Raw Descriptor (hex)    0110: 81 01 05 01 09 30 15 00  26 FF 7F 75 10 95 01 81
                            Raw Descriptor (hex)    0120: 02 09 31 15 00 25 7F 75  08 95 01 81 02 C0 05 0D
                            Raw Descriptor (hex)    0130: 09 22 A1 02 05 0D 09 38  75 04 95 01 81 02 09 33
                            Raw Descriptor (hex)    0140: 15 00 25 01 75 01 95 01  81 02 09 32 15 00 25 01
                            Raw Descriptor (hex)    0150: 75 01 95 01 81 02 75 02  95 01 81 01 05 01 09 30
                            Raw Descriptor (hex)    0160: 15 00 26 FF 7F 75 10 95  01 81 02 09 31 15 00 25
                            Raw Descriptor (hex)    0170: 7F 75 08 95 01 81 02 C0  05 0D 09 22 A1 02 05 0D
                            Raw Descriptor (hex)    0180: 09 38 75 04 95 01 81 02  09 33 15 00 25 01 75 01
                            Raw Descriptor (hex)    0190: 95 01 81 02 09 32 15 00  25 01 75 01 95 01 81 02
                            Raw Descriptor (hex)    01a0: 75 02 95 01 81 01 05 01  09 30 15 00 26 FF 7F 75
                            Raw Descriptor (hex)    01b0: 10 95 01 81 02 09 31 15  00 25 7F 75 08 95 01 81
                            Raw Descriptor (hex)    01c0: 02 C0 05 0D 09 22 A1 02  05 0D 09 38 75 04 95 01
                            Raw Descriptor (hex)    01d0: 81 02 09 33 15 00 25 01  75 01 95 01 81 02 09 32
                            Raw Descriptor (hex)    01e0: 15 00 25 01 75 01 95 01  81 02 75 02 95 01 81 01
                            Raw Descriptor (hex)    01f0: 05 01 09 30 15 00 26 FF  7F 75 10 95 01 81 02 09
                            Raw Descriptor (hex)    0200: 31 15 00 25 7F 75 08 95  01 81 02 C0 05 0D 09 22
                            Raw Descriptor (hex)    0210: A1 02 05 0D 09 38 75 04  95 01 81 02 09 33 15 00
                            Raw Descriptor (hex)    0220: 25 01 75 01 95 01 81 02  09 32 15 00 25 01 75 01
                            Raw Descriptor (hex)    0230: 95 01 81 02 75 02 95 01  81 01 05 01 09 30 15 00
                            Raw Descriptor (hex)    0240: 26 FF 7F 75 10 95 01 81  02 09 31 15 00 25 7F 75
                            Raw Descriptor (hex)    0250: 08 95 01 81 02 C0 05 0D  09 22 A1 02 05 0D 09 38
                            Raw Descriptor (hex)    0260: 75 04 95 01 81 02 09 33  15 00 25 01 75 01 95 01
                            Raw Descriptor (hex)    0270: 81 02 09 32 15 00 25 01  75 01 95 01 81 02 75 02
                            Raw Descriptor (hex)    0280: 95 01 81 01 05 01 09 30  15 00 26 FF 7F 75 10 95
                            Raw Descriptor (hex)    0290: 01 81 02 09 31 15 00 25  7F 75 08 95 01 81 02 C0
                            Raw Descriptor (hex)    02a0: 05 0D 09 22 A1 02 05 0D  09 38 75 04 95 01 81 02
                            Raw Descriptor (hex)    02b0: 09 33 15 00 25 01 75 01  95 01 81 02 09 32 15 00
                            Raw Descriptor (hex)    02c0: 25 01 75 01 95 01 81 02  75 02 95 01 81 01 05 01
                            Raw Descriptor (hex)    02d0: 09 30 15 00 26 FF 7F 75  10 95 01 81 02 09 31 15
                            Raw Descriptor (hex)    02e0: 00 25 7F 75 08 95 01 81  02 C0 06 00 FF 09 23 A1
                            Raw Descriptor (hex)    02f0: 00 06 11 FF 09 01 95 01  75 40 81 02 09 02 75 20
                            Raw Descriptor (hex)    0300: 95 01 81 02 C0 06 00 FF  09 16 A1 01 C0 C0
                        Parsed Report Descriptor:
                              Usage Page    (Digitizer)
                              Usage 5 (0x5)
                                  Collection (Application)
                                    Usage 34 (0x22)
                                        Collection (Logical)
                                          Usage 56 (0x38)
                                          Report Size.............    (4)
                                          Report Count............    (1)
                                          Input...................   (Data, Variable, Absolute, No Wrap, Linear, Preferred State, No Null Position, Bitfield)
                                          Usage 51 (0x33)
                                          Logical Minimum.........    (0)
                                          Logical Maximum.........    (1)
                                          Report Size.............    (1)
                                          Usage 50 (0x32)
                                          Report Size.............    (2)
                                          Input...................   (Constant, Array, Absolute)
                                          Usage Page    (Generic Desktop)
                                          Usage (X)
                                          Logical Maximum.........    (32767)
                                          Report Size.............    (16)
                                          Usage (Y)
                                          Logical Maximum.........    (127)
                                          Report Size.............    (8)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage 34 (0x22)
                                          Usage 56 (0x38)
                                          Usage 51 (0x33)
                                          Usage 50 (0x32)
                                          Usage (X)
                                          Usage (Y)
                                        End Collection
                                    Usage Page    (Vendor defined 0)
                                    Usage 35 (0x23)
                                        Collection (Physical)
                                          Usage Page    (Vendor defined 17)
                                          Usage 1 (0x1)
                                          Report Size.............    (64)
                                          Usage 2 (0x2)
                                          Report Size.............    (32)
                                        End Collection
                                    Usage 22 (0x16)
                                        End Collection
                                  End Collection
                    Address:   0x83  (IN)
                    Polling Interval:   5 (16 microframes (2 msecs) )
            Interface #3 - Unknown
                Alternate Setting   0
                Number of Endpoints   2
                Interface Class:   16   (Unknown)
                Endpoint 0x85 - Bulk Input
                    Address:   0x85  (IN)
                    Polling Interval:   10 ( At most 1 NAK every 10 microframe(s) )
                Endpoint 0x02 - Bulk Output
                    Address:   0x02  (OUT)
            Interface #4 - Communications-Control ..............................................   "NCM Control"
                Alternate Setting   0
                Interface Class:   2   (Communications-Control)
                Interface Subclass;   13
                Comm Class Header Functional Descriptor
                    Raw Descriptor (hex)   0000: 05 24 00 10 01
                Comm Class Union Functional Descriptor
                    Raw Descriptor (hex)   0000: 05 24 06 04 05
                Comm Class Ethernet Networking Functional Descriptor
                    Raw Descriptor (hex)   0000: 0D 24 0F 0A 00 00 00 00  EA 05 00 00 00
                Comm Class Reserved Functional Descriptor (26)
                    Raw Descriptor (hex)   0000: 06 24 1A 00 01 33
            Interface #5 - Communications-Data/Unknown Comm Class Model ..............................................   "NCM Data"
                Alternate Setting   0
                Interface Class:   10   (Communications-Data)
                Interface Subclass;   0   (Unknown Comm Class Model)
            Interface #5 - Communications-Data/Unknown Comm Class Model (#1) ..............................................   "NCM Data"
                Alternate Setting   1
                Endpoint 0x86 - Bulk Input
                    Address:   0x86  (IN)
                Endpoint 0x04 - Bulk Output
                    Address:   0x04  (OUT)
            Interface #6 - HID
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                        Length (and contents):   634
                            Raw Descriptor (hex)    0000: 05 20 09 41 A1 01 85 01  05 20 0A 16 03 15 01 25
                            Raw Descriptor (hex)    0010: 02 75 08 95 01 A1 02 0A  40 08 0A 41 08 B1 00 C0
                            Raw Descriptor (hex)    0020: 0A 0E 03 16 C8 00 26 10  27 75 10 95 01 B1 02 0A
                            Raw Descriptor (hex)    0030: 09 03 15 01 25 01 75 08  95 01 A1 02 0A 30 08 B1
                            Raw Descriptor (hex)    0040: 00 C0 0A 19 03 15 01 25  04 75 08 95 01 A1 02 0A
                            Raw Descriptor (hex)    0050: 50 08 0A 51 08 0A 52 08  0A 55 08 B1 00 C0 0A 18
                            Raw Descriptor (hex)    0060: 03 16 01 80 26 FF 7F 75  10 95 0A 55 00 B1 02 0A
                            Raw Descriptor (hex)    0070: 01 02 15 01 25 07 75 08  95 01 A1 02 0A 00 08 0A
                            Raw Descriptor (hex)    0080: 01 08 0A 02 08 0A 03 08  0A 04 08 0A 05 08 0A 06
                            Raw Descriptor (hex)    0090: 08 B1 00 C0 0A D1 14 15  00 26 88 13 75 20 95 01
                            Raw Descriptor (hex)    00a0: B1 02 0A 04 03 75 10 95  01 B1 02 05 20 0A 02 02
                            Raw Descriptor (hex)    00b0: 15 01 25 01 75 08 95 01  A1 02 0A 11 08 0A 13 08
                            Raw Descriptor (hex)    00c0: 81 00 C0 05 20 0A D1 04  15 00 26 88 13 75 20 95
                            Raw Descriptor (hex)    00d0: 01 81 02 C0 06 12 FF 09  01 A1 01 85 04 09 10 15
                            Raw Descriptor (hex)    00e0: 01 25 02 35 01 45 02 75  08 95 01 B1 02 09 11 15
                            Raw Descriptor (hex)    00f0: 00 27 80 84 1E 00 35 00  46 D0 07 75 20 95 01 B1
                            Raw Descriptor (hex)    0100: 02 09 12 15 00 26 E8 03  35 00 45 01 75 20 95 01
                            Raw Descriptor (hex)    0110: B1 02 09 13 15 00 27 A0  86 01 00 35 00 45 64 75
                            Raw Descriptor (hex)    0120: 20 95 01 B1 02 85 02 09  20 15 01 25 04 35 01 45
                            Raw Descriptor (hex)    0130: 04 75 08 95 01 B1 02 09  21 15 01 25 04 35 01 45
                            Raw Descriptor (hex)    0140: 04 75 08 95 01 B1 02 09  22 15 00 27 A0 86 01 00
                            Raw Descriptor (hex)    0150: 35 00 45 64 75 20 95 01  B1 02 09 23 15 00 26 E8
                            Raw Descriptor (hex)    0160: 03 35 00 45 01 75 20 95  01 B1 02 85 03 09 31 15
                            Raw Descriptor (hex)    0170: 01 25 02 35 01 45 02 75  08 95 01 B1 02 09 32 15
                            Raw Descriptor (hex)    0180: 00 27 A0 86 01 00 35 00  45 64 75 20 95 01 B1 02
                            Raw Descriptor (hex)    0190: 09 50 15 01 25 01 35 01  45 01 75 08 95 01 B1 02
                            Raw Descriptor (hex)    01a0: 09 51 15 00 27 FF FF FF  FF 35 00 47 FF FF FF FF
                            Raw Descriptor (hex)    01b0: 75 40 95 01 B1 02 85 05  09 40 15 01 25 01 35 01
                            Raw Descriptor (hex)    01c0: 45 01 75 10 95 01 B1 02  09 41 15 01 25 02 35 01
                            Raw Descriptor (hex)    01d0: 45 02 75 08 95 01 B1 02  09 42 15 00 27 80 84 1E
                            Raw Descriptor (hex)    01e0: 00 35 00 46 D0 07 75 20  95 01 B1 02 09 43 75 20
                            Raw Descriptor (hex)    01f0: 95 01 B1 02 09 44 15 00  25 0A 35 01 45 0A 75 10
                            Raw Descriptor (hex)    0200: 95 01 B1 02 09 45 15 01  25 0B 35 01 45 0B 75 10
                            Raw Descriptor (hex)    0210: 95 01 B1 02 09 46 15 00  27 A0 86 01 00 35 00 45
                            Raw Descriptor (hex)    0220: 64 75 20 95 01 B1 02 09  47 15 00 27 00 E1 F5 05
                            Raw Descriptor (hex)    0230: 35 00 47 A0 86 01 00 75  20 95 0C B1 02 09 48 15
                            Raw Descriptor (hex)    0240: 00 27 80 84 1E 00 35 00  46 D0 07 75 20 95 0C B1
                            Raw Descriptor (hex)    0250: 02 85 06 09 31 15 01 25  02 35 01 45 02 75 08 95
                            Raw Descriptor (hex)    0260: 01 81 02 09 51 15 00 27  FF FF FF FF 35 00 47 FF
                            Raw Descriptor (hex)    0270: FF FF FF 75 40 95 01 81  02 C0
                              Usage Page    (32)
                              Usage 65 (0x41)
                                    ReportID................    (1)
                                    Usage Page    (32)
                                    Usage 790 (0x316)
                                    Logical Minimum.........    (1)
                                    Logical Maximum.........    (2)
                                          Usage 2112 (0x840)
                                          Usage 2113 (0x841)
                                          Feature.................   (Data, Array, Absolute, No Wrap, Linear, Preferred State, No Null Position, Nonvolatile, Bitfield)
                                        End Collection
                                    Usage 782 (0x30e)
                                    Logical Minimum.........    (200)
                                    Logical Maximum.........    (10000)
                                    Feature.................   (Data, Variable, Absolute, No Wrap, Linear, Preferred State, No Null Position, Nonvolatile, Bitfield)
                                    Usage 777 (0x309)
                                          Usage 2096 (0x830)
                                        End Collection
                                    Usage 793 (0x319)
                                    Logical Maximum.........    (4)
                                          Usage 2128 (0x850)
                                          Usage 2129 (0x851)
                                          Usage 2130 (0x852)
                                          Usage 2133 (0x855)
                                        End Collection
                                    Usage 792 (0x318)
                                    Logical Minimum.........    (-32767)
                                    Report Count............    (10)
                                    Unit Exponent...........    (0)
                                    Usage 513 (0x201)
                                    Logical Maximum.........    (7)
                                          Usage 2048 (0x800)
                                          Usage 2049 (0x801)
                                          Usage 2050 (0x802)
                                          Usage 2051 (0x803)
                                          Usage 2052 (0x804)
                                          Usage 2053 (0x805)
                                          Usage 2054 (0x806)
                                        End Collection
                                    Usage 5329 (0x14d1)
                                    Logical Maximum.........    (5000)
                                    Usage 772 (0x304)
                                    Usage Page    (32)
                                    Usage 514 (0x202)
                                          Usage 2065 (0x811)
                                          Usage 2067 (0x813)
                                          Input...................   (Data, Array, Absolute)
                                        End Collection
                                    Usage Page    (32)
                                    Usage 1233 (0x4d1)
                                  End Collection
                              Usage Page    (Vendor defined 18)
                              Usage 1 (0x1)
                                    ReportID................    (4)
                                    Usage 16 (0x10)
                                    Physical Minimum........    (1)
                                    Physical Maximum........    (2)
                                    Usage 17 (0x11)
                                    Logical Maximum.........    (2000000)
                                    Physical Minimum........    (0)
                                    Physical Maximum........    (2000)
                                    Usage 18 (0x12)
                                    Logical Maximum.........    (1000)
                                    Physical Maximum........    (1)
                                    Usage 19 (0x13)
                                    Logical Maximum.........    (100000)
                                    Physical Maximum........    (100)
                                    ReportID................    (2)
                                    Usage 32 (0x20)
                                    Physical Maximum........    (4)
                                    Usage 33 (0x21)
                                    Usage 34 (0x22)
                                    Usage 35 (0x23)
                                    ReportID................    (3)
                                    Usage 49 (0x31)
                                    Usage 50 (0x32)
                                    Usage 80 (0x50)
                                    Usage 81 (0x51)
                                    Logical Maximum.........    (4294967295)
                                    Physical Maximum........    (4294967295)
                                    ReportID................    (5)
                                    Usage 64 (0x40)
                                    Usage 65 (0x41)
                                    Usage 66 (0x42)
                                    Usage 67 (0x43)
                                    Usage 68 (0x44)
                                    Logical Maximum.........    (10)
                                    Physical Maximum........    (10)
                                    Usage 69 (0x45)
                                    Logical Maximum.........    (11)
                                    Physical Maximum........    (11)
                                    Usage 70 (0x46)
                                    Usage 71 (0x47)
                                    Logical Maximum.........    (100000000)
                                    Physical Maximum........    (100000)
                                    Report Count............    (12)
                                    Usage 72 (0x48)
                                    ReportID................    (6)
                                    Usage 49 (0x31)
                                    Usage 81 (0x51)
                                  End Collection
                Endpoint 0x87 - Interrupt Input
                    Address:   0x87  (IN)
            Interface #7 - Vendor-specific ..............................................   "Apple USB SEP Interface"
                Alternate Setting   0
                Interface Class:   255   (Vendor-specific)
                Interface Subclass;   249   (Vendor-specific)
                Interface Protocol:   17
                Endpoint 0x05 - Bulk Output
                    Address:   0x05  (OUT)
                Endpoint 0x88 - Bulk Input
                    Address:   0x88  (IN)
        Configuration Descriptor: .......................................   "Default iBridge Interfaces(Recovery)"
            Length (and contents):   539
                Raw Descriptor (hex)    0000: 09 02 1B 02 06 03 07 E0  00 08 0B 00 02 0E 01 00
                Raw Descriptor (hex)    0010: 08 09 04 00 00 00 0E 01  00 0D 0D 24 01 50 01 36
                Raw Descriptor (hex)    01d0: 85 03 00 04 07 09 04 04  00 00 02 0D 00 0B 05 24
                Raw Descriptor (hex)    01e0: 00 10 01 05 24 06 04 05  0D 24 0F 0A 00 00 00 00
                Raw Descriptor (hex)    01f0: EA 05 00 00 00 06 24 1A  00 01 33 09 04 05 00 00
                Raw Descriptor (hex)    0200: 0A 00 01 0C 09 04 05 01  02 0A 00 01 0C 07 05 86
                Raw Descriptor (hex)    0210: 02 00 02 00 07 05 02 02  00 02 00
            Number of Interfaces:   6
            Configuration Value:   3
            MaxPower:   0 mA
                First Interface   0
                Interface Count   2
                Function String   8 "FaceTime HD Camera (Build-in)"
                Alternate Setting   0
                    Terminal ID   1
                    Terminal ID:   2
                    Unit ID:   3
                    Source ID:   1
                           Brightness
                           Contrast
                           Hue
                           Saturation
                           Sharpness
                Alternate Setting   0
                    bNumFormats:   1
                    bTerminalLink:   2
                    bControlSize:   0x1
                    bFormatIndex:   0x1
                    bmFlags   (0x0)
                    bAspectRatioX:   0x0
                    bAspectRatioY:   0x0
                        Fields per frame   1
                        Field 1 first   No
                    bFrameIndex:   1
                    bFrameIndex:   2
                    wWidth:   0x280 (640)
                    Address:   0x81  (IN)
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                    Address:   0x83  (IN)
            Interface #3 - HID
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                    Address:   0x85  (IN)
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   1
                    Address:   0x86  (IN)
                    Address:   0x02  (OUT)
        Device Qualifier Descriptor
            Device Class   239   (Miscellaneous)
            Device Subclass   2   (Common Class)
            Device Protocol   1   (Interface Association)
            bReserved:   0
    second half to follow...
        Other Speed Configuration Descriptor: .......................................   "Default iBridge Interfaces"
                Raw Descriptor (hex)    0000: 09 07 D5 01 04 01 03 E0  00 08 0B 00 02 0E 01 00
                Raw Descriptor (hex)    01a0: 40 00 00 09 04 02 00 01  03 01 01 00 09 21 01 01
                Raw Descriptor (hex)    01b0: 00 01 22 53 00 07 05 83  03 40 00 08 09 04 03 00
                Raw Descriptor (hex)    01d0: 85 03 40 00 08
            MaxPower:   0 mA
                First Interface   0
                Interface Count   2
                Alternate Setting   0
                    Terminal ID   1
                    Terminal ID:   2
                    Unit ID:   3
                    Source ID:   1
                           Brightness
                           Contrast
                           Hue
                           Saturation
                           Sharpness
                Alternate Setting   0
                    bNumFormats:   1
                    bTerminalLink:   2
                    bControlSize:   0x1
                    bFormatIndex:   0x1
                    bmFlags   (0x0)
                    bAspectRatioX:   0x0
                    bAspectRatioY:   0x0
                        Fields per frame   1
                        Field 1 first   No
                    bFrameIndex:   1
                    bFrameIndex:   2
                    wWidth:   0x280 (640)
                    Address:   0x81  (IN)
                    Max Packet Size:   64
                    Polling Interval:   0 ms
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                    Address:   0x83  (IN)
                    Max Packet Size:   64
                    Polling Interval:   8 ms
            Interface #3 - HID
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                    Address:   0x85  (IN)
                    Max Packet Size:   64
        Other Speed Configuration Descriptor: .......................................   "Default iBridge Interfaces(OS X)"
                Raw Descriptor (hex)    0000: 09 07 96 02 08 02 05 E0  00 08 0B 00 02 0E 01 00
                Raw Descriptor (hex)    01e0: 96 98 00 06 24 0D 01 01  04 07 05 81 02 40 00 00
                Raw Descriptor (hex)    0200: 0E 03 07 05 83 03 40 00  02 09 04 03 00 02 10 00
                Raw Descriptor (hex)    0210: 00 00 07 05 85 02 40 00  00 07 05 02 02 40 00 00
                Raw Descriptor (hex)    0250: 04 05 01 02 0A 00 01 0C  07 05 86 02 40 00 00 07
                Raw Descriptor (hex)    0260: 05 04 02 40 00 00 09 04  06 00 01 03 00 01 00 09
                Raw Descriptor (hex)    0270: 21 01 01 00 01 22 7A 02  07 05 87 03 40 00 08 09
                Raw Descriptor (hex)    0280: 04 07 00 02 FF F9 11 09  07 05 05 02 40 00 00 07
                Raw Descriptor (hex)    0290: 05 88 02 40 00 00
            MaxPower:   0 mA
                First Interface   0
                Interface Count   2
                Alternate Setting   0
                    Terminal ID   1
                    Terminal ID:   2
                    Unit ID:   3
                    Source ID:   1
                           Brightness
                           Contrast
                           Hue
                           Saturation
                           Sharpness
                Alternate Setting   0
                    bNumFormats:   1
                    bTerminalLink:   2
                    bControlSize:   0x1
                    Address:   0x81  (IN)
                    Max Packet Size:   64
            Interface #2 - HID
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                        Length (interface does not currently exist):   782
                    Address:   0x83  (IN)
                    Max Packet Size:   64
                    Polling Interval:   2 ms
                Alternate Setting   0
                    Address:   0x85  (IN)
                    Max Packet Size:   64
                    Address:   0x02  (OUT)
                    Max Packet Size:   64
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   1
                    Address:   0x86  (IN)
                    Max Packet Size:   64
                    Address:   0x04  (OUT)
                    Max Packet Size:   64
            Interface #6 - HID
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                    Address:   0x87  (IN)
                    Max Packet Size:   64
                Alternate Setting   0
                    Address:   0x05  (OUT)
                    Max Packet Size:   64
                    Address:   0x88  (IN)
                    Max Packet Size:   64
        Other Speed Configuration Descriptor: .......................................   "Default iBridge Interfaces(Recovery)"
                Raw Descriptor (hex)    0000: 09 07 1B 02 06 03 07 E0  00 08 0B 00 02 0E 01 00
                Raw Descriptor (hex)    01d0: 85 03 40 00 08 09 04 04  00 00 02 0D 00 0B 05 24
                Raw Descriptor (hex)    0210: 02 40 00 00 07 05 02 02  40 00 00
            MaxPower:   0 mA
                First Interface   0
                Interface Count   2
                Alternate Setting   0
                    Terminal ID   1
                    Terminal ID:   2
                    Unit ID:   3
                    Source ID:   1
                           Brightness
                           Contrast
                           Hue
                           Saturation
                           Sharpness
                Alternate Setting   0
                    bNumFormats:   1
                    bTerminalLink:   2
                    bControlSize:   0x1
                    bFormatIndex:   0x1
                    bmFlags   (0x0)
                    bAspectRatioX:   0x0
                    bAspectRatioY:   0x0
                        Fields per frame   1
                        Field 1 first   No
                    bFrameIndex:   1
                    bFrameIndex:   2
                    wWidth:   0x280 (640)
                    Address:   0x81  (IN)
                    Max Packet Size:   64
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                    Address:   0x83  (IN)
                    Max Packet Size:   64
            Interface #3 - HID
                Alternate Setting   0
                HID Descriptor
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                    Address:   0x85  (IN)
                    Max Packet Size:   64
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   1
                    Address:   0x86  (IN)
                    Max Packet Size:   64
                    Address:   0x02  (OUT)
                    Max Packet Size:   64
    High Speed device @ 33 (0x14300000): .............................................   Hub device: "USB 2.0 Hub [MTT]"
        Port Information:   0x001a
               Not Captive
               External Device
               Connected
               Enabled
            Total Endpoints for Configuration 1 (current):   2
        Device Descriptor
            Device Subclass:   0
            Device Protocol:   2   (High Speed Multiple Transaction Translators)
            Device VendorID/ProductID:   0x1A40/0x0201   (TERMINUS TECHNOLOGY INC.)
            Device Version Number:   0x0100
            Product String:   1 "USB 2.0 Hub [MTT]"
            Length (and contents):   41
                Raw Descriptor (hex)    0000: 09 02 29 00 01 01 00 E0  32 09 04 00 00 01 09 00
                Raw Descriptor (hex)    0010: 01 00 07 05 81 03 01 00  0C 09 04 00 01 01 09 00
                Raw Descriptor (hex)    0020: 02 00 07 05 81 03 01 00  0C
            Number of Interfaces:   1
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                Interface Class:   9   (Hub)
                Interface Protocol:   1   (Multi TT Hub configured as a Single TT Hub)
                Endpoint 0x81 - Interrupt Input
                    Address:   0x81  (IN)
                    Max Packet Size:   0x0001  (1 x 1  transactions opportunities per microframe)
                    Polling Interval:   12 (2048 microframes (256 msecs) )
            Interface #0 - Hub (#1)
                Alternate Setting   1
                Interface Protocol:   2   (Multi TT Hub)
                    Address:   0x81  (IN)
        Hub Descriptor
                Raw Descriptor (hex)   0000: 09 29 07 88 00 32 64 00  FF
            Number of Ports:   0x07
            Hub Characteristics:   0x88 (Gang switched standalone hub with individual port overcurrent protection requiring 8 FS bit times and having port indicators)
            PowerOnToGood time:   100 ms
            Controller current:   100 mA
            Device Removable (byte):   0x0
            Port Power Control Mask (byte):   0xff
            Device Class   9   (Hub)
            Device Subclass   0
            Device Protocol   0   (Full/Low Speed)
            bReserved:   0
            Length (and contents):   25
                Raw Descriptor (hex)    0000: 09 07 19 00 01 01 00 E0  32 09 04 00 00 01 09 00
                Raw Descriptor (hex)    0010: 00 00 07 05 81 03 01 00  FF
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                    Address:   0x81  (IN)
                    Max Packet Size:   1
                    Polling Interval:   255 ms
    High Speed device @ 34 (0x14320000): .............................................   Hub device: "USB2.0 Hub"
        Port Information:   0x0018
               Not Captive
               External Device
               Connected
               Enabled
        Device Descriptor
            Descriptor Version Number:   0x0210
            Device Subclass:   0
            Device Protocol:   1   (High Speed Single Transaction Translator)
            Device VendorID/ProductID:   0x05E3/0x0608   (Genesys Logic, Inc.)
            Device Version Number:   0x6052
            Product String:   1 "USB2.0 Hub"
                Raw Descriptor (hex)    0000: 09 02 19 00 01 01 00 E0  32 09 04 00 00 01 09 00
                Raw Descriptor (hex)    0010: 00 00 07 05 81 03 01 00  0C
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                    Address:   0x81  (IN)
        Hub Descriptor
                Raw Descriptor (hex)   0000: 09 29 04 ED 00 32 64 10  FF
            Number of Ports:   0x04
            Hub Characteristics:   0xed (Individually switched compound hub with individual port overcurrent protection)
            Device Removable (byte):   0x10
            Device Subclass   0
            bReserved:   0
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                    Address:   0x81  (IN)
                    Max Packet Size:   1
    Full Speed device @ 35 (0x14370000): .............................................   Composite device: "Virus TI"
               Not Captive
               External Device
               Connected
               Enabled
            Total Endpoints for Configuration 1 (current):   7
        Device Descriptor
            Descriptor Version Number:   0x0110
            Device Class:   0   (Composite)
            Device Subclass:   0
            Device Protocol:   0
            Device MaxPacketSize:   16
            Device VendorID/ProductID:   0x133E/0x0815   (unknown vendor)
            Manufacturer String:   1 "Access Music"
            Product String:   2 "Virus TI"
            Length (and contents):   234
                Raw Descriptor (hex)    0000: 09 02 EA 00 05 01 00 40  00 09 04 00 00 00 01 01
                Raw Descriptor (hex)    0010: 00 00 0A 24 01 00 01 34  00 02 01 02 0C 24 02 01
                Raw Descriptor (hex)    0020: 01 01 00 02 03 00 00 00  09 24 03 03 01 03 00 01
                Raw Descriptor (hex)    0030: 00 0C 24 02 04 03 06 00  02 00 00 00 00 09 24 03
                Raw Descriptor (hex)    0040: 07 01 01 00 04 00 09 04  01 00 00 01 02 00 00 09
                Raw Descriptor (hex)    0050: 04 01 01 01 01 02 00 00  07 24 01 01 01 01 00 0E
                Raw Descriptor (hex)    0060: 24 02 01 02 02 10 02 44  AC 00 80 BB 00 09 05 01
                Raw Descriptor (hex)    0070: 09 C8 00 01 00 00 07 25  01 01 02 00 02 09 04 02
                Raw Descriptor (hex)    0080: 00 00 01 02 00 00 09 04  02 01 01 01 02 00 00 07
                Raw Descriptor (hex)    0090: 24 01 07 00 01 00 0E 24  02 01 06 02 10 02 44 AC
                Raw Descriptor (hex)    00a0: 00 80 BB 00 09 05 82 0D  50 02 01 00 00 07 25 01
                Raw Descriptor (hex)    00b0: 01 02 00 00 09 04 03 00  02 FF 00 00 00 09 05 05
                Raw Descriptor (hex)    00c0: 03 08 00 01 00 00 09 05  85 03 10 00 01 00 00 09
                Raw Descriptor (hex)    00d0: 04 04 00 02 FF 00 00 00  09 05 06 03 20 00 01 00
                Raw Descriptor (hex)    00e0: 00 09 05 86 03 20 00 01  00 00
            Number of Interfaces:   5
            Attributes:   0x40 (self-powered)
            MaxPower:   0 mA
            Interface #0 - Audio/Control
                Alternate Setting   0
                Interface Class:   1   (Audio)
                Audio Control Class Specific Header
                    Descriptor Version Number:   01.00
                    Class Specific Size:   52
                    Number of Audio Interfaces:   2
                    Audio Interface Number:   1
                    Audio Interface Number:   2
                    Dump Contents (hex):   0A 24 01 00 01 34 00 02 01 02
                Audio Class Specific Input Terminal
                    Terminal ID:   1
                    Input Terminal Type:   0x101 (USB streaming)
                    OutTerminal ID:   0 [NONE]
                    Number of Channels:   2
                    Spatial config of channels:   0000000000000011
                                      ^.  Left Front
                                     ^..  Right Front
                    String index for first logical channel:   0
                    Terminal Name String Index:   0 [NONE]
                Audio Class Specific Output Terminal
                    Terminal ID:   3
                    Output Terminal Type:   0x301 (Speaker)
                    InTerminal ID:   0 [NONE]
                    Source ID:   1
                    Terminal ID:   4
                    Input Terminal Type:   0x603 (Line connector)
                    Spatial config of channels:   0000000000000000
                    Terminal ID:   7
                    Output Terminal Type:   0x101 (USB Isochronous Stream)
                    Source ID:   4
            Interface #1 - Audio/Streaming
                Alternate Setting   0
            Interface #1 - Audio/Streaming (#1)
                Alternate Setting   1
                    Audio Stream General
                        Endpoint Terminal ID:   1
                        Delay:   1 frames
                        Format Tag:   0x0001 (PCM)
                Audio Class Specific Audio Data Format
                    Audio Stream Format Type Desc.
                        Format Type:   1 PCM
                        Number Of Channels:   2 STEREO
                        Sub Frame Size:   2
                        Bit Resolution:   16
                        Sample Frequency Type:   0x02 (Discrete)
                        Sample Frequency:   44100 Hz
                        Sample Frequency:   48000 Hz
                Endpoint 0x01 - Isochronous Output
                    Address:   0x01  (OUT)
                    Attributes:   0x09  (Isochronous adaptive data endpoint)
                    Max Packet Size:   200
                    Polling Interval:   1 ms
                Class-Specific AS Audio EndPoint
                    Attributes:   0x01  Sample Frequency,
                    bLockDelayUnits:   0x02  (Decoded PCM Samples)
                    wLockDelay:   512 Decoded PCM Samples
            Interface #2 - Audio/Streaming
                Alternate Setting   0
            Interface #2 - Audio/Streaming (#1)
                Alternate Setting   1
                        Endpoint Terminal ID:   7
                        Delay:   0 frames     (Delay NOT SUPPORTED)
                        Format Type:   1 PCM
                        Number Of Channels:   6 MULTICHANNEL
                        Sub Frame Size:   2
                        Bit Resolution:   16
                Endpoint 0x82 - Isochronous Input
                    Address:   0x82  (IN)
                    Attributes:   0x0D  (Isochronous synchronous data endpoint)
                    Max Packet Size:   592
                    wLockDelay:   0 Decoded PCM Samples
            Interface #3 - Vendor-specific
                Alternate Setting   0
                Interface Subclass;   0   (Vendor-specific)
                Endpoint 0x05 - Interrupt Output
                    Address:   0x05  (OUT)
                    Max Packet Size:   8
                    Address:   0x85  (IN)
                    Max Packet Size:   16
            Interface #4 - Vendor-specific
                Alternate Setting   0
                Endpoint 0x06 - Interrupt Output
                    Address:   0x06  (OUT)
                    Max Packet Size:   32
                Endpoint 0x86 - Interrupt Input
                    Address:   0x86  (IN)
                    Max Packet Size:   32
    High Speed device @ 37 (0x14340000): .............................................   Vendor-specific device: "TR-8S"
               Not Captive
               External Device
               Connected
               Enabled
            Total Endpoints for Configuration 1 (current):   5
        Device Descriptor
            Device Class:   255   (Vendor-specific)
            Device Subclass:   0   (Vendor-specific)
            Device Protocol:   255
            Device VendorID/ProductID:   0x0582/0x020A   (Roland Corporation)
            Manufacturer String:   1 "Roland"
            Product String:   2 "TR-8S"
            Length (and contents):   282
                Raw Descriptor (hex)    0000: 09 02 1A 01 04 01 00 C0  01 09 04 00 00 00 FF FF
                Raw Descriptor (hex)    0010: 00 00 09 04 01 00 00 FF  02 02 00 06 24 F1 01 00
                Raw Descriptor (hex)    0020: 00 09 04 01 01 01 FF 02  02 00 07 24 01 01 00 03
                Raw Descriptor (hex)    0030: 00 0B 24 02 01 08 04 20  01 00 77 01 06 24 F1 04
                Raw Descriptor (hex)    0040: 5E 00 07 05 0D 05 C0 01  01 07 25 01 00 00 00 00
                Raw Descriptor (hex)    0050: 09 04 01 02 01 FF 02 02  00 07 24 01 01 00 03 00
                Raw Descriptor (hex)    0060: 0B 24 02 01 02 04 20 01  00 77 01 06 24 F1 04 5E
                Raw Descriptor (hex)    0070: 00 07 05 0D 05 70 00 01  07 25 01 00 00 00 00 09
                Raw Descriptor (hex)    0080: 04 02 00 00 FF 02 01 00  09 04 02 01 01 FF 02 01
                Raw Descriptor (hex)    0090: 00 07 24 01 07 00 03 00  0B 24 02 01 0E 04 20 01
                Raw Descriptor (hex)    00a0: 00 77 01 06 24 F1 04 5E  00 07 05 8E 25 10 03 01
                Raw Descriptor (hex)    00b0: 07 25 01 00 00 00 00 09  04 02 02 01 FF 02 01 00
                Raw Descriptor (hex)    00c0: 07 24 01 07 00 03 00 0B  24 02 01 02 04 20 01 00
                Raw Descriptor (hex)    00d0: 77 01 06 24 F1 04 5E 00  07 05 8E 25 70 00 01 07
                Raw Descriptor (hex)    00e0: 25 01 00 00 00 00 09 04  03 00 02 FF 03 00 00 06
                Raw Descriptor (hex)    00f0: 24 F1 02 02 02 07 05 03  02 00 02 01 07 05 84 02
                Raw Descriptor (hex)    0100: 00 02 00 09 04 03 01 02  FF 03 00 00 07 05 03 03
                Raw Descriptor (hex)    0110: 00 02 04 07 05 85 03 00  02 04
            Attributes:   0xC0 (self-powered)
            MaxPower:   2 mA
            Interface #0 - Vendor-specific
                Alternate Setting   0
                Interface Subclass;   255   (Vendor-specific)
            Interface #1 - Vendor-specific
                Alternate Setting   0
                Interface Subclass;   2   (Vendor-specific)
            Raw Descriptor (hex)   0000: 06 24 F1 01 00 00
            Interface #1 - Vendor-specific (#1)
                Alternate Setting   1
            Raw Descriptor (hex)   0000: 07 24 01 01 00 03 00
            Raw Descriptor (hex)   0000: 0B 24 02 01 08 04 20 01  00 77 01
            Raw Descriptor (hex)   0000: 06 24 F1 04 5E 00
                Endpoint 0x0D - Isochronous Output
                    Address:   0x0D  (OUT)
                    Attributes:   0x05  (Isochronous asynchronous data endpoint)
                    Max Packet Size:   0x01c0  (448 x 1  transactions opportunities per microframe)
                    Polling Interval:   1 (1 microframe (125 microsecs) )
            Raw Descriptor (hex)   0000: 07 25 01 00 00 00 00
            Interface #1 - Vendor-specific (#2)
                Alternate Setting   2
            Raw Descriptor (hex)   0000: 0B 24 02 01 02 04 20 01  00 77 01
                    Address:   0x0D  (OUT)
                    Max Packet Size:   0x0070  (112 x 1  transactions opportunities per microframe)
            Interface #2 - Vendor-specific
                Alternate Setting   0
            Interface #2 - Vendor-specific (#1)
                Alternate Setting   1
            Raw Descriptor (hex)   0000: 07 24 01 07 00 03 00
            Raw Descriptor (hex)   0000: 0B 24 02 01 0E 04 20 01  00 77 01
                Endpoint 0x8E - Isochronous Input
                    Address:   0x8E  (IN)
                    Attributes:   0x25  (Isochronous asynchronous implicit feedback data endpoint)
                    Max Packet Size:   0x0310  (784 x 1  transactions opportunities per microframe)
            Interface #2 - Vendor-specific (#2)
                Alternate Setting   2
                    Address:   0x8E  (IN)
                Alternate Setting   0
                Interface Subclass;   3   (Vendor-specific)
            Raw Descriptor (hex)   0000: 06 24 F1 02 02 02
                Endpoint 0x03 - Bulk Output
                    Address:   0x03  (OUT)
                    Polling Interval:   1 ( At most 1 NAK every 1 microframe(s) )
                Endpoint 0x84 - Bulk Input
                    Address:   0x84  (IN)
            Interface #3 - Vendor-specific (#1)
                Alternate Setting   1
                Endpoint 0x03 - Interrupt Output
                    Address:   0x03  (OUT)
                    Max Packet Size:   0x0200  (512 x 1  transactions opportunities per microframe)
                    Polling Interval:   4 (8 microframes (1 msecs) )
                    Address:   0x85  (IN)
            Device Class   255   (Vendor-specific)
            Device Subclass   0   (Vendor-specific)
            Device Protocol   255
            bReserved:   0
            Length (and contents):   45
                Raw Descriptor (hex)    0000: 09 07 2D 00 04 01 00 C0  01 09 04 00 00 00 FF FF
                Raw Descriptor (hex)    0010: 00 00 09 04 01 00 00 FF  FF 00 00 09 04 02 00 00
                Raw Descriptor (hex)    0020: FF FF 00 00 09 04 03 00  00 FF FF 00 00
            MaxPower:   2 mA
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   0
    High Speed device @ 38 (0x14324000): .............................................   Hub device: "USB2.0 Hub"
        Port Information:   0x0019
               Captive
               External Device
               Connected
               Enabled
        Device Descriptor
            Device Subclass:   0
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                    Address:   0x81  (IN)
        Hub Descriptor
                Raw Descriptor (hex)   0000: 09 29 04 E9 00 32 64 00  FF
            Hub Characteristics:   0xe9 (Individually switched standalone hub with individual port overcurrent protection)
            Device Subclass   0
            bReserved:   0
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                    Address:   0x81  (IN)
                    Max Packet Size:   1
    Full Speed device @ 39 (0x14322000): .............................................   Composite device: "AltoidCV"
               Not Captive
               External Device
               Connected
               Enabled
        Device Descriptor
            Device Subclass:   0
            Device Protocol:   0
            Device VendorID/ProductID:   0x16C0/0x0485   (unknown vendor)
            Device Version Number:   0x0275
            Manufacturer String:   1 "Teensyduino"
            Product String:   2 "AltoidCV"
            Serial Number String:   3 "2487200"
            Length (and contents):   115
                Raw Descriptor (hex)    0000: 09 02 73 00 02 01 00 C0  32 09 04 00 00 02 01 03
                Raw Descriptor (hex)    0010: 00 00 07 24 01 00 01 25  00 06 24 02 01 01 00 06
                Raw Descriptor (hex)    0020: 24 02 02 02 00 09 24 03  01 03 01 02 01 00 09 24
                Raw Descriptor (hex)    0030: 03 02 04 01 01 01 00 09  05 04 02 40 00 00 00 00
                Raw Descriptor (hex)    0040: 05 25 01 01 01 09 05 83  02 40 00 00 00 00 05 25
                Raw Descriptor (hex)    0050: 01 01 03 09 04 01 00 02  03 00 00 00 09 21 11 01
                Raw Descriptor (hex)    0060: 00 01 22 21 00 07 05 81  03 40 00 01 07 05 02 03
                Raw Descriptor (hex)    0070: 20 00 02
            Number of Interfaces:   2
            MaxPower:   100 mA
            Interface #0 - Audio/Streaming
                Alternate Setting   0
                Interface Subclass;   3   (Streaming)
                Uknown Interface SubClass Type
                    Address:   0x04  (OUT)
                    Max Packet Size:   64
                    bLockDelayUnits:   0x01  (Milliseconds)
                    wLockDelay:   1289 ms
                Endpoint 0x83 - Bulk Input
                    Address:   0x83  (IN)
                    Max Packet Size:   64
                    bLockDelayUnits:   0x03  (RESERVED)
                    wLockDelay:   1033
            Interface #1 - HID
                Alternate Setting   0
                HID Descriptor
                    Descriptor Version Number:   0x0111
                    Country Code:   0
                    Descriptor Count:   1
                    Descriptor 1
                        Length (and contents):   33
                            Raw Descriptor (hex)    0000: 06 C9 FF 09 04 A1 5C 75  08 15 00 26 FF 00 95 40
                            Raw Descriptor (hex)    0010: 09 75 81 02 95 20 09 76  91 02 95 04 09 76 B1 02
                            Raw Descriptor (hex)    0020: C0
                              Usage Page    (Vendor defined 201)
                              Usage 4 (0x4)
                                  Collection (Collection )
                                    Logical Maximum.........    (255)
                                    Report Count............    (64)
                                    Usage 117 (0x75)
                                    Report Count............    (32)
                                    Usage 118 (0x76)
                                    Output..................   (Data, Variable, Absolute, No Wrap, Linear, Preferred State, No Null Position, Nonvolatile, Bitfield)
                                    Report Count............    (4)
                                    Usage 118 (0x76)
                                  End Collection
                    Address:   0x81  (IN)
                    Max Packet Size:   64
                Endpoint 0x02 - Interrupt Output
                    Address:   0x02  (OUT)
                    Max Packet Size:   32
    Full Speed device @ 40 (0x14324300): .............................................   Composite device: "ReMOTE SL"
               Not Captive
               External Device
               Connected
               Enabled
            Total Endpoints for Configuration 1 (current):   3
        Device Descriptor
            Device Subclass:   0
            Device Protocol:   0
            Device VendorID/ProductID:   0x1235/0x0003   (unknown vendor)
            Device Version Number:   0x0301
            Manufacturer String:   1 "Novation DMS"
            Product String:   2 "ReMOTE SL"
            Length (and contents):   165
                Raw Descriptor (hex)    0000: 09 02 A5 00 02 01 00 80  F0 09 04 00 00 00 01 01
                Raw Descriptor (hex)    0010: 00 02 09 24 01 00 01 09  00 01 01 09 04 01 00 02
                Raw Descriptor (hex)    0020: 01 03 00 02 07 24 01 00  01 81 00 06 24 02 01 01
                Raw Descriptor (hex)    0030: 00 09 24 03 02 02 01 01  01 00 09 24 03 01 03 01
                Raw Descriptor (hex)    0040: 04 01 00 06 24 02 02 04  00 06 24 02 01 05 00 09
                Raw Descriptor (hex)    0050: 24 03 02 06 01 05 01 00  09 24 03 01 07 01 08 01
                Raw Descriptor (hex)    0060: 00 06 24 02 02 08 00 06  24 02 01 09 00 09 24 03
                Raw Descriptor (hex)    0070: 02 0A 01 09 01 00 09 24  03 01 0B 01 0C 01 00 06
                Raw Descriptor (hex)    0080: 24 02 02 0C 00 09 05 05  02 20 00 00 00 00 07 25
                Raw Descriptor (hex)    0090: 01 03 01 05 09 09 05 84  02 20 00 00 00 00 07 25
                Raw Descriptor (hex)    00a0: 01 03 03 07 0B
            Attributes:   0x80 (bus-powered)
            MaxPower:   480 mA
            Interface #0 - Audio/Control ..............................................   "ReMOTE SL"
                Alternate Setting   0
                    Class Specific Size:   9
                    Number of Audio Interfaces:   1
                    Dump Contents (hex):   09 24 01 00 01 09 00 01 01
            Interface #1 - Audio/Streaming ..............................................   "ReMOTE SL"
                Alternate Setting   0
                    Address:   0x05  (OUT)
                    Max Packet Size:   32
                    Attributes:   0x03  Sample Frequency, Pitch,
                    wLockDelay:   2309 ms
                    Address:   0x84  (IN)
                    Max Packet Size:   32
                    wLockDelay:   2823
    High Speed device @ 41 (0x14324100): .............................................   Vendor-specific device: "Boutiq"
               Not Captive
               External Device
               Connected
               Enabled
        Device Descriptor
            Device VendorID/ProductID:   0x0582/0x01B5   (Roland Corporation)
            Product String:   2 "Boutiq"
            Serial Number String:   3 "BQJX352DDA05465335330F0B1943"
            Length (and contents):   258
                Raw Descriptor (hex)    0000: 09 02 02 01 04 01 00 80  FA 09 04 00 00 00 FF FF
                Raw Descriptor (hex)    0020: 00 09 04 01 01 01 FF 02  02 00 07 24 01 01 00 01
                Raw Descriptor (hex)    0030: 00 0B 24 02 01 02 04 18  01 44 AC 00 07 05 0D 05
                Raw Descriptor (hex)    0040: 38 00 01 07 25 01 00 00  00 00 09 04 01 02 01 FF
                Raw Descriptor (hex)    0050: 02 02 00 07 24 01 01 00  01 00 0B 24 02 01 02 04
                Raw Descriptor (hex)    0060: 18 01 44 AC 00 07 05 0D  05 38 00 01 07 25 01 00
                Raw Descriptor (hex)    0070: 00 00 00 09 04 02 00 00  FF 02 01 00 09 04 02 01
                Raw Descriptor (hex)    0080: 01 FF 02 01 00 07 24 01  07 00 01 00 0B 24 02 01
                Raw Descriptor (hex)    0090: 02 04 18 01 44 AC 00 07  05 8E 25 38 00 01 07 25
                Raw Descriptor (hex)    00a0: 01 00 00 00 00 09 04 02  02 01 FF 02 01 00 07 24
                Raw Descriptor (hex)    00b0: 01 07 00 01 00 0B 24 02  01 02 04 18 01 44 AC 00
                Raw Descriptor (hex)    00c0: 07 05 8E 25 38 00 01 07  25 01 00 00 00 00 09 04
                Raw Descriptor (hex)    00d0: 03 00 02 FF 03 00 00 06  24 F1 02 01 01 07 05 03
                Raw Descriptor (hex)    00e0: 02 00 02 01 07 05 84 02  00 02 00 09 04 03 01 02
                Raw Descriptor (hex)    00f0: FF 03 00 00 07 05 03 03  00 02 04 07 05 85 03 00
                Raw Descriptor (hex)    0100: 02 04
            MaxPower:   500 mA
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   1
            Raw Descriptor (hex)   0000: 07 24 01 01 00 01 00
            Raw Descriptor (hex)   0000: 0B 24 02 01 02 04 18 01  44 AC 00
                    Address:   0x0D  (OUT)
                    Max Packet Size:   0x0038  (56 x 1  transactions opportunities per microframe)
                Alternate Setting   2
                    Address:   0x0D  (OUT)
                Alternate Setting   0
                Alternate Setting   1
            Raw Descriptor (hex)   0000: 07 24 01 07 00 01 00
                    Address:   0x8E  (IN)
                Alternate Setting   2
                    Address:   0x8E  (IN)
                Alternate Setting   0
            Raw Descriptor (hex)   0000: 06 24 F1 02 01 01
                    Address:   0x03  (OUT)
                    Address:   0x84  (IN)
                Alternate Setting   1
                    Address:   0x03  (OUT)
                    Address:   0x85  (IN)
            Device Protocol   255
            bReserved:   0
                Raw Descriptor (hex)    0000: 09 07 2D 00 04 01 00 80  FA 09 04 00 00 00 FF FF
            MaxPower:   500 mA
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   0
                Alternate Setting   0
    Full Speed device @ 42 (0x14360000): .............................................   Composite device: "OB-6"
               Not Captive
               External Device
               Connected
               Enabled
        Device Descriptor
            Device Subclass:   0
            Device Protocol:   0
            Device VendorID/ProductID:   0x20CB/0x0026   (unknown vendor)
            Device Version Number:   0x0001
            Manufacturer String:   1 "Dave Smith Instruments"
            Product String:   2 "OB-6"
            Length (and contents):   101
                Raw Descriptor (hex)    0000: 09 02 65 00 02 01 00 C0  00 09 04 00 00 00 01 01
                Raw Descriptor (hex)    0010: 00 00 09 24 01 00 01 09  00 01 01 09 04 01 00 02
                Raw Descriptor (hex)    0020: 01 03 00 00 07 24 01 00  01 41 00 06 24 02 01 01
                Raw Descriptor (hex)    0030: 00 06 24 02 02 02 00 09  24 03 01 03 01 02 01 00
                Raw Descriptor (hex)    0040: 09 24 03 02 04 01 01 01  00 09 05 01 02 40 00 00
                Raw Descriptor (hex)    0050: 00 00 05 25 01 01 01 09  05 81 02 40 00 00 00 00
                Raw Descriptor (hex)    0060: 05 25 01 01 03
            MaxPower:   0 mA
                Alternate Setting   0
                Alternate Setting   0
                Endpoint 0x01 - Bulk Output
                    Address:   0x01  (OUT)
                    Max Packet Size:   64
                    wLockDelay:   1289 ms
                    Address:   0x81  (IN)
                    Max Packet Size:   64
                    wLockDelay:   127
    High Speed device @ 44 (0x14350000): .............................................   Hub device: "USB 2.0 Hub"
               Not Captive
               External Device
               Connected
               Enabled
        Device Descriptor
            Device Subclass:   0
            Device VendorID/ProductID:   0x1A40/0x0101   (TERMINUS TECHNOLOGY INC.)
            Device Version Number:   0x0111
            Product String:   1 "USB 2.0 Hub"
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                    Address:   0x81  (IN)
        Hub Descriptor
                Raw Descriptor (hex)   0000: 09 29 04 00 00 32 64 00  FF
            Hub Characteristics:   0x0 (Gang switched standalone hub with global overcurrent protection requiring 8 FS bit times and  no port indicators)
            Device Subclass   0
            bReserved:   0
            MaxPower:   100 mA
            Interface #0 - Hub
                Alternate Setting   0
                    Address:   0x81  (IN)
                    Max Packet Size:   1
    Just as a followup, I now believe that the names of the ports/virtual cables in these devices come from manufacturer drivers. Turns out these aren't class compliant MIDI devices, so I don't believe that there will be a way to read the port names (or even access the MIDI data streams).
