Results 1 to 3 of 3
Thread: Dimensioned drawing for Teensy 3.6
    Jan 2019
    5
    I'm using Teensy 3.6 as a daughterboard for another PCB and a vendor "needs" a mechanical drawing of the "footprint." I'm 99% sure the Teensy is a 2x24 DIP with pitches of 0.1" and 0.6". Does such a drawing exist?
    It would be similar to the dimensions page for the Teensy 3.2 and Teensy LC. There's a similar question for the 3.5 on the forums, but only Eagle source files are posted (that includes 3.5 and 3.6), which doens't help me here.
    19,536
    Quote Originally Posted by pRabbit View Post
    Yep, that's correct.
    Nope, it never was drawn. After 3.6 was released, all the engineering hours went into various libraries, 4 bit SDIO in SD, then USBHost_t36, some brief work on Audio & Ethernet, and then T4.
    Maybe someday this and tons of other unfinished work will happen, but there's only so many hours in every day and a huge list of stuff people want!
    Jan 2019
    5
    In that case, let me know what you think of the attached. Thanks for your efforts...
    Attached Files Attached Files
    Last edited by pRabbit; 01-11-2019 at 07:41 PM. Reason: Minor changes to drawing format
