newbie don't want to fry it's Teensy 3.5 with SSR's
Christian67
New member
Hi to everyone!
I am doing electronics only on a hobby level and especially that analog part (do I need a resistor or not, which value, etc.) is often a headache for me... :(
I have searched this forum and also the web on this topic, but unfortunately I haven't found a 100% answer that gave me enough confidence to test it.
The whole project is a bit complex as it is a management system for my backyard observatory (Astronomy is my main hobby), including power management, roof control (open/close), weather monitoring, web interface and heat/cool of electronics and the observatory.
I had a prototype running a while based on two Arduinos (Mega and Uno), but this had several problems. Now I want to transfer it to a Teensy 3.5 and already made some progress. But for the SSR's I am completely lost, as my SSR's say they have a input range of 3V to 32V, with a 20mA LED.
On the Arduino Uno the following circuit worked fine (don't ask me why there is a resistor - found this circuit on the web and it works ;) ):
With this circuit my code was very simple:
In the setup() routine a pinMode(1, OUTPUT); and later to switch the SSR on or off a digitalWrite(1, HIGH); or a digitalWrite(1, LOW);
Due to the 20mA LED I am pretty sure I can't use this circuit with the Teensy 3.5. Now I have some optional circuits and have no idea which one is the correct on:
What is the right one? Do I need some more resistors? :confused:
And will the code be the same or do I need to swap HIGH/LOW?
Any help is highly appreciated!
Best regards,
Christian
It seems the resistor only pulls the Pinn D1 down when unused.
Looking up a datasheet of a SSR (maybe different model) it suggested to drive the SSR with a transistor
(e.g. NPN with Collector connected to SSR +)
This shows the use of a diode to direct the reverse current to GND instead of the Teensy: circuitdigest.com/microcontroller-projects/arduino-relay-control
If I read it right it also shows a transistor in use to supply the power for the relay that would handle the LED current as well - as it is a solid state relay the current may not have the backflow concern.
That is the first I found - if unsure maybe a better answer will appear - or find a second source for safe connection.
Thanks for your quick replies.
Seems option C will be the correct way.
I don't think that the diode is needed, because as far as I know only for a inductive relay this would be necessary. But for testing it might be a safe way. As far as I understood, having 5V on the relays + isn't a problem for the Teensy. So this could also increase the chance to get the SSR running w/o baking the Teensy (?)
Maybe someone already successful connected such a SSR to a Teensy 3.5?
Best regards,
Christian
