Results 1 to 3 of 3
Thread: Sharing Pins- Audio Adapter Shield- and Wi Fi Breakbreakout
    Jan 2019
    2
    Hello, can I share Teensy 3.2 pins- (11 & 12) on my between the audio adaptor board https://www.pjrc.com/store/teensy3_audio.html and wifi breakout https://learn.adafruit.com/adafruit-...eakout/pinouts ?
    Thank you! Sanone
    2,861
    Quote Originally Posted by Sanone View Post
    Thank you! Sanone
    You need to use the alternate SPI pins for pins 11 and 13. The alternate pin for 11 (MOSI) is pin 7. The alternate pin for 13 (SCLK) is pin 14. The audio board needs to use pins 11 and 13 for I2S objects, instead of them being used as the default pins for SPI:
    Note, some boards don't work too well being shared with other SPI devices like the SD card and flash memory readers on the audio shield. I've heard that for those boards, you need to have additional hardware (tri-state buffer?). Also, if the wifi driver doesn't have support for SPI_TRANSACTIONS, you may need to add that as well.
    Jan 2019
    2
    Thank you Michael, I will try this and let you know.
