Results 1 to 4 of 4
Thread: How many cycles should I use for a specific frequency?
    Mar 2018
    10
    I'm writing a DTMF decoding program now. And I use "DialTone_7segment" in the example as a reference. But I don't know how to calculate the "cycles" as the parameter of frequency() function. Ex:
    row1.frequency(697, 21);
    row2.frequency(770, 23);
    row3.frequency(852, 25);
    row4.frequency(941, 28);
    column1.frequency(1209, 36);
    column2.frequency(1336, 40);
    column3.frequency(1477, 44);
    Why "21" is used from 687Hz and "44" is used from 1477?
    Thanks in advance.
    Here is the complete example source code:
    // Dial Tone (DTMF) decoding example.
    // The audio with dial tones is connected to analog input A2,
    // example for using the audio shield.
    // Create the Audio components. These should be created in the
    // order data flows, inputs/sources -> processing -> outputs
    AudioInputAnalog audioIn;
    AudioAnalyzeToneDetect row1; // 7 tone detectors are needed
    AudioAnalyzeToneDetect row2; // to receive DTMF dial tones
    AudioAnalyzeToneDetect row3;
    AudioAnalyzeToneDetect row4;
    AudioAnalyzeToneDetect column1;
    AudioAnalyzeToneDetect column2;
    AudioAnalyzeToneDetect column3;
    // Create Audio connections between the components
    AudioConnection patchCord1(audioIn, 0, row1, 0);
    AudioConnection patchCord2(audioIn, 0, row2, 0);
    AudioConnection patchCord3(audioIn, 0, row3, 0);
    AudioConnection patchCord4(audioIn, 0, row4, 0);
    AudioConnection patchCord5(audioIn, 0, column1, 0);
    AudioConnection patchCord6(audioIn, 0, column2, 0);
    AudioConnection patchCord7(audioIn, 0, column3, 0);
    // pins where the 7 segment LEDs are connected
    const int sevenseg_a = 17; // aaa
    const int sevenseg_b = 9; // f b
    const int sevenseg_c = 11; // f b
    const int sevenseg_d = 12; // ggg
    const int sevenseg_e = 14; // e c
    const int sevenseg_f = 15; // e c
    const int sevenseg_g = 10; // ddd
    // Audio connections require memory to work. For more
    AudioMemory(3);
    //while (!Serial) ;
    //delay(100);
    // Configure the tone detectors with the frequency and number
    // of cycles to match. These numbers were picked for match
    // times of approx 30 ms. Longer times are more precise.
    // The 7 segment display is "common anode), where the
    // common pin connects to +3.3V. LOW turns the LED on
    // and HIGH turns the LED off. If you use a common
    // cathode display, you will need to change all the HIGH
    // to LOW and LOW to HIGH.
    pinMode(sevenseg_a, OUTPUT);
    pinMode(sevenseg_b, OUTPUT);
    pinMode(sevenseg_c, OUTPUT);
    pinMode(sevenseg_d, OUTPUT);
    pinMode(sevenseg_e, OUTPUT);
    pinMode(sevenseg_f, OUTPUT);
    pinMode(sevenseg_g, OUTPUT);
    digitalWrite(sevenseg_a, HIGH);
    digitalWrite(sevenseg_b, HIGH);
    digitalWrite(sevenseg_c, HIGH);
    digitalWrite(sevenseg_d, HIGH);
    digitalWrite(sevenseg_e, HIGH);
    digitalWrite(sevenseg_f, HIGH);
    digitalWrite(sevenseg_g, HIGH);
    const float row_threshold = 0.2;
    const float column_threshold = 0.2;
    float r1, r2, r3, r4, c1, c2, c3;
    char digit=0;
    // read all seven tone detectors
    r1 = row1.read();
    r2 = row2.read();
    r3 = row3.read();
    r4 = row4.read();
    c1 = column1.read();
    c2 = column2.read();
    c3 = column3.read();
    // print the raw data, for troubleshooting
    Serial.print("tones: ");
    Serial.print(r1);
    Serial.print(", ");
    Serial.print(r2);
    Serial.print(", ");
    Serial.print(r3);
    Serial.print(", ");
    Serial.print(r4);
    Serial.print(", ");
    Serial.print(c1);
    Serial.print(", ");
    Serial.print(c2);
    Serial.print(", ");
    Serial.print(c3);
    // check all 12 combinations for key press
    if (r1 >= row_threshold) {
    if (c1 > column_threshold) {
    digit = '1';
    digitalWrite(sevenseg_b, LOW);
    digitalWrite(sevenseg_c, LOW);
    } else if (c2 > column_threshold) {
    digit = '2';
    digitalWrite(sevenseg_a, LOW);
    digitalWrite(sevenseg_d, LOW);
    digitalWrite(sevenseg_e, LOW);
    digitalWrite(sevenseg_g, LOW);
    } else if (c3 > column_threshold) {
    digit = '3';
    } else if (r2 >= row_threshold) {
    digit = '4';
    digitalWrite(sevenseg_f, LOW);
    digit = '5';
    digit = '6';
    } else if (r3 >= row_threshold) {
    digit = '7';
    digit = '8';
    digit = '9';
    } else if (r4 >= row_threshold) {
    digit = '*';
    digit = '0';
    digit = '#';
    // print the key, if any found
    if (digit > 0) {
    Serial.print(" --> Key: ");
    Serial.print(digit);
    // uncomment these lines to see how much CPU time
    // the tone detectors and audio library are using
    //Serial.print("CPU=");
    //Serial.print(AudioProcessorUsage());
    //Serial.print("%, max=");
    //Serial.print(AudioProcessorUsageMax());
    //Serial.print("% ");
    delay(25);
    Z.t
    Feb 2014
    Colmar, France
    2,329
    Man... the period duration of one cycle is 1 / frequency. 7th grade...
    19,718
    Quote Originally Posted by Zoologist View Post
    So that all 7 have similar detection time.
    Mar 2018
    10
    OK, thanks a lot. It's really knowledge of 7th grade. It's calculated as below:
    cycles = 30ms / frequency
    0.03 / (1/697) = 21
    0.03 / (1/770) = 23
    0.03 / (1/1477)=44
